Dodge Intrepid
1272830323367
  • Jason5Jason5 Member Posts: 440
    I would agree with Andre's assessment. I'm a large man so I give the nod to the larger car. I also find the Intrepid's suspension a bit better sorted out--though the Stratus seems fine. My 2000 ES has done extremely well with only a replacement CD player early on due to skipping (a somewhat common occurance) and most recently a problem with refueling. No serious or particularly costly items--tires replaced at 30K, front brake pads at 40K, dealer says I should consider replacing the accessory belt within the next 5000 miles (I'm just shy of 50,000 miles total). My mom and aunt have first gen Intrepids that are still going strong with no serious repairs.
    ...that sounds like about the same intervals I got: 30K out of the tires (I was pushing it though, they were down to almost slicks!) and 39K out of the front brake pads. My rear pads got replaced around 51K, so you may be just about to that point with yours.
    I'm taking the car in to my mechanic soon, to have him check the belts, hoses, and coolant. The coolant's supposed to be good for 5 years/100K, but I'd rather have him check it out just to be safe. Supposedly, the spark plugs were also 5 year/100K, but mine also had to be replaced around 51K.
    I don't even know how long the belts are supposed to last. I'm still used to the old days, when it was 3/36K. Well, I'm at almost 75K now!
    One thing I did notice about the Stratus/Sebring, versus the Intrepid, is that up front, legroom seems to be about the same, and I can actually stretch my left leg out a bit further in the Stratus/Sebring. I could probably get along just fine with a Sebring or Stratus, but I like the Intrepid's extra shoulder room, and the back seat is much roomier, so it keeps the backseat riders' knees out of my back! The 'Trep's trunk is also noticeably larger, and I always preferred the more stable ride of a car with a longer wheelbase and wider stance.
  • duffer5duffer5 Member Posts: 10
    Got a little nervous with some new sounds and knew I was going to have some $$$ repairs coming up in the future, so we took advantage of the 60 month, 0% financing from DC.
        Wife and I decided to get a 2003 300M (light almond pearl/ with taupe interior + bells and whistles) Great road car like the Intrepid and handling is also agile like the Intrepid.
        Ottowrkr, liked your comments as well as the helpful information from the rest of the group.
    Thanks,gang!
  • ottowrkrottowrkr Member Posts: 778
    great to hear about the 300. Enjoy.
    ...congrats on the 300M! Glad to see you've had a good enough experience with Chrysler to get another! How many miles did that '95 Intrepid have on it?
    I went to the DC auto show back in December, and I think out of all the cars there (well, the ones in my price range, at least!) if I had to go get another new car, it'd be another LH car.
    They had a silver '03 SXT there, and sitting in it felt exactly like my '00 base model. The only thing I don't like is that they swapped out the cloth inserts on the door panels for vinyl. I guess it matches the optional leather better, and is cheaper for them to just make all the door panel inserts the same. Still, I kinda liked the cloth. It was just one of those extra touches that made the base Intrepid feel like it was a step or 2 above a base Impala, Taurus, or the other cars in its class.
  • 0patience0patience Member Posts: 1,712
    Don't know if you got your problem solved or not, but here is the info of that TSB you were looking for. TSB 14-003-01
    Fuel tank slow to fill.
  • patpat Member Posts: 10,421
    Nice to see you here. :-)
    Hi Pat,
    thanks, gonna try and make a habit of it. :)
  • homerkchomerkc Member Posts: 113
    I just read a post elsewhere that pointed out most people only post if they have problems. I have had little problems with a 2000 Intrepid (base) bought new almost three years ago. It has 47,000 miles, maintained regularly, and has cost me nothing beyond maintenance. It has original brakes, etc, though the tires were replaced at 35K miles (some tread left, but....) It is comfortable, economical - a very good car. It makes me want to look at Chrysler cars FIRST. DC should be proud of their products these days.
  • jbriesejbriese Member Posts: 4
    Have a question for the group, what are the possible thing that could be wrong with a Intrepid that has the check engine light on and is showing the misfire code. I changed plugs and wire's so far, did not help, even though the old plugs were severely toasted.
  • njdevilsrnnjdevilsrn Member Posts: 185
    Had the same problem in my 2002 Intrepid (2.7L) this past summer. First they changed some plugs and wires. Then a new computer. Still no fix. Wound up needing some new fuel injectors. Lucky for me I was under warranty...I have no idea how much this trial and error repair effort would have cost if it wasn't.
    Also, it was comforting to have them tell me each time I went in there that they "had never seen the code before" as far as what they were reading on the computer.
    The '95 Intrepid ES had 102K on it when I traded it in on a 300M. Been a really good car but the maintenance was really important: changed the oil + filter every 3000 miles; changed transmission fluid every 30,000 miles; changed coolant every 2 years; changed brake fluid (anti-locks)every 2 years. Brakes and other maintenance items were also reasonable. Still had original exhaust system. Work was done by a local garage after the warranty expired.
    Did have some problems @60,000 miles--replaced timing belt and water pump (3.5 Engine) Also had to replace the AC--partially reimbursed by Chrysler. Had to change the check engine module at 85,000 (after the 80,000 emissions warranty. Decided to stay with Chrysler for a trip car.
    Really like the 2003 Chrysler 300-styling is great, lots of power, great touring car. 0% financing for 60 months also was a great deal. My sister-in-law also has a 300M (2001) which convinced us to buy one.
  • cheddarheadcheddarhead Member Posts: 3
    Greetings....
    I've been lurking for some time...thought it about time introduced myself.
    I've got a '95 ES with the 3.3L engine. I've had some minor issues and a couple of major ones, too. The car's approaching 200K on the odometer, so it's seen some highway since I bought it (used...I'm the 3rd owner, apparently) with 49K on the meter.
    The car's on it's 3rd transmission (1 at 56K under warranty, the next at 120K on my nickel) which seems troubling. I'm much more religious about the tranny fluid now! A/C hasn't worked in years...I'm told the condensor leaks (lousy design?) and fails repeatedly. Not really an issue, except for 1-2 days per year as long as I don't sit in traffic on I-294!
    Now I'm looking at two significant repairs:
    Airbag clock spring ($385 P/L)
    Multi-function Switch (brights/turn signal/cruise) @ $458!!!
    I've replaced the two headlamp switches previously. The dealer now says that the new M/F Switch has a harness change. I couldn't find any data on a TSB about this...has anybody else had this?
    Interesting to hear the comments about door seals...thought I was the beneficiary of Monday AM build quality, as the rains come in if/when I go through a car wash. That'll get fixed next week!
    Overall...I like the car, but don't "love" it. Ride is good, power is OK. Styling is a real positive. Fit/finish are OK, or will be as soon as I fix the door seals. Audio system leaves something to be desired..this too can be fixed. Still, after 200K, it looks good...and it's long since paid for. I regularly cast longing looks at newer cars such as the Maxima, but, given the high mileage I run regularly (750-1,000 miles/week) it seems crazy to shell out $25K for a depreciating asset.
    cheddarhead- 200K wow not bad for that kind of mileage. First off why are you changing the clockspring?? The multifunction switch was a problem , I have had to change 3 on my 94. I cant belive the prices you quote , are they dealer prices?? I would not by these from a dealer , why dont you check a few wrecking yards for these parts. These are very simple parts to change but I just cant see spending close to 1000 $ for them WAY OVERPRICED !!!
  • speedingticketspeedingticket Member Posts: 33
    I drive one as a company car. 36,000 km in 8 months and I can say not too many problems except a reoccurring high pitched whine on the highway in cold weather.
    The dealer is stumped and thinks it may be coming from the tranny but refuses to open the tranny up (surprised?). Anyone have any ideas what it may be?
  • honda1990honda1990 Member Posts: 2
    there is a sale ad for dodge intrpid 1996 model for about $4500. I wanted to know about the maintance cost and the mileage for this car...any help is greatly appreciated.
    A good friend of mine had a 1995 Intrepid and had over $ 6000 of repairs done in 2 years. The worst of which was replacing the transmission twice. My friend ended up dumping the car for whatever he could get for it. The car only had 100,000 mi. when he sold it. The car was such a piece of crap! I drive one, but I would never buy one!
    ...which engine does that '96 Intrepid have in it? The 3.3 isn't as torquey as the 3.5, so it's not as hard on the transmission. BTW, the tranny did have some running changes made for '96, so the '96-97 'treps tend to be less troublesome than the '93-95 (or the previous Dynasty/NYer, which had that same tranny).
    I've known a few people who have gotten well over 100,000 miles out of their first-gen Intrepids, with no tranny problems, although one buddy, with a '94 Concorde 3.5, had a/c problems and water pump problems.
    One of the biggest problems with the transmission is putting the wrong fluid in. They're supposed to take Type +4 (or 9196), but often Type +3 (7176) gets put in, and it's rougher on the tranny. I think for awhile, the owners manuals even erroneously had Type +3 printed in them.
    How many miles are on this '96? $4500 doesn't sound like too bad of a price, but keep in mind it's almost 8 model years old...any car that age can be a gamble. First thing I'd probably do is get the tranny serviced, unless you have records proving that it was recently done, and using the correct fluid.
    I forgot to mention the miles.. its got 71,000 on it and its 3.3 V6 engine. Drove the vehicle and it runs pretty smooth. Only thing i noticed was the brakes and alignment needed to be worked upon. The seller is ready to give for 3500$....now that the brakes need some work. Is there any way i can figure out if the transmission is bad? And what about the gas mileage for this car ... does it guzzle too much gas.
    ThankS for all replies...it helps.
    ...find out just how much work the brakes need. After 71,000 miles, I don't think you could do TOO much damage to the brakes, but if it needed new pads and rotors all around (I think they were 4-wheel disk back then, weren't they?), then you could be looking at some serious money. If you have bad wheel calipers, a bad master cylinder, or whatever, that could also run into some serious money. There's just so many different things that can go wrong with brakes, it's safe to see how much it's going to cost, up front.
    Same with the alignment. Maybe the car's just out of alignment, which is a simple enough fix...and cars can go a long time nowadays without needing one. My 00 Trep went about 62,000 miles before needing its first alignment. But then if some suspension component is actually bent or broken, again you could be looking as some serious money.
    The 3.3 V-6 is a fairly simple, rugged pushod engine that I believe made its debut in the Dynasty and New Yorker around 1989 or 1990. By '94 it was putting out around 161 hp, which, for a base engine, was decent at the time. I have a co-worker whose Mom traded a '94 3.3 for a '99 2.7, and even though the 2.7 has 200 hp, she liked the '94 better! It had better low-end torque, so it would take off the second you tapped the gas pedal, and that's the way she'd been used to driving. With the 2.7, it is faster, but you have to really rev it to get the peak power, and she wasn't used to stomping on a car like that.
    The 3.3 is still used in minivans, as is the 3.8, which is an enlarged version of it. With older Intrepids, you're probably better off, reliability-wise, with the 3.3. It's simpler, and I believe it's also chain-driven, whereas the 3.5 has a timing belt. The 3.3 also didn't have the water pump problems that the earlier 3.5's had.
    As for fuel economy, the EPA rates the '96 Intrepid 3.3 at 19/27. That's probably a touch lower than cars like the Ford Taurus or Chevy Lumina at the time, but then the 'Trep is a heavier, roomier car than either of those two.
    As for the transmission, probably the first thing to do would just pull the dipstick and see how the fluid looks. It should be a pinkish color. If it smells burnt, or has too much of a brownish/grayish/blackish color to it, there could be a problem. If you see lots of little metallic flecks in it, be weary. When you drive it, make sure it shifts fairly smoothly through all 4 gears upon acceleration, and goes smoothly in reverse. All transmissions make some noise when they shift, if you listen carefully for it. If it sounds like it's straining to shift gears, or holding the gears too long and over-revving the engine, there could be problems. From what I've heard, when these transmissions do fail, they don't do it immediately...they actually do give signs and a gradual decrease in performance. So if it doesn't feel "right" when you're driving, there might be impending problems. Sometimes it might just need a servicing or adjustment though, so it's not a guaranteed sign of a bad tranny. Again, I hate to sound like a broken record, but have a mechanic you trust check it out.
    Anyway, good luck! For $3500, it sounds like a decent deal, provided that the brakes and alignment don't require too much work.
    I would like to echo some of the comments that Andre posted.
    The 3.3L engine is very robust...almost bulletproof. The engine has a timing chain instead of a belt, so replacement isn't critical at 60-70,000 miles. Change the oil regularly and flush the cooling system and you should be good for a while.
    I had complete brake job done, including rotors and calipers (at 130,000 miles) for about $600. Alot of money, but given the mileage, I'm ok with it.
    Apart from the previously-mentioned transmission issues, the only other major concern is the A/C. Mine failed due to a leaking condensor, which they wanted $800+ to replace.
    Good luck!
    '95 SE with the 3.3L Engine...power is acceptable, but not overwhelming. More than enough to get up and cruise, but not going to pin you into your seat.
    I get 22.4 MPG using 87 octane, averaging 650 - 750 miles per week. 90% highway. Typically 75 MPH, but fairly gentle on acceleration and decelleration.
    Given the size of this car, the mileage is one of it's strong points, I think...
  • pkciccopkcicco Member Posts: 13
    I just picked up a 2002 ES with the 3.5, 17K. I've been driving it for about a week and I notice that when you decelerate to under 30mph (like coming off an exit ramp) and then hit the gas the tranny bumps hard and sometimes double bumps going into a lower gear to accelerate. I doesn't do it at any other speeds or when accelerating from a dead stop.
    Does anyone know if this is normal or what it might be? Also for those of you who have the 3.5 234hp engine, what grade of gasoline do you use? The book says use 87 but I'm wondering if using a higher grade would increase performance.
    Thanks for your help
    I remember hearing that if you put in higher octane gas, it's supposed to improve your performance slightly on up to about 90% of wide open throttle.
  • nelson33nelson33 Member Posts: 100
    I am planning on draining my 99 Trep this week. Does anyone have any coolant recomendations. Do you think I should go w. MOPAR coolant or the Prestone 5year/150K miles Orange coolant. I've done quite a bit of reading on the subject and it seems like the Prestone will be just fine. Also is there anything I should know about this cooling system that is different from the typical systems. If so, please post, I would appreciate it.
    My car just hit 40K and I took it to the shop for an oil change and the mechanic topped off my coolant w. the green stuff. :-{
  • emaleemale Member Posts: 1,380
    be careful because you can't mix and match coolant types. use whatever chrysler recommends...that's the safest thing to do.
  • smithedsmithed Member Posts: 444
    The 99 ES is celebrating it's fourth year of our ownership. Only 63000 miles, so you can see we are not big drivers. A few trips a year from SC to PA, a couple to the kids at college. We have really liked the car and have been generally happy. There have been a few problems, but so far (fingers crossed) nothing major. The problems have been: AC out at only 45,000 miles. All window motors were replaced within the first year of ownership. two episodes where the trans sensors went bad and we went into limp home mode (second gear only). One covered by warranty, the other cost about $185. New tires at 33,000. The Cooper Lifeliners (now with 30,000 on themselves) I put on then will last a lot longer than the original Goodyears, sound a lot quiter and look better, too. I did something unusual and went with pinstrip whitewalls and they look better (to me).
    Haven't replaced brake pads yet, and when I had tires rotated recently at dealer (they were doing the oil and filter for $5.00 coupon they gave me at purchase time) they said the pads still looked good. It is nice and flat here, so the brakes do not take a beating.
    So you can see that there have been problems. However, when things are right and we are cruising with that sunroof open, it still makes my wife and me happy. We would buy another. Plan to keep it and hand it down to our son when he goes off to college in 4 years. It will be at least as good as the used Legend I bought for our daughter.
    By the way, our beater car is a 1990 Spirit that just won't die. Don't know how many miles are on it, the odometer broke at 117,400 about 4 years ago. Seems like that thing was built to take some punishment. The 2.5 runs pretty good, leaks a little oil, but keeps on pulling.
    ES
    I decided to take it to the dealership for the coolant service for I did not wish to take any chances w. my engine. However, I had already purchased some Peak (orange) Long Life engine coolant from a local pep boys because I was planning on flushing it myself. However, after I changed my mind about doing it myself, I left it in the bag and stored it in the trunk to take it back to the store for a refund. When I went to the Dodge dealership on 3/19/03 for a drain and flush, I told the manager if he wouldn't mind using the deionized water which I also kept in the trunk in a clear, plastic bottle. The service manager clearly stated in the service order "use customers water in trunk". When the job was complete, I looked in the trunk and noticed that my coolant was used up but the deionized water was unused. The manager was pretty cool about it and redrained and flushed my radiator again and reimbursed me for my coolant.
    I use this car quite a bit for very long drives (ie NY to Florica, NY to Wisconsin, etc. so I try to take good care of it. 40K miles and still going strong.
  • mike372mike372 Member Posts: 354
    I have recently purchased a new 2002 Intrepid SE. It has the 2.7 L. engine. I have read some negative comments about this engine ie. sludge buildup leading to engine failure on sites such as intrepid.clan-510.org. The Dodge dealer told me this is a high performance engine and will last a long time if I change the oil every 3K miles. Would appreciate any comments from those with over 50K on their Intrepids with the 2.7 liter engine. Thanks.
    ...in one of the online Mopar clubs I belong to. Here's what one guy said about the 2.7....
    'Just a note: - the 2.7 V6 engine is truly a "work of art" IMHO. It looks more like an "Indy car" engine than one that seems to propel every
    "rental fleet" Intrepid on the planet. However, - this thing literally "lives & dies" by the oil change. I have had them in here with 40K on the clock and the engine is pure junk. Cause: - "lack of maintenance". This engine will NOT tolerate any "sludge" accumulation whatsoever.
    I also have one customer with 150K+ miles and no engine problems at all. Reason: - the engine gets regular oil changes every 3,000. For most of us "enthusiasts", - changing the oil every 3000 is practically a "way of life", - not so for "the masses". I would be VERY careful when buying a used 2.7-powered vehicle, and if I could not *absolutely* verify a good (i.e. almost "fanatical")maintenance record, I would not buy it. This engine is very expensive to repair, and the prices of used (wrecking yard) engines is out of sight.'
    I've got almost 77K miles on mine, and have been pretty good about the oil changes. I was bad last time around though, and let it slip to about 5K miles, where usually I do it every 3K.
    in line with the complaints on the site IntrepidClan-510.org. People say the engine is very expensive at the salvage yards. However, the parts at most salvage yards are too expensive anyway and there are dealers that sell OEM parts for 20%off like my local Honda dealer(my girlfriend has a 2000 Civic). So, I would be hard pressed to go to salvage yards anyway. I peviously owned old cars and have been to many yards. But I would like to know why the 2.7L engine is so difficult to rebuild. I asked the mechanic at the Dodge dealer why this engine was considered 'high performance' and he said it was the way in which it was "setup". I am not sure what he meant. I have personally rebuilt a Pontiac 4.9 Liter engine about 12 years ago for my 1979 Firebird (which is still running). But I am just interested in knowing why the Dodge 2.7 L engine is so difficult the rebuild that many shops wont touch it according to the previously mentioned site.
  • evandroevandro Member Posts: 1,108
    IIRC, it's built with such tight tolerances that only very high-end machinery would have to be used. The kind of machinery commonly found in manufacturers' engine foundries, not in retail engine rebuilding facilities... :-(
  • fuzzer34fuzzer34 Member Posts: 28
    Spy Shots: ’04 Chrysler LX
    www.thecarconnection.com/index.asp?article=5862
    If I remember correctly the year that it was new, the 2.7 garnered lots of awards as one of the finest designed engines for a passenger car. Ours is a 3.2 from '99. Oil change at 3,000 to 4,000 as a routine. The 3.2 did not get the awards. The sludge discussion reminds me of what they say on the Toyota boards about their 3 liter V-6. Apparently the Dodges aren't as bad as the Toyotas, but maintenance seems to be the key element to keep these new low displacement power engines from becoming junk early. That was probably always true, even for the old iron.
    Happy Motoring in your 'Trep.
    ES
    I'm not positive on this, but isn't the 2.7 actually a different design from the 3.2/3.5? I was under the impression that the 3.2 was just a smaller-displacement version of the 3.5, whereas the 2.7 was a whole new engine.
    Anyway, with the 2.7 being DOHC and the 3.2 and 3.5 only being SOHC, that probably adds to the 2.7's complexity, and with more moving parts, there's less room for error, so the things had to be built to tighter tolerances. The 2.7 also puts out more hp per liter than the 3.2 did, and even more than the 255-hp 3.5, so it had to be engineered for that extra strain.
    I've heard elsewhere that that 200 hp out of the 2.7 translates to about 150 at the wheels, after the transmission and everything else has sapped its power. Awhile back, I remember hearing about a 2.7 that was built up to where it actually dynoed at something like 220 hp or so (at the wheels). So evidently, these things can take some modding.
    I always wondered if it would be worth it, if a 2.7 goes bad, to replace it with a 3.2 or 3.5? I wonder how much stuff would have to be replaced? I guess it would be a bit harder than the old days, when you could just rip out a 318 and drop in a 340 or 360, and everything would more or less bolt right up?
    The 2.7 is an entirely different engine from the 3.2/3.5 which are basically the same with differences in displacement, which are slight. Car makers have done that for years, with different displacements of the same basic structure. Done that way to keep costs down.
    For all you want to know and more about new and old Mopar engines:
    Allpar. com
    Well I just hope that the 2.7L engine lasts a long time. I just could not pass up the good deal I got on this Steel Blue leftover. With the 'D' package (pwr. drivers seat, cd player, cruise control,alloy wheels, fold down rear seat) plus ABS I paid $16,800 + $100 doc. fee. I was looking at used rentals from Chrysler dealers but finally decided on this car. The only problem so far is with the ABS controller which acted up at only 500 miles. But I have an appointment tomorrow to get it fixed at a local Dodge dealer. I still think it is a great looking car with good handling qualities. Plus steel blue was by far my favorite color. Drove all the way to CT to buy this car.
    I like that color too. If I had been more patient and looked around more, or ordered one, that steel blue was the color I would've picked. I ended up getting silver. Not my first choice, since my previous car, an '89 Gran Fury, was silver, and I don't like to buy the same color twice in a row, but I've been happy with it. Also, since I wasn't too crazy about the color, the dealer gave me a bit more incentive to take the car, throwing in a 12-disk cd changer.
    There's a real pale silver-blue that Chrysler makes that's really nice, but unfortunately it seems to be available only on the Sebring/Stratus. Shame too...it'd look nice on their other cars!
    I passed up a beautiful 2002 SXT with the 3.5 motor with only 7752 miles for around 14,500 to 14,700. Was not a scratch on it. It was only in service since Dec. 2002 and whoever owned it put on alot of miles in a short time period. It also had a moonroof, but the reason I didnt but it was because it did not have ABS. And it wasnt a rental like all the others I saw. But maybe I s/h bought it since I would have been less concerned with the engine. I actually talked to the previous owner which was difficult to do since it was on a dealers lot. It was silver and also had 17 inch chrome wheels with Michelins. I think the previous owner could not make the paymennts and it was a repo. But not positive. Anyway, a beautiful car.
    I wanted a Cypress Green when we bought our ES in '99, but it only came with a dark gray interior (which I didn't like), so we went with Champagne and tan interior. Next time I am getting blue or green.
    Enjoy your 'Trep. Nice car.
    ES
    sounds like it would go well with a light brown/tan interior. I wonder why they only teamed it up with the dark gray? That sounds like it would clash to me!
    When I was at the dealership the day I bought mine, I did have an interest in the Cypress Green...I liked the way it looked in the sales brochure. They showed me a minivan in that color though, and I didn't like it. I don't know what came over me that day though, because every once in awhile I'll see one now, and I think they look pretty nice. Sometimes though, when that color gets dirty, or the light hits it the right way, it looks too grayed-out.
    One nice thing about silver, is that even when it gets dirty, it really doesn't show!
    is not the best looking color but it went well with a Steel Blue exterior. The other choice was taupe which did not look as good. Taupe is sort of a cross between light gray and beige. Sort of a screwed up color. I did look at an ES with a dark gray interior but the seats, which were mostly vinyl with leather seating areas, almost looked black. I just got turned off with the interior. Dark gray cloth seats look better than the leather/vinyl combination.
    The car makers actually give us fewer choices in colors, arrangements, interiors than they did years ago. Again to hold down costs. It used to be you could get all kinds of color schemes, 4 door sedans, hardtops, coupes, convertibles, station wagons of the same model. Now I guess there are more models to chose from, but within a model they do restrict you a little on the options. Again, less custom made means more profit for them. Yes, the dark gray leather was really black. My neighbor has one like that and I didn't like it, but to each his own. The dealer I bought ours from didn't like the tan, and I only got it because I ordered the car to be built the way I wanted it. Took 4 weeks to get it, and when it came in it said on the window sticker : "Made for "My Wife's Name" by DaimlerChrysler. She really liked that. We bought it mostly for her. Although it is our tripmobile, too.
    I didnt have much of a choice if i wanted to keep the price down. It was too late to order a 2003 as the 2003 model year was very short and the 04's are out now. Dodge is offering $4,500 dealer cash on all leftover 02's. Plus dealer discount and most dealers are willing to give up most of their holdback on 02's. So I found mine in CT. I liked everything but the engine. But the price was right and I have a very limited budget! The 04's are currently in dealers lots till the end of the year when the restyled Intrepids, actually called Chargers, will make their debut as '05 models. Just a note, Chrysler is very clever and is actually taking some things out of the base Intrepid, like the four wheel independent touring suspension which mine has. Its the same suspension as an ES model. So most of the '03 and all of the 04's dont have this suspension if they are SE's. Pretty sleazy since most customers do not know this unless you read the 'fine print' on the sticker.
  • mamablairmamablair Member Posts: 2
    Hi All, Well I test drove the 2002 SE dodge Int. and really liked it but I am a little worried out the reliability of the car I am a mother of 2 and want a safe dependable car with lots of back seat space and so far this is what I have came up with I currently own a 96 Maxima and love it but its getting a lot of miles. Can any one reassure me on this buy? :0)
    I would look for one with 10 to 14K miles. If you are shopping at dealerships, nearly all are previous rentals, I dont care what the dealer tells you. I looked at many used 2002's and also subscribed to Carfax and looked up the history of many used Intrepids. In fact, sometimes I called Chryslers 800 Warranty Number, checking on the warranty, and they will tell you if it was registered to a rental company or not. Just give them the VIN. Because Carfax was not completely reliable. But there are some with low miles but you have to look harder. There are many in the high teens to twenties but I would try to find one with less miles. You are not going to pay much more dollars. Also, I would pay no more than $13,000. The dealers pay between $9500 and $10,500 for SE's at auctions like the Chrysler auction in Hatfield, PA. And this is for the low miles Intrepids. As far as reliability, its a chance with a Dodge, and it probably wont be as reliable as imports. But I decided to take a chance, and bought a brand new 2002 leftover.
    See my post about about the reliability of our '99 ES. Not perfect, but it also has never let us down in the middle of nowhere. I have been satisfied with the reliability of ours. I have had friends who have had new Hondas and Toyotas let them down, too. The Intrepid has been as reliable as an Acura that I have had, which is a Honda. The Intrepids are great family cars with regard to back seat room and trunk space. I would buy another. I hope I can say that when it has 150,000 miles on it, which will be a few more years.
    If you can get the right price and know the history of the car, buy it.
    ...it sounds decent to me. 19,000 miles really isn't enough to damage the tranny, unless the previous owner was really abusive, or the fluid ran low for some reason or other. Main thing I'd be concerned about is oil changes. If you can verify that they were done around every 3,000 miles, then it should be fine.
    I've been hearing that the 2.7 can't tolerate a lot of abuse, such as running low on oil, or overly extended oil change intervals. While that's bad for any engine, some engines can just put up with it better than others. The 2.7, from what I've heard, is built to tighter tolerances than the 3.2/3.5, and since it's smaller it does have to rev faster to move that weight around. As a result, it's going to be working harder, and any kind of sludge buildup is going to be more harmful.
    This shouldn't be a problem though, if it's been changed regularly. My '00 2.7 will probably hit 77K miles either tonite or tomorrow, with no engine problems yet.
    it is very difficult, if not impossible, to verify the maintenance records for the Intrepids sold at dealerships, since they are all previous rentals. Actually, a significant number of the used ones I looked at had trans fluid leaks at the cooler lines. Some worst that others. The ES I looked at in NY State only had 8700 miles on it and had a bad leak in the cooler lines. The dealer had the car only a few days. In fact, as I was leaving the dealer, the car was in the shop getting the lines replaced. There was trans fluid all over the frame of the car. This is one reason why I did not buy the car. You did not know how many miles it was driven with low fluid since it was a previous rental. I guess the dealer wished I had seen the car the next day but I intentionally did not give him notice before I came. It was probably OK but you never know. I also saw leaks on SE's but not as bad as this particular car. The dealer confirmed that Chrysler was having problems with the cooler lines. Actually, I would probably buy a used ES with the 3.5 motor since it seems to have better reliability that the 2.7 L engine. At least the oil changes dont seem to be as critical.
