Why are you going to replace the steering gear box? Just wondering as I approach 130K miles. :shades:
I'm around 139,400 with my 2000 2.7. And I'm in sort of the same predicament...a bit weary of throwing any more money into it, but at the same time, I do still like the car.
Are you sure it's the steering box? The play in my steering was fixed by replacing the inner tie rod bushings and then aligning the front end. :confuse:
Well, all last week, I drove it to work and back, and it was fine. Then on Monday, I was ready to leave work, and it refused to start. It would crank and crank and crank, but wouldn't fire up. So I left it and got a ride home.
Yesterday I tried it again after work, and at first it wouldn't start. Then, the weirdest thing happened. The trip odometer went totally blank, just all dashes. Then a "P" came up. Then it showed "DONE". I guess that's a sign from above, that the car is done for! :P
Oddly though, right after that it started back up, and behaved perfectly on the 6 mile trip to the mechanic. So does this sound like it could be one of those sensors, like the camshaft or crankshaft position? I mentioned both of those to the mechanic, and someone else told me to mention a MAF sensor, or something like that? And something else, like a "Cold position start" sensor?
Anyway, I hope it doesn't end up being too cost-prohibitive to fix. I know it sounds weird, but I'd almost feel better if the car died from something a bit more heroic, like an accident, tranny failure, engine blowout, or whatever. In contrast, a several thousand $ electrical repair just sounds kinda wussy.
But, the car does have about 140,000 miles on it, so I shouldn't complain. I shouldn't, but I will.
Keep us posted.
I believe that is a MAP sensor (but MAF sensor may be right). :shades:
Ed
I have a feeling that what's happening is that he's driving it around, trying to get it to act up, but it's playing the perfect little angel routine for him. Naturally, I'm sure that if I got it back from him, it would leave me stranded within a day. :surprise:
I don't like the idea of having the waterpump in the crankcase, but it is a strong nice running engine. I have mostly Northstar Cadillacs and they get a bad rap too, But I think that they are one of the best engines around, given the number that are on the road.
He told me to come pick it up for the weekend, drive it around, and then call him in a few days to let him know how it was acting. Well, I'll give the car this much...it made the 9 mile trip home just fine. And then got me out to the liquor store okay. So I thought maybe it was fixed. Until I was stopped, waiting for a red light on the way home, and it cut out on me. So, back to the shop it went. :sick:
shades
When I took my engine apart, that was locked, it looked like someone had left it on the barbecue too long. The sludge, or what had been sludge, was now charcoal.
Just crispy, flaky carbon that felt like saw dust.
So far so good, although I've only driven it home so far. Guess the big test will be to see if it leaves me stranded at work tomorrow. :surprise:
Now that I understand how power brakes work (howstuffworks), this sound must mean that there is a leak back toward the passenger compartment from the air side of the vacuum booster. The brakes work fine, but the sound can be disconcerting.
So, hopefully it still has a few good years left in it!
My neighbor had a party the other day, and someone pulled up in a red Intrepid. I started talking to him, and found out it was an '02 2.7, and he had around 126,000 miles on it. He had bought it used at CarMax, with around 18,000 miles on it, and has had good luck with it.
I had the tires rotated and checked to see if they were out of balance and everything checked out OK.
What should I be looking for? Any suggestions would be greatly appreciated.
Thank You
I forget now how much it cost to do the bearing hubs, as I had other work done at the same time. All I know is the first time around, it was $1053 total, but that included a lot of other work. Second time around it was around $590, but that also included an a/c recharge and replacing some other minor part in the suspension. Again, I probably should have had the mechanic do both sides on that minor part (forget what it was, now), but he said the other side was okay. The part only came as a pair though, so he gave me the one he didn't use and just said to keep it in the car, in case it ever needed it.
Yeah, I guess nowadays those things don't go bad like they used to. And if it's any consolation, mine did last a fairly long time. Driver's side bearing hub got replaced around 130,000 miles or so, while the passenger side was around 138,000. Heck, once upon a time, most cars were in the junkyard by that time. Although I guess back in the day, if people actually serviced those bearings and kept up on it, they could theoretically last forever.
Something broke at the rack and pinion. Have you had it looked at yet?
At the beginning of this month, I helped my mom buy a used 1995 3.5L 6-cylinder Intrepid off of Craigslist. It only has 82,000 miles on it and seems well maintained by the service records. A car-handy friend looked it over well before we bought it. Its only noticeable defect being a significant dent on the corner of its front bumper.
The other night, my mother was driving downhill and pulled off into a gas station, and the car immediately stalled. She tried to restart it, but it wouldn't. Only after putting the car in park, taking her foot off the pedals, turning off the ignition, and starting all over again was it able to start. She drove the next mile back to her neighborhood, but as soon as she turned off the highway, the car stalled again. This time, when she tried to restart it, it made some weird choking noises. The ABS light came on and then went off during part of the fail. Once again, it only started after she pretty much parked the car and started over. She drove down the street and turned her corner, and the car stalled again. She cruised it over to the side of the street and parked for the night.
The stalling seems to be related to turning or braking (or both), possibly in relation to the ABS
My mother took the car to her mechanic today who said he can't really find the problem and suggested taking the car to a dealership for repair, as he suspects a sensor or main computer problem. She will be doing that.
However, cost is of course an issue. I'm wondering if anybody has experience with or an idea of what could be causing this problem, what would need to be fixed, and if this is a really expensive problem. I feel so bad that I steered my mother to this car that is causing headaches already.
Hopefully another 75000 to go-car still looks/runs great.
It's not really getting driven that much these days, though. With the nice summer weather, I have a few antique cars I've been driving. Plus, my commute to work is only about 3.5 miles, so it's hard to rack up any considerable mileage these days. I doubt if the Trep will see 5,000 miles this year. Around 150,000 miles, I'll probably get the belts done and the transmission serviced, and it might need new rear brake pads by then. Just to be safe, I like to get the tranny done every 30K. Belts were last done at 86K. Rear brakes were done at 51K and 102K, so I figure around 150K it'll be time again.
I've never had the brake fluid changed, but it might be a good idea. I had them flush the power steering back in February, when they also changed the spark plugs and did something else that I'm drawing a blank on right now.
Should probably do a battery when I do the brakes, the first tire rotation will be in the middle of winter. Gonna try the from the top approach this time. Read the instructions on a mopar forum.
Might just jump the gun and schedule the cam and crank sensors soon. I have seen many posts about problems there. Already had the trans speed sensors replaced. I really hate breakdowns.
Greatly appreciate the INFORMATIVE posts from other owners. Such as yours. Sadly as the cars age we get more and more of the "car is junk" "don't run don't know why and too stupid to do anything sensible about it" posts.
A little voice in my head is telling me to use this as an excuse to get a new car, but fixing the a/c is still a heckuva lot cheaper than a new car payment!
I've thought about just not getting it fixed and dealing with it, as-is. I'm masochistic enough, I guess, that I could probably put up with it! But I know I'd get constant complaints from passengers. People would refuse to ride in my car, and if I was going out somewhere with friends, they'd insist we take one of their cars instead of mine. So maybe leaving it broken isn't such a bad idea, after all! :shades:
I do run the oil in my commuter 5000 miles between changes.
There is no reason for you to change " If it works dont fix it"
ohh by the way...i have a 93 dodge intrepid
