Visitor Agreement.
http://www.acura.ca/AcuraEng/Models/TL/Overview.htm
On a 04 TL... I was quoted a price of $1100.00 for 7/75k or $ 1000.00 with a $50.00 deductible.
Al
The other car I'm going to test-drive is the 2004 Volvo T-5. Nice incentives already out on the Volvos. Has anyone compared the two?
I believe I understand the way these boards/threads are put together. You do not have a board for an "Acura TL"...but you do have a board for "Sedan" which includes discussions on the TL.
I know this is how the system was set up at Edmunds, but I think it would be better if this could EVOLVE to boards by a particular model.
I would bet that most people look for info by model type than by car type (sedan/coupe).
If someone wanted to look at sedans instead of a particular make/model, you/Edmunds could have a "program" that would identify all cars that would qualify as a sedan, then the "shopper" could look at each of those boards/threads.
I realize this make be a too significant change to what has already been established, but IMO it would make your site BETTER.
1243 of 1294 by kirstie_h HOST Oct 16, 2003 (7:32 pm)
OK, just to clarify... there is no Acura TL "board." It's a view you choose when you use the make/model drop-down menus. The boards here are divided into Sedans, Coupes, Hatchbacks, etc. Unfortunately, we can't just move this to the Sedans board as-is. The issue is that, if we start having a different discussion there for each re-design of each make/model, things will quickly get out of hand for the Sedans host, Pat.
I understand why you would like this discussion to remain open, and we're talking behind the scenes about the best way to do this. In the mean time, this board is staying open here. Thanks for your patience while we work things out!
(question mark gone, btw)
Good luck!
http://www.acurainspired.com/gallery/showalbum.php?aid=198&uu- id=898
Thx.
http://www.thecarconnection.com/index.asp?article=6501
Now to the test...car is silky smooth and adequate power at low and high RPM, very quiet, brakes are fine and stereo is outstanding.
Here is the bad part, car was pulling consistently to the left at highway speeds but minimal torque steer when accelerating.
From my 40yrs of driving experience this would indicate a bad tire. Saleskid admitted this is not right and will investigate and get back to me. Also, I challenged him on the difference of the US vs Canadian warranty, he did not have an answer.
Overall I like the car a lot and will probably purchase silver with black interior if I get satisfactory answer on the pull to the left and of course will test drive again after they correct the problem. Test drive took 75 minutes.
The problem with the glove box is very unusual for Acura. Unless it was damaged during or after delivery, that car should not have left the factory. Regardless, don't rely on that sales kid. I would go to another Acura dealership and ask for an experienced sales person and another test drive. Unfortunately, all Acura dealerships are not created equal.
Canadian Warranty:
Major component – 5 year/100,000 km
Vehicle – 3 year/60,000 km
Rust Perforation – 5 year unlimited distance
Surface Corrosion – 3 year unlimited distance
24-hour Roadside Assistance for the first four years of ownership
Accessories – 3 year/60,000 km
3.2-Liter V6 Engine - No scheduled tune-ups required for 168,000 km
US Warranty:
Vehicle - 4 year/50,000 miles
Outer Body Rust-through - 5 year/unlimited miles
Acura Total Luxury Care (TLC) with roadside assistance - 4 year/50,000 miles
Accessories - 4 year/50,000 miles
3.2-Liter V6 Engine - No scheduled tune-ups required for 105,000 miles
My 2002 Accord Coupe was doing the same...changed tires and the problem was gone but I think it is slowly coming back ( pull to the left). My wifes 2003 civic is tracking perfect!
I've owned Honda & Acura products for the last 14 years and I never had a problem with steering pull. However, because the steering setup on these cars is very precise, you will experience steering pull in varying degrees under the following conditions:
1) Incorrect tire pressure - even a couple pounds off may have an effect. To my wife's amazement, I can always tell when a tire on her Civic needs air just by driving it.
2) Uneven or sloped/graded roads - most highway roads are sloped or graded for water drainage. The more severe the grade angle is, the more pronounced is the steering pull.
3) Out of alignment - it wouldn't take much to knock out the front alignment on these cars, even slightly. For obvious reasons, this occurs more commonly with demos, loaners and especially front-wheel drive rental cars.
The above phenomena becomes even more pronounced when high-performance/low-profile tires are introduced into the mix.
If it turns out to be unreliable in the first 4 years, I would dump the car, not get an extended warranty.
You can expect the most mechanical failures to start happening after 100,000 miles, when even an extended warranty would have expired and be no use.
I never really like the Desert Mist on the Accord. IMO, it looks conservative and forgettable. Kind of a piss gold (pardon the language). This means my choice for the TL will be down to between the Diamond White/Parchment, and Abyss Blue/Camel. I was hoping the Abyss Blue was less like midnight blue and closer to Eternal Blue.
Any comments? Would Anthracite would hide dirt/swirls better?
1987 Legend. I agree with you kahunah on the listed causes however a 50K ( cdn ) automobile should not have any pulling .... specially in the demo. What is interesting that the saleskid drove for the first 15 min to show me how to handle the car ( ha, ha ! ) and did not notice this and he told me that this was his 3 rd test drive today.
When I pointed this out to him and demonstrated on the highway how the car wonders away regardless of the road conditions he had no defence. This may not be an issue for folks that drive in the city or novices.
I am still waiting for his response and explanation.
I would like an explanation, please.
BTW, it's interesting that your profile is very similar to mine, right down your view on the G35, ES, German brands, etc., and your objective for the new car. Well....you're older but we can't hold that against you
I drove the white/parchment with auto/nav. It looked like an expensive car to me. this is essentially the same combo I had on my 98 TL, it was pretty easy to keep looking good on the outside. I am leaning toward the desert mist/ebony w/6m and nav. I need to test the optional tires though.
The issue I wanted to raise is that a number of people who checked the new TL Navigation reported that the screen resolution is a bit fuzzy. They say when Acura increased the screen size from 6 to 8 inches they didn't adjust the DVD resolution accordingly, and that's why the maps look slightly out-of-focus. I think Acura owes it to a customer paying $2,000 to provide a sharp-looking navi screen! What do you guys think?
What are your choices for other 2004 near luxury/sport sedans (assuming you want a manual tranny)?
BMW 5-series - pricey
BMW 3- series - interior room, overall "small"
Volvo S60 T-5/R - interior quality, interior room
Saab 9-5 - pricey
Cadillac CTS - quality, handling
Infiniti G35 - interior quality, interior room
Audi A6 - pricey
Audi A4 - interior room, overall "small"
Mercedes C-class- interior room, overall "small"
What is the dealer holdback on these vehicles? Since they are "flying" off the lot, can we negotiate to have this amount deducted from the price...considering anyway how much we're getting raked for the difference between MSRP and INVOICE.
What does everyone think?
Eddie G
The agreement states:
"You agree to not promote other auto forums that provide message boards or chats."
And just linking to such message boards is considered promotion.
If this is what happened, you should receive an e-mail outlining the nature of your violation.
1violinist - The TSX and TL have similar nav systems. I have the TSX and the Nav screen is very clear with no blurs at all. I seriously doubt there is any problem with the TL's system, which also figures to be excellent.
General comment on ride quality - I wonder about this too. My TSX is very stiff and fairly busy on the highway. The ride in my '96 Accord was much more comfortable. I hope the ride is a lot better n the TL.
