Jennie Phipps
2. Can you increase the volume of the beep that signals that you have properly locked the car with the remote? I have put it to "beep sound on" in the Key settings, but I still can't hear it.
Blerner2 -- Glad someone else noticed that XM radio deficiency. (Not being able to see artist and song without manually toggling.) It's been driving me crazy!
bodble: Stop contorting your neck, get the rear park sensors.... I did!
I think it has more to do with the new car's improved sound deadening and Acura just didn't account for this.
The thing is TL is shorter than b4! The only reason rear sensors become a topic on this near-lux. mid-size sport sedan is because the rear visibilty is poor (small rear window + high rear headrests, and high/tall trunk...). Got to be a minus from inside looking back/out.
I was downtown last night in the rain and had to back up to get to a parking spot. The visibility sucked as the rain and the reflection of the street lights on the rear window pretty much obscured whatever vision was possible. Looking into your NAV while backing up on busy city streets isn't really an option since you have to be loking for cars and where you are going while in reverse. The TL does have limited visibility out the back window and the side mirrors are very small.
In regard to igiban's question, the rear sensor option on the TL is not a rear camera, is it? I think the rear sensor just emits a beeping sound as you back closer to an object.
These are a thinner carpet, the logo is not embroidered in, and the backing is gray sponge. Is this "normal?"
I guess I'll opt. for the all weathers if they cover the whole floor.
One place Acura's luxury really shines is in the rear wheel wells with this carpet like material instead of hard undercoating.
I just noticed on my '04 TL there is what I'll call a "Dummy Plate" next to the VSA and Mirror switches, that is typcially put on when a customer opts out of a certain option.
Since there are no options (and I don't think its'related to Nav units) does anyone know what this is for? Plans for a switch for a future option by Acura perhaps?
http://slashdot.org/articles/04/02/10/0654252.shtml?tid=126&t- id=137&tid=172&tid=193
Being involved in such issues in my work, I am saddened to see such a fundamental issue get missed -- especially since cell phone companies have had to worry about security issues on the phone communications protocols for years.
Wonder if the other manufacturers are better?
http://www.nhtsa.gov/NCAP/Cars/2641.html
http://www.acura.ca/AcuraEng/Innovation/Technology/Related/HiTech- Features.htm
Audiobahn has created a true sonic monster with our new A5100T. With 6
RCA inputs, two separate power supplies and crossovers for front, rear, center and subwoofer channels, we're not messing around. The center channel is giving out 75 watts, while the front 2 channels are at 125 watts and the rear 2 channels are at 75 watts a piece. The best part is that th subwoofer portion of the amp contains a
separate high current power supply that is putting out 300 watts at 4 ohm and is 1 ohm stable. This amp is so sweet you could go into insulin shock.
A5100T 5.1 surround amplifier
Class A/B MOSFET — High Current Hybrid Circuitry PWM MOSFET Power Supplies Double Sided Glass Epoxy Circuit Board
THD: 0.02%
S/N Ratio: >100dB
Frequency Response: 10Hz - 40KHz (+/- 1dB)
Variable 18dB Hi-pass Crossovers: 30Hz- 500Hz
Variable 18dB Low-pass Crossovers:30Hz To 120Hz
Center Channel Hi-Pass, Full or Bandpassfor Mid-bass
Bass boost @ 45Hz: 0/18dB
6-Channel RCA Input Connections
3-way Protection Circuitry: Thermal,Short Circuit and Overload; Cooling Fan
Cobalt Blue Illumination
High gloss Chrome Plated Finish
Nickel Plated Block Terminals
Circuit City was shown as a distributor so I ambled over there at lunch today. Yes they can get it and yes...it is $1200. They were doing some checking for me to see if there are any installation issues. I think the Acura ad men say the TL stereo is 270 Watts? but I can't find out how that is split. I also doubt the sub-woofer will handle 300 watts but that just means replacing it. You can never have too much power under the hood or in the trunk in the form of a power amp! It will take some real talking on my part to convince my wife this is something we can't live without but she listens to music in the car all day every day so I will be persistent..
It is like anything else you decide to upgrade, once you start there is no stopping because everything affects everything else and on and on and on. I am however looking forward to a really fine sound in a really nice car !
I started reeling my wife in tonight as to why this needs to be a priority in our lives. She didn't give me as much resistance as I thought she might so I believe I am good to go.
The adventure begins.
It seems she's been babied. Hardly a scratch on her. Obviously garaged. Barely any outward signs of wear.
QUESTION - With 75K on the odometer, should I be expecting some major repair bills in the near future. The TL has received many high ratings for reliability, but you guys know best. I have read that there have been transmission issues.
Thanks in advance.
Also, I paid $13K for it. Couldn't believe the price. I think I did very well. Any comments on this would also be appreciated.
The dealer knocked an additional $500 off the price during final negotiations today, bringing the purchase price down to $12,500. I found out that they were about to dump the car at an auction from one of the porters. I'm now convinced I've got a really great deal. Lucky me. Other 2000 owners take heart...I couldn't find a single one in the Chicago area this nice for even close to that. I really believe it's a one-off. They are going for even a little more than that on eBay.
Anyone have any experience on getting XM in the 2000 TL? Thanks in advance.
When I start the car there is no yellow triangle, and it comes on only when I press the VSA OFF button. But since there is no light on the button itself, I do not know which is on and which is off! The OFF button is obviosly an ON/OFF button, so what is which and when????
BTW, had my '04 TL w/Navi for a month now and have never been happier with any car I ever purchased. I hope this keeps up.
