Have you actually compared the two in person and sat in the backseat?
You may ask, how can that be? Well, remember that when a driver gets into the front seat and a passenger gets into the front seat, the seats are adjusted. So, if the Front Seat in Car A has more leg room than the Front Seat in Car B, then Car A's seats can be adjusted for more rear legroom. And, since Car A has more Front Leg Room, the Front Driver in car A will have just as much front leg room as he/she would have had in Car B. I will post some examples. Notice how the TL actually has more leg room than the BMW 5 Series and Mercedes E Series. Here are some real world examples:
Car Front Legroom Rear Legroom Total Leg Room
Acura TL 42.8 34.9 77.7
Acura RL 42.4 36.3 78.7
BMW 530 41.5 36 77.5
BMW 330 41.5 34.6 76.1
Toyota Avalon 41.3 40.9 82.2
Lexus GS 300 43.5 36.4 79.9
Infiniti M35 44.2 37.3 81.5
Mercedes E Class41.9 35.6 77.5
Honda Accord 42.6 36.8 79.4
I agree with your statement - but not quite with your methodology of just looking at the numbers.
IMO, The ONLY way to really get a consistent measurment on back seat legroom is for the same driver to get into the front seat, adjust to his/her preferences and take a tape measure to the back seat. Do this for all cars being considered.
You would think that front seat legroom measurments by the manufacturers would be consistent enough to avoid this self measurement requirement. But I found that pedal placement and angle,seat height, even steering wheel adjustments varies enough that there can be a 1-2" difference in the fore/aft direction where I am comfortable having the front seat. This is even more true for me in maunual transmission cars.
So, although the total legreeom is usually a pretty good surrogate, I have found that my Stanley tape measure is a necessary tool when car shopping. Same by the way, goes for the width of the vehicle. Back when we had both of our kids in car seats, an extra inch or two in rear seat width was very critical.
"Passenger volume" can be deceiving. Our TL has 97 cubic feet, our old 1995 Maxima had 100. The difference is mostly in headroom, with the Maxima being a boxier shape, especially for the rear seat. In the dimensions of importance to us, the TL is a bit bigger. Volume is good for comparing how many ping pong balls will fit inside your car, but not how comfortable your passengers might be. Run through a trash compactor, the "volume" of a 165 lb human body is about 3 cubic feet (90% water). But try fitting 30 people - with arms and legs intact - inside your TL.
bmwdoug is absolutely right that the front and back legrooms need to be added together. A reported 34" of rear seat legroom doesn't mean much if you don't know what the front seat legroom is. If it's 40", it will barely accomodeate a 6' driver. If it's 44", it will accomodate a 6'6" driver, and in the case of an actual 6' driver, you will have 4" more legroom in the rear.
My point was, that if I "use" say 38" of front leg room in one car, that does not mean I will use exactly 38" of front legroom in another car to find a comfortable driving position. It could easily be 37-39". I don't grow or shrink, but whether or not the sttering wheel telescopes, the position and angle of the pedals, etc. all influence where I set the front seat. And that difference would translate into a potential 2" difference in rear seat legroom between one car and another.
I'm not trying to split hairs, but if you are out test driving cars (which you should always do before you buy anything) it's a simple task to check the rear seat legroom yourself. Trust me, you will find differences not fully explained by the manufacturers or CR's numbers.
BTW, I'm paying MSRP less $2500 (CDN) for an '06. I think I did well but it's a fantanstic value even at MSRP.
Has acura fixed these nagging rattling issues that so many people complained about on the '04 models??
The interior and functionality of the TL seems to have been designed around the nav unit, and the non-nav could be considered an after thought. If you subsequently decide that navigation is needed , a Garmin or other GPS unit could be purchased for a third of the cost, plus it could easily be moved it to another car. But an add on does not do justice to the interior.
MSRP less $2500 is a good deal for an 06 at this time, esp in Canada, as we tend not to get the same type of deals that US buyers get.
My 1 week old 06 is tight and no rattles or squeaks, but these tend to show up months after battering the car over rough roads. It is much too soon to tell if any improvements made to the 06 have solved the problem. There are owners with 05's and even some 04's that have no complaints.
P.S. If I went strictly by published measuremetns, it would not have been possible for my daughter to sit behind me in our new 911. But, after "test sitting" in the car ourselves, bingo, there was an extra 2" more than expected. The new 911 steering wheel telescopes (didn't before), I set it all the way "in" and can correspondingly slide the seat bottom in about 2" compared with the old model. It's my ideal seating position and it gives my daughter enough additional room that her knees aren't touching the back of the driver's seat. Nowhere - Porsche figures, CR figures, or elsewhere - would anyone have been able to figure out this significant difference between the 996 and 997 model 911's without doing a "test sit" themselves. Granted, this revelation cost me $40,000 when my family pleaded me to get the 911 over the Boxster S I had been considering, but it was the right decision only made possible by a "test sit".
I elected to get the nav system option on our Porsche 911 and, for $2,070 it is three rungs down the ladder form Acura in functionality and ease of use. Even a friend commented that the latest generation Lexus system he has in his GX470 isn't as good as the Acura system.
On the rattling front, we have a 2004 6-speed with 20,000 miles and not a single rattle or squeek. The 6-speed has a stiffer suspension than the automatic, so, if anything, you might expect more rattles over time. However, according to my service manager, the opposite appears true. Probably purely coincidental, but our TL still feels very tight.
One thing you should be prepared for, if you haven't already experienced it in test drives. The BMW 330i, being RWD, tracks like it's on rails. And it's steering precision is about the best there is in the small coupe/sedan segment. The FWD TL has more play in it's steering and will require more driver input and attention, whether it's turning under acceleration or just driving down the highway. I didn't really notice how much this is the case until began switching between our TL and 911 frequently. I can take my hands off the wheel of the 911 at 80 mph on the PA turnpike and it won't budge from the line it's set on. That would be a high risk maneuver on the TL. Small bumps affect the steering line. Throw in torque steer on the TL and you just need to be OK with this tradeoff. You are going to a decent handling FWD TL - but coming from one of the very best handling RWD sport coupes available.
I say that measurements are a start. Ultimately a test drive is in order.
branco327 where are you getting this good a deal?
By the way, I'd highly recommend you go with the Navigation system.
Personally, I think the car would look good with fog lights mounted below the bumper ( in the black grille openings ).
post 722 on the Acura 2006+ TL forum
PS - my '04 TL (6MT) has about 19000 squeak-free, vibration-free miles and counting!!!
Yes.
I agree, they would look better below.
My wife really likes the nav but one of the reasons I gave up my 330CI was because of that "toy factor" and hence did not want to waste anymore money on these "toys" but I see the the benefit (although seldom for me) of the nav.
I was settled on the non -nav but the demo car they gave us had the nav and now I'm trying to convince the wife we really don't need it......
or am I trying to talk myself back into the toys?
Geeez, I am about to purchase it tonight and don't know what to do now! :confuse:
BTW, yes, I realize this car handles no where near my 330CI with PP but for me the TL is a much more practical car.
I can get the silver non-nav now or have to wait for either black or silver with nav until december. Any thoughts?
Besides, nothing wrong with having some toys in your new ride. If you were to be completely practical, buy a Camry! :P
You haven't passed up too many opportunities to inject your 911 into your discussions (here and on other threads too).
You looking for a round of applause, or for us to stand up and bow?
To paraphrase Shania Twain, "So what if you've got a Porsche, it don't impress us much".
I love the TL. Although I can afford it, I still have not parted with my money. I must be a cheapskate.
The nav seems better integrated, appearing and comes with better Michelin tires (rather than the frequently criticized Bridgestones).
And I figured I'd like to try the toy
I agree about it appearing better with the nav but I figured it still wasn't worth the $3000CDN with taxes. That's a whopping 7% of the car's whole value for basically a talking map I would hardly use!
As for the tires, the '06 non nav comes with Michelin Pilots up here in canada.
BTW, I puchased the silver non-nav tonight and the clincher for me was that I noticed a couple of used black '04's with nav on the lot that apparently weren't selling all that well. When I inquired with the manager he said it was because of the nav and therefore the higher asking price. The implication here was resale wise the non-nav is the better seller according to his experience....and I live in a oil rich city with lots of money. Go figure!
Anyways, thank you for your replies and suggestions. I am picking up the new family member tomorrow.
cheers!
And I'd bet you didn't know my "other car" is a red Enzo. I've never mentioned it.
Well, ok, I haven't mentioned it 'cause I haven't bought it yet. :P
BUT, if I did have one, I wouldn't parade it around on this thread.
Look, I've frequently made references to other cars I own or have owned for comparative purposes, including the TL, former Honda S2000, 1995 Maxima, former Trooper, MDX.... If you are suggesting I get off topic by doing so, then I'll take that as constructive criticism. But if you are singling out the 911, for the reasons you suggested, perhaps you need to ease up. I'm not trying to impress, let alone offend, anybody. I have never posted what I paid for it. And, for the record, I'm still the same guy that changes his own oil and filter in our 11 year old Maxima.
So, if I've somehow offended you (or others), I apologize.
All joking about Enzo's aside, I think we can all agree that although what you drive may make your commute more pleasant, it is pretty low in the overall meaning of life. So long as it is a stick shift.
But again, if your intention was not to impress, then let's just shake hands, and move on, and not bore the other fine folks here. :shades:
Also, what color combination would you choose? Black on Black, Black on Grey, Black on Tan, or Silver on Grey, Silver on Black, or White on Tan?
The basic car is great as is. Common accessories are all season floor mat, wheel locks, and splash guards.
You also need to decide between manual (6MT) and automatic (5AT). The enthuasistic drivers all choose 6MT.
Exterior colours tend to be regional:
- Black (NBP) for those perfectionist who can spend a lot of time professionally cleaning and waxing
- White (WDP) for areas with little or no snow, also good for hot regions
- Anthracite (AM) great all round
Interior colour may drive the external colour. Parchment is beautiful, but is not available with all exteriors. Black on black, or silver on grey is too much of the same thing, no contrast.
I personally chose Silver (ASM) with ebony. Only you can decide what is right for you. Go search some forums that have pictures with custom mods, but be warned, you may end up spending more than you planned.
So, far, with only about 2,000 miles on the Avon's, I'm very pleased with the ride and handling.
Also, I "upsized" to 245/45/17" tires from the 235's that came standard. The TL wheels are very wide - wider by at least 1" than our MDX wheels. As such, I got the slightly wider 245's hoping to cut down on the likelihood of scraping the wheels on curbs. That was actually a recommendation of my Acura service manager.
As for the options, Navigation is a must. Floor mats, wheel locks, and splash guards seem to be a reasonable addition as well. I believe this is the pro pack. Am I correct? I think the Standard Wheels are pretty nice. I know some people on the forum have gone with 18" wheels. What is the main reason for the 18" wheels? Is it for a sporty appearance, ride?
If anyone else has any opinions, please share.
My TL is the discontinued green exterior with the camel interior. I love it!!!
Hope this helps. :shades:
