also, the accord has standard 16", which i wish the camry le had too, but the accord doesn't have 60/40 rear seats (only 100 fold down)which may reduce the utility of the accord
btw, whatever car you get, a cargo net is one of the coolest features, definitely worth the $40.
I'll continue to read and consider the input - then try to make my best deal.
BTW - Thanks for the thoughts on side-impact airbags - something to consider.
They also see that a good part of that 60% have a large body physique, unlike that of their Japanese homemarket customers (estimated average height: male: 5'6", female: 5'0") or even their own auto engineers.
Management of both companies decide: let's do American-sized vehicles to capture the mainstream market, and let's make them quiet and smooth on the interstates. Result: Buicky Accords and Camrys.
Another effect: alienation of the traditional Import buyer, which those carmakers are probably willing to risk for long-term survival.
maybe its different in your part of the country?
btw, i heard that they are redesigning the rear of accord sedan for next year? This is probably not true right?
But then, I am clearly an older, less educated driver (guess I will have to turn in my PhD).
All that PhD does is allow you to pay more for a Toyota, get less, and have worse resale value than a Honda.
Any further questions before I go back to my job as foam control on the Camry line. And yes, the Accord is more advanced, VTEC motor, double wishbone suspension, 5 speed auto trans. BTW, if your kids need a smoother ride out of a Camry to keep from getting car sick, why not overpay for the worse depreciation vehicle, a Cadillac while your at it.
Anybody here know anything that can help me make this decision?
(E.g., suppose Honda equips the Accord with head-curtain bags in 2004. Would I be able to have them retrofitted into my 2003? Or should I wait to avoid buyer's remorse?)
NHTSA.com for results and actual crash test info in forces exerted on your body in an actual accident.
http://biz.yahoo.com/rb/030506/autos_quality_1.html
I wouldn't say that the Camry doesn't have power. For one thing, you are WRONG about the Camry's V6 power, it now makes 210 hp out of the V6 and the Camry has more torque than the Accord V6. Also the V6 Camry now comes STANDARD with a 5spd. Automatic.
True, the Accords resale is higher, but not by much I don't believe.
On top of that, the Accord "ain't" exactly the youth mobile it used to be. The 1986-1989 and the 1990-1993 models were the "youthful" Accord models. I see just as many older people driving Camrys as I do Accords. My school's media specialist has a 2001 Accord and she is thinking about getting a 2003. Now the coupe may attract younger people (I saw a college girl in a 03 Coupe EX-l Friday) but the sedan attracts its share of older people.
Ref:
http://www.nhtsa.dot.gov/nhtsa/announce/press/pressdisplay.cfm?ye- - ar=2003&filename=pr17-03.html
All EX Accords have side impact airbage & ABS standard. EXV6 Accords add front & rear head curtain. Camry makes you pay for all 3. Accord has more standard features.
Personal slams are off-limits.
But.... the Camry lets you buy a head-curtain airbag on (I think??) any model. So you not only have a side airbag protecting your lower body, you also have this bag protecting the left hemisphere of your brain. By contrast, with the Accord you can only get the head-curtain bag if you buy a V-6. Otherwise, the best you can do is a shoulder-height side bag that protects your shoulders and upper torso, but not your head. Right?
But I'd still like to find an argument for the Accord (since I like it better). E.g., could it be that your head is far enough away from the frame that with the side-bag you probably won't get beaned in a side collision? Or is that wishful thinking? (Or.... you can always wear a crash helmet for your commute... just kidding).
Anybody know anything about weighing all these factors? Just how important is that head-curtain bag for Accord drivers wanting to avoid brain damage? Thanks!
The Accord is more powerful though.
Road and Track had the same opinion, saying that it pulls hard through a wide rev range and is "absolutely scintillating" in the stoplight wars.
Anyone who thinks that the Accord V6 doesn't have far more than ample power AND torque for its family car mission probably should be looking at a different class of car, like the $30000+ sports sedan.
I removed some posts including some comments I made that were ignored.
Accord:
2.4L, 160 hp @ 5500 RPM, 161 lb-ft @ 4500 RPM
Camry:
2.4L, 157 hp @ 5600 RPM, 162 lb-ft @ 4000 RPM
Both engines have variable valve timing.
Acceleration figures from Car and Driver with 5-speed MT:
Accord:
0-30: 2.5 sec.
0-60: 7.5 sec.
0-90: 17.4 sec.
1/4 mile: 16.1 @ 87 mph
Camry:
0-30: 2.8 sec.
0-60: 8.3 sec.
0-90: 19.1 sec.
1/4 mile: 16.5 @ 85 mph
Then we have Motor Trend, same engines, with automatics (5-speed for Accord, 4-speed for Camry):
Accord:
0-60: 8.5 sec.
1/4 mile: 16.4 @ 84.8
Camry:
0-60: 9.5 sec.
1/4 mile: 17.1 @ 81.2
So, despite similar specs to their engines and similar curb weights, the Accord managed to outperform the Camry to a measurable degree.
If this disparity in how the engines perform vs. their specs applies to the V6's as well, the Accord may have an advantage that the specs don't reflect.
Not that these slight performance differences matter all that much in this class of car... I doubt that many Accord and Camry owners do a lot of drag racing regardless of which engine/transmission they choose. But this seems to be today's topic of discussion.
does the accord LX come with keyless entry standard? or is that extra? my 2001 coupe LX didnt come with keyless entry-- seems that should be standard now like the camry has.... they probably charge too much for it and better to go with aftermarket eh?
The 2003 Accord's steering wheel is now tilt and telescope. Way better than the tilt on my 2000 Accord.
While not denying that Camcords are some of the best cars available in mid-size segment, Detroit is indeed catching up FAAST..
I love the part about the owners complaining about reduced gas mileage in certain trucks, which they based on the fact that they had to fill up more often. Of course these rocket scientists had missed the fact that the gas tanks had been made smaller. Unbelievable...
After seeing their scores and articles like this, JD Power hasn't a shred of credibility left in my eyes.
http://www.detnews.com/2003/insiders/0305/12/-161375.htm
http://www.jdpower.com/auto/search/winners.asp?StudyID=736&Ca- tID=1
Answers to maxamillion, jsmath, talon95:
It is initial Quality rankings. Though reliability is certainly different than Initial Quality - I for one, believe that - better Initial Quality goes a long way in achieving long-term reliability. Put it differently, you can't have reliable vehicles if Initial Quality is bad. Well begun, is half-won. I would definitely give credit to Malibu for achieving #1 in Quality. Besides, long-term reliability canNOT be measured on this year i.e. 2003 models. Reliability can be measured only by let's say 5-6 years down the line. For 2003 vehicles, only 'measurable' Quality can only be Initial Quality.
JDPower vs CR: I like JDPower reports better simply 'cause, it just reports the facts i.e. rankings as obtained from the owners. It does not put any twist to the rankings by having it's own reviews on the vehicles. Which is exactly what CR does. Though I wouldn't disrespect CR for doing that. It's just my view that any review is afterall a review i.e. a subjective viewpoint. I for one, do not think the re-skinned Camry (2002) can be readily accorded high reliability ratings (CR gives it glowing reviews) - simply because reliability cannot be measured on the same year it is manufactured. Infact, 2002 Camry did not receive good Safety ratings when the test was done. Whereas I am realistic enough to agree that yester-year Camrys has had very good reliability records.
My original point was that Detroit is catching up FAST with the [non-permissible content removed] - which is indeed true per recent JDPower rankings. I do not discredit Camcords - as they still continue to be some of the best cars available to the consumers. It's just that - 5 years back, I would never have imagined a Chevy mid-size vehicle bettering Camry/Accord in any Quality rankings and am a bit surpirsed to see that happening. And with the 0-0-60 offers going on right now, some Detroit vehicles could even be a good value comparatively.
And it's abundantly clear from the reports that have surfaced lately that JD Power has no means of assuring meaningful measurements of "quality" from the people that they survey. Hence we have cars getting heavily penalized in "initial quality" for having cupholders that don't hold full sized cups. What in the world does that have to do with quality? As the article says, that's a satisfaction issue and as such is misreported by JDP. So since JD Power uses an unconventional and misleading definition of the term quality in their surveys, it's no surprise to see that cars that are ranked as unreliable in other surveys come out on top there, and that JDP's "quality winners" can easily end up having reliability problems as the miles pile on.
I think Mr. McCormick sums it up best with this quote:
"Those are clearly customer satisfaction issues and bear no relation to the actual quality of the vehicles concerned. The clear failure of J.D. Power's process in these instances naturally raises questions about the dependability of the rest of the survey."
He's absolutely right. Their measurements and controls are a joke from a statistical sense. These "findings" tell us nothing that's really useful about the quality of these cars. So a few Detroit cars winning these meaningless awards is in no way a true indication that Detroit is catching up.
If you want to rely on JDP, that's your call. As for me, I'll stick with CR, since their reliability ratings at least correlate to what most owners actually experience. They measure real problems, not owner satisfaction with cupholders.
What in the hell does that have to do with quality? That is pure SATISFACTION! Someone also pointed out that the Hummer H2 lost points on quality because of its low gas mileage. That also has absolutely nothing to do with quality.
If the survey indeed takes into affect the usefulness of certain features in a car, and claims them as quality, that is downright stupid if you ask me.
For example
What if the Toyota Corolla was a good car, with good quality, and the only real problems were silly issues like the cupholders being too small, the gas tank being too small, and the stereo buttons being too small, etc. The Corolla would get a lower rating that a comparable Cavailer because it has better cupholders? Those things DO get included in the survey. That makes absolutely no sense.
I congrats to Chevy on the initial quality survey, but I aint buyin it for a second.
