Visitor Agreement.
I am very ALEGRO with my car indeed. A Minor problem, tachometer indicates +/- 10 km on the conservative side, any suggestions?
please reply to : walterc@wanadoo.nl (the Netherlands)
Many thanks.
I guess all I can do is try and find a used fuse box from a yard and hope it will get it going for another year or so sense I can’t afford a window seal.
(Anyone know how to remove and replace said box?)
Alero 2001 AC not cooling.
The compressor is engaging and disengaging normally when I work the controls as the engine runs.
The discharge line from the compressor is hot enough so it appears that the compressor is pumping well.
The suction line going into the evaporator behind the dash at the firewall outside is cool as I think it should be. The return line is close to freezing. Condensate drips and falls to the ground.
I did not put a set on gauges to check the pressures.
Would there be some controls that are not working so the air is not blowing cold into the cabin?
Send me an email REPLY to:
tansane@bellsouth.net.
I lost my password and cannot get in normally. I will have to check into this later.
Meanwhile my wife is going crazy by not having AC in her car! I have to lend her my truck while I fix this problem.
Thanks for your help [anyone]
Ken 38
END
Has anyone had the above issue- i checked the bulbs and they are ok, i also checked the fuses and they are not burned either. I wanted to get feedback prior to taking the car into the dealer-also the service vehicle soon light comes on intermittantly.
Thank you in advance for any feedback!!!!! :confuse:
Thanks for any help!!!!!
-Greg
WHO THINKS THEY SHOULD RECALL SOME OF THESE ALEROS?
Exasperated,
Cdub :confuse:
Price sounds about what I've been hearing from others, and this place is about the only dealer I trust. He said it may last quiet a while without needing a new gasket, but at this point, why take a chance? Looks like a full day the technician to replace.
If it's not leaking now, I wouldn't worry about it. Most never do.
Maybe someone else can chime in here, is there some reason you can't change the rear valve cover gasket without doing a bunch of other work? I looked on my 04 Grand Am, and I can't see any reason why you wouldn't be able to do it, but access is tight.
You may want to check this:
http://www.lemonauto.com/complaints/gm/olds_alero.htm
It's located under the dash on the passenger side way up in the back. It's held in with two bolts that can be removed with a socket that has a "universal joint" connection to it.
By the way, this is not only an Alero problem, I have replaced them in two of my Pontiac Grand Prixs. With the right tools, this is a 30-45 minute job. Without the proper socket connection, it's a real sob.
Thanks in advance!
Dan
It looks like this is not a common problem for Alero or even Grand Am or Malibu. What is a common problem is the ignition switch failing for the passlock/security feature not the key. Dealer usually gets around $600 to replace. I can get a junkyard ignition w/keys for $35 or a new GM one w/keys for $85. The way to get to the switch is to remove the speedo/guage cluster, vent, radio. The Alero is still sitting in my garage while I decide what to do.
