Visitor Agreement.
As far as what to use, you cannot go wrong with Castrol GTX. Depending upon the temps in the area where you live you could use anything up to a 10W30. If you are in an area with cool summers and cold winters, you might want to look at 5W30 or even 5W20. If there is still an owners manual in the car it will show the preferred viscosity for the average ambient temperature.
Jim
Then again, I have seen disasters happen when a high detergent oil was placed in an engine that hadn't had regular maintenance. The HD oil will break sludge loose and cause all kinds of problems.
I have stayed with Castrol GTX because of decades of very good results. I have pulled valve covers for gasket replacement on engines with 70K+ miles on them and found no varnish or sludge.
Yeah right.
*Dreadfully easy if the car hasn't seen northern winters; can be a b!tch if the bolts are rusted on... but still do-able.
Yeah right.
jvenezia--- email through my profile...thanks.
I have a 2005 Elantra GLS sedan with 19,000 miles. I love
the car and it runs flawlessly! I have been doing 4000 mile
oil/filter changes with Castrol GTX start up and the engine
runs super smooth.
I plan on keep this can a very long time, probably close
to 160,000 miles or so. I have always babied my car and
always make sure all the scheduled maintanence is done on
time.
My question is would it be benifical for me to switch over
to a full synthetic oil like a Mobil 1 5W-30 at this stage
in the life of the car? Will gas mileage really improve,
or do most folks just exaggerate?
I also am a little rough on cars, tend to drive them hard at times and sometimes go a little long between the oil changes. So I think you should be ok with regular dino squeezins.
But if you want the man made stuff better start soon, never a good ideal to switch after a lot of miles.
Thats encouraging news. What type of oil/filter have you been
using and at what intervals?
Can a switch to synthetic really improve my mileage?
It may, and if it does its going to be real slight.
Filters are a funny thing in that there is a bypass valve in the Hyundai OEM filter that opens up at times demanding high oil flow. Some aftermarket filters don't have the valve and/or the valve opens up at different flow rates, which can result in oil starvation and serious engine damage. I have no direct experience in this since I always use OEM, but I know there is a Hyundai Technical Service Bulletin that discusses engine noise and aftermarket filters. They don't name names, but I've heard that at least some Fram filters that fit the Elantra don't have the right valve. I've heard Purolator is supposed to be good, and lots of people swear by Amsoil filters.
My thought, though, is that to make sure it's the right filter, go with OEM. Yeah, you shouldn't have to, but they aren't *that* much more expensive and I like the peace of mind. If you get an oil-related problem down the road and he wrong filter happens to be on the car, the dealer may not want to cover repairs under warranty.
So far I've run dino oil when I've done oil changes, but two dealers who have serviced the car stated "Mobil super synth" or something like that, and I think I did see slightly better mileage (although it might have been just random variation).
My buddy runs Mobil 1 synthetic in his full sized (extended cab) pick up and claims that his mileage has improved since switching over to synthetic - by a couple of mpg.
I switched over to synthetic in my '02 Elantra at 72K miles. It currently has 78K on it, and my mileage is the same as it was before going to synthetic. The main reason I switched was because my dealer does the synthetic oil change for less than twice the cost of a regular oil change, but he claims it is good for twice as long as regular oil.
I also switched my '03 AWD Mitsubishi Outlander over to synthetic at 35K miles. It now has 40K miles on it, and my mileage has stayed the same on it as well.
I *have* trained myself to drive more conservatively with my Elantra and it probably increases my mileage about 10% or so.
So have I, partially due to the price of gas and partially die to the number of miles on the car. I am able to get better than EPA estimates.
I have also heard that synthetic oil does not break down like regular oil over time (don't know if this is true or not). Take my Outlander for example...It is currently spending most of its time sitting in my garage, and is mainly just being driven on highway trips. I would be suprised if we put 3,000 miles on it over the course of the next year. I have always heard in the past that you should change regular oil every 3,000 miles or every 3 months, whichever comes first. If all of this is true, I can probably get away with doing a synthetic oil change 1 time per year, vs 3-4 regular oil changes per year.
Just curious what you guys' thoughts are about synthetic vs regular holding up over time in a car that sits around a lot.
ELantra GLS for the OEM Michelins??
I currently have 19,000 miles and although the tires are
wearing nice and evenly, I do not like the ride quality
and the way they hanlde in the rain. Also, the steering
always seems to feel very heavy in my hands.
Im looking for a tire that will provide a more smoother
ride and also better handling and wet traction.
Any recomendations would be greatly appreciated!
Im considering the Bridgestone LST, Kumho Solus KH16.
My theory on this is yes they will increase your gas mileage but only very slightly (like taking you from 25 MPG to 25.2 MPG). Such a difference can be eliminated or exaggerated by many factors such as wind (do you have a tail wind or head wind and how strong), temperature and driving style. That being said I don't think the mileage increase would be outside the margin of error for a controlled experiment.
My understanding is that the fake oils don't break down as fast as the dinosaur squeezins under driving conditions, I am not sure about time wise. I have a Caddy that I am putting about 5-6K a year on that has the man made stuff in it. I change that twice a year.
I have Cooper Lifeliner SLE Touring tires on my Elantra, and I love them. Smooth, quiet, good in rain, etc...
I have a set of BFGoodrich Traction T/A on my other car, and they are nice also.
I plan to replace my own OEM Michies with Falkens. They are relatively inexpensive performance tires. In 60 and 65 series sizes they have a 60,000 mile treadwear warranty. (If you go with a sportier 50 or 55 series series, the treadwear warranty drops to only 30,000 miles.)
On Edit: After reading backy's post about the Kumhos, they sounds a lot like the Falkens.
A drawback to the BFGoodrich tires, though, is much increased noise and a stiffer ride. They have incredibly stiff sidewalls and the place where I had them mounted thought at first they were run-flats.
I'm now looking at a set of Yokohama AVID H4S or (for a little less) Kumho ECSTA ASX for my three-season driving and I'll keep the oustanding Winterforce tires for winter.
I really recommend Tirerack. They're great.
Factors that contributed to the increase during the trip:
• Use of cruise control with steadier driving, although average speed was 75;
• Freshly changed oil, oil filter, and air filter.
Factors that should have worked against the increase:
• An extra 200 pounds of weight;
• Use of air conditioning for part of the trip, where I didn't use AC at all prior to that (wrong time of year).
Unfortunately, several months after changing out the oil again with the exact same synthetic, I get only about 32-34 mpg in mixed driving. I never got 39 again
It may be that the Elantra engine also will "adapt" to octane and the big bumps in mileage came from getting a tank of higher than advertised octane.
Just a thought.
Jim
Speaking of which, I'm constantly frustrated by big-a_ _ed pickups and SUVs that are now driving at 50-55 mph on our rural highways because of their 15 mpg mileage. A year ago, they were terrorizing the road. My little (comparatively speaking) Elantra is now running rings around them and enjoying twice the mileage. I'm seeing a huge load of pickups and SUVs for sale now on the side of the road...rusting out because no one's even looking at them.
I suppose if you wanted to be really sarcastic, you could have told the guy at Sears, "No, I'd rather pay three times as much for a tire that is harsher, noisier, has poor wet traction, and is faster-wearing than the Kumhos."
You have stated that the Cooper tires you had(im assuming
they were the Lifeliner SLE?) were more quiet and smoother
than the OEM Michelins....but you said the Kumhos were even
better?
Do you feel the Kumhos are ever quieter and smoother than
the Coopers? Im wondering which tire, Cooper or Kumho will
prove be to the better wearing tire over a 50,000 mile
period.
What are your thoughts??
So when you had the Coopers install, you immediately noticed
an improvement in ride qality and smoothness than the OEM
Michelins?
After much research, im debating between the Kumho Solus
KH16 or the Yokohama TRZ.
I have my Elantra on synthetic oil now, and every 5-6K, I am getting the oil changed, and having the tires rotated. I bought the tires from my dealer, and they rotate them for free. I think they are listed as a 60K tire, but I am not sure without going back to the Cooper website.
I'm not saying that the Kumhos may not be better, but I have been thoroughly impressed with the Cooper Lifeliners.
Are the Coopers you have the H or T rated version??
The Lifeliner SLE is available in both speed rating for
the 195/60/15 size. As you know, the OEM Michelins on our
Elantras are H rated.
As soon as I got my '05 Elantra I replaced the Michelin garbage with BFGoodrich Traction T/A H tires. Far superior tire, but much noisier and stiffer. You'll give up comfort for a much safer ride.
to me exactly what this so called shimmy problem is with the
Elantras??
What exactly is it, what is the course of action to correct
this and is this a warranty repair?
I was out on the interstate today for the first time in
quite a while. I have a 2005 GLS which I love with 19,000
miles. I noticed when I hit 65-70mph, the steering wheel
was dancing in my hands slighty, but not too much. Is this
a part of the shimmy problem?
I drive very conservatively, never hit a pothole or a
curb and the car tracks completely straight and has never
pulled to either side.
The set I have now are the Kumho ASX and these are great!
I never had Coopers but I heard they were better then the stock Michelins as well.
may be possbile, if I should always request to have my
tires balanced with every rotation?
Typically a standard rotation does not include balancing.
Im taking my O5 GLS into the dealer tomorrow for them
to look at the slight steering wheel shaking at 65-75mph.
Hopefully, a good balance willl solve the problem.
