Visitor Agreement.
I've always used Hyundai OEM oil filters. I can get them for $6 each at my dealer, or a whole oil change for $15.95. I don't think it's worth chancing the engine to save a few bucks here and there. For aftermarket filters, Purolator's site shows that they have the correct bypass value (12-15 psi) and I've also heard that Wix is good.
Model: 2002 elantra -GLS- with 62k, sunroof,Cd player,power windows
I am planning to buy above vehicle - cuold some please suggest me the best price- the asking price is : $5200 dollars
Naveen
But, they are good solid cars.
I will enquire all the details.
Naveen
I caculated the gas mileage, it is ONLY 17.1MPG for the last 150miles(local)!!!
isn't it claimed to be 26/34?? I use 88 gas.
does this indicate a problem in my car??
Also we had the plugs and wires changed, now when we put gas in the car the wheel will vibrate for a few miles this is something new too. any information on this
Much thanks in advance.
I caculate the MPG in your way.
fill and refill then caculate.
so is there any way I can improve the MPG?
I just drive it from and to school and never drive as a sport car.
the car has 73k on it.
Does anyone know if we can use 20/50 oil for an oil change, has anyone use this on their car, we have 2001 Elantra with 133,000 miles on it.
Second, at what rpm should the car be set at? If someone can answer before Friday, much appreciated
Dria
Idle is computer controlled, at around 800rpm if I remember correctly.
Does anyone know about "Turbine Speed Sensor" it has to do with the sensor in the transmission, I have a 2001 Elantra has 135,000 miles. Does this say the transmission will go or what?? Thanks in advance
Dria
I just purchased a 2002 Elantra. The interior dome lights are out. I don't have a owner's manual so I'm not sure exactly what fuse to replace in the fuse box. Does anyone know which one I could replace?
Other than this, I am still VERY happy with this car, which will be seven years old in July.
Your car is fast approaching the 60k service. This is a major service and very important one. It will cost some bucks, but it includes some important maintenance items, including replacement of the timing belt. If that breaks, the engine will be seriously damaged.
You can have the services performed anywhere you want. You can even do them yourself if you have the skill and time. Just be sure to keep records of all services, and use OEM parts or OEM-equivalent parts, even for parts as mundane as oil filters.
I have a 2002 Elantra GT automatic and live on the peninsula in the San Francisco Bay Area. I used to go to east bay for major service (richmond to be exact) since there is no hyundai dealer on the peninsula.
Just by chance, I found there is a dodge dealer in redwood city selling new hyundais called "peninsula dodge hyundai". Does anyone here have good experience having their hyundais serviced there? If yes, I would try it out wholeheartly without spending time and gasoline traveling 80 miles both ways to my old dealer.
min
QUESTION: I have a 2001 Hyundai Elantra with 51,000 miles on it. My check engine light has been popping up every now and than so I checked the code. It said, "P 0715, input turbune speed sensor / circuit malfunction" and P1529 Vehiclle speed idle control auxillary input" I could not figure out anything about it nor my mechenic.
Is this something that would be covered under the Hyundai Powertrain warranty ? Is it something small that my mechenic would be able to fix with a small charge.
Thanks very much.
Warranty repairs:
Gas filler neck
Plastic piece at base of windshield
Headlights
Drivers seat left side plastic molding
Heater hot air to foot vent - not fixed
Non-warranty repairs:
Timing belt preventative relacement - around $250 at dealers
Front discs at 57K - a new record for me - never more than 30K on other cars
Numerous 4 wheel alingments
Tail light and license plate bulbs
Things I like about the car:
Good rear visibility - low trunk unlike 2007 and newer.
Summer 34 MPG superhighway driving, 30 MPG light traffic local driving
Patterned fabric - been called "airplane fabric" but I like it - still looks new
The tachometer still works - unlike 3 Chrysler Corp cars I had
Things I don't like about the car:
Can't seem to hold an alignment for a year - a 2700 pound car should not have this problem. My 1989 Plymouth Acclaim was the same weight and never required an alignment.
The drivers seat bottom is uncomfortable for me on a long trip
Many of the exposed fasteners (screws) are rusting - I go after them with WD40
Slight rust appering on lip of rear fender well
Headlight lenses are starting to fog
Suggestions for improvement:
If a timing chain or some other alternative is possible I would pay extra at the time of purchase to avoid the expensive PM later.
Better corrosion protection of fasteners
More comfortable driver seat
More robust running gear to reduce alignments.
My mechanic had not seen one of these cars when I bought it and asked me how I liked it. I told him wait 5 years and then ask me - the answer is yes.
The reason I can not hear the noise except at low fan speed, is that the fan gets too noisy. I think the noise goes up with RPM. Will try with a stethoscope next.
I would like to have the pleasure to report my '02 GT (5-door) AT as well.
It is currently at 55K miles and I just had 60K service (480), new battery (95), RR brake light (5) and rear brake pads (210) replaced. The front pads still have 40% left and should last till 90K service (at which point I will have spend over 400 for timing belt here in CA).
Except some trim issues, such as the black tapes on the doors, fixed under warranty early on, my car has not failed on me, not even once. Besides new tires at 35K, all other parts are still original unless mentioned above.
I bought Hyundai oil filter and washer online and used them when doing oil change at local shops. But always try to get the major things done at the dealer so that no BS later should anything weird happens.
Overall, I really like the reliability and utility of this car.
QUESTION: I have a 2001 Hyundai Elantra with 51,000 miles on it. My check engine light has been popping up every now and than so I checked the code. It said, "P 0715, input turbune speed sensor / circuit malfunction" and 1529 Vehiclle speed idle control auxillary input" I could not figure out anything about it nor my mechenic.
Thanks very much.
I haven't posted in here for quite some time. Just have been busy. I have a 2005 Elantra hatchback. Just got my 33K service. I have had relatively few problems. The window and door lock control on the driver's side wouldn't raise and lower the passenger side window. My dealer replaced the entire console at no charge. The driver's side door window came loose and fell down inside the door. Dealer fixed it no charge. I had one tire that picked up a nail or something, and I got it replaced with a used tire with similar tread left on it from a local Goodyear dealer (tire couldn't be repaired). Otherwise, my tires seem to be holding up very well. At last check they still have plenty of tread left, according to my dealer, and brakes are in great shape. I must be blessed with a decent dealership. All my services have cost me much less than I expected. The 15K service came to about $173 and the 30K ran $420. The other services have run anywhere from $28 to $35. I haven't checked MPG for quite some time as almost all my driving has been in town, but I'm 59 and a pretty gentle driver. That seems to be why I haven't had many problems. I haven't been particularly happy with the windshield wipers. They are great on the up sweep but leave liquid on the window with the down sweep. I've asked the dealer to check them a couple of times and the dealer says they are fine. Still, I'm not real happy with them. Any suggestions for replacement wipers? I do use RainX on the windshield and that seems to help quite a bit.
I do have a question. At some point someone got my passenger back door with their back door, I suspect. I have a spot in the middle of my back door that is pushed in. Paint was not cracked or chipped and no actual crease in the door. It's just pushed in. I checked with my dealer's repair facility, and they told me it would be over $1,000.00 to fix. Said they would have to take off the back quarter panel and front passenger door, etc. to be sure paint matched up. This seems over the top. If paint was chipped or cracked or there was an actual crease in the door, then maybe, but this almost looks like if you could reach in behind it you could just push it back into place. In years past I remember seeing advertisements for a tool that was supposed to take minor dents out. You could get them at auto supply stores. Does anyone know if these are still available and do they work? Anyone had any experience with one of these? I'm disabled and on a very limited budget and a $1000 is virtually out of the question, yet the "dent" in that door bothers me. Sure would appreciate a less expensive method for pushing or pulling the skin back out into place.
Otherwise, I'm very happy with my Elantra and definitely would get another when it comes time to replace. I just hope Hyundai comes out with some kind of hatchback type vehicle by the time I need to replace mine. I love the hatchback. It has had some hauling duties and did them beautifully.
And if the dent is as you say, your dealer is planning on doing the whole sanding, bondo, repaint and it really doesn't sound called for from your description.
Suddenly my gas mileage has dropped like a brick.
Where I was getting about 500 miles to a full tank of gas
I'm now getting 375 to 400 miles!
This occured almost overnight.
With gas prices at four bucks a gallon this is scary.
She runs good and idles smmoth.
No visible leaks or fuel odors.
Nobody punched a hole in my gas tank to siphon it off either.
I have no other complaints about this car for the four years I've owned it.
Anyone have any advice/suggestions??
GM1258
I have used them on a number of occasions. One time for very similar door damage you describe. Each time they are done, the area is either totally restored to original condition or so close it's difficult to tell. I recommend them for this type of repair.
The best place to get a good one is through a large dealership. They often use this service for hail damage and have a few contractors numbers handy. Sometimes they willl lease space at the dealer and work right there.
The one gripe I have about these cars is the sheetmetal is a bit too thin as they dent easily. My friend has a 2008 Elantra which seems to have a much thicker skin. Good luck. --Jack
