Visitor Agreement.
This is the Accord (TSX) I want. Over 130 mph, and 92 mpg (Imperial).
Please can we have one! : ^ ) Manual tranny wagon preferably.
i fear i might have the infamous Accord rattles. now that it is warm, and the car is "looser", i hear noise in the headliner, more towards the passenger side, and also a slight rattle in my drivers door. if i elbow the door it goes away.
any TSB's for those? anyone have any successful fixes? they aren't really too bad, but i tend to be a little crazy about my cars..
thanks!
oh, for the first 250 miles, i got over 30 mpg, driving through mountains at around 80 mpg with a/c on and two passengers. not bad at all!
Are the recommended numbers "maximum numbers?" Sure... but don't let the use of the term "maximum" be spun in such a way that it implies "bad". Those numbers are part of Honda's recommended normal maintenance schedule. And if you look at the conditions that define that schedule, most driver's would easily fit into that category. Even Honda says that they expect the normal maintenance schedule to apply to most cars.
By all means, change it more often if it helps you sleep better at night. But don't let antediluvian opinions about auto maintenance and predictions of doom and gloom if you don't follow them frighten you into thinking that you're abusing your car by following the manufacturer's recommendation. That's total nonsense. They designed and build the car... nobody knows the car better than they do.
IF your oil is driven on most trips 15 minutes or more so that the contaminants are being purged by heat and the PCV system, run up nearer the max recommended by the manufacturer. IF your trips include more than 20 percent short starts and stops with a cold engine, change at the minimum or sooner nearer 3K if you plan to keep the car past 100 or 125K and want to minimize wear.
IF your climate is cold, increase oil changes to nearer the 3K intervals.--just my opinion.
Point taken... this was a more "sweeping" description of some opinions expressed here that seem to be strongly rooted in the past... it goes beyond the 3000 mile service intervals.
With regards to oil change interval there are many strong opinions on this and go with what you feel comfortable with. With the exceptions of a few manufacturer design flaws (not in Honda's) the vast majority of engines do not fail if you follow the manufacturer's recommendations. Oil related engine failures are extremely rare even up to mileage around 150k-200k.
Greg, we've been through this before. And I've posted the specifics of the Toyota problem. Yes, it's partially because of oil starvation, due to a design defect in the engine. Toyota has recognized that defect and addressed it. The failure of the oil in an engine with a design defect in its oil circulation system has no bearing on the potential of oil failure in a properly designed engine.
To save typing, I'm simply including portions of my previous post on this topic.
Toyota acknowledged that engine design was at least part of the problem when they made a design change to the engine that improved circulation by enabling oil to drain faster into the sump.
In addition, some experts believe that the problems are worse than Toyota admits. One expert says that the problem occurred mostly because of excessive heat in the cylinder head, which resulted in a 60 to 70 degree temperature difference between the cylinder head and the block. This is far greater than the industry "rule of thumb" of 10 to 15 degrees, and such dramatic temperature changes are extremely hard on the oil.
So the oil in these engines was stressed way beyond normal conditions. The oil was being stressed at a "severe" or worse level even if the car was driven at defined "normal" levels. Since the oil was abused in such a manner, it comes as no surprise that more frequent changes helped in this situation. However, it definitely doesn't follow that engines without such a design defect would achieve any benefits from more frequent oil changes than those recommended by the manufacturer, or that they'd suffer from similar breakdowns as a result of following the recommendations.
I feel that the Toyota sludge issue is apples-to-oranges to this discussion. It tells us little except for the consequences of a design defect.
So does this imply that no level of preventive maintenance is too much? So perhaps you should change your oil every 2000 miles. Or every 100 miles. After all, wouldn't that be improving the quality of the preventive maintenance on the vehicle as well? You tell us that improving the quality of the preventive maintenance is a good thing... so how much improvement is enough? When does the "improvement" stop and the extra maintenance become a waste of time and money?
That's where we primarily differ. Whether or not improving the quality of the preventive maintenance on the vehicle is necessary depends on your position as to whether or not the recommended level of preventive maintenance is inadequate. You seem to think so. That's your right. Excuse me if I take the word of the manufacturer over yours, or over your dealer's.
I should mention the oil test -- let the oil do the talking. If it gets black and changes feel to a heavier feel, change it. Drop a drop onto a paper towel and look for the dark inner ring when the oil is new. Then do that every couple of weeks as your miles build up. When the center dark ring is the size of a dime or bigger after a few minutes of spreading out in the paper, it's time to change.
Using that method your driving style will show up in the look of the oil. This method also would have shown visually the oil problems from the hot spot in Toyotas deteriorating the oil.
Those of you who keep butting heads on this need to agree to disagree now, and leave the subject alone.
It might be several years before my car is even close to 10,000 miles--my last car, a '91 Mazda Protegé, was 12.5 years old and had only 19,000 miles on it when I sold it!
My question is: Should I change the oil after one year (this coming August) with so few, mostly highway miles on the car, or change the oil and filter because they had been in the car for one full year?.....Richard
It doesn't seem to mind it. Oil is still clean and the engine is still very powerful. Syntec seems to take the "abuse" well.
I am also a low milage driver. There are maximums on time for all the service intervals. Read the manual.
You need to do this to keep within the warranty guideline - if you ever do need Honda to fix something on the car, under warranty.
I changed out a perfectly good 2002 Accord air filter, with less than 10,000 miles on it. There were just a few soot spots on it, almost no dirt, dust, etc. But there is a 24 month time period for the filter. Absolute waste of money, but I did it.
I thought about that, but renting a car on short notice or cabbing to fairly distant destinations is inconvenient and I like the freedom of having my own car. The cost is high, but not really an issue.
Yes, owning such a nice car as the new Accord EX-L and driving it so little is a bit of a waste, but when I do drive, I want a car that's comfortable, safe, and a pleasure to drive......Richard
I see from your profile that you're in the Bay Area. I would presume that something like http://www.zipcar.com is available there. It's pretty big here in Boston.
Yes, there's a "City Car Share" outfit here, but I'd have to drive one of their VW Beetles. EEEEEWWWW!
.......Richard
Jeez - they aren't that bad!! Zipcar has Bettles, Jettas, Passats, Golfs, Priuses, RAV's, Matrixes, Corollas, Camrys, Xa's, Xb's, Civics, Elements, Minis, Focuses and even a couple of 325's!! They had some Tacomas but I can imagine the workout those would get.
Any other specific trouble spots I should be careful of with this car? Thanks for any advice.
EX adds sunroof, wheels, wood/aluminum interior trim, 4-wheel disc brakes, side airbags, optional leather which adds dual-zone climate control, heated seats, curtain airbags, and XM radio.
As a side note all 05 Accords will have standard side airbags and side curtain airbags.
For nw1997; IMHO, synthetic I believe only provides any real benefit under extreme conditions, (ie racing, extreme heat/cold, etc.) I've used dino in all my vehicles, and have never had an oil related engine problem.
As snarks says, there are many opinions - the best thing to do would be to take some time to read what others have already posted and make up your own mind.
Enjoy!
The Accord's 4 cyl. engine is smoother and more powerful than many competing V6s. And at today's gas prices, you'll like it even better.
And the EX-L Accord is not only a pleasure to drive, but it's one of the safest cars you can own with its standard side, curtain airbags (all 2005 Accords will have them). The EX-L Accord is a near-luxury car for thousands of dollars less.
Drive your new car in good health.........Richard
I have never driven the V6 but my 04 EX-L drives great.
