Visitor Agreement.
perhaps, i'm not as sensitive to such an issue?
Last time I was at my dealer he drained some of the tranny fluid as it was high, which seemed to have helped but now...no luck...the problem still exists. I've checked the fluid level and it is fine. I have around 7000mi so I think I've broken the car in.
Has anyone else with an '02 EX V-6 noticed anything? Should I start the ball rolling for Honda to extend the tranny replacement to include '02's? Any other suggestions for me to have the dealer check? Is this just a "characteristic" of the Honda trans...coming from a Pontiac Grand Am there are already a lot of differences...all for the better! Thanks in advance for your assistance!!
oh well. we just crossed 1000 miles and besides my anal-retentiveness about this rattle, it's been a great car. the more i drive it [my wife is starting to wonder if this is really *her* car], the more i appreciate how well it drives. the power is truly effortless--this weekend, i had to punch it to get up to speed from a short onramp and i was left with a smile on my face: amazing considering its a 4 cylinder. Sure, it's not as fast as the V6, but certainly more than adequate.
Unlike most aftermarket bars, which are so stiff that the car not only corners flatter, but actually OVERSTEERS, this particular change integrates very nicely into the car. Many years ago I tried an aftermarket rear bar on a 1967 Dodge that made the car hazardous in sudden swerves; I got it broadside several times and caught it before it spun, and finally removed the bar. Many years later I tried another aftermarket bar on my 1995 Ford Aerostar van, and everyone who drove the car commented on the fact that the rear end always seemed to be trying to pass the front on highway curves. I removed it also.
Remember that as you increase rear roll stiffness, you do two things at the same time: reduce lean on turns, and shift handling away from understeer towards oversteer. A little can be very good, making the car almost neutral; too much can be scary as h***!
Also note that the stiffness of a torsion bar increases as the cube of the diameter, so a small change in diameter makes a big difference in stiffness.
For our generation of Accord, we have several choices in rear bar to "tune" the handling to your preferences. The V6 sedan comes with a 16mm bar; the V6 Coupe uses a 17 mm; the Acura TL uses an 18mm ; and the TL Type S uses a 19mm (same as the Neuspeed). All can fit the same mounting bolts; all you need is the bar and the appropriate bushings to fit.
The 17mm diameter bar is 21% stiffer than the 16; the 18mm is 43% stiffer, and the 19mm is 67% stiffer. AFAIK, the I4 doesn't use a rear bar, so you could add the 16mm bar for a nice change.
I haven't noticed any change in the car's response to crowned roads. It has always felt completely normal to me; and quite the contrary to any "drift", I have found the Accord's steering to be very precise, almost telepathic. I drove a Passat before I bought the Accord, and preferred the Accord's steering feel; the Passat steering felt overboosted, too light for my taste. YMMV, I guess.
I just received this item for my new EXV6 from collegehillshonda.com I din't think to look at the instructions before hand since I easily installed it in my 99. The install is so complicated, you wonder why they just didn't install the mounting screws at the factory.
http://www.collegehillshonda.com/instructions/03accord/cargonet.pdf
Not sure If I am going to do it myself or let the dealer do it.
Jeff
You need a couple of box end wrenches, and there is a metric Allen wrench "socket" in the end of the the bolt for the end link. You use that to keep the bolt from turning while you turn the nut.
This whole thing is harder to describe than to do it, once you get under the car. The entire process took less than an hour, including backing the car onto the ramps and driving it off afterward.
The sway bar is just a torsion "spring", and has no effect on alignment, so no re-alignment is needed.
It was probably overkill, but I used a little bit of stringy, viscous grease on the bar where it turns inside the urethane bushings just to be sure it didn't develop any kind of squeak over time.
If you buy the Neuspeed kit, you get all the directions; if you get the parts from Acura, I guess you'll just have to plunge in and do it. The only thing that is not obvious is the little hole for an Allen wrench in the end of the end-link bolt; if you didn't know it was there, you might have a hard time removing the end-link connection. The nut is tight enough that I feared I'd break the Allen key, but not so...I finally decided that if Honda could tighten it without breaking THEIR Allen key, I could loosen it without breaking MY Allen key. Since all name-brand Allen wrenches are some kind of hard steel alloy, heat-treated to some phenomenal strength, that was indeed the case.
2. Gas mileage. My 03 EX V-6 is getting 27 in average driving. I do wish I could get the 38 like the I-4 guys. I think 38 is commendable.
Anyone test V-6 on pure trip. I am hoping for 30 plus on a trip. Around town and communiting, i am content with 27 on regular gas. Tried premium but no seat of pants difference to me.
3. I agree that road slope (ie crown for drainage) has tremendous effect on this car. I am getting used to it, but my 02 Acura 3.2 did not have this. Hmmn.
INKY
When the engine is cold, the car will accelerate to 20 km/h even when I'm off the gas. The car idles rough when I brake. Once the engine is warm, the car accelerates to 10 km/h on its own and it usually idles smooth.
Are other 2003 LX automatic owners having the same experience? I am thinking of taking the car into the dealer but since it took them 2.5 hours to install the cargo net (my car was the first they did this in), I am not sure they would have the answer just yet.
BTW, what does the G in LX-G signify?
Styling is really subjective I guess, but comparing it to a KIA RIO is going a bit far. To me it looks like a modified cool looking CIVIC at the front and a crunched Buick Regal at the back.
Is this a mistake for Honda? I don't know, time will tell. Just like the new 7 series from BMW>>> a very odd looking car IMO...
Its either your theory is right(4.5g left in your tank,) or your fuel meter sensor/solenoid/float is out of whack. However, having 4.5 gallons in your tank and your gauge is reading E I think is out norm.
Temperature seems to have some strange effect on gas too... I noticed in the summer I would put about 17+ gallons in, and during the winter, only 16... not sure how that computes, but just something I noticed.
I filled my '03 Accord up w/ just under 1/2 tank the other day and the guy squeezed about 7 gallons into it... perhaps this is just the way that the gauge is calibrated....(read too many people driving until E then run out of gas... =o) ... hehe)
I guess honda figures we need a 100+ mile buffer.
OTOH, my Honda civic, with its 11.9 gallon tank, has the "low fuel light" come on with about 1-1.5 gallons left. it's flickering with 1.5 gallons left, and the time i let it go solid and bought gas immediately after that point, i bought 10.9 gallons.
4 gallons seems a bit excessive. i would have though 2 gallons is more appropriate. but of course, i'm sure Honda will claim a "bug" is a feature like many other companies i know of. [even though i like all the Hondas i have had, i know they definitely play their games...]
Just works better for me...
Cheers...
http://www.motorcities.com/contents/02IID514901914.html
http://www.fabio.com.pt/Accord.htm
If these come over as a TL it would be great.
Is it safe to keep a car with this much miles on it?
Can it go to 250,000 miles?
Well, you'll be able to get it as a NEW Acura model (not the TL replacement).
Expect it to debut at NAIAS in January and on-sale Spring '03.
Just keep in mind there is a slight chance that it could have the bad trannie, but my guess would be that if it lasted 169k miles then it should be fine...
Just my .02 worth..
