Older Honda Accords
1173174176178179389
  • codog2codog2 Member Posts: 13
    Does anybody know if Honda will offer the V6 speed coupe setup (17" wheels, 6spd manual) for the sedan in the future. I've tested the speed coupe and love the car, however with a 1 year old, I really need a 4 door. Do you think Honda will offer it in a later model, or perhaps on the Acura TL?
    You think they would to compete with the Altima/Maxima & the Mazda 6.
  • davegod75davegod75 Member Posts: 48
    lets hope so...
  • s852s852 Member Posts: 1,051
    Nothing has been annonuced about a 6-speed sedan. I'm sure someone will post that news without needing to be prompted if that ever happens.
    It looks like Honda is not worried about competing with manual transmission V6 Madza6s and Maximas though, since V6 manuals had been available even in the previous generation models and they did not bother to respond then either.
    It is only a small market for those cars and that is why Honda isn't even building many 6-speed coupes.
    The Altima, Maxima and Mazda6 is there for those who want that drivetrain combo badly enough.
  • bowke28bowke28 Member Posts: 2,185
    no plans for 6-sp. sedan.
    the leather package to upgrade from ex to exl is $1300. last year it was $1400. pretty great deal to me.
  • ickes_mobileickes_mobile Member Posts: 675
    you'll have to visit your local Acura dealer for a TSX...
  • talon95talon95 Member Posts: 1,110
    "you'll have to visit your local Acura dealer for a TSX... "
    I believe the only engine available in the TSX at this point is the 2.4L 200hp I-VTEC I4. No V6 has been announced.
  • robmarchrobmarch Member Posts: 482
    I know the 2002 CRV has it. I believe it's the same basic I-4 engine that's in the new accord.
    Many people who want the moonroof like the cloth interior better than leather, but also prefer the V6 to the 4 (even if for no other reason than they don't want a noisy car), so they don't want either EXV6 or a 2.4 EX. An EXV6 with cloth or an Accord equipped like a 2.4 EX, but with the V6 instead would be the ideal Accord for them.
    Since that is not available, I thought that the LX V6, with an aftermarket moonroof could work.
    Has anyone had experience with a car with aftermarket moonroof? Is it as nice and leak-free as a factory moonroof and does it have a sliding sunshade? What are average prices for aftermarket moonroof installation?
  • stretchsjestretchsje Member Posts: 700
    That clatter after start-up on a cold day is normal on lots of cars, not just the Accord. I've seen on the Protege board that this has to do with improving emissions before the engine warms up.
    As far as i4 versus V6 reliability, that's an interesting topic. A V6 does not have to work as hard to accelerate the car at the same rate as an i4. Yet, the angled nature of the V6's pistons means gravity will cause one side of the piston's seal to wear more than the other. Subaru uses completely horizontally-opposed "boxer" engines, and from the ones I've seen, they don't have nearly the longevity of other Japanese i4's. Could this be from the seals wearing unevenly?
    Likewise, since variable valve timing makes an engine more efficient, it won't have to work as hard to accelerate the car, but it also adds more moving parts to the engine and encourages revving. The variable valve timing control of an engine isn't a high-wear item, so I would suspect it to have much of any impact on reliability.
    If there's been any conclusive studies on this in the past, I'm all ears.
  • w62w62 Member Posts: 27
    I got an area of scratch on the rear bumper( 01 Accord). It is not deep. Could someone recommend some material to fix this?
    Thanks a lot!
  • ariesvirgoariesvirgo Member Posts: 4
    Has anyone noticed that there is always a high pitch background noise (although very tiny volume) coming out from speakers all the time when the stereo is on? If I adjust the volume to zero, it is gone. But when the volume is 01 or up, the noise comes back.
    I've heard someone says this probably is the amplifier problem. Will the noise gone if I change to another amplifier? Is this normal? Or this is a bad stereo so I need to have it fixed? Everything else seems perfectly fine. Does it worth to have dealer take down the dash board and risk the possible rattling problem later on?
    Thanks for the suggestion!!
    Chao
    Modern amplifiers are always at full gain- that is, they are turned up all the way. This is because modern head units use digital volume controls rather than analog ones- the volume is digitally quieted before it ever hits the amplifier. That's why you'd here a noise at any volume other than "0", when the amplifier completely shuts off.
    Whether or not that particular noise is normal, well... I'll leave that to the other Accord owners to answer. It sounds normal to me- irregularites usually form as hum, popping, or cutting-out.
  • ramped1ramped1 Member Posts: 159
    I hear you about wishing for an Accord V-6 with cloth and sunroof. A Nissan dealer recently quoted me about $1,100 to put a roof in a Maxima that I was interested in. Said it looks and operates like factory.
    I did test drive a Maxima GXE with an aftermarket roof a couple of years ago, and as I recall, it did have the sliding sunshade and seemed to work fine. That being said, I would not opt for an aftermarket sunroof. My option would be to take the EX-4 with cloth, or, if you are flexible, look at a Maxima, Camry, Passat, Altima or Mazda 6. All have factory sunroof/cloth options with a V6.
  • phil4vers4phil4vers4 Member Posts: 18
    Can someone fill me in on the average gas mileage you are experiencing in city and highway driving for the automatic I4 and V6 2003 accords?
  • mikek37mikek37 Member Posts: 411
    Average gas mileage for the V6 03 Accord:
    City: 21-23 mpg
    Highway: 27-30 mpg ( Average speed 70-80mph)
  • revgslickrevgslick Member Posts: 5
    I've found the mileage on my '03 Accord EX 4cyl Auto somewhat disappointing. After my first half tank I have only got 268 kms. Assuming a 64.7L tank, this means the car is using 12L/100kms. Hardly close to the claimed 9.5L(City) 6.5L (Highway). My driving is about 60% City, 40% Highway. Will the mileage improve after break-in? Also, will having the A/C mode on recirculate mean that A/C is turned off and thus improve mileage? Thanks
      Kevin
    Kevin, give it some time. Let the VTEC break in, and I reccomend not calculating mpg on a half tank , yet try a full tank. I have a about 5k miles on my 03, and the gas mileage has slowly crept up to what the manuf stated.
  • ray_h71ray_h71 Member Posts: 212
    "Modern amplifiers are always at full gain- that is, they are turned up all the way. This is because modern head units use digital volume controls rather than analog ones- the volume is digitally quieted before it ever hits the amplifier."
    I disagree, stretchsje. ALL amplifiers, whether using efficient switching power supplies or conventional power supplies, are analog circuits. (They HAVE to be - they're driving analog devices: speakers.) Their gain is determined by the INPUT level of the analog line feed. That line feed level is taken off the head-unit's pre-amp chip which varies gain from the volume control, whether mechanical or electronic (does not have to be a digital volume control, though in the CD player section, its own output volume IS by necessity determined digitally - I believe that's the basis for your confusion). The AM/FM radio and cassette audio sections' signals are full-monty analog from the getgo.
  • atlantabennyatlantabenny Member Posts: 735
    Our 03 EX-L with the in-dash 6 changer also emits a "baby mosquito" noise in CD mode between tracks and between-CD changes at normal (1/4 - 1/3) volume. I'm not sure if it's an under-spec noise filter/suppressor but our other cars with external amps don't have this noise.
    I'm thinking of taking it in for warranty work, and though I'm expecting a "that's normal" diagnosis at this point, corporate Honda needs owner assertion of the problem to correct it for the 04s. When that happens, then we can claim warranty work/replacement.
    "Has anyone noticed that there is always a high pitch background noise (although very tiny volume) coming out from speakers all the time when the stereo is on? If I adjust the volume to zero, it is gone. But when the volume is 01 or up, the noise comes back."
    ariesvirgo, all modern car audio amplification systems use a servo configuration to control the amplifier. The amplifier shuts off bias current to the power transistors in the absense of an input signal. (No sense "idling" them when unneeded...) stretchsje had that part of the equation absolutley right. If your high pitched whine is always at a constant volume when present, regardless of volume setting beyond "0", it's a post-amplification signal getting into the amplified leads going to one or more of the speakers. If it varies in pitch, too, it's could be radiated noise RF or a ground fault from the alternator. If it doesn't vary in pitch, it could be hash from the various computerized electronics in the car making its way into the speaker lead(s). If the volume varies, either at the same pitch, or varying according to engine speed, it could be unintended RF from those same electronics or the alternator finding its way into the head unit or the amp's input circuitry, itself. If your car is under warranty, and it's a Honda audio system, I'd let Honda worry about it. These noises can be a som-'a-gun to track down and eradicate, yourself. I know. I went through something similar with a church organ I built 20 years ago. Fortunately for me the company that made the kit had some heads-up "Jimmy-Electron" techies who helped me through the diagnosis and to a solution.
  • beanctrbeanctr Member Posts: 99
    w62,
    I used Meguiar's Scratch X -Fine Scratch & Swirl Remover on a light scratch on my bumper and a deeper scratch on the hood. It worked pretty well on the light scratch (can barely see it now) but didn't have much of an effect on the deeper scratch.
    Doh!!!
    Thanks for the correction Talon...
  • jmessjmess Member Posts: 677
    I have found the sterio in our 03 EX 4cyl to be pretty flat. It really doesn't seem to do anything very well: lows, midrange, and highs seem to be pretty bland. You have to use a lot of volume to get any separation between the highs and lows. Midrange seems really shallow.
    What would be the easiest cheapest fix to get a little more depth to the sound?
  • jcrobertsjcroberts Member Posts: 54
    My old Buick just threw the timing chain. It appears to be a good time to buy an 2003 Accord. I would like to instal a trip computer on the LX (the EX Navigation system is out of my price range). Might you know where I could find one to instal?
    it doesn't matter. My point was, the amplifier (which I know is analog) is always up all the way. Only the pre-amp output varies in volume, be it analog or digital- but in this case the volume control is digital. Or- let me better put it- it's electronic.
    Analog controls feature a rotary variable resistor dedicated to that circuit.
    What I meant to say was not all people feel side air bags are a big deal. The Hondas we sell that have side bags as an option do not sell very well.
    And, aside from an occassional "safety customer" we really don't hear much about the desire to have side bags.
    And, to the shock of some, I suppose, I'm in that camp myself. Having grown up with old VW bugs and busses and MG's, I've learned to be a careful driver. Maybe I should drive my non-side airbag cars in fear but I don't.
    Having said this, I'm sure my next new Honda will have side bags. It's just not a big deal to me, nor does it seem to be to the majority of my customers.
    And, I'm not sure how much good they even do.
  • fredvhfredvh Member Posts: 857
    Are you talking about the regular side air bags or the side-curtain air bags?
    I was talking about regular side bags.
    It wouldn't surprise me if five years from now the entire interior was wrapped in air bags. What's next? roof bags?
  • outrunoutrun Member Posts: 539
    One of the factors in buying my '02 Passat was it had front, side, and curtain airbags.
    One of the factors of my not getting an EX-L (4
    cyl) is it doesn't even offer curtain airbags.
    Having two youngins at home makes me think more safety nowadays.
    A few other issues is it doesn't have side mirror defroster or back-lighted buttons on the steering wheel.
    -Craig
  • tunefultuneful Member Posts: 35
    Hi folks,
    I am considering a 2003 Accord as a potential purchase. However, when I test-drove it, the steering wheel had a high level of vibration, especially when idling and even more so when the a/c or max a/c was turned on.
    I raised this concern in an online discussion held by a consumer publication and was told by a staffer that their tested Accords did not have this issue, and I must have driven a defective car.
    I am getting rid of an 87 civic, and it has the same problem--mucho vibration at idle.
    Has anyone else experienced this in Hondas, especially the 2003 Accord?
    My other concern is that the a/c in my Civic was absolutely terrible. I don't want to repeat either of these experiences.
    Tuneful
  • bodble2bodble2 Member Posts: 4,514
    I think nowadays safety sells.
  • mbfjackmbfjack Member Posts: 23
    The AC in my '94 Civic is awful as well. Don't have a problem with vibration, though.
  • fritz1224fritz1224 Member Posts: 398
    Having been a professional FF/EMT for almost 27 yrs, I've done more extrications than I care to. The most fortunate ones with non-life threatening injuries are usually the occupants of;
    1. the bigger and heavier vehicle
    2. the vehicle with properly deployed airbags and seat belts used
    3. vehicles with seat belts used
    4. no airbags and no seat belts used(sheer luck)
    In that order.
    Now in some cases, nothing would have made a difference, but in most(even in the smaller vehicle), the severity of the injuries are a direct result of the presence or lack of the occupant safety systems of the vehicle.
    I don't think your customers don't want SAB, they just don't want the EX or V6 that SAB comes standard and they don't appreciate their value enough to shell out more money for the bundled options they would have to get.
  • gee35coupegee35coupe Member Posts: 3,387
    But I don't think most consumers are exactly sure how much safety they want. ABS is a definite and so are airbags. But just how many airbags are needed? I don't really think the lack of Side Curtains is going to hurt that much right now. Most consumers have just gotten used to dual fronts. The mass market isn't THAT sophisticated yet. I'll side with Isell on the curtains. Most folk wouldn't pay for em.
    As far as the SAB...They are optional on the LX and I'd be willing to bet the number of them sold with SAB is pretty small.
    I wouldn't turn hem down if they were standard but I wouldn't pay extra for them.
    For this amp noise problem, I think I will wait a while until HONDA posts warranty repair since it is not actually an annoying thing after all for me. As a daily commuter, the environmental noise coming from highway and other cars has already covered the buzz pretty well.
    From this discussion, I've also learned a lot on amplifier and digital/analog knowledge. Thanks again stretchsje, ray_h71, and atlantabenny for your in-depth explanations.
    when the IIHS started offset crashing vehicles at 40MPH, and then televised the results on national tv (Dateline NBC)?
    Cars that failed miserably are now redesigend with great results. If safety didnt sell, manufacturers wouldnt care, and things wouldnt have changed. They have.Now, most cars do exceptionally well in that test, earning at least a "Good" if not "Good-Best Pick". So leave it to the IIHS not to rest on its laurels--from what I understand, they are going to introduce extenisve and incredibly demanding side impact crash tests in the near future. Insiders say the preliminary findings have not been encouraging.
    Time will indeed tell if we have a repeat of the offset situation.
    -alpha
    But safety features above and beyond the "norm" don't. The Accord scored exemplary without the curtains. A car can be designed to pass the test without all the safety doo-dads.
    ...to us. So do sporty cars- look at much more interest there is the Mazda6 thread, yet the Accord sells much (much much!) larger volumes in real life. Edmund's isn't a typical demographic, and I think we sometimes forget that.
    I haven't heard a car dealer say that safety sells. GM pushed ABS on every car, and withdrew this after it didn't sell.
    Edmunds would have you thinking we all wanted W-20 supercharged 6 speed AWD land missles. With lotsa airbags. Lotsa lotsa airbags.
    For once I agree with Stretch
    wow.
    For the record, if Honda and Mazda both made "W-20 supercharged 6 speed AWD land missles"... oh nevermind.
  • brandon17brandon17 Member Posts: 9
    I have had an 86 civic and an 93 accord 2dr SE. Both cars I experienced steering vibration. This was a mechanical problem only and was repaired. I bought both accords used and both had this problem when purchased. I have a 2003 EX V6 Accord and the steering is perfect! I just sold my 93 accord last year so the steering problem is still fresh in my mind. If the steering vibration is the only thing that is holding you back - don't worry about it - buy, and if you are like me you'll love it!
    Of course, anyone in your position would want as many safety features as possible. My point was/is that side air bags are optional in ALL Honda models. We try to keep a few in stock for the few people that ask for them. Safety DOES sell for SOME people. There are a whole lot more that really don't seem to care.
    If these people spent a Saturday night riding with you, they would no doubt feel differently.
  • tgozdalski1tgozdalski1 Member Posts: 34
    I think location has a lot to do with demand for safety equipment. I live in South Texas where some people did not see snow in their entire life. It's obvious items like traction control, ABS, etc. are not the most important thing on people's mind. Another thing to consider, the cost of long-term ownership can be much higher with additional electronic components. As for air bags, I ride Kawasaki 750 daily. Use my Accord only when dropping off kids to school. At least I don't have to worry about not buckling up.
    Many people wear seatbelts only because they don't want to be fined for not wearing them.
    They would also run redlights and speed in wet and icy conditions if they were 100% sure that they would not get caught.
    These people could care less about side curtain airbags.
    I've got mixed emotions on this issue. In November I survived a head-on collision without injury after the SRS front bags popped. I've used seat belts and then shoulder harnesses zealously since they were mandated and before, so I really don't know to what degree the bags helped. But they certainly didn't hurt. The issue of side air bags (seat mounted) and curtain air bags is subject to even more consideration. Certainly anything that further assures survivability in an accident can't be discouinted. But, if these devices are that important, I'm dismayed at the number of manufacturers who hold their buyers hostage to accepting the dictum to buy unrelated options and/or model upgrades just to qualify for the privilege of ordering them.* On the issue of ABS, G.M. essentially surrendered to pressure from the insurance industry. The insurance industry lobbied G.M. hard for nearly a decade because it figured with G.M.'s sales dominance, if they got G.M. on board to provide ABS as standard equipment, the other companies would have no choice but to come around, too. Didn't work. And, G.M.'s field service experience resulted in a net loss to the company for the past 4 years despite the economies of scale they were counting on to at least break even. Now, in most G.M. lines, if you want ABS, you're gonna have to kick in. My wife has a 2000 Cavalier with ABS. It's been in the shop for various ABS-related malfunctions ten times. I still feel that more people than not misunderstand what ABS will do and what it won't do. Just getting my wife to understand that in an emergency she needs to stand on that brake pedal and ignore the shuddering as the ABS cycles to maintain traction and steering control. (Can't blame her in view of the fact that every component of this technoplogy has failed at least once in the time she's owned this car, I guess...) Yet she, (and I'm sure many others) blithely presume that ABS means the car will stop shorter than cars without ABS. (It will, of course, but only if the non-ABS equipped car goes into an uncontrolled skid because its driver panicked. Ironic that drivers who own non-ABS cars are more likely to stand on the brake pedal than owners with ABS-equipped cars...)
    *My replacement car, a 2003 base level Hyundai Sonata has side air bags as standard equipment. But TC is only available on Hyundai's primo LX level in the Sonata line...
  • anonymouspostsanonymousposts Member Posts: 3,802
    Lots of airbags is a plus, however I would rather have a strong safety cage with only front airbags than a marshmallow surrounding me with 10 airbags.
    If you're talking about a vibration at a stop, I'm assuming you are in a 4 cylinder. It's a big 4, and it does have more vibration than some, I definitely feel some in my CRV. I also have a Nissan Altima with a 2.4L 4 cylinder, which has the same results.
    If you're talking about a V6, I can't help. If you're talking about vibration at higher speeds, it could be a wheel out of balance.
    good luck :)
    if it's a vibration that only occurs sporatically with a certain friend in the car, that person probably has gas.
    Hey, it's happens... :-/
  • chillenhondachillenhonda Member Posts: 105
    I'm about to install a sound system in a 2000 Accord EX 4-door. If any has done this, or have helpful advice about equipment, products, or ideas, I'd appreciate it. Im looking to upgrade the speakers and add an amp and possibly a sub, but attempting to keep the head unit so the dash still looks stock. Thanks.
