Visitor Agreement.
To turn off SmartQuotes in Word 97 (may be diff in Word 2000), go to Tools > AutoCorrect > AutoFormat as you Type, and click the box that says Replace as you Type, straight quotes for smart quotes.
Steve
Mine does this a lot, because I just can't quite break the habit of turning the wheel a little when I get out of the car. (You were suppose to in order to lock the wheel in my old wagon, but if you do it to the MPV you jamb it, because it is already locked.)
As to hesitation between 1st and 2nd: the shift at 25mph is very noticible on mine, but not really a hesitation. I think that others have mentioned this before.
I also was losing air preassure- wound up being a little screw stuck in the tire. I had to get it plugged (from the inside) a non-dealer job (dealer is too far for me to frequent).
--javadoc
(1250-javadoc) I did try turning off the A/C (or pressing the turbo button). It still hesitates sometimes. I am able to force it NOT to happen by being conscious of the pressure on the accelerator. My wife doesn't drive manual, and I don't think this trick comes naturally to her. She drives the van most of the time and is really unhappy with this problem. Although everything else about the van is great! Is the hesitation you're experiencing of similar duration? Does it make you nervous, or is it just a minor inconvenience? We'll be driving with the A/C on for the next 4-months here in NC :-) Should I have the dealer look into the fuel-line theory?
Taking the prob to the dealer may help, but you'd need to be able to almost reproduce the sympton at will. For instance, if it 75% of the time does it at a certain point, either at cruise on the freeway, or on the onramp (yikes), tell them...maybe nicely ask if the tech has ten minutes to ride with you so you can show them what's going on. That works better for me than explaining to the Service Advisor (an oxymoron...) and them telling you later, "We couldn't reproduce the symptom."
--javadoc
I used conv. Mobil 5w-30 this change as I plan to do at 3k. At 5k, I'm going to switch to Mobil 1 syn. and change it at 5k intervals.
This first oil change on the MPV was much easier than it was on my wifes 95 Tercel. It took a hammer and cold chisel to get that OEM filter to move!
Good luck!
best of luck!
--java
However, the lean is still there, same as before. Let me know how it works for you.
Steve
I bought touch-up paint (sand mica) from the dealer but am wondering what's the best way to fix the scratch to get the best results.
Any suggestions???
First, you need to have a small model paint brush (for kid's plastic airplane models), a small paint removal wire brush, and either wet/dry sandpaper (get some 200-1200grit assortment) or a sanding stone. The sanding stone and wire brush you'd have to get from a paint supply store that carries automotive supplies.
Cut the paint brush to a point (more accurate).
Take the wire brush and gently scratch the area of the scratch. This will remove dirt/oil/wax from the surface. Don't scratch up more than just around the current scrape (no more than 1/16" extra).
Then, use the paint brush to carefully fill the offending scratch. Apply as many coats as needed, waiting about an hour between coats, until the scratch is completely filled and then some.
Then, after at least 24 hours, use the sanding stone (better than the sand paper) and CAREFULLY wet sand the area until the high spot of the touch up paint is worn down and level with the factory paint. Make sure you keep the area wet at all times (lower friction, doesn't hurt the paint. Use a spray bottle or hose to do this.
If you do this right, you'd have to get right up on the scratch to even see it. I've fixed a couple large ones on MochaVan this way...takes longer but I think it's worth the effort, and shouldn't cost more than $30-$40.
--javadoc
Anyways, I hope I can reciprocate to some of you (especially Billmckinley and Mazdad) with the following info:
RJ I have enjoyed your creative descriptions of your smelly problem and have often found myself ROTFLMHO. Hopefully this can lead you to the path of clean air. This problem was recently addressed via a letter to our local paper to our resident car 'experts'. The link to the letter is http://www.carclickbc.com/carclick/articles/070601/5064393.html but just in case it is missing or the link is broken here it is:
Rob MacGregor and Jeremy Cato
Vancouver Sun
Dear Car Guys:
I bought a new 2001 Mazda MPV in January, 2001. I ordered it with the 2.5-litre V6 engine.
The problem I have is that it smells really bad, like rotten eggs, after I have climbed a hill. There is no smell or very little when I am alone in the car. I noticed the smell at about 1,000 km.
The dealer checked the van and said there is no problem. The van is not running rich. He said it's due to sulphur in the gas and I will not have this problem once the sulphur is removed from gasoline in the future. A friend of mine tells me the catalytic converter is working too hard.
I really want to get rid of the smell; it's really obnoxious! I intend on keeping the Mazda but I certainly do not want to keep the odour. Please help!
Al
Dear Al:
Rob: Can't blame you. Who'd want to spend their days with the whiff of rotten eggs filling up the ol' nostrils.
So we did a search of recalls and technical service bulletins and found something very interesting -- that is if you get excited about late model engine management.
Jeremy: Rob, I know there is no topic more dear to your heart. Stay up late at night reading those late model engine management magazines, right? That's why you're such interesting company at dinner parties.
Anyway, the answer to Al's problem is found in Transport Canada recall number 1999138 and NHTSA (National Highway Traffic Safety Administration) recall no. 99V171000. And all this has to do with an intake manifold/fuel injection leak.
Rob: Now if you just read the recall notice, it's not entirely clear that this problem can lead to a rotten egg smell. That's where my interest in engine management comes in, wise guy. That's why they call me The Car Doctor.
The recall talks about a vacuum leak at the intake manifold. It can cause the oxygen sensor in the exhaust system to be fooled into thinking the engine is running lean, or with not enough gas.
Jeremy: That in turn signals the on-board computer to increase the fuel to correct for this false-lean condition. And that causes the engine to run rich, or with more fuel being injected into the engine than is actually necessary.
Rob: So what we have here is extra fuel in the exhaust being treated in the catalytic converter. Guess what? The car gets overloaded and the result is a rotten eggs smell.
I do like his take on a vacuum leak causing the problem and that very well could be the case, but I'm not sure it relates to the intake manifold recall.
Mostly "The President McKinley" behaved itself on my recent road trip. And I have laid that to a change of diet on the road. Especially since, just to experiment, I filled it again at the local station I normally use. Guess what. Stinky car is back. The next step is to start using another station for fill ups to make sure it is the gas. If it turns out that it's not the gas [and if it actually begins to bother me as opposed to merely revolting those around me], I'll have something to show the Wacky Wizards at Wonderful Rohrich Automotive Group. Now if I can get somebody to explain all the big words to them. . . .
Thanks again.
RJ
Drew
Rj: Come on let's keep western PA's air clean, its hard enough with all those steel mills:) Here in Ohio, there are a couple of fuel brands that use sulfer. I use Speedway/Super America and our van smells like a rose.
We'll see how a change of diet works over the long haul.
RJ
Wasn't anywhere near the airport this past weekend. If I'd have seen another Sand Mica, I'd have greeted you like a long-lost brother.
RJ
I will however use your tip about the paint brush - sounds like a very good idea.
--j
I recently brought in our 01 LX for it's first oil change (2600 miles). The Service Manager told me to bring back the MPV at 7500 miles for the next service( oil & filter and tire rotation). I believe it isn't nescessary to change your oil every 3000 miles, it wastes money and wastes a natural resource. If you drive under harsh conditions(extreme temps, all stop and go, dirt roads) I would change my oil more often.
If I owned a Toyota Sienna(glad I don't) I would change the oil every 2500 to 3000 miles. Sienna's have had engine failures due to excessive sludge in their engines. A Toyota design flaw, although they won't admit it. There are alot of upset owners on the Sienna problem board.
Cutter, sounds like you have a good service dept. I'm with you having the dealer change the oil, at least under warranty.
BTW, if anyone has 16" alloy rims laying about please let me know. I have one that is out of round. I will be researching fixing this one once I get back from Oregon. But it may just be cheaper to buy one someone isn't using.
It's funny, but I just dug up a service flyer from the dealer that was with a lot of my other paperwork. It mentions the 3k mi. service including topping off fluids, adjusting tire pressure, tightening clamps, checking belts and hoses, lubing hinges and latches, inspecting the air filter an adding an oil additive. it also mentions it being $35.95. The 6k mi. service includes all that plus rotating and balancing tires, checking exhaust system, brake linings, A/C system and adding fuel system cleaner. That's listed as $69.95. On the one hand, I like the thought of spending $40 vs $70., but I'd like to think they're doing what's necessary, too.
As for the MPV. There's one van with frontal impact whose airbags did not deploy... That was the only one that sort of scared me. The rest were good enough, if I can say so :-)
Anyway, what is it there for ??? To access the lock itself ? It seems that to do that you would have to take the whole license plate panel/light kit out...
Dealer has no clue, when I called but mentioned would look at other MPVs...
BTW, this in on a 2001 LX.
I put on a CD, press random... Song 3 plays, then song 5, then song 3 !!!! So I press random again.. Song 1 plays, song 3 plays !!!. Press random again... Song 5 plays !!!
A random option on a CD player (IMHO) has always been randomize the sequence of the song, but not repeat them.
It's so annoying it should be recalled !!!
2 months ago I bought a 2001 MPV DX. We have really enjoyed the van however I've noticed the black plastic "trim" (roofrack strips, sideview mirrors and doorhandles) are becoming oxidized- turning a weathered white/grey colour. NOT impressed! Any ideas or experience with this?
Nick
It seems you would be the first to report such a problem, and there are people who've had an MPV for over 18 months now without reporting such a problem.
I've got a few wax spots on mine, but no uniform color changes.
Dunno what product to use, I think there once was a trim cleaner called "Back to Black" but I've no experience with it.
TB
Sorry Tony, I couldn't resist.
Wonder what that sounds like on the MPV's sound system. (Required subject matter reference)
Oh, I've got a problem, only a CD player in our van.
Stereo input to sound card...create MP3...convert and write to CD-R. Where's Napster when you need it?
MPV content...mine has a tape deck.
RJ
