Visitor Agreement.
I have not yet tried to install the convertible seat in the rear facing position. (I have one in the forward position for our toddler). In our previous car I was able to find a bolt under the front passenger seat to attach the tether to. It wasn't a tether bolt, but rather a part of the assembly which attaches the passenger seat to the frame of the car. As long as you're on the frame-side it should work for a tether.
He preceeded to throw up on me. Thrill...
Got to the vets and said "Don't ask".
I ended up hosing myself off in the driveway - at least saved me the hours you spent.
I took it in to my local dealer and they were as surprised as I was to see rust developing there (let alone on a car that is less than 2 year old - purchased Nov. 1999). They said they would repair both sides at no cost. I took it in tonight so I will let you know how the repairs look.
Last week I had the tie rods replaced based on the TSB on the subject (dealer initially did not know about the TSB but did find it and initiated the repair - took about 6 weeks to get the parts).
Two weeks ago I had 2 stones hit the windshield. You guessed it one hit the very edge of the windshield initiated a crack that slowly crept across the window. Initially there was no crack but it sat in the hot sun for an afternoon and when I used the van next there it was! Took it to Speedy Autoglass and now looks as good as new.
Otherwise all is good with my MPV!
Also, the rear doors are showing surface rust, on the black portion just to the rear of the glass. This is a warranty repair, but what a pain!
NEVER AGAIN will we buy ANY Mazda product.
I, too, recently freaked when I spotted these small "dots" of surface rust on rear hatch. I used some of Meguair's heavy duty cleaner/wax. Be sure you buy the HEAVY DUTY CLEANER/RESTORER - not their regular wax. The spots came off!! I have run into this before on my '98 Honda Accord. That has lead be to think that maybe they weren't rust spots after all (NOT sure what it is).
Anyway, give this a try before you go to the hassle/headaches of unnecessary body/paint work.
Good luck & PLEASE let the rest of us know how you make out with this.
"Searching everywhere...." No, wait, that was an old song...
Apparently, the setup on the MPV (at least my 2001) is real sensitive to tire pressure. I pumped the Yoko's back to 36PSI and was steady again. I don't know if the front end design, wheelbase or what would cause that. I haven't experienced that in any other automobile at least to this degree. The MPV is the most nimble and great handling van I have driven.
Any input out there?
I think that if you use the pool noodles or rolled up towels you will find the base easier to install (and by the way it is safe to use them and is recommended to get the proper recline for an infant). Let us know if you have any more questions!
Steve
/J
We thought the clunking was the tie-rod bulletin but they said it was to do with a bulletin on the brake pads slipping. They of course didn't notice the transmission issue which doesn't happen very often. The van really has been great though and the couple problems we have had are minor. I would have to say having our van since Jan. 2000 and only 16,000 miles we are staying pretty low compared to some out that have posted here. I have now seen 3 MPV in our neighborhood but there sure seems to be an over-abundance of Odysseys out here.
PLEASE let us know if your dealer resolved the brake "clink" via the TSB that's been mentioned here. My dealer didn't have the shims needed to correct the problem when I was in for my last oil change.
As for your transmission's "jerkiness", I think this is a common quirk w/Maz's trans. I've found that turning the overdrive off (depress button on gear selector - "O/D off" dash light illuminates) in stop-and-go traffic helps keep the "jerk" to a minimum. Give it a try if you haven't already.
regards
(a fellow DuPager in D Grove, IL)
Since we recently moved here this was our first trip to Bill Jacobs Mazda in Aurora. Where do you take yours?
If changing to synthetic will help out, I'm all for it. Question: when's the earliest it can be done? I currently have less than 7k on The Prez.
RJ
FWIW, after I switched to synth atx fluid, the tranny had shifted remarkably better at all temperatures, esp. warmup time
/J
RJ
I take mine (2000 ES) to Wikins Buick-Mazda in Villa Park IL on Roosevelt Road (Route 38). This is my 5th Mazda I've purchased from them. One of the best service depts I've ever dealt with. I have sent several friends there to purchase & they highly agree that their sales & service dept are second to none.
regards
brmuda
I wouldn't worry about that really, but it's good to be aware of all the noises the car makes...so you can tell the bad from the good.
happy motoring!
/Java
It doesn't seem like it has to do with the heater; still hearing it when it is turned OFF... Instead, it seems to sound "louder" on deceleration (not applying brakes)...
Silver (and still pleased) Driver
Just got my new mpv, and I just love the van. I have a question for you. Do your vans have a hole about 1.5 inch x 3 inches on the carpet wall on the right side of the gas pedal? I called the dealer about it and he said it was factory made because of a blower at that particular place. I have to say that I am particularly surprised since the hole was hand made probably by a cutter and that the finishing is not nice at all!!!
Aym
If that hole you're talking about is on the wall of the center console above your right foot, it is indeed the heating floor vent. And you're right about the finish. It's so ugly that I try not to look too closely down there, especially when I'm driving. ;>
RJ
I think mazda should have done better here. It look like a last minute fixing, and since it's a 01 LX, they should have come up with a better solution a long time ago. A small piece a plastic part to mask the cutting would have done it.
Don't worry, I don't look down there while driving, but each time I enter in my van I see that hole. Well, I just have to get use to it.
aym
Pjd58
/J
I take her van for service and refueling. Once a week I'm on the driveway washing, drying and cleaning windows. I Zymol her van every couple of months. I'm such a nice hubby! :>)
Problem content.......Why does it always rain the day after I detail the MPV?
It's hard for me to wash it because he doesn't want me using our water, I have to go to one of our parents who have a well. He also doesn't want me spending money on car washes but since they are opening a new one in town, I may just have to become a regular customer there. Think I can use this as an example of "cruel and unusual punishment?"
Java, I looked for the Resolve powder and couldn't find it. Where did you get it? We bought Scotchguard to put on everything but we didn't get it on there and now there are some stains.
I'm the same as PJD, I wash the outside, thoroughly, and the inside is hers. I do wipe down all the door jambs and sill plates, but the carpet is hers unless I do the annual scrub. I think this comes from my complaint about her giving every imaginable type of cookie/cracker to them in the car. aaaarrgggghhhh!
Problem: my driver's seat is slowly turning from beige to a rather disturbing shade of ecru. Blech!
RJ
Now if I can figure out how to get him to change the oil...
Oh, and about the carpet spots, our janitor (of 30 years) swears by Hoover pre-wash/spot remover carpet shampoo or Ace Hardware carpet shampoo. He says he's tried them all and these are the only two that are worth a darn. I tried the Hoover stuff and he was right!! You can get it at home depot.
RJ
Java, it does get dirty I would have prefered a sand mica because of it but this is what the dealer had and we got a good deal. I'm hoping that I can vacuum it tomorrow though, I did shovel it out the other day and got rid of some of the stuff.
The Emerald mica is almost as bad keeping clean as the black (and the dark blue would be hard, but gorgeous!), I feel your pain.
I'll be in SEA in a week, but my washing mit won't reach to your suburb, sorry! Cinka has a good method! I do that all winter long, $10 a pop, every week.
MPV content...for real. First snow today, about 2 inches so far. Put the Hakks on Mochavan, gonna risk it with Rolf tomorrow (test out the traction control features). I got the van up the greasy driveway on the nearly-bald Done-lops using a feature that I stumbled across this summer on accident. If you put the van in "2" instead of "D" the van will start in second, instead of first. Killer method of climbing slick hills, or my steep driveway.
/J
That was the sound I heard today as I backed into the corner of a higher-than-usual concrete curb in our 01 LX. . . .
Sorry I've been a way for quite a while . . . been REAL busy at work for the past month or so, and since the terrorist attacks, haven't been surfing much else on the net, other than news sites.
Anyway, back to my little mishap. I work at a community college here in So. California, and today we had a grand opening of a new center I've spent the past year developing and will be directing. So it was my job to get the cake, party platters, beverages, etc. from the supermarket, and various other errands. Which made it necessary for me to borrow the MPV from my wife, who usually drives it during the week. (my usual ride to work is a 98 Camry, more on that later).
Anyway, it's an hour before the big party with all guests arriving. I got permission to drive onto the walkways on campus so that I don't have to carry all this stuff from the parking lot. No problem getting in, and getting unloaded. Getting out required me backing up about 80 feet, on a relatively busy walkway that narrows in one spot. Students continue walking around and past my van, making little or no effort to move out of the way as I am slowly backing up (no surprise, really). I am going very cautiously as I don't want to hit anyone, and then -- screeeech!! -- a very low, sort of growling scraping noise, as I just caught the corner of the high curb I just decribed. Panic, depression, rage, frustration, fear of death-by-spouse -- all of these emotions in the first 3-4 seconds as I stop. I hear snickers from students sitting close by who watched the whole thing -- no time at that moment to stop and choke them! I got out to the parking lot and surveyed the damage -- a 14-inch scrape at the very bottom of the left-rear bumper, just behind the rear driver's side wheel. Kind of in the area that gets dirty from mud, road dirt, etc. So in a not so obvious area, but definitely noticeable. Thankfully, no dents.
So back to the death-by-spouse thing. I realize that my wife will absolutely kill me when I got home tonight. She absolutely loves our MPV, it's our first new car, and though it's definitely got the clutter and markings of a family cruiser (we've got 2 little kids), we've kept it pretty clean. Grand opening goes extremely well, and I was pretty psyched about that. Then comes the drive home, and the dread of having to let my wife know that I hurt her baby. . .
Well, we both happen to pull up in front of my daughter's daycare at the same time (we usually divide up the task of picking up the kids, and she had called me and asked me to pick up both kids today). And as you can imagine, I'm guaging her mood to determine whether it would be a good time to tell her . . .
But before I could say a word -- it turned out that she was preparing me for similar bit of bad news. . .
This morning, while backing the Camry (MY baby) out of the garage, she scraped up against a shelving unit, and nearly ripped the passenger-side rear view mirror off the car!
This mishap of hers, while disappointing (and certainly equally distressing), probably saved my life!!
We drove over to our mechanic's place, and after surveying our respective instances of pilot error, basically agreed with me that the scratch on the MPV, while unfortunate, is liveable, and not worth the $300 or so it would take to repaint the entire rear bumper. The mirror, OTOH, should at some point be replaced. It actually still functions fine (the power adjusters work), but there are two large unsightly cracks at the point which the plastic had flexed and broke. I might wait a bit before getting it fixed. It's also going to cost around $300 for the mirror assembly, the matching paint, and the hour or so of labor to install it.
Today wasn't the best day karmically-speaking for our automobiles, but given the recent craziness in the world, we can't really complain . . .
Gary
MSGJVH
Condolences.
RJ
Now catch your breath it was in the 87 LeSabre. However, MrsTboner had the MPV full of all sorts of shopping loot from performing her heroic and patriotic duty of single-handedly propping up the local economy.
I couldn't get all of my stuff out of the Buick and into the MPV since we also had to leave room for the 11 year old.
The upside was, I got off work early today. Also, I was planning to take the Buick to Chicago, so I'm glad it failed close to home.
I wonder if they can fit a stickshift to an 87 LeSabre. I've experienced three Automatic Transmission failures, but have never lost a manual.
Now, how can I blame this on bin Laden?
TB
Java, I can't believe you're getting snow. We actually haven't gotten a lot of rain this year, but it's raining now. We did wash "zoom zoom" today, just not quite as thoroughly as you do. I tried convincing hubby to clean the doors but it didn't work. Now if I can just get the inside done...
For more information about reverse warning systems, please have a look at the existing Reverse warning systems discussion topic in the Aftermarket & Accessories message board.
Here are a few of pictures of my setup though:
Drew
Anyway, I love being part of this board -- it's so cool that so many of you wrote back with kind things to say, and with great advice!
Gary
P.S. I was thumbing through the latest issue (Nov 01) of Car & Driver, and found an article on the MPV. It was their "long-term test drive" column. Basically, the author slammed the MPV, her two big beefs being with the horsepower issue as well as the entertainment system. I basically agreed with the latter issue (though I don't have the entertainment system myself), but I think the power issue is overblown, and the article came off as something less than even-handed.
I need to change mine (again) ... my van is well over two years old now(!)
