Visitor Agreement.
Also, has the engine been re-tuned for a quicker 0-60 time?
Does the manual get worse mileage than the auto?
Just the opposite. Crazy world.
Jose
The tires I have now are Dunlop WinterSport M3's (love 'em) in 225/50-17. This is also the standard tire size on the 535.
I'm getting the sport package on the 535, which gives me 245/40R-18 front and 275/35R-18 rear. I can get the Dunlop WinterSport M3's in this setup, but would I get better traction using the 17 inch tires? From what I understand, the smaller tire gives better traction due to the increased pressure on the smaller contact patch. Is this true?
As I see it, here are my options:
1) Use 225/50-17 at all four corners, and enjoy better traction. Would also have to get another 17 inch tire to use as a spare since the 'space saver' that comes with the SP is 18 inch.
2) Use the 245/275 setup, and enjoy better performance when dry but suffer with loss of traction in snow. Would not need another tire as spare.
I'll be buying new rims for either setup, so that isn't a factor.
Is my understanding correct? Are there any other options I'm missing?
I decided to prioritize traction and go w the narrower, smaller diameter tire because I live atop a long steep hill.
(225-55-15 Blizzaks)
If you live in a relatively flat area and do most of your driving on roads like I-93 and I-495 you could be alright on 245-40-17 but if you find it neccessary to be on secondary roads in bad weather you should go with the "traction" setup IMO.
In no case would I consider a 275 size tire for your driving wheels. I really think you're asking for trouble w something that wide. :surprise:
Thanks for the feedback! 15 inch for you, huh? The stock setup with the 535 is 225-50-17. I'm no tire expert - can I pick anything in the 225-50 range, like 225-50-16, or 225-50-15? If so, am I losing anything by going with the smaller size?
e39 528 models had smaller brake rotors than the later 530, which used 540 set up and can't use anything less than 16 inch wheels. Yours may have the same limitation, so I'd definitely check with tirerack.
Hmmm....double check this as the guzzler tax MAY be on all 550's with SP's.
As a general rule, go with the 225 section width tires mounted on the smallest wheels you can get to fit around your brakes (which are 16s). No one has mentioned this, and I assume you already know it, but I feel I need to point this out, the wheels from your GS300 are guaranteed NOT to fit your 535i.
As I see it, you have two options:
1) Buy a complete new set of wheels and tires (225/55 R16 mounted on 16x7 or 16x7.5 wheels) and peddle your set for the GS.
2) Buy a new set of 17x7.5, 17x8.0 or 17x8.5 wheels and mount the Dunlops from the GS on them. Then you can peddle just the wheels from the GS.
Keep us posted. ;-)
Best Regards,
Shipo
>"the wheels from your GS300 are guaranteed NOT to fit your 535i."
Yep - knew that, but thanks for making sure. I never bought an extra set of wheels for the GS, so they have to stay where they are. I'm sure when I Lemon the car they'll want it with wheels.
>"Buy a complete new set of wheels and tires (225/55 R16 mounted on 16x7 or 16x7.5 wheels) and peddle your set for the GS."
That's probably what I'll end up doing. I'm still in the process of building my tire kung-fu, so I have a question: what does the 7 or 7.5 in 16X7/16X7.5 represent? I know all the other numbers, but not this one. Can either one be used with a 225/55 tire?
With regard to the different width wheels I listed for you, they will all work with the tire applications that I listed. That said, the only ones I'd stay away from (unless you really like the wheels) are the 17x8.5 wheels. They are just wide enough that the tire sidewalls won't be able to protect them from curb rash as well as the slightly narrower wheels. ;-)
Best Regards,
Shipo
Looks like it's going to be 225/55-16, depending on the price of the BMW wheels. I'll give Bavarian Auto Works a call to see if they sell the specific wheels I'm looking for. Maybe they'll even let me pick them up and save some money on shipping...
Best Regards,
Shipo
That said, he already has a set of winter tires in the stock 535 size.. I'd just get wheels for them, and be done with it... Unless the 16" tires are appreciably narrower, it isn't going to make much difference, anyway..
I'd double check the 16" thing with a phone call.. The stock size on the 535 is 225/50-17.. That is for the base model, not sport. Not sure I'd want to downgrade from that. Even the 528i comes with 17" standard.
regards,
kyfdx
visiting host
Best Regards,
Shipo
Best Regards,
Shipo
I'm trying to find out how much better the traction would be between 16 and 17.. probably tough to measure. Since I already have the 17s it makes sense to go with those, but since I'll have the car for many years I don't want to have worse traction every year just to save a few bucks on the tires this year.
>"I'd double check the 16" thing with a phone call.."
BMW lists 16 inch tires on the accessory page for the 2008 535i (star spoke 115), but you're right - better safe than sorry.
Assuming the same section width (i.e. 225), probably impossible to measure. I've never seen any compelling evidence that proves that a winter tire of any given width and diameter will perform better if the wheel is smaller.
Best Regards,
Shipo
So, given that the 16 and 17 have the same width (therefore the same traction as well), would there be any major reason to go with the 16 other than cost?
If you have bad potholes, or your spouse is maybe not as careful as you would like, then you do have a small amount of increased protection from pothole damage.
But, traction/winter handling improvements would probably be too small to calculate.
If you stick with 17" wheels, you'll have a lot more choices... Personally, I like my car to look just as good in the winter as the rest of the year, which is why I don't like to downsize... (but, that's just me).
regards,
kyfdx
visiting host
EDIT: Some people think that extra 1/2" of sidewall lets the tire flex more, and find better tracton in deep snow.. Not sure that makes sense to me, but there you have it.
On the diesel evaluation sheet I stated:
"Put this motor in a 3er coupe with the European M Sport package and I will buy one. Put it in a 1er M Sport 5 door hatch and I'll buy two."
I still think the 535xi is a better car, but I need something for weekly driving as I am putting to many miles on my M35x. The E 350 4 matic will be my commuter car and the M35x wil be my weekend car. The 535xi performed as well as my M35x, so I decided to go with something less powerful with better gas mileage.
Thank You again for your advice.
The names should be on the CCA site shortly, if they aren't there already. My son was at one party when they announced that one winner was from KY. Wasn't me, sad to say.
You could've saved a bunch of money on those wheels if you had gone to The Tire Rack's website. You can get the exact same wheels for, IIR, much less than $1K.
I'm not familiar with this magazine, or their reputation, but they apparently liked the ride and handling of the CTS better, but preferred the engine and transmission of the 535i.
FYI, I have a 535Xi and think the balance between ride quality and handling is outstanding.
Bruce
What on Earth would cause such a reaction?? Ladies and Gentlement, I spotted... On the dealer lot... A new 550i Sport with a MANUAL TRANSMISSION!!!! Just sitting there! In the open! Unabashed! For all to see!
After 100446 miles, I have averaged 52.5 MPH and 26.7 MPG. My costs that would have been covered by an extended maintenance/warranty package was $1402.45; but the right hand mirror quit lowering when shifted into reverse this afternoon.
My costs by year are: 2002, $117.59; 2003, $43.38; 2004, $1819.35; 2005, $1741.21; 2006, $1609.38; and 2007 to date, $1940.08.
My costs by category are: Scheduled, $2240.56; Recurring, $3019.07; Damage, $621.00; and Unscheduled, $1393.06.
Additionally, my gas mileage to Hilton Head was 30.37 MPG at 80-85 MPH and return gas mileage was 30.04 (more uphill) at 80-85 MPH.
I still love the way the car rides, drives and handles; I intend to keep it another 5 years and 100k miles.
Make sure that the selector switch which controls which mirror you're adjusting is set for the driver's side, then it should lower when you hit Reverse.
My experience with a 2000 MY 528iA has been similar to yours except for a warranty repair to the Air Bag Control Module
($appx. $700 IIRC) and a non-warranty fix of the VANOS control thing-ama-jig ($1200). Other than that not much has gone wrong at 102,525 miles and counting. :shades:
I'm at 133K in my 2003 540I. It was the last of the E39 series. I've spent a bit more, since I've done a few things like replaced the cooling system (radiator, water pump, thermostat etc) brakes a few times, and more tires than you can shake a stick at.
Unfortunately the machine has left me stranded a couple of times - Blew an upper radiator hose in my driveway, at the end of a rather spirited 70 mile run... (ok, at least it was considerate enough to wait until I got home). Alternator quit, resulting in a tow, and those water cooled alternators are NOT cheap!
I still find it the best car, even though not as reliable as my Camry.... I still glance back when I walk away from it.
Unfortunately, more recently, the climate control has acted erraticly, hoping that it is an electrical gremlin that will settle down. Ever had any problems with yours? Curiously (or maybe not), my E34 (which was still running great at 102k miles when I sold it) also had some climate control electrical problems.
The AC fan sometimes speeds up or stops when you think it shouldn't, but it always soon corrects and I do not want it screwed up by someone trying to fix it. The radio has also increased in volume twice in 5 years, same decision.
