Visitor Agreement.
RJ
MB
When I bought my MPV one remote was missing. I got the new one from the dealer and it did not work because it wasn't setup. My sales person programmed it while I was watching. It takes 2 minutes of few sequences of turning an ignition key to set a remote.
MB
Trust me, I am the last person to want to bring up a problem, but it is a bit annoying. I have not had the sulphur smell (Amoco gas), but even if the MPV smelled like a sewer, and the engine roared like a freight train, I would still prefer my mpv to any other minivan!!
MB
/j
Brand of fuel does make a difference in some of these cases, but it looks like that may not be the problem for your van I'm sorry to say. The reason brand switching could help sometimes is that different brands use different forumulas in refining their fuel. Also, sulphur content varies drastically from refinery to refinery, and also depends on where the oil was from. (Plug for Alaskan crude...). I too do not know why some folks' vans have this problem and some don't. Could it be traced back to a supplier for the cat. converters? That may be a place Mazda may want to look, for instance.
The MPV is a great van, but I feel your grief. Having a horrid odor makes life with a $20k plus rig difficult, at best.
/javadoc
Whoops, I doubled with beach on some of my comments, sorry.
In my new 2002 MPV I had bad smell for about 1000 miles but I could only smell it sometimes when I stopped at intersection's traffic lights. I never smelled sulfur while driving. After 1000 miles the smell went away. If I were you I would try the following. Drive your van till your gas tank is almost empty then fill it up with Chevron Supreme. Drive till your gas tank is almost empty again and fill it up with Chevron Supreme one more time. If you do that and your van still stinks then you should for sure demanded repair.
MB
Does someone with stinking MPV also have another car? Does the other one stink as well? Just curious.
Another question. Are sulphur sufferers using high-octane (91/92) fuel in their MPVs? I heard somewhere else that this may cause issues in cars not meant for premium fuel. Just a thought.
/j
For example, in the St. Louis area, there are two refineries. There are more than two brands sold here.
Sure, some gasoline is moved via pipeline, but I suspect a good porition is produced locally.
Uh oh, pager went off, I'm on call again this week.
More later.
TB
MB
I guess I should be glad that I don't own a Focus - I agree that there are worse problems. Will post about the new converters.
I am a little sad to finally have a problem - even as small as that. My van has been great since we bought - January 2000. Oh and it has to share the garage now with a newer vehicle that is getting lots of attention: my husband's Ford F-150 SuperCrew King Ranch Edition.
1. Improper Fuel Pressure
2. Loose or disconnected vacuum lines
3. Improperly connected vacuum lines
4. Charcoal canister is malfunctioning
5. Faulty Fuel tank vent system
Okay, that was five. Maybe they'll try these spots (they should).
/javadoc
Another question, I have a driving trip to Canada (about 1000 miles worth of driving) planned with the family in early July. Is it a bad idea to take a new car on such a trip only a couple of weeks after purchasing it?
Regarding the sulfur smell, I am happy not to have that problem and feel for the folks who do. We only noticed a VERY slight burning smell--probably something burning off hot exhaust pipes--the first couple of times we parked the car. After that, there was nothing. To help alleviate your concerns, if you are buying something already on the lot, test drive it a bunch to make the problem happen so you can steer clear or convince yourself you are OK (will also help get your 800 miles in ;-). From what I recall from reading posts (if this is wrong, someone please correct me), if the problem is there it will make itself known fairly quickly. Best of luck.--danandkat
I had sulfur smell for the first 500 or 1000 miles. I am talking about the smell that was easily noticeable inside the van. Then the smell went away. I can occasionally smell it outside the car when I buy other gas than Chevron Supreme or Amoco Premium. But this occasional smell is no big deal. Any car that was driven stinks anyway. Does not matter to me if these are fumes of gas or sulfur as long as I don’t have stinky air inside.
Beside the smell van is excellent. I wouldn't change it for any minivan on the market. I have 2900 miles on my ES 2002. No problems yet.
MB
DO you hear it luke15? You need to set on green (right) to draw fresh air.
MB
Steve
RBB
The difference is phenomenal. Gone is the pull to the right [what I had thought of as Mazda's crown sensitivity]. Gone is the low-speed shimmy. Gone is the high-speed vibration. In their place is an improvement in handling that is a revelation. I'd always liked the handling of the van, but I simply had no idea that any minivan could handle as sure-footedly as the Prez now does. Cost me $550, but if I get any near 80k out of them, it would have been cheap at twice the price. And I'll get the bonus of driving a van that handles effortlessly.
RJ
Also has anyone replaced the brake pads yet? I have 54k on them and think they need replacing sooonnnnn.
How talented are you w/a soldering iron? No, I'm just kidding. You can fix the panel from behind with some epoxy and if you're careful it'll be perfect, if the crack isn't huge and there are no pieces missing.
Re: Brakes, pull the front tires off. Replacement specs for the front pads is 2mm, which imho, is really thin. I'd go for 5mm personally. When measuring pad thickness, you're only measuring the pad material itself, and not the metal backing plate... which is going to be 5-10mm thick itself. Minimum rotor thickness is spec'd at 26mm mimimum. Let us know what you find b/c I'd be interested in how much life folks are seeing in the front pads.
/java
But everything else I wrote about them is gospel
Typically, to get a tire that will last 80K miles, you have to give up a bit of cornering and braking to get that long life.
Now, if the tire can't/wont stay balanced, throws a belt, tread seperates, or it just plain has poor traction, then I believe those qualify as attributes of a bad tire.
But short life, by itself, doesn't make a tire bad.
I try to buy the highest traction and heat ratings (AA and A, respectively) that I can buy, and if I can get a bit longer life out of them, then all the better.
Minivans are VERY hard on tires, so if this is your first van, don't expect the tires to last the 80K miles the Michelin ads claim.
Not to mention that letting your tread wear down to 2/32nd's is not such a good idea if you plan on driving in rain or snow.
You have to have good tires for the brakes and steering to work. You can only brake and turn upto the limits of your tires traction. Harder, long life tires typically have reduced traction, so braking distances increase and cornering limits are reduced as the harder tire will break traction sooner.
So put the best tires you can on your vehicle, as they are truely a safety feature.
My $0.02
TB
Good explanation TB!
Steve
Service engine light has come on a few days after the wife put gas in (I never have the problem!). Dealer said so long as it isn't flashing, no problem. Sounds suspicious to me but I'm no expert on thses things. Any thoughts?
Finally, my mileage on my '00 LX (built August 99)is probably as bad as anyone here. After 30,000, still only around 15 local and 20-21 highway.
Generally the CEL is lit, such as after you've filled up w/fuel, because the gas cap wasn't tighened enough. This is a common OBD-II issue, and plagues many different brands of cars. I generally tighten the cap until it has clicked loudly a few times.
I think the vakcer.com/mpv site was moved to www.mpvclub.com so you may try there for the info you were looking for.
/j
thanks. Is it the case that the light may come on a few days later? I guess it's possible the cap may loosen up or may be jarred loose but it strikes me as odd.
Bill
Here is the info on the sticking fuel door for you: http://www.mpvclub.com/info/prb/3433.htm
And yes, www.vakcer.com/mpv has moved to http://www.mpvclub.com
Alex
