Visitor Agreement.
I've had about the same issues you have... so basically problem-free for almost 28k miles now. Looking forward to the next MPV purchase!
/java
I am 5'6", 150 Lbs and 45 for those keeping track.
I could not have been more wrong. During our recent across the country 7000 miles odyssey, I twice drove 26 hours/1500 miles straight (LA - Wichita, Lawrence - LA). I experienced absolutely no aches of any kind. Even better, my ears were not even buzzing. Sure I was tired, but less so than after shorter stretches with other vehicles. Taller people may have a different experience, but for now, the only way I could be happier with my MPV is if it were paid off.
ANY ideas would be appreciated. I really have never seen tires on a car this bad!
We just turned over 30k on our '01 LX. I barely passed inspection last month due to the unevenly worn tires on the front. I've been pretty good about rotating them every 7500 miles or so. Anyway, we're doing a road trip next month and it's time for new shoes. Most all the reviews on Tirerack.com rave about the Yokohama Aegis LS4. I have the stock Yokos on the van now and I'm a little hesitant because of the neg comments here and my wear. Does anyone know what MODEL the stock Yokos are? Are they the Aegis LS4 or some special oem model? Does anyone have any other strong recommendations for an alternative? By the way, cheap is good. I don't want to spend $100 a tire on Michelins.
Also, since I'm here I might as well ask this as well. I'm going to have my mechanic do a 30k service. Anything particular I should have him perform, other than the oil/filter, maybe plugs, check brakes, hoses, belts, etc.?
Thanks so much for any advice. Better to ask another owner than anyone else, in my book.
Also, they must be manuallly assigned (at this point) by the mazda dist. mgr. not like a "normal" order...some dealers may not realize this
Has anyone figured out how to disable the door ajar chime or fooled the car so it thinks all the door are closed?
Joe
Cheers.
It's a little bit of a pain, but it works.
Maltb's trick of manually closing the latch in the tailgate works too. I have to use that one on my Aerostar. I found that one out the hard way at a drive in. I needed to get the cabin lights off, so I pulled the fuse. Unfortunately, the circuit was also used for the radio's memory. So the moment the fuse was pulled, the radio wandered off the station used for the drive-in... And yes, I know what the sound of a closed latch hitting the striker...
While we are on the subject of open tailgates, it would be nice if someday they added a tailgate release to the interior - it would sure make it easier to exit the van that way if you are sleeping in the back... And maybe a power rear window... (I miss the 71 Olds Vista Cruiser I grew up with).
RBB
"If the overdrive-off indicator light flashes, the transaxle has an electrical problem. Continuing to drive your Mazda in this condition could cause damage to your transaxle. Consult an authorized Mazda Dealer as soon as possible."
I'd get it towed to the dealer ASAP and take advantage of the free rental for warranty repairs from Mazda.
-Brian
mlott@kingston.net
THANKS
OldStyle
I used to have a 91 MPV with the same problem. The problem was the ECU computer that was located under the passenger side floor (under the carpet) the Mazda dealer hooked up there troubleshooting equipment and determined that it was a bad ECU. The dealer wanted about $1500 which I thought was a outrageous price so I visited a local junk yard which had the same engine and accessory as my van. I replace that part and the car stopped stalling, not starting and all those symptoms that you had described.
Hope this helps
ALOHA from Hawaii
I checked the manual and it does mention that there is a sound of valve opening and closing BUT THAT IS WHEN the engine has just been turned off.
The clicking sound is not problematic yet ... but is it a symptom of something else. My 2002 MPV is only at 550 miles (only 3 weeks old).
Does anyone else have this problem ?
Is this a problem at all ?
Ok, to be serious though, use that warranty, that's what it's for.
dealer just put mine in and it seems to run way hotter than what it really is outside
what I would really like is docs on how to calibrate it and maybe details on how it is installed heheh
IIRC, the unit on the MPV is mounted down by the front tow hook.
The compass works fine heheh.
If the van is sitting for some time the temp displayed is way above the actual temp. But after driving for about 5-7 minutes (by the time you are also comfortable inside temp) it starts displaying correct temp. By this time the whole van's temp has become normal/equal to the outside temp.
Compass is always acurate.
John
I am considering replacing my aging Nissan Quest with A MPV LX and wonder if I should wait for the 2003's or take advantage of the $2500 rebate while I can.
The sulfur smell issue was the only item I saw that seemed to be a rather frequent problem, was their any other issue that I should concern myself with on the 2002 model? Thanks for the advice!
JX4. I would take the money and run with the 2002. With a major update scheduled for 2005 and a major refresh in 2002, I would not expect the 2003 model to be very different.
Besides, where does the sulfur come from. Sulfur is not part of a catalytic converter, as far as I know, it is a component in your gasoline.
So your biggest beef is with those who blend your fuel.
Now maybe some converters handle it better than others, but if your car is within emissions specs, then there is not much you can do other than get a different source for gasoline.
I do suspect that it will go away. I don't know if that is because you grow familiar with it or if the converter gets better at "processing" the sulfur.
I would be interested in viewing the emissions test results to see if the vehicle is marginal.
One more thing to consider. The MPV is probably tuned for Truck emissions, so one theory is they don't tune it to run as clean as a car, hence a more noticeable sulfur odor.
TB
Since, your issue is not mechanical. (Meaning, causing the vehicle not to function). It appears not so urgent to most. I a sure you that most of us feel for you and want to be informed of your situation and how it is being handled. Long term data can be the most beneficial of all. Especially in how you are being treated my the manufacture Mazda. Good luck.
Do you live in a high altitude >4000'? The ignition timing (controlled by the computer) may be off. But I assume the dealer checked the computer - Eh?
Tbone had a thought too - what does the emissions check show? Get the dealer to run it if he hasn't already.
As far as the hissing sound, my Altmia (2000) did this too. This is normal. This happens during hot days... when the engine has been driven for quite some time with A/C on.
Hope this helps.
My first MPV problem: DW takes the van to the coast. Next morning there is a 3" crack in the windshield right in front of driver. No way it happened while driving. By end of day the crack is 9" long. Anyone have experience with windshield/warranty issues? I imagine the MPV with all of its front glass commands a pretty penny for replacement.
Has anyone tested to see if it makes a difference on what octane fuel you use? I use the lowest one I think it is 89
The gasoline I used was regular unleaded - 87 octane. I used Arco and Valero (95 %) of the time.
When I got the van - the dealer used 76' - this was also when the smell was at the worst! Could either be the gas OR simply bec. everything was so new.
BTW - 76' in CA does not use MTBE. Arco and Valero in CA still do. Maybe another factor.
Will let you know the outcome.
Mazda MPV at the top of the list.
http://lemonlaw.com/lemonlist.html
I notice sometimes the smell is worse than others. Yesterday the wife drove in and parked in the garage...it was like a brick wall of rotten egg smell. We have never really had the smell IN the car.
http://www.lemonaidcars.com/update.htm
Scroll down to the MPV update.
MB
Phil Edmonston has a few good rants, but there are better sources for car buying and car quality info.
About the only thing I'd recommend is his approach to getting issues resolved.
