It helps a bit when the car is a rental or if it isn't the car you normally drive. I like your idea of having it let you know the door is open, though -- now *that* would be useful!
Sean
The mirror problem sounds unrelated. Maybe the mirror switch got bumped and turned off?
Sean
Sounds like they are making the effort required to fix this. Good news!
Keep us posted.
Sean
Anyone else? Is this "normal" for operating the A/C in colder weather? I do not recall hearing this in the summer and fall when it was hot.
I had a car once that leaked refrigerant constantly and it made the same noise whenever the refirgerant got low.
There are no real common problems to the LS400 especially the 2000 model. IMO, that would be one of the best years to own, since it's the last year production run of the 2nd generation LS400. I would say you could drive it until the wheels fall off, if you take proper care of it.
maxhonda99- thanks for your advice also, the dealer is Toyota yet i think it may be associated with a nearby Lexus dealer since a Lexus car salesman was the one that told me about the particular car, but for the most part i would have to say the LS400 is from the Toyota dealership. And i think it has a 60,000 miles warranty. Could i try to convince them in giving a 7-yr/100k warranty? It has the navigation package, I don't know if it is a platinum edition, How could i tell if it was a platinum edition? I would have to guess that this is the top of the line 2000 Lexus LS400 since many 2000 LS400's dont have a navigation system. Once again thanks for the advice.
Platinum edition LS400's have a few differences. First the wheels are different, the Platinum has brushed aluminum wheels and they are 6 or 7-spoke wheels, second, platinum edition cars have a badge on the front fenders right in front of both front doors that says "Platinum Edition".
Third, they have perforated leather seat inserts, and the chrome badging comes in the black nickel plated finish.
And yes, the car you are looking at is basically top of the line, navigation, heated seats, and HID lights should be on it.
The LS doesn't have two gas tanks, though. It is a single tank in a saddle configuration. Hard to explain without a diagram, but picture a large box with a hump down the center to allow for the drive shaft to fit underneath. The gas collects on either side of the hump, and a mechanism attached to the fuel pump causes it to pump from both sides evenly. There is a level sensor on both sides of the hump, one of which was defective on your car.
Sean
Hope you and everyone here has a good holiday!
Sean
Do you hear this all the time or just over certain road surfaces?
Sprayed carpeted mats with cleaner, let it sit for about 10 mins or so, then rub vigorously with moist towel (don't drench the mats). Allow them to dry overnight before putting back in the car. Anyway, all the dirt came off and the carpeted mats are almost as good as new.
I'm not sure if this product is endorsed by Lexus or not, or if there could be longer term issues that I'm not aware of, but so far so good.
Anyone have a clue as to what is going on here.
Ed
Any chance Lexus offers rear seat entertainment system like on the GX470 ?
When the body style changed in 2001 the car came out in November if I remember right.
