Visitor Agreement.
I wouldn't take your friend's advice on that. Your car has a timing belt that is due for replacement at that mileage. Your engine is an Interference type so if that belt were to snap your engine will need some real work.
The 90K service normally costs $1,000-1,500. It's not cheap but they do alot of work. Half of the engine needs to be taken apart to get at that Timing Belt. Most dealers will replace the water pump at the same time. (Cheap insurance) They will also change all the fluids. You may want them to change the Power Steering Fluid at the same time. (If they don't already).
Hope this helps,
Sam
Thanks for your advice with these questions.
I have a question. Anybody heard about a LS430 recall and reason ??
Lou
Thank you. Lou"
Lou, if you'll go to the "Search This Discussion" box on the right, just above the posts, and type in the word recall you should find what you're looking for.
Lou
Also, I have mich harmony and all 4 have plenty of thread left and are wearing evenly.
Gwen
Gwen
If worn, they can allow vibration to develop, initially at set speeds, and then growing worse over time.
However, this is only one of many possible causes in your case.
which repair should I try first?
Basically, the mechanic will install several microphones/vibrameters on the suspect components (bearings, propellor shaft, differential etc) and go for a ride, with a computer device recording the vibrations. This is the best way to pin point the culprit. It will save you a lot of hassle in just throwing parts at the problem hit-or-miss style.
In this siutation, some money spent for proper diagnosis will save more expense and especially aggravation.
May not be your issue but something to look and listen to.
Gwen
A variable displacement compressor uses a wobble plate (think variable pitch helicopter blades) which is adjusted to control/limit the travel of the compressor pistons. Like that helicopter blade, the "pitch" can be infinitely adjusted, full capacity or all the way down to neutral wherein no refrigerant is being pumped.
And now as the engine RPM rises gear to gear for acceleration or uphill travel the servomotor can move the wobble plate to keep the refrigerant flow rate (work effort, engine load) constant.
No longer a need for a refrigerant reservoir and no clutch to wear out...
Replace Air Conditioner Filter
Replace Brake Fluid
Replace Engine Air Filter
Replace Engine Coolant
Replace Engine oil and oil filter
Replace Timing Belt
Re-torque drive shaft flange bolts
Rotate Tire
Inspect the following:
Ball joints and dust covers
Body
Brake lines and hoses
Brake linings/drums and brake pads/discs
Differential Oil
Drive Belts
Drive shaft boots
Exhaust pipes and mountings
Fuel lines and connections, fuel tank band and fuel tank vapor vent system hoses.
Fuel tank cap gasket
Rack and pinion assembly.
Steering linkage and boots
Transmission fluid.
A hefty mother-in-law.
Thanks for any help given.
cn
Wow, thanks for your time and the very through reply. This is a great forum full of helpful people and good info.
cn
Wow, I'm glad I avoided my dealer for the 15k service last month. I took ours to our regular mechanic/tire dealer who is a Toyota Authorized Parts place and services lots of Lexus. I paid either $70 or $80 for the oil change and tire rotation.
They have on their computer all the specs for the 15k service and check a lot of other things, too.
Thanks again to all...
cn
If you don't get any recommendations here, you might try the www.cartalk.com website. They have a section called The Mechanic X-files (or something like that) where people post good local mechanics by state, with comments, etc. That's how we found a good mechanic for our son's Toyota Avalon in Atlanta after he moved there.
cn
I will buy the '07 LS460 from them as I'm accustom to the ride - or they would drive from Fort Wayne to my home, leave me a rental, and drive my car to the dealership for servicing returning it later that day. Now my wife likes to shop in Fort Wayne so we take the car in.
Bill
Northwest IN.
cn
Would you please share your experience of purchasing a demo. Did you save a great deal of money on that type of purchase? Has anyone else here made such a purchase? What was your experience?
cn
