Visitor Agreement.
And do not have the fuel induction service done.
Also I would call the Mazda consumer information (check your manual for a phone number)line and expalin your problem to them. They should be more helpful then the dealeship
PF Flyer
Chat is on TONIGHT. Check out the schedule
-Brian
I also have the problem of clunking (from R to D).
Dealer told me it was the brakes so I will bring it in for a brake check (BrakeMasters - they do it for free).
Otherwise, the only problem I had was the PCV valve (fixed by recall).
My van is in the shop right now for the PCV and fan control module recalls.
I have a 2002 LX - with 53,000 miles.
My left one is loose and is causing a noise.
Go check this out.
Has anyone else seen this rust problem yet? If not, it sounds like it's not going to be a big deal...right! I had a DC Van and had similar issues AFTER 5 YEARS though and Chrysler stood behind it and REPLACED the door! Mazda will probably put duck tape on it and spray paint it with some rustolium stuff...whatever!
After replacing the TCM, could you feel the gear shifted at all?
It is mentioned in the Lemon-aide book that the 2000 model has power problems because it doesn't have a large enough engine for the size. Also it mentions that it is not good for winter driving because of the light rearend.
It anyone has any info on this as it seems like a great minivan but these issues worry me.
This discussion was created in March of 2000. Start on page one and scroll through reading the posts that interest you. It may take some time, but the info and opinions you're seeking are all here.
I have actually scrolled through many of the posts and have seen nothing mentioning winter driving.
Cher
In reguards to the "light rearend" you could always throw some dead weight(cement blocks,weightlifting weights, husband)into the rear seat area for added traction. Good Luck.
My 2000+ Mazda MPV
As far as it being difficult to drive in the winter due to a light rear end, this doesn't make sense. Being a fwd vehicle, traction is coming from the front end of the van, and rear weight will only reduce front axle traction. If you threw sandbags in the back, you'd accomplish two things. First, you'd change the weight distribution of the van to the rear more, and off of the drive wheels, reducing traction. Second, it will make the rear end of the van tend to want to come around, because you'll be adding weight behind the rear axles, which is never good.
Perhaps the comment you read about rear lightness was from a 89-98 MPV. These were rwd and 4wd vehicles, and I can see the comment applying to those rather than the 2000> MPVs.
HTH
Cher
Also, we have a severe heat problem in the rear luggage area (3rd seat down) In the summer a long trip resulted in the luggage almost burning. We were told by the dealer that there is no rear heat shield in this model ie. "live with it" We carry a fire extinguisher now. Anyone else have this problem?
Anyway, I found one at a junkyard and it was an easy bolt-on job (~$80 iirc). Maybe try eBay or craigslist.org too.
My questions, have others heard of this and what are my options to get reimbursed?
If it started jerking or having hardshift problems at 98,000 it sounds like it may be something other than the TCM.I belive most of the hardshift problems have occured with 2002-early 2004 models. Many people have taken their MPV in to have the TCM "reflashed" which is a way of reprogramming the TCM so that it will shift more smoothly. There has also been a recall on the PCV valve. It sounds as if your dealer may have screwed up putting in the PC.
You can just turn the rear vent off to solve the problem.
1. Torque converter clutch solenoid
2. Missfire from #2 cylinder
3. Transmission replacement !!! yikes!!
4. Tune Up
5. Cat converter plugged
This what seems like a missfire, happens even when the car is in park, which leads me toward bad plugs or some other timing issue.
Do you have any suggestions for me? I really appreciate it.
Problem: fog lights did not work so i traced the wiring back from lamps to relay to the switch on my dash. that took about 2 hours. now the wire on the other side of the switch (the +12v side) i could not find where it went (other then going into a massive maze of a wire harnesses) so i hooked it up to the aux. fuse in the fuse box inside by my feet. it works great and will turn off when van is turned off. bbbuuutttt.... the engine light comes on now every time i start the van. Q,is the wiring so sensitive that its finding it a problem or did i screw it up. Q, can this be disabled. please,someone help me.if this poses no problem in itself it still may mask a real problem that may come up later.
• The fuel tank level being very low or approaching empty.
• The engine’s electrical system has a problem.
• The emission control system has a problem.
• The fuel-filler cap is missing or not tightened securely.
You can have the code(s) read at a local AutoZone, typically for free. That's the best place to start, since it will tell you what is wrong. You might have accidentally unplugged something, or perhaps it's coincidental that there is a real issue with something.
Also, OBDII can NOT be disabled. You can disconnect the battery to clear the light, but if the condition still exists when you restart the van, the light will illuminate again.
-Brian
-Brian
it's just a document from corporate that explains details of a repair procedure. it's not a recall.
-Brian
