Hyundai Sonata 2005 and earlier
1464749515258
    wantapassatnowwantapassatnow Member Posts: 100
    The current incentive on the 2004 Sonata apparently expires Dec. 1. ($1000 rebate or 0%-3.9% financing.) What are the chances this will be extended through the end of December? I plan to buy my car sometime between now and the end of the year, but I would hate to rush into something just because of the incentive. Thanks!
    Unfortunately, I can't wait that long. My current lease is up on Jan. 3, 2004. So if the incentive grows in December, great! I just want to make sure there will still *be* an incentive in December. Thanks!
    Thank you for your explanations about fuel, reliability, etc. This board is so informative! :)
    safetyredsafetyred Member Posts: 14
    Does anyone know if the '03 Sonata LX has rear seat heater ducts, and if so, where are they located? thanks.
    ray_h71ray_h71 Member Posts: 212
    Yep! Unfortunately they aren't the type that are integrated in the rear of the console with nifty adjustable registers, but they're there alright - under the front seats to spread toasty warm air on the rear seat passengers' piddies.
    otoluvaotoluva Member Posts: 196
    Any of you Sonata owners (2002 or newer)with sunroof experiencing water leakage or excessive wind noise?
    nato1nato1 Member Posts: 102
    The sunroof is designed to allow a little bit of seepage, if there is water in the cabin, then I would check to see the drains are clogged.
    my '02 sonata factory installed sunroof, no problems.
    I'm suspicious of the claim that sunroofs are intentionaly "designed to allow a little seepage". And, that, in turn, would automatically promote excessive wind noise. The drainage channels are designed in simply to allow an exit point -in case- water finds its way into the sliding rails' innards before the hapless owner is able to get the sunroof closed. Otherwise, trapped water would promote rust in an area you really, Really, REALLY don't want rust. If your sunroof is leaking and subject to excessive wind noise, either it's misadjusted, has a defective sealing gasket, or both. If the designed-in drainage channels are clogged, that would trap moisture and promote rust, too. Getting your problem attended to sooner would definitely be better than putting it off until later - expecially with the wet weather on us now.
    nato and ray, thanks for your reply, I actually don't own a Sonata but my wife really likes the car ( with sunroof ) and I'm doing some research before we buy it, and quite frankly the more I learn about the Sonata the more I love it and I just wanted to make sure the sunroof hold up well over time.
    Thanks again
    Ray,
    can you tell us how a sunroof that opens up and opens in is going to hold back 100 percent of a driving rain without a positive seal over a temperature range of about -20 to 120 degrees with totally different coefficients of expansion of metal and glass?
    The drains are there to catch the seepage and the occasional 'oops I left it open'.
    bart6okbart6ok Member Posts: 1
    Hi, thinking of buying a sonata...I live in NYC and commute about 60mpday out of the city. Having spun out at 90mph (my rear wheel drive 300zx...deadly on NY highways...(I'm from TX)) I'm now, surprisingly, concerned about safety. The Sonata doesn't seem to do as well on IIHS and NHTSA as civic / toyota camry or corolla...
    Any insight? Appreciate. P.
    alpha01alpha01 Member Posts: 4,747
    I like the slick, if unadventurous, exterior. Flavors of Passat in the front, and Phaeton & Accord in back. That new gauge cluster is sharp as well, but I'm not too sure about the radio's seeming non-integration. It looks a bit lost.
    Certainly, you cant judge a car by its pictures, but Hyundai continues to impress me.
    Do we have any mechanical info on this model yet? Engines/transmissions/etc. Stability control and Curtains expected?
    PZEV- thanks for the pics! Do you have any info on other vehicles?
    ~alpha
    Eek, that first photo makes it look like a Chevy Impala from the front. Other angles are better, though.
    I see a profile like the Camry.
    The interior looks very nice.
    -juice
    Thanks for posting these pics. Seeing them makes me really glad I am getting a 2004. ;)
    Why do car companies *insist* on making their cars looks exactly like all the other cars on the road? *sigh*
    747pilot747pilot Member Posts: 38
    I have mixed feelings about the 2005 Sonata.
    On the outside it does look more generic then the current EF Sonata. It also looks a little smaller as well but it is hard to tell from the pictures.
    On the inside I love the dash layout. Simplicity at its finest. Also in one of the pictures it looks like it might have a GPS navigation system.
    I am sure the 2005 Sonata will offer even more refinement over the current Sonata. Like many re designs they are not liked at first but then they start to grow on you.
    One thing I noticed that needs to be improved on is the wheels. I wish the Asian manufactures would follow the European manufactures and put extra wide and low profile wheels. This would speak performance instead of economics.
    (I posted this on the Elantra GT 5-door forum, too.)
    As you know, I have been considering getting a 2004 Sonata LX, but I can't get the Elantra GT 5-door hatchback out of my head! I test-drove both of them, and I did prefer the ride of the Elantra better; the Sonata seemed a bit slow and loud. However, the Elantra seemed a bit "young" for me -- I prefer the elegance of sedans -- and quite frankly the color choice of the Elantra sucks. Still, the Elantra's price is, of course, a lot more attractive to me than the Sonata, though they both seem like a great value. I like that both have leather seats.
    Can anyone give me the pros and cons to getting the Elantra GT hatchback vs. the Sonata LX? Things like insurance prices, maintenance, fuel economy, etc.? BTW, I do mostly city driving (short hops to and from work). Also, I am not at all interested in the Elantra 4-door sedan. Thanks!
    Here is the only "pro" that really counts - you prefer the Elantra. Get that one.
    Being accused of youth ain't so bad. ;-)
    -juice
    The problem with youth is that it's wasted on the young...
    Today I decided between the Sonata LX and Elantra GT hatchback, and the Sonata won. So now I am checking out all the aftermarket stuff that I can have fun with after I get my car. There is a badge out there for the Sonata that says "EF." What does "EF" mean in relation to the Sonata? Thanks for answering what I know is probably a really stupid question. :)
    jimbeaumijimbeaumi Member Posts: 620
    I think EF Sonata is the model's name in Korea. Take a look a the Hyundai website (not the USA site): www.hyundai.com. Cancel the translation popups.
    pzevpzev Member Posts: 807
    "thanks for the pics! Do you have any info on other vehicles?"
    I have some, but you might have seen them already somewhere or aren't interested in them. Any particular cars in mind? I usually only pay attention to cars that I could afford or one day afford. BMWs, Ferraris, etc. I don't really pay attention to and don't bother with.
    Is there a thread on Edmunds anywhere where people post spy pics of any and all cars or do people mainly just post them in the car's topic directly?
    re: Sonata Safety
    Just my 2 cents on the topic. Like you I do pay attention to crash scores. The problem is crashes are so different and so many variables are involved it's really hard to say how much safer an Accord for example would be over a Sonata.
    Personally I think the Sonata is good enough with this that if you value the extra long warranty and lower price a lot, I would consider going for it.
    Best thing to do is look at the specs and prices of the vehicles you're interested in and narrow it down from that. Then take what's left and go sit in them and test drive them.
    I don't think the Sonata has side curtain airbags (the next one coming up in a year should though I think) and in some accidents that could make a world of difference. Also which car has better brakes may make a difference, or the one with better handling to avoid an accident altogether. If it was me I would try to find the best balance possible.
    edit: video is on autoexpress so it requires a membership so Edmunds probably won't allow a link.
    It's a video of the camouflaged Sonata posted above and shows it driving around in the desert and moving around in town. Looks pretty good.
    I, like you, am only interested in "everyday" cars. Honda, Toyota, Nissan are my main interests, though I am not AGAINST any mfr. Of the domestic makes, I prefer GM. Anything interesting along those lines? If it off topic for this forum, feel free to email me if you'd like.
    (Specifically, if you have any info on the 05 Avalon, the 05 Tacoma, or the the 05 Camry refresh, thatd be cool. I think Honda's sedan lineup is quiet for 05, and finally, if you have anything on the 05 Altima refresh or the redesigned Sentra, thatd be awesome as well.)
    Thanks!!
    ~alpha
    charlie616charlie616 Member Posts: 5
    I bought my Sonata GLS-V6 about 3 months ago,
    and I've posted that the suspension was way too
    soft compared to other sedans that I drove.
    I think ray actually replied that Sonata is KNOWN
    for its soft suspension.
    Anyway, a few days ago, I've checked the tire
    pressure, and it was only 30 psi. And that WAS
    the manufacturere recommended setting, when actual Maximum pressure on the Michelin MXV+ was
    44 psi.
    I pumped it upto 35 psi, and what do you know....
    It grips the road a lot tighter with great cornering without sacrificing much of the soft ride.
    Anyway, I happened to avoid a close accident today when another car just stormed into my lane
    from a middle of no where. My Sonata handled
    superbly.
    If you want a better suspension, pump up your tire a bit. Just a thought.
    Charlie
    I'll post on here but I'll try to leave it to this one post because this is about the Sonata.
    2005 Camry and Tacoma
    Haven't heard much about either of these. I'm not all that interested in trucks/SUVs so I don't really pay attention to stuff about the Tacoma. Rumors say there will be a hybrid version of the Camry but I have no idea how true that is.
    2005 Nissan Altima
    http://www.compugenius.com/hosted/2005altima2.jpg
    Same as the Camry, just look for a minor refresh. The Altima will probably get a "tooth" grille like the rest of the Nissans and there's rumors the taillights will be changed to red from the current clear ones. Also rumors about the interior being upgraded, which it surely needs.
    2005 Toyota Avalon
    No pictures for this, but I've heard crazy rumors about this. Some people say it'll go RWD and have a more powerful engine than the Camry and ES330. My guess is it'll continue to be a Japanese Buick and stay FWD and styling will stay fairly conservative. This is purely a guess on my part though.
    2005 Nissan Sentra
    No spy pictures for this either. I would say the Nissan C-Note concept from the Tokyo show is a hint at what the Sentra will look like.
    Other stuff
    2005/2006 Volkswagen Jetta
    http://www.imagestation.com/picture/sraid67/p5bd29cca08991adad8cc- cf6ddf6e1234/fbd4ad85.jpg
    Not sure how legit that is though.
    2005 Chevrolet Cobalt
    http://www.gminsidenews.com/spy2.jpg
    Supposedly the car in the background may be the Cobalt, but not sure.
    2005 Hondas
    Like the Camry, rumors say the Accord will get a hybrid version at some point. Something that is pretty much confirmed though is Honda says by 2007 or so that 99% of their cars (excluding the Insight, S2000, NSX) will have STANDARD side air bags and side curtains and ABS. Also the trucks/SUVs will have stability control in addition to those things. This makes me believe that the next generation Civic and Accord will pretty much have standard SAB/SAC and ABS.
    2005 Kia Spectra
    I just posted some NA spec pictures over in the 2005 Spectra topic but it's really nothing special. Like a lot of these cars, it will be shown in Detroit next month so a lot of questions will be answered then. The Korean version has already been shown but it'll be interesting to see if the Spectra gets side curtains and what the price will be, etc.
    2005 Lexus IS330 / Toyota Supra
    Even though these are fairly expensive, I'm really interested to see what the next IS300 looks like. Seen lots of pictures but no actual spy pics except the ones of the V8 test mule. It has an IS300 shell on it so it's nothing special. Seems to me this may be the next IS300 with just the current IS300 body on it. They could possibly do what Nissan did with the G35 and Z car and have the IS and Supra share platforms and the V8 could go into the Supra. Toyota needs more youthful/sporty cars in their lineup and the Supra would help build some interest in the Toyota brand. Also I think the current engine is being dropped in favor of the 3.3 V6, possibly souped up a little more to be more sporty than the ES330.
    2005 Ford Focus
    Ford Media says the 2005 Focus will be shown sometime this week. It'll probably just be a refresh even though the car has been out since the 2000 model year. It'll keep the current platform until 2007-2010. Looks as if it won't use the Focus II platform like the European Focus and Mazda3 will use.
    Can you send me an email? (click on my user name, then the link) I'm guessing that you dont want your email public, which is why its not shown on your profile. I have several comments and a few questions on the information you have provided (thank you!) but I dont want to post them here, b/c it borders on off topic and I have been lambasted a lot recently by the hosts, and dont want to get kicked off.
    One thing that irks me- Honda is all proclaiming their new safety initiative, meanwhile, its gone almost unnoticed that effective for THIS, the 2004 MODEL YEAR, Toyota already made ABS and VSC, Toyota's stability control system, standard on EVERY SUV sold in the US, and all pickups have ABS. Ok, thats off my chest now.
    alpha
    Subaru has had AWD and ABS standard on every model for several years now. Way, way ahead of Honda or Toyota.
    Really VW is the pioneer, I think. Passat has had ABS and side curtain air bags standard for a while, plus stability control and AWD optional.
    Hyundai has made great strides lately and I think offering this kind of level of safety may be what finalizes their move out of the bargain basement.
    -juice
    atex-I see VW as an upscale mainstream, as they sell barely any vehicles with pricing under $18,500. Honda, Toyota, GM etc... do. I'd expect a more premium brand to offer standard features that competing vehicles have as optional, as in the case of your example, the Passat. Option a Camry XLE (4 or V6) or Accord EX (4 or V6) with the same safety items as the similar model Passat, and the price of entry is about the same, or lower.
    Subaru has had AWD and ABS standard ahead of Honda and Toyota- but I dont see AWD, at least for MANY regions of the US, as valuable as VSC. Toyota is the first non-premium automaker to make stability control and ABS standard on all its SUVs, the vehicle type that benefits most from said system, period. I DEFINITELY would like to see Toyota follow Subarus lead with ABS standard on all passenger cars. I agree with you about Hyundai- although it doesnt yet offer curtains, head and chest protection front SAB on all models is HIGHLY commendable.
    ~alpha
    Passat offered those several years ago, though. I think back in '98, maybe a little later (?). Honda and Toyota only recently jumped on that bandwagon. IMO they are a step behind VW.
    Toyota's SUVs cost more than the Passat, so I see that as less of a break through in terms of bringing safety features to the masses. And again, that was only recently, this year I think. Highlander didn't have ABS standard when we shopped for one in 2002.
    The lowly Impreza TS wagon, at about $16k street price, did. AWD too.
    Whoever does it first, it benefits us all as it puts pressure on manufacturers to offer these on more mainstream models, like the Camry and Sonata.
    -juice
    nato1 wrote:
    "Ray,
    The drains are there to catch the seepage and the occasional 'oops I left it open'."
    Sure - the same way the windshield is designed not to leak - the sealing material's elasticity will maintain water tightness despite the differing coefficients of expansion. That there may be
     -some- seepage past the sunroof's sealing under -some- conditions is irrelevant. I simply objected to the claim that the seepage was an intentional design factor. The drainage channel you noted, however, IS a design factor to accomodate the water intrusion if and when it occurs. Now, nato1, can YOU tell us why Hyundai, or any other car builder for that matter, would
     -intentionally- design a sunroof assembly to leak?
    Hi all. Most of you know from my previous posts that I'd prefer to lease a Sonata LX than buy one, but you have all informed me that leasing, well, sucks with Hyundai due to the residual value.
    Just now on the Hyundai site, I saw they updated their incentives for December. One of the things added for the Sonata is this:
    "2004 Triple Play Sonata Lease
    Lease a 2004 Hyundai Sonata for $179/month, 12,000 miles/year. $0 customer security deposit. This program is effective from December 2, 2003 through January 2, 2004."
    OMG! This was not there before. It is brand new.
    Yes, I know this will be a base model. But geez, if they are at least advertising a lease, should I at least be hopeful that I can get something decent on the 2004 LX? Say, $1,000 down, about $250 a month?
    I can dream, can't I? :)
    I mean, I have resorted to considering a lease on a 2004 Chevy Malibu because GM has sent me so many combinable certificates, they are practically giving me the car.
    But I don't want a GM. I really want the Hyundai. If I could lease it and keep my down payment and monthly payments low -- which is what I really need to be doing right now -- it would be the ideal.
    Any insights on this new addition to the incentives? Thanks!
    Hmm, for some reason it won't let me edit the above post. Sorry. I spoke to the dealership, and it turns out I would be able to lease the Sonata for a decent price.
    Now I need your unbiased opinion: I am *extremely* torn between the 2004 Hyundai Sonata LX and the 2004 Chevy Malibu LT. Price is now not a factor, because the lease payment will be virtually the same, given all the incentives I have received from GM.
    My own pros and cons:
    > I prefer the look (exterior and interior) of the Hyundai.
    > I prefer the ride and handling of the Chevy.
    > Chevy has more hp.
    > Hyundai has a better warranty ... but is that because I'll need the warranty?
    > I like that the Hyundai has a cassette player.
    > There are more Chevy dealerships near me than Hyundai, so servicing will be less of a hassle with Chevy.
    > Hyundai has side airbags, but Chevy has head curtain side airbags and ABS.
    > Insurance is cheaper on the Chevy.
    Ugh, I am just so torn. Your help is very much appreciated. I am posting this on the Chevy Malibu board, too. Thanks!
    wantapassatnow, if you have at least two Hyundai dealerships within reasonable driving distance, you'll probably not have difficulty finding satisfactory service. Remember, you do not have to have your car serviced by the selling dealer for warranty or routine maintenance work. The ONLY reason Hyundai has the 10 yr./100,000 mile warranty is MARKETING considerations. It's been a long, uphill struggle to overcome the stigma of the early Hyundais when they were released in the mid-80s and buyers found out quickly that Korean quality did not equate to Japanese quality. The long warranty has helped quell doubts among buyers, and Hyundai's contractual committment has helped keep the company honest. Hyundais are not up to the quality level of Honda and Toyota yet, but each year they're better than the year before. They're pretty reliable, now, in my opinion. I had a '91 Sonata that was mechanically trouble-free through 60,000 miles at which point I traded it for a '96 Accord. My 2003 Sonata is easily several orders of magnitude better in terms of QC and freedom from structure flexure than the old Sonata and at least the equivalent of the '96 Accord. Would I have rather had an Accord when I bought my Sonata last year? Yep. But, finances being what they are, the Sonata got the nod. Would I still rather have an Accord? Yep. But the Sonata has not disappointed - and it's only the base model. Though the Michelin tires Hyundai installs on these cars, good though they are in terms of traction, fuel mileage, and long wear, are not the quietest rolling tires on the market. Yet, my base Sonata is nevertheless surprisingly quiet. If, as I suspect, the GLS and LX Sonata models come with additional sound insulation, they must be nearly tomb-like inside. Quiet-riding cars do not a reliable car make. But, they do imbue driver and passengers with a sense that they're riding in a refined car. Sugar coating, but I believe it helps explain why Camrys are outselling Accords for several years. Best of luck in your selection.
    riezriez Member Posts: 2,361
    Read the latest issue of CR, January '04. Tests the Kia Optima (the Hyundai Sonata's sibling). They now top-rate the new Malibu as the best USA domestic product. And they rate it 5th in their 14-car family car segment, behind only the Passat, Camry, Accord, and Altima.
    Sonata is rated 7th and Optima 10th. Sonata/Optima is ancient in the car world. Dates back to '98 when introduced as a MY99.
    As CR puts it, 2.7L V6 is a bit smallish and underpowered for the weight. Their Optima was the slowest car (0-60 mph in 9.1 seconds) and got the worst fuel economy (20 mpg overall: 13 city and 29 highway). It is projected to use the most fuel.
    Hyundai needs to update the Sonata/Optima and not a moment too soon. Needs better safety equipment (e.g., curtain airbags), more powerful optional engine, and 5-speed automatic transmission.
    At least reliability is OK for Sonata. They don't project for Malibu or Optima.
    Have you considered looking at an Optima lease? Might be less expensive.
    I've driven the Malibu, it's better than I expected. CR agreed, rated it nicely. One thing was the their mileage (26mpg overall) was their best ever for a V6 family sedan. Very impressive. EPA figures are also good. And their acceleration was good, too.
    I drove a Sonata V6 and Malibu V6 back to back at the Chevy intro event. I like the Hyundai's styling better, inside and out. The 'bu is quicker and more efficient. The Sonata is softer, seems more luxurious, while the 'bu is a little sportier.
    Both are a good value, but drive them both, I think they differ enough in character that you will have a clear favorite.
    -juice
    intrepidspiritintrepidspirit Member Posts: 662
    If you are looking at a 3 year 36,000 mile lease, you can eliminate the Hyundai's 10 year 100,000 mile warranty from your decision making process...
    I have owned my 04 Sonata LX for 3 1/2 months now. It only has 2,000 miles on it but I spend a great deal of time riding my motorcycle when I can.
    Only problem to date is the Check Engine Light came on when it had about 800 miles on it. It was the O2 Sensor and it was promply replaced under warrantee. No other problems to date.
    I find the car continues to ride nicely and seems to have more power now then when new. Fuel economy has been a steady 22 miles per gallon.
    Only interior anomoly to date is a buzz located in the radio area. I have tried poking around trying to isolate it but have failed to find it. Only time it shows up is when driving on coarse pavement. We have lots of coarse pavement from studded snow tires and high traffic. For the record my father's Toyota Camry does the same exact thing on coarse roads. I might mention it next time I take it in but in my experience they usually create 10 more rattles trying to fix the first rattle.
    Everyone who rides in it just loves it. They admire the nice ride and quiet engine. Plus the style turns a lot of heads. It looks and drives like a much more expensive car.
    I would say that Hyundai offers a very good value with this car.
    747pilot, I had a resonnance buzz over coarse pavement that sounded like it was centered behind the upper console in my base Sonata, too. Since the base Sonata doesn't come with the cabin air filtration system as do the GSL and LX trim levels, I decided to purchase the filter and install it myself. (The lidded compartment for the cabin air filter in the HVAC evaporator case is there behind the glove compartment - just empty on the base Sonata) In the course of this installation, I had to remove the right side dash decorative "endcap" - held on by an exposed phillips head self-tapping screw. As it came off, a small "U" shaped push-on spring steel "nut" fell to the floor. I figured out that a cast-in tab with a hole centered in it on the reverse side of the decorative endcap -had- to be where the push-on "nut" was -supposed- to have been placed, but evidently wasn't positioned properly by the happy-merry worker at the Asan Sonata assembly plant or fell free during installation of the endcap. Either the screw, itself, was loose enough in the bare plastic hole that the plastic resonnated, or the push-on "nut" was lying loose against the inner bottom of the endcap (or both!) to buzz when conditions were "right". To make a long story longer, I placed the push-on "nut" where I thought it ought to be when I re-attached the decorative piece. I noticed more resistance when tightening the screw than when I'd removed it, and my car's annoying dash buzz is now just a distant memory. The way noises can telegraph through the hard pieces in a car, it can be all but impossible to accurately define -where- a
    #@%&ed buzz or rattle is -really- coming from. I just lucked into it in my case. Whether your resonnance problem is the same as mine could only be verified by examination, but, just a heads-up in case you want to bring it to the attention of your dealer's service writer.
    Thanks for the tip. If I have time I will have a look at it or just wait to bring it to my dealers attention. The procedure sounds simple enough.
    It seems odd that the end piece could cause a rattle sound in the center console but you never know. With the shape of the dashboard the sound can travel and be coming from just about enything.
    It definently sounds like a loose piece of plastic that is resonating against another piece of plastic.
    rexligett831rexligett831 Member Posts: 2
    Am thinking hard about a purchasing a 2000 Hyundai Sonata. They look great inside and out, what gets my attention is the price. The car sells for about $14,000 new and it when they are only three years old, they are selling for about $5,000 or so. They don't appear to hold any value.
    What kind of problems can one expect to see with the sonata?
    rexligett831... My '00 Sonata GLS now has 50,000 miles. I bought her new in 5/00. I have not had a single signficant problem. A burned out headlamp. Then just routine LOF, tire rotates, new set of tires, and other maintenance. She has been an outstanding car.
    Mine is a rare V6 5-speed manual. She has Pkg 13, which includes leather, sunroof, and traction control. She has been an absolute joy to own. So much so that I paid her off early. She is all mine. I plan on keeping her for a long, long time!
    Check out the latest and future Consumer Reports reliability data. Has been pretty good for '00 and later Sonatas.
    You have hit the one weak spot: resale value. But if you keep for ever it isn't a problem; if you buy one used, you get a great car at a low, low price.
    Just be aware that you only get the unused portion of the basic 5 yr./60,000 mile warranty, NOT the 10 yr./100,000 mile powertrain warranty. I'd be leery about ANY make used car that I couldn't examine the service records of.
    brad898brad898 Member Posts: 7
    You're obviously an expert ;).
    Will be trading in my well-cared-for '99 Malibu next summer for either a '04 Sonata LX or a Malibu LT. Have GM MC credits, so the warranty is no biggie, any thoughts? Thanks. No rush.
    patpat Member Posts: 10,421
    The Sonata is included in Edmunds' latest Family Sedans comparo. You can access the article from the Helpful Links box on the left side of the page.
    chevyguy657chevyguy657 Member Posts: 216
    Am in the process of researching new vehicles for an upcoming summer purchase (just on-line so far; no test-drives yet).
    I've gotten a hold of the Hyundai warranty booklet, courtesy of a friend and Elantra owner, and have read thru the warranty. Am troubled by some of the exceptions, most notably the lack of rental reimbursement.
    Solution appears to be to purchase a Hyundai Advantage plan (they come in 6/75,000 and 10/100,000 varieties). I know that GM and Honda charge around $1,000 for their plans, depending on length of coverage.
    Any one know how much Hyundai charges for theirs? Am a bit afraid to see the answer. Much higher than $1,000 will knock the Sonata off the short-list.
    chevyguy657, there -is- provision for rental reimbursement in the "HYUNDAI ROADSIDE ASSISTANCE PROGRAM" section (Page 8 in the 2003 (and presumably 2004) "Owner's Handbook & Warranty Information" supplement booklet. To whit:
    "Trip Interuption Benefit: In the event a warrantable mechanical disablement occurs more than 150 miles away from home, and your vehicle is disabled overnight due to a repair in progress, Hyundai Roadside Assistance will reimburse for reasonable expenses for meals, lodging, or ALTERNATE TRANSPORTATION [emphasis mine]. Trip Interutption Benefit is limited to $100 per day subject to a three-day maximum limit per incident. It is required that you contact Hyundai Roadside Assitance to obtain preauthorization of eligibility."
    The above coverage extends to 5 yrs./60,000 miles, matching the basic Hyundai inclusive warranty in duration. I trust you're already aware that Hyundai also provides for a powertrain warranty extension to 10 yrs./100,000 miles. All of these warranties and the Trip Interuption Benefit are provided by Hyundai, America at no additional charge. I'll leave it to you to ponder the math about whether a warrantable blown engine or trannie at, say, 70,000 miles -without- car rental reimbursement is better financially to you than -paying- for the engine or trannie exchange and getting reimbursed for car rental. (You probably won't need a spreadsheet... :))
    Thanks much. I've only recently been a registered member, since I hated to cause a stir when I wasn't yet in the market. I'm aware that you're very knowledgeable and thank you.
    I have a short list of about 5 vehicles that I'm considering, including the Sonata. Also aware that a new one is due next spring ('05) (but US produced, for better or worse). Most of the others are GM products and I get the GM Extended Warranty for "free" via my GM Card Earnings. So, the spreadsheet is unnecessary, but I get your point. Prob is GM is being cheap with rebates right now on the competition.
    I'm a busy guy, and don't want to have to sit at a dealer for a 4-hour power window regulator fix (for example). With GM, I'd get an immediate rental. That's why the Hyundai Advantage Plan is under the scope. Not concerned about trip interruption; the few vacations I manage are all via airplane.
