Visitor Agreement.
As in the above post, I've been trying to decide between the SE and LE and this is even more diffult to do without knowing whats included.
Standard Equipment
Every 2002 Toyota Camry 4dr Sdn SE Auto (Natl) comes with the standard equipment below. Unless otherwise noted, standard equipment is the same for vehicles in different model years.
MECHANICAL
· 2.4L twin-cam EFI 16-valve 4-cyl engine
· 4-speed electronically-controlled automatic transmission w/OD & intelligence (ECTi)
· Front wheel drive
· Electronic distributorless direct ignition system
· MacPherson strut front suspension
· Independent dual-link MacPherson strut rear suspension
· Front/rear stabilizer bar/gas-filled shock absorbers/vibration-dampening sub-frames
· Sport tuned suspension
· Strut tower brace
· P215/60R16 all-season SBR BSW tires
· Full size spare tire
· 16'' steel wheels w/full covers
· Variable assist pwr rack & pinion steering
· Pwr front ventilated disc/rear drum brakes
· 18.5 gallon fuel tank
EXTERIOR
· Color-keyed rear spoiler w/integrated center stop lamp
· Color-keyed protective body-side moldings
· Color-keyed door handles
· Black-out sport grille w/chrome trim
· Daytime running lamps
· Aerodynamic halogen headlamps w/black-out sport trim
· Integrated fog lamps
· Dual color-keyed pwr mirrors
· High solar-energy absorbing (HSEA) glass
· Washer-linked variable intermittent front windshield wipers
· Black Pearl sport badging w/chrome logos
· Chrome-tipped exhaust
INTERIOR
· Multi-adjustable front bucket seats w/adjustable headrests
· Driver seat cushion vertical height adjuster
· Covered center console w/bi-level storage
· 60/40 split fold-down rear seat w/fold-down center armrest, adjustable outboard headrests, security locks, seatbelt positioning clips
· Unique sport cloth seat trim
· Cut-pile carpeting w/driver-side footrest
· Leather-wrapped tilt steering wheel
· White-faced sport gauges
· Instrumentation-inc: speedometer, tachometer, digital odometer, dual tripmeters, temp/fuel gauges
· Warning lights-inc: airbag, seat belts, fuel level, door-ajar, battery, check engine, oil pressure, tail lamp failure
· Pwr windows w/driver side auto-down, retained pwr feature
· Automatic pwr door locks w/anti-lockout feature
· Cruise control
· Remote releases-inc: trunk, hood, fuel-filler door
· Defroster-linked air conditioning w/air filtration
· Heavy-duty rear window defogger w/timer
· Deluxe AM/FM stereo w/cassette/compact disc-inc: (6) speakers
· On-glass antenna
· Lockable illuminated glove box
· Digital clock w/exterior temp display
· Cloth door trim w/integrated armrest, map pockets
· (2) 12-volt auxiliary pwr outlets
· Metallic style interior trim
· Overhead console w/maplights & sunglasses holder
· Illuminated entry
· (3) front cup holders
· Trunk luggage box
EPA FUEL ECONOMY RATINGS
· City 24/hwy 32 (2.4L engine/4-speed auto trans) *Estimated*
SAFETY
· Driver & front passenger airbag Supplemental Restraint System (SRS)
· 3-point front shoulder belts w/adjustable anchors, pretensioners w/force limiters, emergency locking retractors
· 3-point rear shoulder belts w/emergency locking retractors
· Child restraint seat tether anchors
· Child-protector rear door locks
· Collapsible steering column
· Side-impact door beams
· Crumple zones
· Internal trunk release handle
WARRANTY
· Basic: 3 Years/36,000 Miles Drivetrain: 5 Years/60,000 Miles Corrosion: 5 Years/Unlimited Miles
NEWS - JD POWERS RATINGS
· NHTSA CRASH TEST RESULTS: Frontal crash ratings: Driver: * * * * Passenger: * * * * * Side crash ratings: Driver: * * * Rear Passenger: * * * Driver: * * * * with side-impact air bag Results based on a 35 MPH frontal crash and 38.5 MPH side crash. Results are reported in a range of one to five stars, with five stars indicating the best crash protection for vehicles within the same weight class. This test used driver and passenger belts and airbags. [NHTSA - APR 2001] NHTSA ROLLOVER RESISTANCE RATING: * * * * * The Rollover Resistance Rating is an estimate of your risk of rolling over if you have a single vehicle crash. It does not predict the likelihood of that crash. The Rollover Resistance Rating essentially measures vehicle characteristics of center of gravity and track width to determine how ''top-heavy'' a vehicle is. The more ''top-heavy'' the vehicle, the more likely it is to roll over. The lowest rated vehicles (1-star) are at least four times more likely to roll over than the highest rated vehicles (5-stars). [NHTSA - APR 2001]
Mackabee
2 questions though. One, that flashing passenger seatbelt light when not buckled. It always flashes when the seatbelt is not locked. I asked the salesman (if you can call him that-he was totally worthless and barely spoke a word of english but I do live in Miami) about it because I rarely have a passenger in the car. He suggested to always keep it buckled. How annoying! I have a laptop and do lots of work in the passenger seat. This would only get in the way. Can this be light turned off??
Second, I see no comment about this anywhere but the poor position of the radio leaves a lot to be desired. I think I strained my back reaching for it. It kind of arcs away from you. So weird. Any comments on this too is appreciated. Do you get use to it?
Mark
I'm sorry to be the bearer of bad news. If you tend to trade frequently, a 3 year lease is always a better idea. With that, you are never more than 36 months away from being able to walk away, no matter what happens to the market.
What recourse do we have? We are going to exercise the lemon law after our October 16 appointment if they don't fix it. We are considering getting a lawyer.
Anyone have any similar problems?
Any ideas on how to proceed from here?
By the way, I think the rear end of the 2002 camry looks like the rear end of a 92 Ford Tempo.
Since this is our first Camry, I wanted to learn if this is "normal" for the automatic transmission. It's not a major issue, but seems inconsistent with the superb performance and fine quality of an excellent automobile.
If the dealer won't cooperate, can you try another Toyota dealer or the tire dealer for your brand of tires?
I wouldn't be surprised if your car came with General tires -- these seem prone to this shortcoming.
If you love the car and want a quick fix, get a set of Michelin X-Ones or MXV4s; this will cost money, but they will be round and straight. If you want Toyota to solve the problem, you must first get a good diagnosis, and I would start with a tire guy that handles the brand on your car. Start by checking for runout [roundness and wobble]...I will wager one or more are not right.
I wouldn't want hubcaps on a car retailing for almost/more than $25k.
-RAVvie4me
Parump
Thanks for the 2002 Se update - I too live in CT and am looking for what you bought for my Mother-in-Law.
Would you mind sharing your pricing and dealership where you bought?
I am new to this forum and looking for help.
I live in the DC area and am looking to buy the new 2002 camery (4 door. NO v6 engine, just regular) and was wondering if others had recommedations of good dealers and ones to stay away from.
Want the following options.
ABS
Z2 Packages (this the alarm package)
Package 2 (this is the keyless entry etc package)
So far i have only gone to 1 dealer and the best they could do was 21300. Ideally 20800 would be something im looking for. Can i get this price??? what have other paid???
thanks for all your help
signed a novice to car buying
The defroster helps, but it should not have to be used so much. I am wondering if there is a problem in the ventilation system or something related.
Any information would be appreciated.
Even though I'm in the US, I downloaded the Camry brochure off the Toyota Canada website and noticed in a few photos that the XLE can be had with foglights. Is that true? I don't think that we can get foglights for the XLE here in the US, only on the SE.
-RAVvie4me
So that's why the Toyota website lists the same price for LE V6 with and without alloy! I thought it was a typo.
Do you know of any other changes to the LE V6 specs? It seems odd that the LE V6 apparently has zero factory option available. I was hoping they would offer a package with leather and/or the JBL stereo, and/or traction control, side airbag/curtain. Looks like Toyota is using the LE almost as a loss leader and then "force" people to go for the high-end models to get the good stuff.
Can't see why there should be any difference for the Canadian market.
-RAVvie4me
canadiancl: I agree with being shortchanged on options in Canada. The LE V6 can't even be had until Nov/ Dec throughout the whole country! I'm waiting til Dec for my red LE V6 to come in. They dealers were trying to upsell me to a SE V6 or downgrade to a 4cyl, which I didn't want. The SE V6 is nice, but I don't think the cosmetic additions is worth an extra few grand and the LE V6 is adequately equipped. I don't believe there are any other changes to the LE V6, but I've heard later on in the year, adjustable pedal extension (???) will be added. Only really helps shorter people (like me), but the height adjustment should be fine.
I'm jealous of all you people who got to negotiate. In AB, we have "Access Toyota" which is a standard price everybody pays. The upside is I get the exact prices off the website, but the discount is ~1% off only. Sure, you save time instead of haggling, but you pay for it anyhow.
Is that blinky security light the little light located to the right of the heater control? Is that light operational even for cars with the standard keyless entry but no security alarm added on? Is it accompanied by a "beep" everytime you lock and unlock?
(I know I should actually go visit a dealer to see for myself, but I've been really busy lately. Hope you don't mind answering all these questions
In recirculate mode, with the AC going, the AC will condense out moisture from inside the car and dump in down the drain outside the car. This will greatly reduce the moisture inside the car.
If you are bringing in 'outside' air, the AC is continuing to fight the moisture coming into the car from outside.
