Visitor Agreement.
I have a rattle around the right rear door panel.
When I go over bumps the driver's seat belt makes a "clicking noise" when it is buckled.
The transmission "shudders" between 40 and 50 mph.
I know about the fix for the transmission: the dealer needs to reflash the computer.
Don't get me wrong, I love the car. I only have minor complaints.
Has anyone else experienced the same problems with their 2002 Camry?
P.S. down in our region SE4 cyl are available, with the auto or standard transmission.
Mackabee
And there is no extra charge for Silver. However if it is a popular colour (and I think it is, along with the Phantom Grey), then you may see dealers holding out for more.
Good luck!
Mackabee
Mackabee
Granted, more luxury items in the ES300, but is it really worth the extra $8K-$10K based on the discounts. Heard ES300's are going out close to MSRP.
I understand this reasoning, but do not agree it is right for the v6 camry. The v6 camry is competing with other mid-size/large v6's, both domestics and imports. At the very least, issues such as driveability and fuel economy should be at par or better than the competition. Certainly, the new vvti 4cylinder I think is one of the best 4 cylinders I have ever driven, the v6 should be one of the best too.
Perhaps the vvti v6 needs to be in the camry and the ES300, Sienna, Avalon need something even better. A near flat torque curve is one thing that makes v6's fun to drive, and low end torque starting at 170lbft does not measure up in my view. Still, with the promise of reliability, I think the v6 would be a good choice, but then so would the 4cylinder.
To canadiancl...engineer.
Even the Solara, a spory car, needs more kick the the tired V6.
Forgot to mention, my camry gets at best 27 mpg highway, the Buick gets around 30-31 easily. Tranny has a lot to do with that but still! Current Camry's are about the same
NOW MAJOR DIFFERENCES:
Toyota V6 Advatages over 3.8 from GM
- Refined, Noise levels, Smoother These qualities are way too imp for Toyota buyers...!
- Efficient Doesn't need 3.8Liters of displacement to produce 200hp !
Yes they could have given 220HP Highlander Engine in Camry but then it needs a retrofit to Avalon & ES300 too !!
Honda is even smarter I guess giving 200HP with REGULAR FUEL !! Now they have upped the Odyssey to 240HP on Regulatr Fuel. Regular Fuel is like getting 5mpg better than the premium !!!
Open Throttle "
Torque ratings are in lb-ft, measured on a dyno for a given load and calculated. I should hope they are comparable between engines for different rpms or we are being misled and they should be in lb-ft per liter for a given rpm.
If you are sure, could you post a reference showing that torque from a 3.8 or 4 is less or inferior than torque from a 3.0 just because of the engine displacement? It would help me in my comparisons.
Regarding displacement, I am not sure why this should be a conceren if the EPA city/hwy fuel economy for a 3.8 in a heavier/larger vehicle is superior to the 3.0v6. What does it matter what the displacement is, if the fuel consumption is better in EPA and road tests and so is performance (0-60 tests).
Again, I am not saying that GM3.8 is better and I am not specifically comparing them either. I am just comparison shopping for a car and looking at all the measurements and units for maxima, GM's, Honda, Toyota etc ...please keep that in mind. If I can't compare EPA and torque/hp curves between cars, then why are they even quoted.
And, as a consumer I don't care about displacement of an engine. I care about maintenance costs,fuel mileage and power.
But I did find a good mechanic just up the street from me in the process, who just finished checking out an '87 Accord for me (compression test and everything ;-) ), and so I was at least able to put some of the advice to good use. Thanks again.
Laura
1. Overall, the car drives beautifully! Very solid handling, quiet, comfortable. The 4-cylinder engine is sufficiently peppy for my driving; it accelerates much better than my old 89 Camry four-banger, especially at lower speeds. It is smooth and quiet enough that it is not hard to easily go past my intended speed. The quietness is confirmed by the lack of my turning the stereo up much higher when going from city streets to the freeway. In my old Camry, the volume would need to be much louder to compensate for road noise! The four makes a little noise when pushed hard, but it's not very noticeable.
2. Quality control seems good, though not perfect. Alignment is slightly off. The rear sun shade rattles when retracted; I may add a little rubber spacer to help that out. I just noticed an intermittent rattle in the driver's door yesterday. I'm a little surprised at these minor faults. Everything else seems solid; controls work well, etc.
3. Comfort of the seats seems fine. MUCH improved over the last generation of Camrys. Rear seat room is terrific, as is headroom. The trunk is huge, and I thought my 89 had a large one.
4. Tires vary; my sales rep. said he had seen several different manufacturers on his recent shipments. I have the Michelin Energy MXV4+, which grips well and is a very smooth-riding tire.
5. The JBL sound system has excellent sound, though it is perhaps a bit bass-heavy (can be adjusted, of course). Even my teenager with his heavy rock CDs commented on this! However, the 6-disc changer is a bit noisy, and it had some trouble handling a CD that my other players handled fine. I don't know if this is an exception or rather indicates a tempermental CD player. The controls looked like they were mounted too high, but I haven't found that to be the case in actual use.
Automatic climate control works flawlessly.
6. Someone mentioned the floor mats. I have a stone gray interior and was hoping for darker mats. Instead, they are a bit lighter than the carpet and will probably show dirt much quicker. I was told there are no darker ones available--is this true for those of you with charcoal interiors?
7. My brochure said that the XLE 4 comes with rear drum brakes, but I've got discs on all four wheels. The front discs are smooth, but the rear ones have substantial scoring in them when new--is this typical? I saw another posting that mentioned this and haven't asked the dealer yet.
8. Finally, I read earlier comments about bad experiences ordering from the factory. I conducted all my business via e-mail with the fleet manager here (Cavender in San Antonio), ordered exactly the car I wanted, and paid neither distributor profit add-ons or even MSRP (paid about $400 over invoice). I added only the CD changer, side airbags, alloy wheels, and mud guards/mats. The saleman told me that was fine, though the side airbags were not common in our region and would make the order take longer. I waited about 6 weeks but got exactly what I wanted. Unlike the floor salemen at some other dealers, I had a straightforward, pleasant experience with buying this way. I was given a VIN and progress on my order frequently after 2 or 3 weeks. Of course, I had to do without the "paint lusterizer" or whatever they call their $200 wax job. :-)
Mackabee
Is it true that Toyota is discontinuing the Avalon XLS model and will only manufacture the XL model?
A saleswoman at New England's largest Toyota dealership says that they have stopped ordering the Avalon XLS because it does not sell, but more importantly, its sales have been canibalized by the NEW CAMRY.
The dealership had over 60 XL models on its lot but ZERO XLS'.
It is a really interesting scenario though, I wonder in which direction Toyota is headed with the Avalon.... Sales jumped to their highest levels ever with the 2000 redesign, so it is peculiar for them to stab that line in the back. I think the Camry is an unlikely flagship for the line, so I don't think Toyota will kill the Avalon. Perhaps when its mid-cycle freshening comes for 2003 we'll see a large power upgrade, perhaps even the 3.5L rumored to be in the next Sienna and RX300? All speculation, I realize, but its anyone's guess, and that's mine.
~alpha
Other than that, is it worth spending about $1500 extra for an SE model instead of an LE model?
Thanks for your help.
I guess I've narrowed down my choices to a Camry, Solara, or Chrysler Sebring. Why the Sebring? Because I find I can get tons of options (including a V6) for about the same price. The 4-cylinder of the Camry and the Solara are appealing because they're less expensive to maintain, provide ample power for the average driver, and are more fuel efficient. It's a bit of a winning formula really... big car, but with powerful 4-cylinder engine.
Thanks, Kelly
Mackabee
I don't notice it much if i gradually increase speed.
I don't have this prob with my 96 or 00' camrys.If anyone has any info Plz let me know
The Boch Toyota salesperson said that the Avalon XL model was selling well, but not the XLS. She insists that her dealership had stopped ordering the XLS model because Toyota was discontinuing the XLS trim line. As one poster noted she was probably trying to push the XL since she had no XLS on the lot anyway.
I think her explanation is all wet since the XLS rather than the XL model differentiates itself better from the Camry. However, a Camry V-6, XLE with navigation system and VSC is a formidable competitor to the Avalon, leaving one to conclude that the Avalon has become irrelevant or superfluous.
On startup the idle is high, perhaps around 1500 rpm and drops back as it warms up. If I wait approximately a minute or a little longer then the rpm drops back to around 1200 rpm and the harshness is usually not noticeable. I usually like to let a car warm up for a few minutes but it seems some folks think that is not good for the engine ... i.e. a minute should be enough to sit idle. Oh the other hand that initial engagement going into drive sounds like it could be hard on the transmission.
My LE V6 only has around 650 miles still and I don't know if this clears up after the breakin period.
If there has been prior discussion ... are there any pointers to those messages?
