The writer at the dealer said it's the transmission and it's normal but I'm not so sure. I'm supposed to have a meet with a regional rep. whenever they get around to it. In the mean time this one time morning jerk into gear cannot be good for the driveline. Also it seems to be getting more noticeable. The car is an '02 LE V6.
Here are my other observations on this issue. When pulling the cars out for a test drive, I noticed that If I was in a hurry and shifted rapidly, the clunk was more prevelant. If I took my time, waited until I was at a full stop and made a deliberate shift through neutral, the clunk would not exist. It also didn't happen after the first time out of reverse.
None of this is to say that you don't have an issue. Like I said, I am not a mechanic and I don't know if the clunk I felt is the same one you have described.
Can anyone confirm my assertion for carrelman?
~alpha
Ken
Hope this helps.
Ken
I think Toyota made a mistake by not explaining how the auto climate control works in the owners manual.
SUBJECT: 2003 Camry V6 Price Announcement
Toyota Motor Sales is pleased to announce pricing for Camry with the new V6 engine,
which begins production on January 20th.
The new V6 incorporates Variable Valve Timing with intelligence (VVT-i) for improved
power and torque without any reduction in fuel economy. The engine produces 210
horsepower @ 5,800 rpm and 220 lb.-ft. of torque @ 4,400 rpm, significant
improvements compared to the old engine’s 192 horsepower and 209 lb.-ft. The new
engine utilizes an Electronic Throttle Control System (ETCS-i) and Acoustic Control
Induction System (ACIS) for superior throttle control, drivability and NVH. Camry V6
models also receive a new 5-speed automatic transmission for enhanced performance
and refinement.
Prices for the new V6 models will be the same as the models that they replace in the
Camry line-up:
LE V6 w/ VVT-i & 5-speed automatic $22,260
SE V6 w/ VVT-i & 5-speed automatic $23,265
XLE V6 w/ VVT-i & 5-speed automatic $25,405
Hope this helps.
Ken
I'm curious why they didn't include them in the 2003 model initially? Can they even do that, adding new features to the current model? Is there anything I can do, because I'm totally shocked how Toyota can do this...
&nbs- p; &n- bsp; : )
&nbs- p; &n- bsp; Mackabee
Another way they are consoled is the fact that the Supra actually appreciated in value. In 1998, you could buy a turbo model with the 6 speed for $38000. Today, if you kept it in great shape and didn't stick on the miles, you can get $44000 for it.
As I have said before though, this Camry, more so than any other I remember, has undergone more mid-year equipment/features changes than any other.
Using the XLE V6 as an example- had you bought one of the first batches of 2002 production, purchasing one now means you get foglights, 6 disc in dash CD changer, moonroof, 5sp auto and VVTi engine- at base price. Clearly, Toyota is feeling the pressure from the kick butt (but butt ugly) new Accord.
~alpha
The changes on V6 make me to consider to purchasing V6 instead of 4 cylinder engine for next few months. If they kept the old engine (192HP), I would take 4 cylinder due to horsepower vs weight ratio, premium gas vs regular gas ...
What do they list for a cherry '69 Camaro?
The reason why it is bothering me so much is that I've been contacting Toyota for the past weeks. I've noticed that the shifting is not at all smooth, compared to my old '94 V6. The strange thing is that shifting from 2 to 3 is only smooth when the car is COLD, when up to temp, there is a slight jerk. Luckily, I just got an email from Toyota stating that I will be contacted by their regional office soon, after I told them that the dealer is not helpful who tells me it is normal.
What should I expect coming out of this situation? My wife even suggested that we trade it in for the auto 5-speed. I'm not crazy about the new engine, but a smoother transmission is desired.
I had emailed NHTSA a while ago asking why there was a repeat of the test -- NHTSA will usually carryover the previous year's results if there is no design change that may affect the test scores.
NHTSA eventually emailed me back and says that indeed, the 2003 Camry received some kind of change and thus the 2002 results were not carried over, and the 2003 re-tested.
NHTSA: "Yes, the 2003 Camry has under gone some design changes"
In my opinion, I don't think the 2002 test was anomalous, and Toyota made a subtle change to improve the driver's side-impact score.
This type of change is not unprecedented, even in the middle of a model year. When the IIHS tested the new 2003 Corolla, it scored "Good" but not "Best Pick." IIHS protocol permits the manufacturer to make a change and request a re-test before any test result is released. This is unlike NHTSA, which will release the test result immediately and re-test later if a design change is made. So after requesting an IIHS-retest, Toyota added more padding in the middle of the model year and when the Corolla was re-tested, it then achieved the "Best Pick" score. Thus pre-January-2003 Corollas are different than January-2003-and-after Corollas.
~alpha
~alpha
"The January production Camry available at dealerships by mid-March will have the same engine but with an added induction system. The engine will now have the VVT-i technology seen currently in the Avalon.
We are continually improving our product and may offer new features during the production cycle."
There is no mention of the 5-speed?
Well, there is no way to know all this with certainty, one can only take the "evidence" and patterns at hand and interpret from there.
I'll answer your question with this question. Do you really think that Toyota would admit that they didn't design/execute the 2002 Camry (without side airbags) to be up-to-snuff in side impacts? Isn't it far easier for Toyota to claim anomalous results while making a small change to the 2003 to get the three stars (and it doesn't require a full redesign to get that far)?
It wouldn't/didn't require a big design change to get the vehicle from two stars to three stars. Sure it's tougher than adding more pads, but it's not a massive effort, especially during a model year changeover.
So I trust NHTSA more than Toyota in this case. As the IIHS example demonstrates and the NHTSA tests further prove, Toyota safety engineering, like many other manufacturers, doesn't necessarily get all things right the first time. They simply missed on the 2002 Camry's without side airbags, just like they missed very slightly on the 2003 Corolla and made a smaller design change. At least to their credit they made actual design changes rather than complaining about the "real world" applicability of the test results (I hate it when some other car companies brag "5 stars!" in an ad, but then turn around and scream "it's not real world" when one of their other vehicles doesn't do well!).
Now, this is not to say that Toyotas are not safe. In general their crash performance is very good, and Toyota has been great in applying VSC and Brake Assist to many of its vehicles.
Sure, cars today are much safer than they were several years ago. But it still doesn't excuse a 2002 vehicle getting a 2-star side impact score.
Any thoughts.....
Mackabee
I recommend/insist that my Camry customers get them as well as the mudguards.
If nobody at the dealership you go to knows what they are, have them refer to the "2003 Accessories Sales Guide"
Good Luck !!!
Steve
No problems with the moisture/snow sitting on the mats and not evaporating or something like that...?
As with carpetted mats, please make sure the carpet underneath is clean before you put mats on top.
A good alternative to the Toyota OEM mats are the popular WeatherTech mats. They are usually more heavy-duty than OEM mats, and come in black, grey, and tan. Not sure if they're cheaper than the OEM mats but they can be bought separately for the fronts or the rears as well as in a set. Sometimes some cutting is necessarily but they are designed so that trimming is simple.
Second did anyone notice how the camry got the best handeling numbers while they said that mazda felt like it conered better, while Camry was much better over broken pavement??? So stupid. They are so pushing mazda 6. So I guess Camry has superior suspension it goes better over broken pavement AND it de-facto handeles better. It is also very quiet.
I know that styling is subjective and I give it to Mazda, they did the best job, but the Accord was just so plain it is laughable. It lookes like Kia rio from the front, and the back it is a bad imitation of 97-01 camry. I give them that it is a good car, but it is so not better than Camry.
I guess the magazine goes with the newest cars that come out. Possibly because companies put a lot of money in hte ad. business, so the magtazines that get the money are biased at that time. I think I am objective when I say that camry is the best car.
Question: The Camry gets better gas milage than the Fords. I have however noticed in the snow the car does not seam to hug the road as much. Is this because the Camry is perhaps a lighter car...better mileage but not as secure in the snow. I did not not opt for the anti-lock brakes because I did not see it coupled with traction control on the LE...did I miss something?
(and follow owners, don't blame the junky tires that now come with the Camry...the Fords always had the same junk too)
Anyone have any experience with the DVD Navigation system? How do you like it? Does it have a voice response similar to what the Magellan system in Hertz cars has? Overall, is it worth the additional price?
Also, how often do you have to upgrade the Mapping software and what does that cost?
