Lexus ES 300/ES 330
Well, one of my tires blew out---completely. And on the freeway. and no, i did not run over anything that could possibly have caused that horrendous event.
JM
However, you could also be annoyed by the shifting of the ES (see posts under ES Transmission complaints).
Bottom line, you need to drive both cars to see which is right for you.
Also, the front suspension makes clunking noises when going over bumps...especially when it is colder...she said it has always done that since new... Concerns me... Thanks for the input.
Clunking/squeaking noise when going over bumps at low speeds in cold weather is a common complaint. It can be annoying, but was told it wasn't a safety issue. Replacing the bushings is supposed to do the trick, if you're willing to pay the $$$ to suppress a noise that will eventually return.
My dealer mentioned one will be available and will be shown at next week's Chicago Auto Show. Supposedly it will be offered in Graphite Gray, Thundercloud or Black with either a Light Charcoal or Black interior. The only other differences are a different wheel design (still 16") and Black Bird's Eye Maple wood trim.
Anyway, the ES will get some cosmetic changes this fall for the 2005 model year. These will include a subtle restyling of the front and back ends, along with some minor equipment changes. To see past examples of similar changes, look at what Lexus did to the ES in 1995 (vs 1994) and in 2000 (vs 1999). Or, for a more recent look at mid-cycle changes, look at what Lexus did to the LS 430 for 2004 vs 2003. At this time nobody knows what the changes will be.
The car will be completely redone in fall 2006 as a 2007 model. At that point the car will be designed by the all-new, Lexus-exclusive team in Japan and will not share a platform or parts with Toyota as is the case now. The car will follow Lexus' new styling trend shown on the new GS (again, to separate Lexus from Toyota) currently at the Chicago Auto Show and going on sale in January 2005. Nobody knows what the next ES will look like, but you can almost be sure AWD will either be an option or standard (as it will for all future Lexus cars).
When the driver and passenger temperatures are set the same, the driver vents blow much colder than the passenger side. Also, I need to have the temperature at 78 degrees to make the interior comfortable when it is 60 degrees outside. The system intended to be sophisticated is very uneven. Lexus said they are aware of the problem but have no plans for a fix.
I have noticed exactly the same behaviour in the beginning (driver side cold air, passenger side warm) and needed to set the temperature somewhat high.
Did Lexus say why that is happening and why they don't want to fix it?
Have you actually driven both 2002+ models?
On SportDesign to come, which has only wheel rim and a logo diff., does seem gimmicky to me. Maybe Lexus finally realizes that every competitor of ES is more sporty. Won't surprise me the 2006/7 model goes with that trend. That said, current ES is more luxy than all the other near-luxiers.
they wore out a set of tires in less than 20k miles. Cost to replace is $1,000 plus tires.
is this a common replacement on a car driven very conservatively?
I did and wow, what a difference. Silence.
Two things I was told.
1. There is a computer programming fix to try that they will do. Just ask.
2. I was also told that the tranny will adjust itself when new, based on the driving style of the driver. They said that this was especially true during the first 200 miles.
Hope this helps.
My 2004 has no such noise like you describe.
The few that do are reporting prices less than the ES330, although the discounts from dealers don't seem to be as high for the TL.
In summary, the TL is less expensive, but they are not going for discounts from MSRP as ES330s are.
http://money.cnn.com/2004/03/09/news/international/toyota_probe.r- eut/index.htm
Has anyone experienced this?
BTW, that Toyota probe must've vindicated some ES tranny problem crusaders used to be on the tranny board. I've not experineced the like behaviors on my 300 but I've seen many posting it in the past all the way to 330 actually.
HK2LA has experienced it. Not sure if she comes around often enough to see the link.
In that case, the 2005-2006 models would have the minor restyling and then the 2007 would the completely new design not shared with the Camry.
