And it's not mac nuts. You add moth balls to up the octane.
Sorry to see the problems are still occurring, but I thought I would add some info. My 2000 LS had many of the common problems and a few unique ones, like not starting intermittently due to some fuel regulator.
Anyway, I had the ISS changed, the steering rack changed and a new and improved reinforced (2001 I was told) cradle installed. Upon return, it was only marginally better and proceeded to be just a terrible after a few thousand miles. The car was repurchased by Chevy and I moved on. It was a hassle, definitely not an easy process, but worth it. Can't tell you how happy I was when my wife picked me up and all I had left of the Impala was license plates and a check. I miss the car, but not the problems, trips to the dealer, loaner cars, etc.
My point is, I believe there still is a problem that had yet to be remedied. So far, one was traded due to frustrations, one repurchased and two still unrepaired....
It seems to accur when I accelerate above 3k RPM's. I was wondering if any of you have developed this since the Impala has the same drivetrain.
Just too add my two cents about ISS/Cradle.
Ive had two cradles replaced (both being the redesigned 2001 version) and the ISS replaced.
After each fix the problem reaccured after a few thousand miles. The front end clinking/clunking
still occurs on my car but it is less severe than before. I imagine that I might not even notice it
if I was not listening for it. I like the Overall car but I am getting tired of noises.
Speaking of noises, I much rather have the cradle problem with the "clunk" noise, then sitting in a car full of squeeks and rattles from the dashboard. My Impala does not have this problem (thank god). Unfortunately for my previous co-worker who owns an M3, and my friend who owns a 540, and the Accounting lady who owns an M5, they all exhibited these spueeks and rattles from the interior. That drove me NUTS! Quite pathetic for a "luxury sedan".
As of today, I love my Impala very much. I can't say the same when I had my previous Accord. Only problem I have on the Impala is engine hestitation when going 5-10 mph (very rare occasions). Anyhow, good to hear that this is a software fix for the PCM.
I'm enjoying my Impala so much that I'm averaging less than 20 mpg. LOL That means I'm taking full advantage of the Impala's quick acceleration by speeding 0-60 at the light. zoom zoom
(Or is it "Keep America Rolling"?)
I'm bringing the car in sometime this week for the service mgr to take a look. I know I will get some negative attitude. That's when I'll send a note directly to Chevy.
All I know is that when I got the car, the seat didn't have any play in it and I "baby" my cars.
http://www.policevehicle.com/2001impala.pdf
I'm from NYC, too. Small world. What are the chances of two people from the same small northeastern town meeting on the internet? Amazing.
I have seen photos of the cradle from a '01 police cruser and from what I can tell, it looks like the consumer '01 cradle. I don't know what the '00 police cradle looked like, so I can't say that the '00 consumer one was the same as the '00 police fleet vehicle.
-mike
It would be interesting to know if any of the others who have had the chuggle problem cured through software updates have had similar mileage increasess.
However, my idle is still uneven. It sometimes fluctuates 100-250 RPMs when sitting at idle. It also sometimes idles roughly, causing vibration or shaking. It was worse before the update, but it still does it.
The seat adjusters which were called "Vertical adjusters" were part number 16607860 &16807200 but I'm telling you now, it doesn't work, at least not for the long haul.
I have what sounds like a ping when the engine is cold and under light accelleration. It seems to go away for the most part after 10 minutes or so of driving.
Changing fuels has no effect on the noise.
Comments?
-Gus
It sounds like possible valve noise. Check your oil level. It's also possible that you're using the wrong viscosity (too thick). If that's the case, it takes until the engine warms up for the oil to properly coat.
If both of those are OK, you may want to bring it in for an oil pressure test. Of course, they'll most likely say "They all do that" or "That's normal".
But, on the bright side, you'll have the fun of being late for work after you drop the car off, having your wife or friend drive you to work and back to the dealer later, and telling your boss you have to leave early after arriving late.
(Yeah. One of those styrofoam rocks they use in the movies. It looks real solid on the outside.)
I don't think any other make/model topic has the same level of quality/quantity as this one.
I will miss the car, somewhat. :-(
I won't miss the service at all. :-)
I thought I heard folks could get updates through Onstar. Anyone else heard that?
K-cid
As for tires, I replaced the Goodyears after 3K miles. I couldn't take the road noise or how easily they squealed on turns. I replaced 'em with Yokohama AVS dB's. Ultra quiet AND high performance. They don't have a very long treadlife, though.
I also have Michelins on my other car. They aren't nearly as quite. And, as a rule, Michelins are way more expensive than Yokos. But, Michelin has those really cute commercials with the baby. I like them. ;-)
A 460 rating on your tire only means it has a longer life than another Firestone with a lesser rating. For instance, a Yokohama or Bridgestone with a rating of 340 may very well have longer treadlife than those Firestones. Conversely, those same brands with a rating of 600, may actually have a shorter treadlife than yours. OTOH, those 600 rated tires would last almost twice as long as those 340 rated tires of the same brand, though.
I'm having Michelin X-ONEs put on my wife's Camry today and the specs on them look great.
Tread rating is 700 and these are suposedly 80,000 mile tires.
Anyone else have Michelin X-ONEs on their IMPALA or any make car?
X-ONES are 3 ply tread in TOYOTA size. They jump to 4 ply on IMPALA size.
Set of 4 X-ONEs for an IMPALA would be about $580. They were $446 for the Camry.
Cabello- Are your Eagle GAs showing wear or are you just looking for a better or quieter ride?
