Toyota Tacoma: Problems & Solutions
You have to buy a new one fuel filter (about $20), you can't clean the old one out and reuse it. You don't have to drain your fuel tank when you change your fuel filter. Your best bet is to put down something like an oil drip pan and have rags ready so when the connections are loosened the gasoline will drip into the pan, and once the fuel filter is disconnected that will be full of fuel as well. Overall you can expect about a couple cups of gas to come out of the lines and filter.
Easiest way to change the filter is to loosen the two nut couplings on each side of the filter. Then take out the screw in the butterfly connection (the metal object that goes around the actual filter to hold it in place. Then disconnect the fuel line brackets that hold the line in place on each side of the filter. This way you can munipulate the fuel lines to disconnect then from the fittings that connect it to the fuel filter. Then fully disconnect the fuel line from the filter and wrestle with them to get them out of the filter. They were a little tough for me so I would probably disconnect the fuel line from more than just one bracket on either side to give the fuel line more play, this should ease getting the lines in and out of the fuel filter. Make sure when putting in the new filter to pay attention to which way you put it in, it says on the actual filter which side is the intake side, the side that goes to the rear of the vehicle. Ther other hard time I had was getting the bolt back in the butterfly connection because it so short and the connection is under pressure. I advise that you use a vise grips to clamp the connection together to leave your hands free to deal with the getting the bolt in. Other than it's a piece of cake.
Again I advise cleaning out your throttle body, it's easy and made the most difference for me when my truck was acting up.
Good Luck and let me know how it goes.
Bill
N.Y.
You said you changed the plugs. Make sure all of them are working. Pull one plug wire at a time.
If you don't know someone with a reader, many autoparts shops have them and will (if you can wait til there's nobody waiting for help at the counter) plug it in to your vehicle and read you the codes.
Alternatively, the OBDII readers can be had for about $100.
The downside is that the systems are again in transition (initial systems went to OBDI, then OBDII in 1996 and newer, now moving to OBDII CAN), so a simple OBDII may not work with 2005 and newer vehicles (as I just found out with my 2005 Taco).
Good luck
However, the water from the exhaust may be. We burn hydrocarbon fuels. Ideally, the carbon combines with oxygen to make CO2, the hydrogen with oxygen to make H2O (water). In a system at full operating temperature under moderate conditions, these exit as gases (carbon dioxide and water vapor- steam). However, when the exhaust system is cold, some of the water vapor will condense in the exhaust and may make it's way out the exhaust pipe before the system warms enough for it to evaporate again.
In warm weather, with the system good and warmed up, you should not have liquid water coming from the exhaust.
Lost coolant could be from a number of external leaks that may not be large enough to show on the garage floor. Telltale traces of a crusty residue may show up. It is not uncommon to find this at the ends of hoses that weep a little, or around the thermostat housing or water pump, or even at gaskets on the block, intake manifold, etc. Another possibility is leakage in the heater core (heat exchanger in the air handler of your heater). Maybe a small leak in the radiator (look for traces on the fins). And of course, you could have a leaking gasket or warped/cracked head or the like that would allow coolant to enter the engine, either the combustion chamber or the crankcase.
Check you oil level. Do you see it RISING day to day instead of remaining stable or falling? If so, it's likely you have coolant leaking into the crankcase. This needs to be dealt with IMMEDIATELY. With the engine cold, remove the radiator cap. Start the engine, allow it to get to operating temperature. Do you see bubbles (like exhaust) coming out the radiator? (The point is to see if the water jacket is leaking into the combustion chambers. If so, on the power stroke, the higher pressure of the gasses in the cylinder will blow into the water jacket, eventually making their way to the radiator.)
In any event, I would bring it to a dealer if still under warranty.
Any input would be appreciated!
-Tracon
I recently bought a 2005 Toyota Tacoma TRD V6 6 speed. I am also having problems with the transfer case. It started with making a grinding noise going into 4 high and would not go into 4 low at all. 4 low light would blink and buzzer would sound, but it would not engage. After four trips to the dealer--the actuator and the transfer case have been replaced. It still will not go into 4 low. Just wondering what you have found out with this similar problem. Have other owners of the 2005 Tacoma ran the truck in 4 low????Any problems???
You had replied about my heat and coolant on my Tacoma.I am having some major issues with this truck.Could you please send me your e-mail address.I would really like to talk to you.I am not understanding much about the heat exchanger.But I do have some very important questions that maybe you could help me with.I would appreciate any advice you can give me.
gdwtch1969@aol.com
Sincerely,
Mississippi Twain
kcram - Pickups Host
I had a friend who runs an Oil change place scan the engine even though no check engine light had come on... just in case (obviously there was nothing there). I'm to the point where I'd gladly take it in, but how would they diagnose it? Now I need a battery 'cause I've drained this one trying to start it when the engine is hot. Not sure what the next course of action is. If you've had any luck, let me know and I'll do the same if I figure mine out.
Dad of 4 Boys!
Thanks Again,
Dad of 4 Boys!
I'm new here and need some older heads advice about my new Tachoma. Its a 4X2 Double Cab Prerunner SR5 model. Its is Impulse Red and my wife loves it. I want to change a few things and dont know how.:
1.Can you rewire the fog lights so the switch controls them intead of them only coming on with head lights??
2. Do you absolutley have to use premium fuel or can you mix 89/92 occasionally??
3. I am ordering a Leer Cap for the bed cover and wonder if anyone else has tried this company or thieir products??
I'm also interseted in after market exhaust products for this truck. Has anyone put dual exahusts on one of these trucks and what kind, how did it work, etc.
Appreciate all advice as I want a nice looking and nice sounding truck but not exotic!
I
You can use 87 octane, just with slightly less performance. (5-10hp difference)
Hope this helps.
Ken
well, this sound /noise could come from the antenna, mud flaps,wipers or windshield gasket but this truck is not that aerodynamic either.
fig.
I live in Florida and it is quite warm and humid right now.
The V6 is not a 2.4litre
