Toyota Tacoma: Problems & Solutions
Please let me know how you ended up resolving your valve issue. Anything that you wished you had done different?
Thank you. Fred
Dumb question -- Can I drive like that anyway until I get it fixed? What's the worst that could happen?
I was driving it last week and got a massive oil leak from one of the seals of the rack and pinion got it towed to the dealer and they replaced it on warranty told me it was a first time they saw that. Ever noticed that the original power steering fluid from factory is not dextron III . It’s a clear oil.
Dont see any dipstick on my 06 v6. can anybody help me?
I work on marine engines and for what I had seen,
for the out board engine steering some people will use regular red hydra/ different
red= a few $$ a quart
clear seastar hydra= 20.00 a quart.
maybe factory invest a lil more on high end oils thinking the part will not fail, and oil will be good for many years.
dealers need to save $$.
Best of luck to you.
T
We are doing some reorganization of topics here, in an effort to make things a little more focused and easier to follow. For those of you who regularly read this discussion, we invite you to check out the new focused discussions here at the Toyota Tacoma Group. We would like you to use these discussions first, based on your particular question or comment, and use this only if you genuinely can't find something appropriate - or just drop me an email if you think a new discussion is needed.
kcram - Pickups Host
http://aaronlinsdau.com/gear/articles/ipod2car.html
Question - My brake lights do not work now. Is the problem related? All fuses are fine, parking lights work, running lights, back up lights, all are fine, just no lights when I hit the brakes. I can live with the manual shifting, but can I get my brake lights back??
jimmyg4
I haven't had this problem on my Taco, but I had a Ford a few years back with the same problem and that's what it ended up being.
THANKS
Let me know if you find a better solution.
I took the truck in yesterday to have the catalytic converter put on and the problem turned out to be a simple clamp on the exhaust. My dealer is an idiot.
I originally thought that was a typo but it was not. When I poured 4.8qt of oil the dip stick end was barely touching the oil. Although it's still hard to read the level on the stick, 5.5-5.7qts of oil seems to be the right amount for my truck.
Does anyone know why that is? Shouldn't the V6 take more oil...
-M
http://www.TacomaWorld.com
check my comment # 2003 here.
It's a slip joint causing the problem, easy fix, just keep greasing
