I hoping that I don't get a flat, but that is how I plan to use this tire. It is a valid concern about tire size however, someone here had a problem with the LSD and TOD with one tire being larger that the other, causing the computer to act funny.
I bit the bullet and bought an alloy wheel for the spare...$269 (ouch!) from St. Charles Isuzu, so the 5-wheel rotation is easy.
-mike
There are sensors on each drive-shaft that measure the speed of each drive-shaft, if your front tires are smaller than the rear, the TOD system will detect the smaller front tires as slipping and put more power to the rear to try to compensate. The problem I had was that I had an-irreparable flat @ 15K miles, and replaced the destroyed tire, with a tire from my old rodeo that I had. It was a Bridgestone Dueler 684, same tread, size, etc. It also had about 20K miles on it and was bought back in '98. My TOD started to whine like crazy especially noticeable in the 30mph range. Also had problems coming out of 4wd Lo into TOD and 2wd. I thought there was a problem with the T-case, but my dealer expertly found that the tire was a different size than the other's (must have measured them all while diagnosing the problem) He put my spare tire on (which was new, the others were 15K) and the noise was gone, and has been gone for 10K miles.
You should rotate your tires every 5K-7K at most on AWD vehicles, and replace all 4 tires or 5 tires at the same time, because of manufacturing differences which is what we came up with as the problem for my 3 year old Dueller v. the newer ones that came on the trooper.
A lot of people will say "that's expensive to replace all 4 at the same time" unfortunately if you want to play, you need to pay. (but SB knew that already )
-mike
Aggressive tread, S rated (106), white outline lettering
http://www.toyo.com/tires/tire_lines/lt_truck/opat.htmlToyo
Toyo makes and excellent tire and has really kept up on the computerized design, manufacturing etc.
A little expensive at Town Fair Tire but with free rotations and damage replacements at no cost except balancing and valves, I think its worth it.
BTW, I would be careful on the Scopion tires, it seems they have changed? their plant to Brazil, and some tires are being sold off now that are made in USA. Anyways with two tire plants, they may not precisely match if they come from one or the other.
Anybody have any thoughts on the white lettering on current model troopers. I haven't seen any like that, but why not go for a new mod!
-mike
Side note, while out there, we went over a lot of hills where the bellie of the trooper was smack against the rock or dirt. A few times I had to muscle my way over them due to my OEM tires. The skid plate is scraped on the TOD unit, but it isn't dented at all. I also have some scrapes on the cross members and a piece of the exhaust pipe as well, but no vital organs were ever in danger of being damaged! Gotta love the troopers.
-mike
Travis
I think I would have at least checked the bolt tightness myself. Granted, over tightening the gasket would be a mistake but if I found a couple of somewhat loose bolts I could solve the problem myself in a few minutes. I would also clean everything off very well and check it in a month. If that works I saved a trip to the dealer and a likely argument about a couple of drips being "normal". If it didn't work I would at least be in a very good position to explain how I know that gasket has to be replaced as it is properly torqued and continues to drip.
-mike
I also wonder are there any filters in this unit that would require seal replacement if replaced as standard maintenance?
I hesitate to tighten anything--without a manual on the torque on those bolts. When I was a teenager I replaced valve cover gaskets once and sheared off a bolt head on a V8 engine and learned a lesson there.
Should you need to pay for a needed alignment I have had good work eventually done by tire shops. However I have had to watch them like a hawk as over the years they have started to set the specs to the wrong model and to a 2wd rather than a 4wd.
As to the bolt tightening I was thinking more in terms of checking the torque to make sure all the bolts were the same. If I found one or two looser than the rest I would probably have just cinched them up to the same torque as the rest. I wouldn't have just automatically tightened all of them. Granted the best way would be to have the factory specs and tighten them to that.
In any event, it sounds like your dealer is going to take care of you.
I wouldn't think there would be any internal filters as I doubt there is a pump requiring one. But you are sure right to think about anything that can be done now as opposed to after the warranty is gone.
Here's an article on all sorts of alignment issues.
http://www.mpt.org/motorweek/goss/20018.shtml
I think what I plan to do is cut a piece of 2x4 to the length I wish to get the height to. Mine measured 12 3/8" at the frame, I'm going to make the board 13" long and give it to the place that I plan on having the Sway-A-Way T-Bars installed to use as a gauge.
Buy the way, the alignment specifications are located in your owners manual in the back. I'm making a copy to give to the tech, just in case!
-mike
My purpose for doing an alignment is to address possible camber changes due to the different ride height. Other than that, my Trooper was tracking straight and true.
I had Sears do the alignment when I had the bigger tires put on, and my Trooper has been pulling to the left ever since. They have put it back on the rack and say "everything is in spec" and have basically thrown up their hands, or blame it on "radial pull", which is a cop-out dating back from when radials were a new thing.
Oh, and they didn't even have to touch the camber, said it was right on. So basically, all they did was screw up what wasn't broken.
I talked to an old-timer who said that you can't rely on a computer to tell you when alignment is good, there is alot more that goes into proper alignment.
So now I'm going to take it to a specialty alignment shop and get it done right...which is what I recommend to any of you. DON'T take it to a shop where they don't know anything more than the computer tells them.
Heck IMHO, given the modest 1" - 1.5" lift when installing OME springs, I really don't think a re-alignment is needed at all!
-mike
When I adjusted mine on our used slightly mis-aligned Trooper I first just measured the height from the ground on the lower ball joint bolt. I then cranked the low side torsion bar to match the high side's ball joint height. The trim height then came out right on spec. The Trooper then tracked somewhat better for the few miles we drove it. We then got larger tires and had a tire shop do an alignment. Heaven only knows if they really checked the trim height. It did come back still set where I had it. We have had absolutely no problems since then. However, my wife reported that the shop tried to first do the alignment to the 2wd specs (I sent her in with the pages from the shop manual just in case). Heaven only knows what problems that would have caused had they actually done the alignment that way.
First I thought only 4wd Troopers were sold here in 1999. That being the case if your alignment shop only shows one setting that should be correct.
I think the problem at out shop was that their software wasn't that precise. I say that because the alignment report we got back had a heading something like "Alignment Specifications Troopers 1997-2001". So if they put in 1999 2wd their computer might take that. Again whether that would have been a problem I don't know. I only know that my wife caught that on their screen and told them to correct it.
When in doubt make them show you how their numbers equal the numbers in the back of the owners manual.
-mike
http://www.edmunds.com/chat/isuzuchat.html
-mike
http://www.tochigi-isuzu.co.jp/bbs/ubs69gw.jpg
Reason I ask is that it looks like I'll be doing my own oil changes. I don't mind too much, but now I'll have the issue of finding somewhere that will accept the old oil. I had an appointment for this past Saturday morning to take it in to the local garage that does all the work on my vehicles. I dropped it off at 8:30 when they opened and was told it would be 60 to 90 minutes. I went back at 11:30 (they close at 12:00) and they hadn't started on it. The counter girl started making a bunch of excuses - which got my curiosity up. I mean, I didn't say anything and she was really laying it on thick. I waited until 11:45 and when they still hadn't even pulled it into a service bay, I told her to forget it. I took my keys and left. The sign out front says "Honesty Is Everything" but I guess that's just for show. I know the garage changed owners not too long ago, and the old owners lived the sign. Looks like the new owners are taking advantage of the garage's reputation. Well, they just lost one 15-year customer.
Sorry for the rant.
Charlie
P.S. The garage is Kimble's in Clinton, Maryland
Jim
-mike
