Perhaps you forgot the number 2 or you mistakened the second i for a 1
Could anyone tell me which one is the right bank?
Also, is Cylinder 2 the middle one on the front row (close to the radiator) or on the back row?
Any help will be greatly appreciated!
Thank you very much in advance!
Any new/redesigned car models may have "defects" no matter how aggressively tested.
My point is "defects" do happen. Best of luck to you!
I got fault code P1320 IGN SPEED which is listed in the Maxima's manual as "Ignition signal primary circuit fault". Since my 1999 Maxima also tested with the fault code P0302, "Cylinder 2 misfire detected" I thought replacing the ignition coil would sure solve the problem.
So I bought an ignition coil (Hanshin) which is exactly the same as the original part number and replaced Cylinder 2 ignition coil. I started the engine but soon I noticed misfiring again. So I hooked up the OBD II scanner and tested again. The reading is the same even after I cleared the codes and retested. The reading also indicated "P1320 Ignition/distributor egine speed input circuit. Received from egine controller address $10."
I was very hopeful that the new ignition coil would fix the problem. Now I'm totally lost. Does anyone know if the code P1320 IGN SPEED means something else than the ignition coil problem? -- I still have an oxygen heater fault problem but I don't see it causing P1320, or will it?
Any tips would be greatly appreciated!
Looks like there's a problem with the ignition module OR it's associated wiring. Remember, scan tools retrieve trouble codes which indicate circuit faults. They can NOT determine if a component has failed. That requires diagnosis of the fault.
I have a '02 Maxima with 17,500 miles on it... I noticed hesitation on my car too! I thought it was just me being over sensitive...but yesterday i was driving on the highway and all of a sudden the "Service Engine Soon" light came on.... i did my business and went home and parked it... Im taking it to the dealer on Monday to get it checked out. I was wondering if u found out anything about ur car's problem. I too have made an appt for the recall... Im getting that done this monday... Could let me know if u have more info to bostonianthug@hotmail.com... Thanks in advance
Thanks in advance !!
Car is only one month old.
Dealer replaced the original player and the new one has the same problem. Just wondering if anyone else is experiencing this with 2004 Maximas.
I was in it today and the CD skipped. It was about 30 degrees. We're in Minnesota, so if it's going to act up when it's cold, we have a problem.
Where did you buy your Maxima? I'm buying one in October and am interested in your experience and what you paid. I know Walser sells everything at 93% of MSRP, so that's a start. I'm sure I can get a Luther or Morries dealer to beat that price. I may also go as far as Rochester, Mankato or St. Cloud to price shop via e-mail
On a different cd issue, I have factory cd's that will stop playing in the middle of songs. I've burned copies of those cd's and the ones I've burned don't have any problems. Go figure.
Please email me at nirajpatel@covad.net
Worst Service Department I have ever encountered!
They replaced my Cap and wires ('93 MAX), and changed my timing belt, then 6 months later when the car started acting up again I found they had snapped the screw securing the rotor, and replaced it with a self-tapping screw!!!!
Then they told me that my car had so many problems (it needed a new muffler, and had just blown a radiator hose, and there was a loud whine from the power steering pump when turning the wheel fully that had been there since they replaced the timing belt) that I should just buy a new car! They actually said it wasn't worth fixing!
Well, as they were inexplicably turning down a significant amount of my money (estimated to be $3000), I believed them, took the car home and proceeded to buy another vehicle (Honda Accord).
After purchasing a new car, I finally got around to looking at my MAX myself...
Solution:
Replaced muffler, less than $50 at Autozone.
Replaced radiator hose ~$8
Tightened tensioner pulley on belt-no longer a whine.
So in less than three hours and ~$60 I had fixed my car that I had been told to scrap by the service department at NATICK NISSAN!
It is unusual that you had no warning symptoms at all. Did the bearing eventually fail to the point that the wheel would not turn?
Good afternoon everyone. A few months ago I posted on this board as mrtrace (I am now using mrtrace1 as I've seem to misplaced my log-in password) regarding a purchase of a 2002 maxima gle that my mother made. There were a few mechanical problems at the beginning of the purchase but there haven't been any since and the only problem since then is that the rear bumper paint has began to peel. When my mother purchased this vehicle it was back in December and in the northeast there was plenty of snow so we could not really inspect the vehicle and she decided since she knew the dealer personally to not even worry about it inspecting the vehicle for body damage. At that time there were a choice of 3 other maxima gles' from other dealers that she was considering but decided to go with this one because of the black-on-black color and because she felt as if the dealer would not deceive her because of their personal experience and her constant referrals to them (she has sent about 10 customers who have purchased vehicles from them and she's also an employee of the credit union that is the lender on all those purchases). In the past I've also looked at a maxima but decided I would not purchase it because the back bumper looked like it had been replaced, which was a sign of significant damage to that vehicle, and it was always a thought that has stuck in the back of my mind including with my mother's purchase. Well getting to the main story now, I finally looked over her car once she bought it and I discovered that the left rear corner panel was misaligned with the bumper and the tailights (there are gaps where the corner panel meets the left tail-lamp and the corner panel and bumper are not flush with each other by more than 1/4 inch on both left and right sides) and might have been in accident but didn't say anything because that's the last thing you want to tell someone once they've bought a major purchase, especially your own mother. Well about a month after I discovered my finding about this body damage the paint on the rear bumper began to chip and at this point the bumper paint has all kind of nicks and cracks up and down it. She has informed the dealer about it but has not had the chance to take it to them and knowing my mother she doesn't want to stir up trouble simply because of the fact that she knows them (and yes I've been trying to explain to her that they weren't her associates when they sold her a wrecked car). Getting even more to the point, one day my mother and I went to a carwash and upon us inspecting the vehicle after the wash I said to her "mom, I think this bumper has been replaced and I noticed it when u first purchased this vehicle but didn't want to tell you but feel as if I should now because this really affects your resale value, and your drive and who wants to pay almost $20,000 for a wrecked car." She dropped me back home but proceeded to go to a body shop and asked if the bumper had been replaced and they told her yes and that there had been a shoddy paint job done on it at that. So its been a little over 2 months since she has had the car and there's been about 8,000 miles put on it (yes, alot). I am asking you guys what does it sound like she should do. I have told her to contact an attorney and lodge a complaint with the New York State Attorney General's office. However, I am interested in hearing what you guys have to say so she is not wasting her time by doing any of the above. I think her main concern is she just wants another maxima that hasn't been wrecked (even though I am trying to convince her to get a refund and get that caddy that fits more in with her over 50-year age range). By the way, when she purchased the vehicle she wasn't told it had body damage to it. She wants to trade it in next year for a used '04 and I've told her she wont get anything for a trade for a vehicle thats been wrecked. Please give your suggestions.
P.S. Tomorrow or on Monday I will be taking the vehicle to a body-shop and have them inspect the undercarriage of the car for welding and replacements parts and will let you all know the outcome.
We shopped a long time, decided we wanted an SL.
Bought at Kline Nissan. I went in and offered 28,600, played the back-and-forth game with the "manager" in the back room and ended up at 28,800. Of course, we then spent a few hundred more on the undercoat, hood protection, etc.
Hope it helps. Wouldn't want to put a bug shield on a car like this.
MY first question relates to a metallic rattle in the drivers side door. It only rattles when going over hard bumps, and when you shut the door, you can here a metallic clang or whatever sound metallic objects make. All the elctronics in the door work fine and if I remember correctly, the window goes all the way down without problems. SO any guess as to what it is, and how hard is it to remove the door panel so i can get in there to see it? Any walkthroughs for this available?
I am also having a little trouble with the keyless entry remote they gave me. It was not the original with this car, it came from another nissan, but they said it could be reporgrammed, and I found out how online, but its not working, it could be a battery, can i replace this with a bettery from say radio shack as long as it fits, or do you have to get it from nissan.
Last but not least, my fog lights do not come on ever. I doubt it is burned out lights, since both probablly wouldn't burn out together would they? I will probablyl let the dealer chekc this one, but if there is some quick fix I can try, let me know.
Oh wait I alsmot forgot, this one is so much a problem any more, but a question none the less. As soon as I had purchased the car, I went to put gas in it and shortly later the service engine soon light came on. Now I know this is a semi common thing on the maxima. And I have read a bit about it. Let me first say I did not have the engine running while fueling, and I checked and rechecked the gas cap to make sure it was on correctly.
If it was indeed the gas cap, would replacing it correctly immediately make the light go out, or would it need to be reset either by the ECU or by sticking the key in the ignition a number of times?
The reason i ask is this. While I was trying to program the keyless entry last night, the walkthrough had a step in it that involved inserting and removing the key from the ignition 6 times. As I wasn't getting it to work, i did this several times. And then low and behold the SES light was gone next time I started.
So basically what I am asking is, did I solve the problem and then reset the light. And if I did not fix the problem, but still reset the light, will it come back on later since the problem is still there, or will it not since I already reset it without getting it fixed?
Hopefully I am not confusing you too much, thanks.
(Firstoff, this kind of issue I see it has been posted before, but given Nissan's slipping customer service and less knowledgeable mechanics, I don't wish to get ripped off)
A) I'm a happy owner of a 96 Maxima GXE with 146K kilometers (about 91K miles). However, yesterday I went to change the oil at a local Mobil station and they suggested to also change the fuel filter, which I suspect hasn't been changed since the original. Well, later on that day, the MIL/check engine light came on. Could the fuel filter change have caused that or the O2 sensor going bad again?? I changed an O2 sensor (can't remember which one though) when I had ~ 65K kilometers when the same light came one and seemed to fix it...[FYI--> For the past 1.5 years I've only been using 91 octane from reliable gas stations (Mobil, Shell) ever since I started hearing some pings/noises in the engine when using the Hess 87 gas]
Overall, the car runs as smooth as it can for its age and miles. However, when waiting for the green light, more often than not I find the car trepidating as if it's not sure what to do, stall or go on. The idle speed ~600, but it varies as it never stays put. My somewhat limited knowledge tells me that I should check the TPS (throttle position sensor), but could it also be the fact that it may be misfiring a cylinder, fuel pressure regulator or some other sensor.
Please advise before I spend my last 2 years' savings! Thanks in advance.
P.S. Btw, you guys are awesome, by reading these postings, one can definitely learn alot...A hat tipping to y'all!!!!
with 6 ignition coils for my 2k GXE:)
Got them for about C$32 each (which is about
US$24) from a Canadian Nissan dealer.
If you live close to the border and need coils,
this is an easy way to save over 50%.
This topic was addressed a year or two ago, but I can't seem to find the solution anywhere. I was under the impression Nissan covered warped rotors on the 01 Maximas for the duration of the 3 yr./36k warranty. I was just told by a dealer that they only cover it for the first 12k miles. Is this true or am I getting the runaround? Thanks.
Leon
Now I am not very car savy, I know a little but not much. One thing I am trying to remember from other cars I have owned. When there is an alignment/pulling problem, does the car just drift that way, or does it go that way because thats the way the steering wheel wants to go???
The reason I ask is because not only does the car pull to the right, but the steering wheel seems to want to always be like 5-10 degrees right of center.
I am just wondering if the pulling is causing the steering wheel to want to go to the right, or if there is a problem with the steering wheel that is just causing the car to drive to the right?
We got it to the dealer (Pacific Nissan in San Diego) at 8AM this morning and I was less than thrilled that we had to agree to pay $42.50 for them to even look at it (if it wasn't a warranty repair). They failed to call us back by 1PM so my wife called to check the status and the (lack of) Service guy says that "it is just "normal" wear for 26k miles and they are worn out and need to be replaced." I told my wife to call them back and tell them B.S., the wear is way too uneven (and in the rear!), so then the guy finally goes and checks with the tech and they agree to be "good guys" and do us a "favor" and just replace the pads. He told my wife that it is effectively a "design flaw" with the emergency brake action on this model of rear caliper and it tends to put more pressure on the inside pad causing it to wear faster. They refused to address anything as a "problem".
What do you think about this? Has anyone else had an issue like this? I may not be a mechanic, but I am a Plastics Engineer, I've changed my own clutch before and I do all of the maintenance on my BMW motorcycle (adjust valves, sync the FI throttle bodies, filters, fluids, brakes, bearings, etc) and most of the maintenance on our cars and I think this is B.S.! I have never seen such uneven pad wear from normal calipers, let alone the rears burning out before the fronts (and I burn out front brake pads on my S-10 about every 10k-12k miles -(the life time racing pads pay for themselves eventually ) and I haven't changed the rear shoes yet at 65k miles).
Any suggestions for my next action? I believe they should replace the caliper or agree to keep replacing the rear pads for the full time I own the car if it is a "design flaw"... Should I contact the service manager or Nissan USA?
Thanks for listening (reading...) and your suggestions,
Eric
P.S. It just makes me chuckle reading about all of the people complaining about the "problems" with their 04 Maximas... Isn't it common knowledge not to buy the first model year after a redesign? I used to supply parts to Honda and GM and there are literally hundreds of ECN's (Engineering Change Notices) that go through in the first year to fix all of the "bugs"... Wait until 06 and it should be a pretty robust model again...
Good luck to you and your Mom and maybe this will be a learning experience for you.
It is possible that Nissan has deliberately made the rear pads thinner, or used less dense pad compound on rear pads on later Maximas so the pads would wear quicker, as there is only about 25% of brake force applied to the rear wheels.
After replacing the pads, I have not washed the wheels with wax containing soap anymore to avoid the same problem.
There is also another reason for scraping noise when brakes are applied lightly. The noise goes away during heavier braking. The cause are sticking caliper sliding pins, which need to be disassembled and lubricated. I had this problem with a 93 Mazda Protege.
