described. I'll let you know what they find and how much it cost.
I am contemplating purchasing a Maxima. Any "major" problems to look out for in current generation Maxima?
Thanks in advance!
Mike
I am going in for my #3 player next Wednesday. Very frustrating.
and check out any recalls and technical service bullentins.
Help?
Also, this is a Federal warranty.... it has nothing to do with your state !!!!
Find another dealer or , twist the arm of your current dealer. :mad:
'17 Chevy Volt Premiere
Try this. turn the key but not enough to crank the engine. Wait about 4 seconds then continue turning the key until the engine cranks. This will allow the fuel pump to engage before the engine cranks. My tech at the dealership suggested this and it did work.
i never got vibration but the 1-2 hour thing was always when it happened.
Alex
Any help would be greatly appreciated!
http://www.partsamerica.com
I can't believe it, my car been at the dealership since April 2nd and they
still can't figure out the problem. I called the service advisor and he said
a Nissan engineer is on his way. They already changed the two 02 sensors,
air flow meter and the throttle chamber. I already called the owner of the dealership
and now he's getting involved.
:mad: :mad: :mad: :mad:
(you can replace one at a time i guess and see if problem goes away or use a voltmeter somehow, they got procedure in nissan service manual for checking them but sounds too complicated). Btw It takes about 2 hours to replace 6 plugs and 6 coils , (faster if you have 10 inch extension for 10mm bolts, otherwise getting to the bolts / spark plugs in the rear is very difficult)
Haven't posted in a while. My 2000 SE now has 79K on it and so far no major stuff besides alternator and 02 sensor. Right now both side marker lights are out, the ones on the front quarter panels. I can't see how to easily replace them. Anybody done these ones? I've done both headlights before but I can't see how to get at these marker lights.
That's not to say I haven't replaced a lot of things as they needed to be. I replaced the starter last fall because it would make a strange noise after cranking that indicated it wasn't letting go of the flywheel for a bit. it had made the noise for about 50,000 miles, but started to get worse.
Other than that, I'm on my third battery, 4th set of tires, change the water pump last year, and had a funny intermittent noise problem for years that was finally fixed by replacing the right front wheel bearing. The interior looks and works great (except for the stupid cupholder design). Amazingly, I've never needed change a marker or brake light! Headlamps yes, about six.
Lesson Learned: Leather upholstery is not a luxury: It's a necessity if you want your interior to hold up.
Since buying it as a young newly married guy, i've jumped several customer segments and am now expecting a third child. Any suggestions for vehicles you can put 3 kid seats (1 can be a backless booster) into and not be an SUV?
Same deal for a rear marker light except that you slide the lens to the rear to take it off. Btw, I believe this info is in the manual.
Manual, that'd been too easy.
To fix your car go and read message#1621 and you will find the solution to your problem. You need to change the AIRE MASS METER ( Aire Flow Meter).
my 01,Max. SE, Here's what they replaced:
1. Volume Air Flow Meter
2. Heated Oxgen sensor
3. Oxgen Sensor
4. Throttle Chamber
5. ECM
The major problem was stalling and hesitation during stop and go traffic.
WOW, big difference the car feels brand new.
Due to length of time in the shop and getting the owner involved I got all this
done for under a grand. The customer relations manager also had a big hand in
this matter.
Good place to get parts is NissanPartsCheap.com
The 02 sensors on these cars are indeed disposible, it would seem. Good luck.
smile
I have a 99 Max with 95k. I just failed Ma emissions testing with three error codes. I looked the code descriptions up and wondering if anyone might have an idea of what I might be looking at. I knew I might have a problem before with my service engine soon light coming on.
p0450 - EVAP system pressure sensor or circute failure
p1444 EVAP canister purge volume control valve or circuit fault
p1446 - EVAP canister vent control valve closed.
Thanks for any help.
Im currently going thru the exact same problem with my 95 Nissan MaximamGLE. Its been spitting out all my cds and says CD ERR. Its been fustrating and I was wondering if you found a solution to the problem yet or did you have to replace the cd player all together. If you did have to replace it, was it difficult? I have another cd player on hand and was wondering if it was a difficult task.
D
1) Car stalls at lights 2) Jerks when revs are pushed to 5000 3) seems to have lost power and accelleration. A "diagnostics" turned up nothing. Mechanic suggested I may have a fuelpump problem
Any thoughts?
Celticvoyager :sick: nissan maxima 2000 se manual
From what I've read, there seems to be alot of problems with the '04's and '05's.
I have an '05 SE that I've had for 4 months now. I love the styling, ride quality and interior space of the Max. However, the whole drivetrain could be much smoother, especially shifts during light acceleration. The car is also very noisy over sand and salt on roads. I've also had the "hard start" problem that the dealer has been unable to fix despite several TSB's on the issue.
Its hard to judge whether the new Max has more problems than other cars, but overall, after owning Buicks for the past 14 years, the Max is a disappointment (other than styling). We'll see how it does long term.
Good luck making your decision!!!
Jerry
mastj@1stsource.com
I have the same problem with my 02 SE 6-Speed. I believe the problem is related to the clutch disk. You may need to get it replaced in order to eliminate the noise. I could never get my car to duplicate the noise at the dealership while it was under warranty. Now that I am at 68,000 miles, it does it much more frequently, although not enough to drive me crazy. Here's a link that explains more about the problem. http://www.infinitihelp.com/Ownership/Bulletins/Nissan/2002/NTB02-084.htm
