Also - still looking for any feedback/assistance to my posting a couple of days ago (#11206).
Vibration:
changed springs
and drive shaft
after 6 visits and 15 days, vibration gone
License plate fell off (front):
Dealer fixed and replaced
Left driver side window would not go down:
fixed it self
OK the latest and greatest:
Head snapping shift from 1st to 2nd
Dealer fixed in 6 days, replace a valve pressure gizmo on tranny.
shifts without spilling coffee, smooth as silk wow!!!!
UMMMM???
Oh, the check engine light came on:
fixed, gas cap was loose, but I did check it, it was cocked at an angle.
I know I forgetting other visits, and repairs, But heck its running fine AVG MPG 18.6 HIGH/CITY, not bad. Truck is running great, fixed some stuff myself, like front bumper wasn't snapped on all the way, and an annoying vibration near the passenger overhead console was making an annoying noise, punched it with my fist, fixed.
Running great, knock on wood!!!!!
I've heard something, but it wasn't as pronounced as a "clunk", mine was more like a single "click" that would occur again in about a minute. It sounded like it was coming from inside the dash and toward the left. At first I thought it was the windshield expanding in the sun or the plastic of the dash. But it does it pretty consistently. Sometimes, even driving down the road at highway speed I have heard it, sometimes every 3-4 miles. But if I forget about it, I don't tend to notice it. So in my case, it isn't always related to having the brakes applied, but in many cases I have heard it while stopped at a light. But I have never noticed the "surge" you describe, so it may not be the same thing. I don't know what it is. I had my tires rotated and axle seals checked (supposedly) recently, but I didn't mention this "click" to them. It hasn't really annoyed me, just made me curious.
I think what you are describing is what I have been experiencing for a few months now. When stopped at a light (tranny in Drive, foot on brake) there will be what I describe as a 'shutter' that feels like an engine miss. It's intermittant.
Mine has been at the shop numerous times for this issue. The GM TAC told them to replace the spark plugs with a different flavor... but that didn't fix it. And the new '03 Envoy they gave me as a loaner for the day had the same problem!
I escalated it to the GM Customer Assistance folks and they assured me that the GM TAC group is aware of the problem and that it affects numerous vehicles. They are working on a fix but did not have any idea on timeframe. In the meantime I'm keeping a written log of the occurrences to see if I can assist them in troubleshooting the issue.
About 90% of the time I can get the truck to stutter at a stop light 1 mile from my house (after a cold start), but then intermittantly after that. For the past 2 days I have tried running with the Automatic Climate Control off and so far no stutters.
Have you seen any pattern to the stutters/surges? Do you live near any AM radio stations? (wondering about interference).
(2003 Envoy SLT, 3.73 gears, autoleveling, locking diff).
I also had the smelly AC problem. Now I noticed that every so often I hear the HVAC fan turn on when the engine is off to dry out any moisture. It seems like this turns on whether or not the AC is used. Will this drain the battery prematurely?
Likely was not the cause why my airbag light stayed on once, since my TB-LS doesn't have OnStar. Happened one time, over a year ago, and restarting the engine (rebooting the system) cleared it out.
New Performance computer chips: Any good ?
and there's some chip boards in the archives, like Chip Upgrades.. worth it?.
#1 - Anyone figured out how to reset the system after an oil chg. to make the "change oil" light go out?
The method stated in the manual does not work and I've repeated it several times.
#2 - What after market oil is specified for the transfer case? Manual states a GM specific name and the auto parts stores have no listing.
Comments / suggestions about changing Diff. & transfer case oils? Thanks.
Here's the exact text from the service bulletin how to do it, and how it is supposed to work.
Info - GM Oil Life System - Resetting #02-00-90-001
GM Oil Life System™ -- Resetting
2002 Chevrolet and GMC S/T Utility Models (TrailBlazer, Envoy),2002 Oldsmobile Bravada
These vehicles have an oil life monitor. The GM Oil Life System™ will show when to change the engine oil and oil filter. The GM Oil Life System™ must be reset after changing the engine oil and oil filter.
Resetting Procedure
The current Owner's Manual contains the following reset procedure:
Turn the ignition to RUN with the engine off.
Fully press and release the accelerator pedal three times within five seconds. If the CHANGE ENG OIL light flashes for five seconds, the system is reset. If the light does not flash, repeat the procedure.
However, it has been found that after completing the reset procedure, the CHANGE ENG OIL light does not flash as stated in the vehicle Owner's Manual.
If the CHANGE ENG OIL light goes out after the reset procedure and does not return after the next ignition cycle, then the system has been reset.
If the vehicle is equipped with a Driver Information Center (DIC), then reset confirmation can also be done by verifying that the Engine Oil Life percentage value has reset to 100%.
Use the above information to prevent the inadvertent replacement of the instrument cluster if there are comments that the oil life reset feature does not work
I only drive a short ways out of the parking lot at work to the first light, enough to get it into 2nd but no more.
The truck is cold.
I am stopped for a while (sometime >1 min.) before the clunk happens.
It makes sense to me that the transmission would stay in 2nd at a stop when cold.
Shifting from 2nd to 1st could be rough when not moving or when the fluid in the torque converter is cold.
The computer realizes after a while that it needs to downshift because I have been stopped so long.
I once reported this to my service manager, but they said it was normal.
Please let us know if someone finds a defect that is causing this! Otherwise, I will try not to worry about it.
25k miles and otherwise running good (02 Envoy SLT)
Your experience sounds similar to ours. But ours has been getting worse and is driving me crazy.
I agree that it may be transmission related. But when my Envoy does the "clunk" (usually after stopped for over 30 seconds), I can stay stopped there and it sometimes will do it again.. or a 3rd time even.
And it's not something loose inside or outside the vehicle banging around. I wish I could reproduce the shutter/clunk at will so I could be outside the vehicle to witness it with the hood open.
I'm baffled. And as I said, GM admits they have widespread reports of this problem and they are working on a fix. I'll be calling every 2 weeks to kindly remind them.
What build date is yours?
(2003 Envoy SLT, build date 12/02, 3.73 gears). The new Envoy loaner that had the issue had a build date of 3/03.
That's different than the noise others are hearing while stopped. Don't know but suggest checking the spare tire and make sure it's solidly pulled up against the bottom, check under the back seat and make sure the jack and all its pieces are secured, look in the rear floor compartment and in the rear storage compartment for something loose, and when all else fails take it to the dealer. From your description should be obvious. Maybe something loose in the suspension? Whatever, it shouldn't do that.
There is nothing false about their advertising at all. Somebody disabled the system. No technology is going to completely stop the professionals.
Yes it's unfortunate, but OnStar owes you nothing.
Made six trips to the dealer over 6 months for reprogramming, new PCM, throttle body, lift gate module, ignition switch replacements, and I still stalled out. We even had the vehicle data recorder installed, but that drained the battery overnight.
So 3 weeks ago GM completed the repurchase of my '02 Envoy SLT 2WD (build 6/01) with only 17K miles.
I owned a 99 Jeep grand Cherokee prior to this and it had the same exact problem. IT IS THE DRIVE SHAFT! I believe it is the same in the TB. The Jeep dealer told me it was the drive shaft moving front to back. When you brake it moves towards the engine. Then when you give it gas, it slides in the spline and moves back causing clunk sound. I am almost positive that this is the problem with the TB.
Mine will be going in soon to get looked at. Jeep had two ways of fixing it. Grease up the drive shaft spline really good. or replace the drive shaft and assembly on it. I prefer the later of the two.
Frank
Frank
has any one had the Lo-Jack system installed in their current or former vehicle?
Really good car thieves know alarm systems like you know where your t-shirts are in your underwear drawer.
I realize you feel pistoff and everything else, but OnStar isn't at fault, and you had an opportunity to install a piggy-back alarm system and didn't.
Blame the thief, or yourself, but GM doesn't owe you anything.
I have an 02 Oldsmobile Bravada AWD and I was just collecting ideas on what other people thought about the Whipple Supercharger for the Vortec 4200. ( http://www.whipplesuperchargers.com/product.asp?ProdID=1169 )
Obviously, that's a lot of money to pay for about 380hp total, but how would it perform? Would Oldsmobile's SmartTrak system defeat any performance boost achieved from the supercharger by braking the tires after spinning? Consequently, is there any way to disable SmartTrak?
I'm just brainstorming engine modifications to make on my Bravada (already ordered the K&N air filter), and the supercharger looked to be the biggest improvement I could make on it. I am only looking around for things to add as of right now, my mind's not set (so criticisms of the supercharger idea is welcome).
It's one of the older '02s, so it probably has a few acceleration-increasing PCM updates, but I haven't checked yet. I love all the power I have in it now, but I'd really like to stand out from the rest. Thanks for your advice.
Yesterday my washers stopped working (intermittently) as well as the regular steady speed on the wipers. I called the dealer at around 12:30p to see if I could schedule an appointment. He asked if I could bring it over sometime that afternoon. I finished the work I was doing and drove right over, arriving at the service dept about 1 hour after I called. He told me it would be less than an hour to check it out. 45 minutes later, I was out the door with a new wiper motor assembly installed.
Amazing service I thought. At first I figured they were just having a slow day, but there were cars and customers coming in and out the entire time I was waiting, The other time I had the TB in for service (the PCM re-program), the same great service.
Dean
When Lojack is inatalled, the installer hasd many places they can locate the cigarette pack sized transciever. The only thing they need is a power source to keep the internal batteries charged. Unless you are there when they uinstall the unit, you will not know where it is placed. Most importantly, Lojack does not put stickers on your vehicle to advertise it's presence.
On another note... Was it that the stolen vehicle was in the L.A. area? If so it would be easy to disable any recovery system in this area.
There are car theft rings in the L.A. area that will steal a vehicle and drive it directly to the
Docks at Long Beach or San Pedro and load it driectly into a Cargo Container. Once inside there is a slim to no chance of getting a signal into or out of the container. Least not enough to receive satelite GPS info or make and erceive a call from the onstar center.
On another note. Within one and a half hours you can be in Mexico, out of cell phone range....
The dealer does not do safety inspections at this location but I always have the safety inspections done at an independent location. The TB is scheduled to be repaired at the dealers on Monday (5/19). They did not seem to be overly surprised when I called to schedule the repair.
I thought the same thing about the seats but realized it makes total sense. If you're cornering fast enough to require lateral support, you're going too fast for an SUV.
Has anyone out there changed the fluid yet (not topped off) and what did you use????
Yup that's same the conclusion I came to especially with the timing of the triplets hitting the market and all the SUV rollover concern. And, the cushions really do get more comfortable as they settle in.
Inconsistency is a problem with GM. If you get a good one, your OK, but a bad one (like my Bravada)
is really bad. My Envoy is better than worse. The problem is that these inconsistencies come out in a test drive, and people base their judgement (rightly so) on that drive. If it sucks, they are NOT going to go look for one that is better. My Envoy still has a lot of wind noise, even after I fixed the problem around the door pillars. I can see where that alone could stop someone from buying it.
GAM
Had the recal done when in for the last oil change and I'm thrilled with the results.
The delayed shift is gone, engine is at least as responsive as it was before, but what is most impressive is the remarkable increase in fuel economy.
Over approx 12K miles of ownership, I found the economy to be about 18 mpg combined. I am now getting a bit over 20.
I have the EXT with 3.42 gears and enough options to put the truck over 5100 lbs. I even have an additioal 100# of WAAG hardware front and back.
It amazes me that if a recal can do that that GM wouldn't encourage their customers to have it done. You would think they could get so good press and look a bit "GREEN"
