I contacted Chevy Marketing and asked about the 04 models and beyond. They confirmed that Chevy has no plans to produce a ZR1 offroad type package for the TB.
It appears most TB owners would rather lower or put 22's on their TB's.
Oh well, my 96 Blazer has been pretty good and I really wanted to stay with an American car company but that is an option anymore.
The best vehicle for me appears to be the Toyota 4Runner.
The fan clutch is controlled by the computer(PCM).
However you do not need to reprogram after replacing the clutch.
I checked the service manual and also spoke to a Tech who happened to do one on an Envoy last week.
Here's how it works:
The electro-viscous clutch is controlled by the PCM. The PCM controls a solenoid that regulates a fluid pressure that controls slip of the fan clutch. Internal to the fan is a centrifugal fluid pump, solenoid, hall effect sensor, valve lever and a hydraulic fluid. There is two chambers for the fluid, these two chambers are separated by a valve lever. The first chamber is the storage chamber, which holds excess fluid. The second chamber is the working chamber. As the pressure of the fluid is increased in the working chamber the amount of slip the fan has is decreased. The position of the valve lever is controlled by an electric solenoid.
One more reason to buy the extended warranty.
Frank
What I can testify too is that it will not adjust enough to compensate for an open window or sunroof. That is how I have tested it to date. I also know that as I go from around town to X-pressway conditions, I do need to increase the volume. It may be working, but not quite enough for my not as young as they once were ears
Started up as normal with Climate Control on. Tach began to wander between 1000 and 1500 RPM.
Started to drive and was actually able to detect some throttle surge as the tach continued to wander, Seemed to clear itself after a few minutes at 40-50 MPH. Has not done it again today.
Other cars I have had, had a noticable drag when the A/C kicked on, both at speed and idle. I have never sensed that on the TB but wonder if that was somehow causing today's situation.
Anyone else experience this?
I have from time to time had the low idle hesitation folks have mentioned in previous posts, but never to an almost stall condition. It feels more like a slight hesitation before the tach jumps from idle to a throttle signal.
I have always blamed this on my driving style which I would call very gentle at least from a dead stop.
Hopefully my test method will work for those interested in trying this. I tried it again today and noticed the difference. Also, you may want to take note that since the Bose setup does not have a MUTE button, I noticed that if I turn off my Auto Volume, I can lower the volume to a very LOW setting so that I can carry on phone conversations, etc. At first I used to get really frustrated with the simple fact that I could not get the volume to turn down REALLY low. Someone enlightened me to the fact that by disabling the auto vol gives you greater control of the overall volume control (hence making it very low).
Give this a try as well!
Good Luck,
IExplore2000
Additionally, I will be installing it on a 4x2 Envoy with the locking rear differential. Would there be any problems to that?
4156, the reason it would not work, the computer looks for the fan speed signal from the internal Hall-effect speed sensor. If for example the computer is commanding it to engage at 50% and it gets an erroneous speed signal back, the computer will compare that fan speed signal to the engine RPM and the expected fan speed, and will set a trouble code if it's too far off. Actually the setup it has is very effective. It is being used on the 5.3 V8 too.
Re: extended warranty- if they extended it an additional 5 years, rather than just adding 2 years to the existing warranty, it would make more sense to me. They don't sell extended warranties to loose money on them. I personally have yet to have a situation in 36 years with a car or truck where a 2 year extention on a warranty would have done any good. I prefer to pay as I go, if needed.
I drive a TB, and formerly owned a '93 S10 Blazer, but wish it was more offroadable than it is.
The Toyota 4Runner always was a nice offroad vehicle, but a little underpowered. Well, as of the '03 model year, there's lots more power, but they put coils on that and lowered it as well. Ya just can't win!
Considering he did bring it to the dealer I merely answered an installation question.
Does anyone have any history with this outfit or any opinions?
However, it has NEVER exhibited such a problem during driving, in gear. That is scary. I'd be complaining all the way up the GM ladder.
You'd have to be nuts. It's technically feasible for sure, but economically impractical. By the time you're done, you'd have spent enough to by a BMW or Lexus. Not that I wouldn't love to have the V8 in my TB. Nice engine!
They replaced the ECM, BCM, throttle body, and a few other things the 6 times it was at the dealer. They could never fix it, so GM bought it back as a lemon. My Envoy is now somewhere in Kansas, probably with a washed title.
My advice: give them the 3-4 chances to fix it (per state law), then get a good lemon law attorney. Don't waste time going through the BBB or GM's Customer Assistance Center.
Background: When at a stop sign (tranny in drive, foot on brake) our '03 Envoy "stutters". Feels like the person behind us tapped our bumper. Noticeable little shake, no change in rpm.
Done so far: Have had it into dealer 8 times, escalated to GM Customer Service. GM divulged that it's a known problem and sent us a letter upping the transmission warranty to 100,000 miles and considered the problem closed. No fix available (yet). No estimate on when, how I'd be notified, etc.
BBB: GM Customer Service considered the issue closed since they increased our warranty. Not acceptable to us - GM said only escalation path was to go through BBB. That was a total waste of time. Their only resolution options for the manufacturer are for them to buy it back. We just want it fixed!
The Arbitrator agreed that we had a problem (I had a written log of the events covering over 2 weeks) and that it should be covered under warranty. But that it wasn't sufficient of a safety or value issue to warrant buy-back. Since they only do resolutions of "buy-back" or "no buy-back" it ended there. How about a "Hey manufacturer, stand behind your product and fix this thing!".
An acquantance of ours owns a Transmission shop and when we told him about the problem he said "Oh yeah, we see that all the time." He said the transmission is dropping in/out of drive - problem with the 'sprague' (?) gear. Requires a complete tranny rebuild. He speculates that GM knows that's the problem and doesn't want to rebuild all these trannies. He also bets that the transmission will eventually fail and GM is hoping some of them fail after the 100,000 warranty extention so they are off the hook.
So I have no other option other than taking it back to the dealer week after week until it's fixed.
Anyone been able to get this problem fixed?
Todd
tim
Todd
The GM bug shield uses a very strong and thick tape on the side wings and four or five screws which go into push-in retaining nuts in the center. There are small square holes along the underside of the hood and the 'nuts' push into these existing holes......no drilling required and takes all of about 15 minutes to install.
Best of all the GM deflector is nicely sculpted to the contour of the hood and looks really good on my White Envoy SLT.
Ray
Also, I am VERY pleased with my new V8 EXT ( I traded an '02 LTZ for this one). I get better mileage in town and while towing (13.9 total) and range, plus the ride is super. I averaged 12.4 on my Labor Day trip to Barber Motorsports Park in Alabama. That trip included sitting in the paddock with the AC on for a couple of hours a day. THIS is a much better tow car than the I-6 SWB TB. MUCH better.
Brian,
A big factor here could be if you plan on towing anything like a boat, or a trailer. If so, this narrows your choices to TB, Envoy and Explorer. All of those are "body on frame" construction. The remainder are "unit body" construction, which cannot tow as much.
After that it becomes a personal choice I think. I used to think Ford drivetrains were inferior to GM, but that may not be true anymore. I would just go drive them all to see which one you like best.
I just went out and looked, yes the front bar (man, is that thing big in diameter) attaches with two pillow blocks attached to the frame.
Glad to hear it helps with buffeting. I'll follow up with a report on its effect on towing.
The dealers tell me that their invoice price has 2% built in for 'Advertising'. Is this BS? Will I have to pay for it? I think I should be able to get an 03 Envoy for atleast 1% less than the advertised Invoice price on Edmunds. Am I wrong for thinking that?
Whats everyone paying before any rebates?
Jeff
