If the service 4x4 light is on, like mine was, the 4wd is not working.
I am at a loss! I really don't know what to do.
Corrina
Ray
Do you know where I can find information on common problems in the 02' TB? Like where you got your tid bit about an extended warranty?
Corrina
You should contact Chevy Customer assistance at 1-800-630-2438 for information.
Good Luck
Is there any difference in the ride or do they just look better.
By the way, this is strictly for on-road. Don't do this if you go off road a lot because there's less protection for the wheels.
You can tow the 4wd trailblazers, but put the transfer case (not just the transmission) in neutral. READ THE MANUAL, it will tell you how.
FYI I have been buying my tires from tirerack.com for years and I can get the 245's for $89 ea and in just a couple days delivered right to my door. Any shop will mount and balance them for about $10 per wheel.
$10 to mount and balance? Where? Cheapest I've ever found was $15, w/a $2.50 per tire disposal fee.
GAM
http://www.tirerack.com/tires/surveyresults/surveydisplay.jsp?typ- e=HAS
Allen
Not always necessary to go to Baskin-Robbins for Ice cream when Rite-Aid sells the same thing.
You should send a complaint to GM and your dealer also.
http://www.blackrobotics.com/
Cost to G.M. to repair defective parts--unknown.
Value to me to have them do it, PRICELESS
Extended Warranty, get it before it's too late.
Greg
Check out www.pistonslap.com for more info.
It doesn't sound so benign after all.
The manual says that by now I should have the fule filter, PVC valve, belts, and tranny fluid replaced. Does any one know if this is something I should do now? My car runs perfectly fine and I want to keep it that way. Is it recommended to do now? I do all highway driving 5 days a week.
That website is of dubious credibility at best.
If you do some searching, the overriding opinion among mechanics is that it is benign as long as it goes away when the engine warms up.
I've got to ask the question to folks here - when did you ever get rid of a vehicle because the engine went bad (and how many miles did it have)?
It just seems that too many people worry to death about car maintenance all while they're getting new cars every 4 years.
Yes, but if they made the piston big enough to not have piston slap when cold, it would expand due to heat and would be grinding against the cylinder wall when warm. It can't be perfect.
The piston slap issue isn't confined to GM. You can go to goole and see complaints against Ford, Toyota, Subaru, Nissan, etc.
http://www.alldata.com/techtips/2002/20021101a.html
Our 03 Tahoe has a little slap as well but again only when its really cold outside. For the Tahoe it lasts about 10 seconds at most.
As for the question on motors blowing up. My 91 s15 jimmy made 200k and 12 years before it quit.
-jay
Back to the Triplets (Doublets?)
Racing. Only mat I could find that covered the dead pedal.
