Chrysler 300M
Welcome to the continuation of the Chrysler 300M XIX topic. Those of you joining us from that topic are welcome to continue your discussion.
If you're new to this topic, you may want to follow the above link for additional archived posts.
L8_Apex
Sedans Message Board
L8_Apex
http://underwire.msn.com/underwire/reallife/Lu/103lucilleA.asp
Racefan9's 300m
Can anyone recommend a good Five-Star Service Dept. in the Northern New Jersey area? My dealer is about 50 miles from home, and I wasn't thrilled with the service there at any rate.
Thanks in advance.
Stumpy
Lynn
Colors-What about slate? Do we combine the attributes of both gray and black? I wonder why green isn't mentioned?
I even like my 5* (so far)!!!!
Lynn
Oh well, had the borla installed Saturday, there is a resonating humm at 2000 rpm, I don't mind it too much but my wife sure noticed it. Oh well like she said, its your car.
Keith
-MMCCCM
Ray was getting a low hum from the Borla exhaust at cruising speed.
Here is how it was fixed:
I installed the resonance venturi's supplied by Borla & they made a difference. No more low hum at cruise. Same noise is there but when accelerating. Behaves like it should, sounds pleasant and Wife is happy, the main issue. Anyone ordering one should get them installed at Borla.
They are a 3" long tube, the dia of the inside of the pipe. They are rolled into a smooth annular venturi about 1/4" in smaller in dia in the middle. They slip inside the pipe and do need to be tack welded in or they will/could migrate. One is installed after the first muffler at the outlet end and the other between the second and third muffler. Both at the joint. Borla claims no flow degradation and from my somewhat limited knowledge of acoustic physics I tend to agree. My installer commented that the system was too open for the size of the engine.
Ray
I'll bet the dealer lflowers was talking about was El Dorado CPJ in McKinney, TX. That's where I bought mine, too, but I haven't used their service dept. yet. Nothing has needed fixing!
-MMCCCM
My M seems to have been repaired (alignment, bad window motor, and loose wiper arm) correctly by them and, so far, they have been friendly and courteous every time I've had any dealings with their service department.
They even throw in a free car wash when they service your car.
Lynn
When I left the office I got the bright idea to have my passenger try the window (it didn't work) then turn on the butt warmer and try the window again. It worked. So can anybody tell me how the window is connected to the seats?
Igor
Grunschev, I do have to work on Saturday so my chances of meeting you are very slim. Still trying. I use my butt warmers almost every night, but will have to check the window thing. There is a thought, maybe the car thinks if it is cold enough to use the seat heaters you should not be having the windows open so it will not let you freeze yourself. Expecting a freeze tonight (what ever that is )
racefan, ever since the XX was added it is a little harder to get on.
want an easy way to post with organized topics, no more repeating ourselves day in and day out, and no logging on and off??? simply bookmark the page and wow it appears, there are no hi-tech graphics or flashy ads (yet) but this my friends is hassel free...and you can post pics and links with little effort, hell you don't even have to sign up to post!!! It's too good to be true, come on over...
Chrysler 300m Owners Board
A New Way A Better Way!!!
I wonder if Edmunds would let us start another 300M forum? Whaddya think?
Gotcha!
Racefan9's 300m
1. I haven't washed the car in at least 2 months.
2. I use the windows almost every day.
3. The windows worked on Friday, didn't work on Monday and Tuesday.
4. Wednesday morning I used the butt warmer and when I tried the window again it worked.
5. Wednesday afternoon I had my passenger try the window (fail), turn on the seat heater, try the window again (success). No tapping on the glass. No secret incantation.
Before I get castigated for abusing my M by not washing it, let me say this: It almost never rains here and my car is garaged at home and at work. I promise I'll wash it this weekend (it rained this week).
Igor
don't mess with Igor, he'll come after you, he reprimanded me on yahoo today, and it was painful!!!
Main Entry: cas·ti·gate
Pronunciation: 'kas-t&-"gAt
Function: transitive verb
Inflected Form(s): -gat·ed; -gat·ing
Etymology: Latin castigatus, past participle of castigare -- more at CHASTEN
Date: 1607
: to subject to severe punishment, reproof, or criticism
synonym see PUNISH
- cas·ti·ga·tion /"kas-t&-'gA-sh&n/ noun
- cas·ti·ga·tor /'kas-t&-"gA-t&r/ noun
Igor
But then, I don't consider the road noise problem much of a problem either.....perhaps I'm just more tolerant than some.
Lynn
Racefan9's 300m
Just set a single bookmark to The Consummate 300M Pages
Then you can easily access the Yahoo, Edmunds, eGroups, Epinions and Consummate 300M boards from one place.
width="125" height="66" border="0">
That is a loooooonnngg reach to do the inside windshield - I know you M-guys have the same problem. Does anyone have any tips to offer?
Thanks for your time.
As for window sticking problems, I've noticed the same sticking window thing. Waxed/polished the window edge--seems to only be on the driver side, though. I've a lso noticed that if its raining and I run the window down to clear the rain from the window--it DOESN'T clear the window. Is this an adjustment problem for the rubber 'wiper' or an undocumented feature, "..oh, they all do that..." thing from DC? You can respond here, or email me...glenn.beye@ny.frb.org
ciao4now, bambino's and bambinettes!
drpixel/Glenn
My windows don't clear when I cycle the windows up/down either.
One face has a Dallas Cowboys logo (star & name -- I found it on the net somewhere). Turned out great! If you can find a digital picture of it, I can put it on a clock face.
http://albums.photopoint.com/j/AlbumIndex?u=1280646&a=9486000
I do have a road trip story. For me, the greatest enjoyment of this car is to go places in it. I know at least some of you guys live in Florida, so you may find it amusing.
From north Florida to Miami and back to deliver a friend to the Miami airport. A simple 1-day deal in a 300m.
The trip was strange to the point of being surreal. Miami is a very entertaining place comprised, apparently, of people determined to drive very fast, regardless of conditions, and an equal number of people equally determined to drive very slow. The two groups appear to be totally unaware of each other.
We saw a mentally-challenged gentleman at a busy Biscayne Blvd. intersection having a violent, but entirely verbal argument with what appeared to be a water bottle sitting atop a mailbox. A woman in Coral Gables made a U-turn accross 4 lanes of traffic from a parking space. People sitting in their cars behind a red traffic light, furiously blowing their horns while having animated conversations on their cell phones. Strangers in a strange land.
The trip home was the most memorable. Imagine, if you will, entering I-95 from Sunrise Blvd. in Ft Lauderdale to find yourself in three to five lanes of northbound traffic, all packed Nascar-like, bumper-to-bumper and side-to-side. Numerous signs, with varying degrees of success, forbid trucks, (which outnumber cars) from using the left, (3rd) lane. So, we have the extreme right lane doing seventy or so, then the center lane, (the truck fast lane), at around eighty, and the third lane doing literally whatever the traffic would bear. The highest I saw in that lane was eighty-seven, but there were cars twenty feet behind me impatiently waiting for me to get out of the way. The posted speed limit is 60 and the county cop in the right lane seemed only to be concerned with surviving to the next exit. This, mind you, is at 2:00 in the afternoon on Thursday. I can't imagine what it's like at, say, 5:30.
The road surface is upholstered with lurid skid marks about every hundred yards, most going diagonally accross three or more lanes of traffic, testament to the mayhem this kind of situation can produce at a moment's notice. Add to this mix, four hapless souls in a twenty year-old Nee-sonn pickup piled higher than the cab with what can only be described as dumpster food tied down with old clothes line. The rear bumper, fastened only on one side, ocasionally drags on the pavement and looks determined to fall off any minute. They're probably running flat-out at fifty, and steadfastly refuse to give up the center lane. Occasionally, the whole procession will slow suddenly to 35 for no apparent reason, then ease back up to a more suicidal pace again.
Every five miles or so, two or more tow trucks idle on the shoulder, apparently on standby for the inevitable. Permanent signs abound ordering us to move 'accident vehicles' out of the traffic flow.
This circus continues unabated for nearly fifty miles until we are well north of West Palm.
I have always regarded my testicles as more or less the same size as most other guys' when it comes to driving fast, but this thrill ride suggests to me that I could easily earn a black belt in wimp-ness, with a whitest-knuckle badge.
My 300M has convinced me that it is the ideal instrument for any activity involving a road. Alas, I have found a situation for which it is entirely unsuited. To place a 300M in this sort of peril borders on criminal neglegence. Nosiree, what you want here is a rusted-out '85 Galaxie four door with caterpillar-blade bumpers, good seat belts, and nothing to lose. 300M's need not apply.
The rest of my trip could be called relatively uneventful if you disregard the state trooper who passed me twice as if I were standing still, once while I was doing eighty, once at seventy-five. On both occasions he suddenly jumped on the brakes, did a magnificent half-donut in the grass median, and hammered off in pursuit of someone in the opposing lanes commiting a worse misdemeanor than I.
Those of us who frequently travel I-95 near Daytona are aware that the interstate lies directly beneath the final approach path for the Daytona airport. It is not unusual to observe large aircraft crossing the highway at three hundred feet or so. As a licenced pilot, I confess that I cannot resist such a sight, and as I drove past this point, I glanced up. There, to my astonishment, 4000 or more piston-engined horsepower gloriously bellowing, was a perfectly restored B-17, authentic Army Air Corps colors and all. No bullet holes that I could see, but perhaps it was too far away.
Back home, pushing buttons on the overhead console, everything normal, 720 miles, 27.5 mpg. Just a simple trip from north Florida to Miami and back. Sure.
The one thing I do love is the speeds I can go in FL. I'm one of those Get out of my way, while you'll doing 85 people. I have made it to Orlando in a record hour, & a half.
So correct about the skid marks, & the 35 slowdowns.... I avoid 95 if I can. I take the Turnpike. Straight, & no traffic.
AT 5:30pm, Don't even think about leaving work, in the Miami area. You will be in trafic for hours! I work In the other direction, Boca Raton. Thanks god for that.
invoice......so I guess it was a good deal. This may sound weird but.....what is Zaino? A type of wax? I see it mentioned a lot. Thanks!
Zaino is indeed a type of wax, the personal choice of almost everyone here. You can find details at http://www.zainobros.com. It is a little more.expensive, but it goes a long way and does a GREAT job. They make a full line of polish and paint care products, tire and leather dressings. As one of our group once said, "If you try it once you'll want everything they make" (maybe slightly paraphrased).
My Grand Prix GTP with its instant torque and a smarter tranny was better suited for this kind of commute.
I miss NY parkways where trucks are not allowed to go.
O-O
John
