Mazda MPV: Care & Maintenance
We purchased a 2002 es MPV today, and were wondering about the "timing belt." I know the new MPVs have a chain, and not a belt - anyone out there know what is in ours (no mention of either in the owner's manual) and when it needs changing?
-Brian
Mobil1 Synthetic works really well (do double check whatever fluid you use is Mercon III <not Mercon V!> compatible). If you are changing the fluid, make sure to drain the torque converter as well. Try to avoid *iffy Lube types with machines and go for a reputable transmission shop or dealer. You don't need backflushing machine for a complete change as it can be done through the AT cooler lines.
Make sure you provide enough ATF for a complete change (appx 14 qts). Also check if your tranny pan needs to be pulled for a filter change. If you only have a screen (like the 2003+ MPVs) you can skip that.
Liven up your evening and join your fellow enthusiasts every Tuesday from 6-7pm PT/9-10pm ET for our Mazda Mania Chat!
The chat room opens 15 minutes before the scheduled chat time, so come early and get a good seat! Hope to see YOU there on Tuesday!
Mazda Mania Chat Room
PF Flyer
No. Mazda does not recommend the use of synthetic oil. To determine which oil should be used for your specific model, consult your Owner's Manual.
http://www.mazdausa.com/MusaWeb/displayPage.action?pageParameter=- contactCustomer#15
Thanks, Gary
Can anyone tell me where you fill up the transmission fluid. I know my car is low but I'm not sure where to fill it. It's the 93 model but I assume later models would be fairly similar.
David
here is my concern: I could not find any recommendation for transmission fluid change in owners manual. Went thru all the pages. Dont see it. So does it need to be changed? If so, why Mazda (as manufacturer) does not include this on maintenance schedule?
Now, dealers recommend to change it every 30k if not even every 15k miles! Are they so much money driven?
Please comment on this.
Who is right? Who do you trust? What do you do?
Just to add something, I have a Honda Civic, and a very good mechanic - a friend. Both him and owners manual for Honda suggest changing the transmission fluid at 90k miles. I understand this. Makes sense.
But the difference on Mazda really puts me into trouble... :confuse:
-Brian
-Brian
Glenn
Thanks in advance for any advice!!!
1) Tires need replacing...seems odd at 30k, but the fronts are pretty worn.
any suggestions on replacements that have a great ride?
2) we have noticed the sulphur like smell a couple of times. I have read in some forums that this problem seems to come from the gas we use, not neccesarily the Cat Converter...any thoughts?
3) where is the easiest place for me to get an owners manual?
4) how in the h@ll do you remove the spare tire? I am sure when i get the owners manual i might have an explanation!
5) How do i get bulletins to see what recalls have been sent out and if i need to have anything done..
Thanks for all your help. will check back soon.
Dale in asheville NC!!
1. Not surprising, if you got the Dunlop 4000's. According to the consumer reviews at Tire Rack, they seem to wear out pretty fast. As far as replacements, sorry, the MPV is my first minivan and it's only got 1000 miles on it.
2. Can't help you there.
3. Did you buy from a dealership? I would guess they would have one.
4. I haven't even checked my manual on the how to.
5. I believe that Edmunds has that info if you go to the specific make, model and year.
Told ya I wouldn't be much help.
2) pass
3)google mazda owners manual,,,or call e-mail Corp Mazda
4)pass
5)ask your dealer, google Mazda mpv recalls and tsb(technical service bulletin)
Congrats and good luck on your MPV
4. The spare tire is underneath the vehicle, below the middle row passenger side seat. There should be a small opening in the carpet to operate a winch mechanism to lower the spare tire.
the tires that came on it are the Dunlops so i guess the wear on them is common.
thanks again..
UPDATE ON TIRE INFO.....after reviewing tirerack.com due to the suggestions from many of you...i believe i have found another great option in tires for the MPV. Tirerack.com rates the Goodyear Assurance Tripleedge as the number 1 tire overall and the Michelin Hydroedge as the number 2...only problem is that it didnt list on tirerack.com that the Goodyear comes in a 17 inch rim size...which my MPV has (225/60/17). So....after calling a couple of local dealers, one of them found that they could get the Tripleedge in the 17 size....of course...they are expensive...about $165 a tire...but they appear to be the top ranked tire.
Just thought I would share in case some of you were like me and thought that you only had a couple of options with size 17's (and a couple of them werent very good options either....more Dunlops or the Continentals!!)
Does this reasoning make any sense? Or is the reliability of the 2004 and 2005 model on par? Will I be "wasting" my money by buying a new 2005 when I can get the same reliability and features by buying a used 2004?
Thanks in advance! I am eager for your feedback.
If I bought a 2004 I would make sure the manufacture date is later than say June 2004. As the first quarter of 2004 the transmission TCM reflash hadn't been addressed yet. Either way you go...you should be able to get a really good deal.
These tires are expensive...at least to me they are....150 each plus....but Tirerack has them rated as the number 1 tire. they do come in a 17 which tirerack didnt list.
Once you take the seat out, you'll see the channel that the seat slides in. How do you get in there to clean it? What do you use to re-grease the rails after you clean it?
I'm wondering whether the 2000 MPV ES works on a timing belt or a timing chain? I'm about to purchase one second hand (at 65000 miles) as I need a vehicle for 18 months while I am in LA. But I'm not sure whether I have to factor in the costs of replacing the timing belt, if there is one. Thanks so so much.
