rough and bloes out black smoke when you rev it up,I replaced the computer and 2 o2 sensors and it ran great until today and it is the same problem over again can anyone
give me any advice whst could be causing this problem again.
thanks,jmm
A tune-up, plugs and wires, might help.
Otherwise, higher octane gas is about the only solution.
I don't think I've ever read a complaint about pinging on a 4 cylinder. This usually is a problem with the 3Liter V6.
Thanks...
Bob
Right is the 'passenger' side'
Left is the 'driver' side.
You need a right manifold.
Any ideas?
In any case, check your fluid level.
ABS is complicated, requires different procedures to even 'pull the codes', etc. That probably why the shop did not want to work on it.
:shades:
1 is used for the temperature guage. I think this one has 1 wire to it.
The second is used to tell the 'computer' if the water temp is 'warmed up'. In other words, is the motor hot or cold. I think this sensor is bad, and it has 2 wires to it. (These wires may be twisted together and one may be yellow/black stripe.) The computer thinks it is doing a hot start and does not increase the fuel thru the injectors, something that is needed on a cold start. After the motor does warm up, it run ok.
Hope this helps
GasGas321
I had the same problems, and i believe you have the same problem as mcann. The idle air control valve controls idle, helping keep it up when cold, and down when warmed up
GasGas 321
I called a dealer and the service guy said he saw this once before and it was a wire that ran from the overdrive button on the gear shifter to the column. He said they sometimes short out and it could be it. Of course without looking at it I really don't expect an instant answer.
If anyone out there has had an experience like this or is more knowledgeable about this stuff than I am (it doesn't take a lot) PLEASE give me some input :-) I don't want to start tearing more crap apart if it isn't really needed. The service people here in Germany charge an unreal amount of money to do anything so I want to avoid them if at all posible.
:P
It has 80K ish miles on it. I replaced the throttle position sensor, plugs, wires, coil pack, valve job on both heads, all new gaskets, checked the fuel injectors with the ohm meter, and they are reading 13.5 ohms, which is within tolerance (12-16 ohms), fuel pressure is up, no codes are coming up on my code reader. I am running out of things that can be wrong with it, and still am not figuring it out.
Here is the kicker... I can unplug the wiring to cylinder 2 fuel injector, and the truck starts running worse, but if i leave it hooked up, i can unplug cylinders 1 + 3 fuel injectors, and the truck doesn't notice a difference. Ok, so i switched cylinder 2 and cylinder 3 injectors, and still, cylinder 2 is the only one to have an effect on the engine.
I have been working on this truck for a while now, and still, no progress. The misfire is slight, but still there, if you listen closely, and when you are accelerating on the freeway, it gets BAD. I hooked up the plug wires to the coil pack, according to my Chilton's manual, but when i do that, the truck will NOT run. AT ALL!! I can get it to spin over a couple of times, but the engine is trying to jump out into my neighbors yard. I hooked the wires up according to the firing order rather than what the manual said, and it runs well, but still has that little misfire. Any help would be nice.
There should be a little square box under your dash that has some prongs sticking out of the top of it, that hook up to some wiring. That box is what makes your blinkers work, and that is the sound you here when it is on. To find it, turn your blinker on, and follow the sound
The problem comes and goes. I keep up with maintenance and only go to major gas stations like Citgo, Shell, Sunoco. The problem comes and goes.
If it is low fuel pressure -- how does one correct this? I already had the fuel filter replaced, which didn't look terrible, even though it was rusted somewhat on the outside and the truck only had 30,000 highway miles on it.
Any input would be appreciated.
So far I have swapped the battery out with a known good battery. Pulled the alternator and taken it to the local advanced auto and auto zone for testing. Pulled the hood light, glove box lights and dome lights. All of which have made no difference.
I then measured across the battery under no/full load conditions with the car idling and I get about 14.2 volts. I also revved the truck up to 2-3000 rpm, and the voltage remained steady.
I then went and pulled each of the fuses in the cab fuse box and measured across each location in the fuse box to see if I could find a short (if the circuit is complete (or shorted) you'll measure voltage across the fuse location). Most of the locations measured 0 volts except for the following:
Location 21 Hazard Lamps
Location 24 Starter/Anti-theft
Location 25 Speedo/GEM
Location 27 Courtesy Lights
Location 28 GEM
I can see how the antitheft and GEM can draw power all the time, but the courtesy lights and hazard lamps kind of threw me.
Anybody have any ideas other than pulling fuses everynight and seeing if I can isolate the current draw that way? Is it possible for the alternator to test out OK, but have leaky diodes that can cause this problem? I'd also be interested in knowing what the typical current draw from the battery is with everything off- I think I measured something like 200 milliamps.
Jim
I agree change all three. I have a 95 2300 Ranger & the fuel pump just went out. Turn the ignition to "ON" you can't here the pump:( Original Ford pump $200.00 at the dealer. Car Quest Air-Tex pump with hanger $179.00. Looks like I'm heading to Car Quest for a pump & than changing all three relays.
The voltage you read across the fuse contacts is explained if the switches that control the corresponding devices are semiconductor-based, not mechanical. Semiconductor switches, when "off," do exhibit some leakage resistance which, when in series with the device being controlled, for example, a light bulb, completes the path needed for the voltmeter to see the battery voltage.
A better test would be to put an ammeter across the fuse contacts and measure the resulting current. Hopefully this will help isolate the current leak. Equivalently you can keep the ammeter connected in series with the battery and pull fuses/disconnect connectors until the 200 mA current draw disappears.
replaced the stater relay, the voltage reglater new
starter switch. help
Keep it in
HighGear
