We will see if it holds-up. In any case I am still outraged that Toyota seems to be downplaying an issue that could easily result in injuries or death if the ABS system engages at the wrong moment. I am also planning to file a complaint with the NHTSB and to contact my state Attorney General's office to discuss this with them.
Additionally, a few years ago we also had the same problem with the gas gauge reading empty (even though the tank was full) as noted in many of the other posts on this board. The problem with the gas level sensor and it was replaced when the vehicle was still under the 3yr/36 warranty.
I am also experiencing a problem with the brake light coming on periodically while driving, for no apparent reason. Once I turn the car off, the light goes off. Have taken to dealer twice. First time they said that I needed new brakes and replaced them. However, the next day, the light came on again. I took it back, and they said they think it was just that the brake fluid plunger stuck. Now the light is still coming on periodically and they want me to bring it in again. Recently, I have also experienced problems with the alignment. Initially, sequoia rode great, but since replacing tires, really bumpy ride despite having tires re balanced and aligned. Still checking into this issue. Anyone with any helpful info?
Good luck - hope this helps.
Help
I really enjoy this vehicle, but do have the "break light" problem. Took it to the dealer twice now and they can't find a thing wrong with it. It has done this pretty much from the start, started around 8-10K miles. This has not happened in the last few months, although I don't think it has to do with anything and its just a matter of time before it comes back. The VSC light did come on on a few occasions, but not recently.
As for alignment, I noticed that the tires wear along the outer edge a lot more than anywhere else on the tire. I rotated them agressively and have been able to make them last until now. I am now, however, due for new tires on this thing. At $150+ a pop, these are not cheap tires. I just don't have enough confidence in the dealers to be able to pinpoint a problem and fix it. Most, if not all, are just part-changers.
The one thing I dreaded happening w/ our Sequoia happened this morning. While my wife was on her way to going to work this morning, the VSC light and TRAC off light came on along with the check engine light.
I am going to call the dealer and bring it in this afternoon, I would appreciate any assistance from those of you with this problem before going on so I can be "Armed" as much as possible.
Thanks in advance.
Advisor had the tech hook the Sequoia up to the diagnostic machine and found the reason for the VSC/TRAC off/engine light on was because the gas cap was not screwed on tight enough. Tech took it out for a 5 mile test drive with positive results.
I drove the truck home and everything was 100%. Hopefully this is the extent of this issue. Cost me about $105.00.
Any luck with your fix yet?
Mine is doing the exact same thing.
Woody
We experience a jerk, or jolt symptoms upon release of the brakes & press the gas. Doesn't happen everytime, and can't describe all conditions it does happen in - but - sounds similar to some other problems described in this forum. It's not a "rear-ended" jolt, more of a bit of slack in the drivetrain feeling. Often it occurs after more aggresive braking ( but not always ), and more frequently after braking on a downhill stop, then a normal accel away from the stop(again, not always). Only does it at the moment of brake release & gas press. I've tried the "racecar" dual pressure on brake pedal & gas simultaneously, no difference in results.
Wife is getting nervous, I need a problem I can reliably demonstrate to take to the dealership ( shoot me now ) - anybody else experience this, or have any knowledge/insights?
Graham
I suppose, in any case, it does not matter. I have had it looked at by 2 different dealerships and they say it is normal for this vehicle. It has something to do with the energy release within transmission after a hard stop (??) I don't beleive it's detrmimental to the transmission, however, but it is annoying. :confuse:
Faulty component could make vehicles difficult to steer
Updated: 11:48 a.m. PT Jan 19, 2007
WASHINGTON - Toyota MotorCorp. said Thursday it was recalling 533,000 Tundra pickup trucks and Sequoia sport utility vehicles because of potential steering problems.
Toyota said the recall involved 2004-2006 Tundra trucks and 2004-2007 Sequoia full-size SUVs. The automaker has received reports of 11 accidents and six injuries connected to the recall, said Toyota spokesman Bill Kwong.
The automaker said there was a possibility of excessive wear to a front suspension lower ball joint that could make it difficult to steer the vehicle and stay in the center of the lane. Drivers may also notice more noise coming from the front suspension, Kwong said.
Toyota recalled about 775,000 pickups and SUVs in May 2005 — one of its largest recalls ever — because of similar problems with the front suspension. The recall included 2002-2004 model years of the Tundra and Sequoia.
Kwong said the company received additional complaints involving newer models of the Tundra and Sequoia, prompting them to issue the recall.
Toyota, which is challenging General Motors Corp. to become the world’s largest automaker, has aggressively touted its redesigned Tundra pickup as a strong competitor in the lucrative truck segment dominated by GM and Ford Motor Co.
The first Tundras built at Toyota’s San Antonio plant are expected in showrooms next month. The automaker recently unveiled its Tundra CrewMax full-size pickup truck at the North American International Auto Show in Detroit. The large pickup will arrive in showrooms in March.
With its expansion, the Japanese automaker has struggled with some quality issues. Toyota had 2.2 million vehicle recalls in 2005, but showed improvements last year when its recalls fell to 766,000 vehicles. Toyota President Katsuaki Watanabe has repeatedly vowed to enhance quality controls.
Owners will be notified in mid-February of the Sequoia and Tundra recall and dealers will replace the left and right front suspension lower ball joint at no charge to the vehicle’s owners.
I have had this same problem with my 06. What did you do to get it fixed? Has anyone else had this problem? What did you do to fix it?
Where should I start looking?
The car has 49000 miles. This just showed up today. I do plan to take it in for repair, but wonder if it is okay to drive.
I will give this info to the service tech that is working on it. I appreciate it.
How do you find the TSB reports? Are they online???
Thanks again
I'm looking for people who have had experience with Sequoia's. I just purchased 2004 Sequoia Limited 4x4 with 60K miles turned in on a lease. I had a 2004 4Runner and was looking to trade up.
The dealer didn't offer me an extended warranty, but after looking at prices ($1400-$2000) for additional 3-4 years of coverage, I'm wondering if it's really worth it to make the purchase now.
I have driven a lot of miles in the past, but have changed my lifestyle and hope to take at least another 4 years to get to 100K miles.
I've had the Sequoia for a week so far and I have noticed that the ride of the vehicle isn't as good as I had hoped. I dropped it off this morning at my local dealership to review the recall on the front lower ball-joint, to see if that is causing some of the problems I'm experiencing. I have also noticed a substancial amount of noise and vibration occurring at speeds of 50-75mph and I don't believe it's because of the tires (new Yokahama's + just had it balanced and alligned...or so the dealer claims).
My question is this: Should I consider the extended warranty or is it something that would be better spent somewhere else?
Thanks in advance to all who answer!
Mike
I just purchased a 2004 Limited off a lease and it doesn't have the remote either. I didn't realize it was necessary to operate the DVD entertainment until I put in a DVD and I couldn't get the screen to come on. I looked on Ebay and found a remote for around $100, but I stil think it's a complete rip-off.
http://cgi.ebay.com/LEXUS-TOYOTA-REAR-SEAT-ENTMNT-DVD-RSES-REMOTE-CONTROL_W0QQit- emZ270090085000QQihZ017QQcategoryZ79834QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
I'll go without before I blow that on a remote.
SUVs and Smart Shopper
I nearly blew a gasket.
Back to square one....Maybe BestBuy can help me out with aftermarket remote?
Anybody tried that?
I guess from your experience it would be a good idea for me to get one considering it covers me for another 4 years or 50K miles. That will get me well over 110K miles.
$1400 for the Gold protection warranty on my 2004 60K Mile Sequoia Limited.
For the center console, there are 2 screws inside the vent hole. If you push this vent windows face up, you will see 2 screws (one in each hole) after you take this screws out, this center console can pull out easily
You don't say if the handle will move. If it moves and does not open, chances are the cheap little plastic connector to the handle is brokern. If it does not move (probably break if you exert some pressure), you may be able to shoot some silicone lublicant into the pivot points on the handle.
In my case the connections to the rear latch were broken. I needed to find and pull the cable release after removing the panel inside the rear door.
Good luck .......... !
My question - my wife's Highlander has superior headlights to the Sequoia - does anyone know if they are interchangable, or, what is a comparable make/model? As I mature I find my night vision needs more help yet the Highlander still lights up my MA. country nights real well. I also know there is a way to 'polish' the cloudy headlamp covers to get the clarity back - this is on many web sites and works for any vehicle. But I am looking primarily for more candlepower, tks
Regarding headlights, you might check PIA, perhaps through the Anything Auto website. Some of the latest mega lumins replacements are there.
A question for you, what radio modifications worked well??
