I took it to the dealer and they have checked/balanced the tires, checked the drive shaft/differential and claim to have replaced the 'exhaust system'. So after two weeks of waiting, the vibration is much less pronounced, but I can feel it under hard acceleration/going uphill etc.
Any ideas/similar problems/suggestions ?
THis is the second problem in as many weeks I have had. Quality car? This is my second 5 series...brand new 530 03. Not impressed.
Good luck. Kim
Has anyone had the same problem? Any fixes?
If I wanted slow acceleration, I would've continued to drive my SUV !
PJ
They had checked the entire alternator/battery/charging system and found nothing wrong. My salesman intervened and insisted that they install a new battery.
Presto! After the car sat untouched and not driven for 3 weeks (we had a hurricane just before departing), I cranked it up yesterday and it started immediately! No problems! So the battery was the culprit after all! I'm relieved, and my faith in BMW is restored.
BTW, saw a new 2004 530iA sitting on display in a square in Budapest last Saturday. Gorgeous! Sticker was around $81,000! But I'm glad I bought the 2003 model.
your feedback is appreciated!
Have developed rattling/creaking noise from sunroof (only when closed). Goes away even when partially opened. Dealer tried lubrication w/o success in abating or eliminating noise. Any similar experience ?
If you go with H-rate winter tires, you can't avoid big bucks (ca. $130 each) - - CR recommends the Dunlop SP Winter Sport M2; also Goodyear Eagle Ulra Grip GW-2 if available and Pirelli Winter 210 Snowsport. These are materially better than all-season tires, but perform less well in braking & handling in dry weather.
All-season H-rated tires are "good" for snow, and they cost less (ca. $100 ea.) - - CR recommends Falken (but no self-respecting BMW owner would want it on the car) - - so the other choices are Michelin Pilot XGT H4, Bridgestone Turanza LS-H, and Continental ContiTouring Contact CH95. My choice would be the Conti since it is my OEM tires, and you can use them all season. These tires handle & brake well in dry and are "good" in snow as compared to "very good" for above winter tires.
Avoid the Bridgestone Potenza RE950; all around excellent in dry weather but has "poor" snow traction.
Had alignment checked. When the car is raised make sure the guy rotates the tires to make sure they are not out of round. I had to replace two tires for being out of round. This was on a new set of tires. When tires are made at the factory they will run the cycle so fast that the tires do not cool and set in on dimensions all the time properly. If weights have to be put on the tire make sure the weights are split on each side of the tire (front and back of tire) After this was done I had no problems with vibration from 60-70MPH
Also, Can I switch from 17" to 16" wheels and tires for the winter? There doesn't seem to be much of a choice in 17" tires
you could have a body shop dissolve off the existing clear enamel and redo it after dismounting the tires, but because the wheels hold the air that keeps the car in control, I would have a specialist do it for me.
I bought these 17 inchers and put Michelin Pilot Sport A/S on them. Although you do have more choice for high performance 17" winter tires now (www.tirerack.com). Depending on where you live this may work for you (though salt may accelerate clearcoat damage). In winter I run the original 16" wheels off my 530i with Michelin Pilot Alpins.
http://bmwtips.com/tipsntricks/headlightadjustment/Adjustment-fix- .htm
Hope this helps.
I recently purchased a 1999 528i, major service just completed. About 2 weeks ago, I filled the tank with fuel, started the engine and about 2 miles later, got a check engine light. I checked the gas cap, not loose. Went to a service center where the car was scanned, not faults found. The next week, I got fuel again and when I started the engine, the light went out! Car was running great and I was happy! Today, I washed the car and went for a short drive to remove excess rinse water, about a mile into the drive, you guessed it, the light returned.......car began to run crappy, poor acceleration, vibrations, ect. Does anyone have a suggestion??
Thanks in advance.....
Confused
Carried the car to a dealer today, cel still lit. The
dealer called me back and said that the light was out,
no faults. I got in the car and drove about 60 miles, all the time, cel was out. I stopped at a store, shut the car off. When I got back in the car,
the light was back on. Running o.k., but the cel is still lit.
HELP
It is what my BMW mechanic terms as an ‘intermittent’ fault
Yelenik
I last posted this message under "check engine prob, 1999 528i".
Now, the mystery continues. Basically, my 528i had been showing a cel at various times, no faults found. Two days ago, I decided to drive the car on a trip. When I left the cel was out, the frist time I refueled, it returned. Today, driving on the interstate,( cel still showing ), my wife reached up and flipped down the sun visor on the passenegr side of the car, and opened the vanity mirror. The lights failed to light, AND when she did this, the cruise control turned off, the radio turned off, the steering wheel tilted up and retracted, the trans indicator light came on and the air bag light came on!!!!!!!!!!!!! As soon as she closed the mirror, everything returned to normal except for the cel light, the trans light and the cruise control. The lights continue to burn and the cruise refuses to work. I also lost all controls on the steering wheel, ie, the radio functions, cruise...
The car continues to run very well, and a short time later the vanitly lights worked perfectly. WHAT THE HECK IS GOING ON???!!!!!!! If it were still halloween, I would believe that I am haunted.
All ideas, similar experiences, or help are GREATLY appreciated. My independent dealer still says that car shows no faults, however I am beginning to suspect an electrical short of some type.
Thanks in advance,
A frustrated but faithful BMW owner
thanks in advance
A new 525 owner.
http://bmwtips.com/tipsntricks/tips_pages/speakerlocations.htm
TIA
