If the starter is bad AND batt is then all the dash lights and headlight will work and car will not turn at all.
I have 2000 I30 that had occasional start problem...it turns out the positive terminal was loose
FWIW: I was using "green felt rings" to prevent corrosion. My mechanic told me not to use those as he noticed in 00 maxima and I30's if you use those felt rings the positive terminal gets loose after some time..
He has no explanation for it...it was just his observation/empirical evidence
1996 infiniti i30, v6 engine
My mechanic could not figure it out. Then he did a computer test and it said there was a TSB yada Yada. Brought to local Inifinity dealer who says that is not the prob. It might be O2 things and probably the catalytic converter. Total cost might be over $2K but they are not sure that is the problem. Still I have to pay that if I want them to try.
My other mechanic says No Way O2 and CC shouldn't only fail in cold weather.
So, anyone have this problem? I hate to pay $2k for a "maybe" plus the car is 10 years old (but only 84K miles)
Awaiting your thoughts!
Scott.
Sanjay
I too am getting code 1320 and dealer wants $1000 to replace all 6 coils and plugs. Debating what to do....I am in southern California
How much did it cost you?
Sanjay
- go buying a honda or toyota!
I orderd the coils from a infiniti dealer in Arizon ($75.00 each). Will install it this weekend. I think its a DIY job.
Found a good service manual at
link title
Probably is the coils but who knows??
As seeing that everyone is having problems with their coils, why didn't infiniti or nissan not do a recall.. sounds like something serious.
Service manuals can be found at
link title
best of luck
Sanjay
Goodluck!
Anyone have an owners manual collecting dust they can part with? Also, couple of questions from new owner...what is the TCS switch all about? And how accruate do you think the MPG reading is?
only once every 20 or 30 times that it will normally.
I have replaced the starter and the neutral/safety switch and checked the battery and no result... and noticed that i have like 9 error codes
Po110, p0130, p0325, p0400, p0750, p0755, p1740, p1746, p1760
the p0750 and p0755 are the A/B shift solenoids.
This morning i tried to start it and it did from the first try. and then back to its old habit no luck again as before.
Can you just replace the lens? Is it fairly easy to do?
I'm guessing you get access from the trunk panel liner.
It drove me crazy and replaced the started , safety switch and tested the battery, then i was on this web site and got an idea about the ignition switch and replaced it... it did the job for me with $28 job and 30 minutes of my time
so look into this and see if you are only getting a click from the starter and the battery is fine? try the switch
good luck...
Joe
What are the repair/maintenance costs on this car like? Would I need to take it to a Infiniti dealer for repair service, or would any mechanic be okay?
Does this car take regular unleaded or premium gas?
And what are the insurance costs like?
