Hyundai Elantra Accessories and Modifications
If you decide to do the rears as well, you can't just push the piston straight back; you have to twist as you push and kind of "screw it in". There are tools for this you can buy at an auto parts store (for as little as $10), or I've heard some people say they used needle nose pliers in the the little indentations in the face of the piston.
If you decide to remove the rotors, you may find they are stuck on and fused to the hub; this happens in some cases. In the exteme, they occasionally need to be cut off with a hack saw or sawzall and replaced. If they are not pulsing or anyting right now, leave well enough alone.
As for the headlight lenses, there are products available at auto parts stores for polishing them, but you might try using plain old toothpaste first.
will give my boyfriend infor on front brakes. is there any one brand 4 brakes?
How did you do it???
Thanks!!
On the Elantra with the wider, larger alloy wheels (SE),unless you have very small hands or special tools, it's all but impossible to install the rear guards without removing the wheel!!!
If anyone out there can help please reply to me.
Thanks so much for your replies.
Nan
I don't have mudguards. I just suggested that maybe a stubby screwdriver might save you from having to remove the wheels, but I said you might have to remove the wheels anyway.
The guide covers more of the physical aspect and doesn't recommend any specific brand. I have a Pioneer head unit and it's pretty good. Basically, any single-DIN size head unit will fit. If you don't plan on replacing your speakers right away, just go with a basic stereo that puts out about 20 watts per channel rms (50 watts peak).
does anyone know if it's possible to change the seats.. either from afternarket place.. or rven the boneyard.. is either this or LOOSE big on a trade..
Funny thing is that my wife has a 2000 model.. and to me that seat is better then the onw on the 2007. personal taste..and back problems.. not implying that these seats are bad for everyone else.
It comes with the alloy wheels.
I was considering purchasing wheel locks for it, and have found a couple web sites that have a set in the $18 to $24 range.
However I seem to find conflicting compatible part numbers and pictures and descriptions that go along with them and was wondering if anyone else has purchased them and know what the correct ones are for my vehicle.
Basically, I see 2 sets advertised. The copper-bronze colored ones that are very short, and an all-chrome really long set.
I assume since I have the alloy wheels on the SE the correct ones are the all-chrome ones to match the existing chrome nuts or doesn't it matter, other than for appearance?
I see them referred to as "with center cover" and "without center cover". I assume with means the chrome ones and without refers to the bronze ones?
I have found 1 site that claims to have the correct oem part number for the SE. Theirs is a net that includes 2 bolts with plastic T's on the end that go into the upper sides behind the blinkers, replacing a bolt that's already there. The net is a "U" shaped net. You spread it apart and the items stay upright and squished from the sides up against the back of the trunk.
I have found other sites selling more of an SUV type net that attaches more towards the floor and you lift up to put stuff under it. I don't really think these are the real correct net and might require mods to mount it?
Does anyone here have the factory net installed and know the correct part number for it? Does it cross with other cars like Accent or Sonata or are they different sizes? (I have only found 1 site with an 07/08 Elantra net part #, while most have tons of nets for the other models in Hyundai's line and wonder if they're really the same thing)
I saw aftermarket body moldings for '07-'08 Elantras on eBay for about $130. They are painted to match and don't look bad at all in the picture. Has anyone installed anything like that on their '07 or '08 Elantra? Anything I should consider when purchasing or installing aftermarket side body moldings?
2 little dimples in the bottom (that should cost $50 each to pop out) but a long folded metal dent in the top that scraped the paint. Estimate is about $200 or more on that one as the door will have to be disassembled, metal 'worked' and then re-clearcoated at the very least, hopefully nothing else.
Comparing the deflection of the metal on the Elantra against our 05 Tucson, and it seems the Elanta is a thinner metal and much more apt to flex with a light touch as compared with the Tucson. Did they get cheap with this recently?
I'm going to order the side moldings I saw on eBay next week. My husband can install them. I just can't even think about that first ding or dent happening so soon.
The Elantra metal doesn't seem any less sound than on my Honda Pilot. My wonderful husband dinged my Pilot within the first two weeks with a ladder he was using to wash the top. I still love him for washing my car for me, but I've been looking at that small ding on my driver side door for more than 4 years now.
Still looking for anyone with experience adding side moldings to an '07 or '08. I'd like to read your story!
I just don't feel like doing this on my own.
Just wondering.
Eric
There are 2 Hyundai parts web sites where you can buy the OEM front pair and rear pair for $14-$15 per pair, plus $8-$9 shipping. Meaning about $38 total including shipping.
Installation is really easy, and CAN be done by someone with no car knowledge but has at least assembled put-together-furniture . I did them on my 05 Tucson and will be ordering them for my 08 Elantra SE shortly from one of these sites.
The front is very easy, just twist the wheels to gain access and use a stubby philips screwdriver.
The rear ones are a bit tougher as the clearance to the wheel is tight. However if you get a thumb ratchet screw driver you can easily do it without needing to remove the wheel.
It's a 30 minute install assuming you have a small philips screwdriver. It really is easy.
thanks!
ez
thanks.
eric
It looks easy enough and I'm happy to hear the color match was excellent. I haven't had a chance to order my moldings yet, but I will soon.
These 2 are the cheapest "Regular" online stores. i.e. those with a friendly web site, some pictures (though may not be entirely accurate), etc..
http://hyundaipartspeople.com -- $15.00 + $8.95 shipping total ($38.95)
http://hyundai.dealerfit.com -- $14.04 + $7.95 shipping total ($36.03)
These links lead you to a normal store with similar prices to the above, BUT there are links to go directly to a OEM parts catalog. If you order by the exact part number, you save. You need to be 100% sure of the part number, and they make you furnish your VIN to verify to prevent you from buying and then returning wrong parts. Both link you to the same parts database/probable drop-ship location, just different 'store front'.
http://hyundai.partsdirect.com -- $12.25 + $9.95+ shipping total ($34.45 though may be higher--this was a baseline and they said it could be adjusted AFTER ordering)
http://hyundai-parts.com -- $12.50 + $6.50 shipping total ($31.50 !)
Obviously, I ordered from the last one. I also ordered the elusive cargo net for $17.50 with no extra shipping (most don't have the 07/08 proper net, only the older model ones or none in stock).
As far as I could tell through numerous web site verifications, here are the correct Hyundai OEM part numbers for the Elantra:
Cargo net: U8170-2H000 (08 specific -- 07 seemed to vary from a couple diff # but theoretically shouldn't since it should have the same chassis/post mounts?)
Front Pair Mud Guards: 08460-2H100 (07 or 08)
Rear Pair Mud Guards: 08460-2H500 (07 or 08)
thanks again!
eric
btw, your 3rd link does not work for me at all.
The Cargo net is not on many sites. The 3rd and 4th site above have it but you need to search the parts catalog by part # only, not browse the normal graphical showroom. When you connect to either site, the process is the same.
On the 3rd link'd site, on the right lower frame it says: "OEM Parts Catalog" and a little below it it says: "2. Search by Factory Part Number"
Or, on the 4th site, there is a link on the left side of the page that says: "Genuine Hyundai Parts" "Hyundai Replacement Parts". Click that link and a new frame will appear, hosted by "TradeMotion" (same for either site).
In the search field, enter the Hyundai OEM part number for the cargo net (U81702H000) and select "Hyundai" in the (select make) drop-down list. Click search and the following should appear:
Item Number MSRP Core Price Price
U81702H000 $25.00 $0.00 $17.50 (or $17.15 for the other site)
CARGO NET- HD ELANTR
The 4th link above is the cheaper shipping link. I was able to order all 3 items for only $6.50 shipping vs. $10 or more at the other link.
Also, you can find the net at PartsPeople site for $17.50 + $8.95 shipping:
http://hyundaipartspeople.com/SearchProduct.asp?Model=Elantra&catid=340532945968- - 9994&year=08&productdesc=Trunk+Cargo+Net
I also ordered the aftermarket body side mouldings from that ebay seller. Should have all by next week.
Also, I looked into the cargo mat and cargo tray for the 2008 Elantra. I didn't order either yet, but thought I'd list the part numbers I got from Hyundai just in case someone wanted them.
2008 Elantra Cargo Mat: 081452H000
2008 Elantra Cargo Tray: U81202H000
The word I got from 1 other site plus one ebay seller is that the mud guards are on backorder and not expected in until early august. I think a poster above said the same thing they heard from their dealer. I dont know if this site is any different.
In any case, the savings was so considerable on both shipping and the guards themselves, throwing in the net cost almost nothing comparably. If it takes a while to come in I guess that's fine. Wish I would have found this 2 months ago when I got the car!
i know what you mean about being out of stock maybe. plenty of dealers have the front guards but no rears. i even called some charlotte dealers as i was there for business the last 3 weeks- they said they had them on order for almost a month already. we'll see i guess. i just want them asap so i don't have to worry about issues with pebbles or the darn asphalt the've been throwing down to repair the roads around here.
i also may pick up the cargo tray for the trunk as well. it seems decent since we always throw a lot of crap back there that may be muddy or wet. we'll see though.
so far so good with the car- very fun!
enjoy!
ez
However.. I actually am a bit disappointed in them - they were not what I exactly expected. I haven't installed them yet, but they are nowhere near the "bulk" I expected to get. I don't honestly see how they will be adding much depth to the door to take the hit from another errant door instead of the rest of the metal itself (depending on the shape of the door that might hit mine of course).
I have had other cars with much thicker moldings, meaning thicker sticking out farther from the metal, plus wider as well. The pictures seemed to make it appear they were bigger than they are.
Anyway, as soon as I get my $300 damage that I already have on the door repaired (since it's just above, under and below -- yes, 3 spots -- where I will be installing this molding on) I will get this installed to hopefully provide a bit better protection.
Again, for $135 shipped, I am a bit disappointed in what they actually are. But we'll see if they help once I can get them installed.
enjoy.
ez
I looked online and found some affordable hitches. Anyone install one? Or anyone go through your dealer for one? I'm thinking Class 1 is good enough. Am I right?
Eric
