According to the book in Wal Mart. The oil filter seems to call for Fram 6607, SuperTech 6607. That's what I had in hand. But when I actually saw the oil filter on the car. Well, the original one is bigger. Can anyone tell me what is the right size for the Elantra GT? Thanks.
Before starting, make sure to stick a thin strip of foam adhesive insulation over the front of the filter. This allows the filter to fit more precisely and therefore does not let air pass around the filter instead of through the filter.
1. Open the glove box and remove the 2 rubber stop blocks from each side of the glove box.
First pull the stop block toward you (1).
Then pull the front edge in toward the inside of the glove box and pull it out to remove it (2).
2. Remove the glove box damper by gently pulling the mounting pin out, then feed the mounting pin through the hole. Hold/support the glove box to prevent it from swinging wide open when the damper is removed. Lower the glove box.
3. Remove the 2 screws that hold the metal bracket at the back of the glove box housing. Lower the bracket out of the way.
4. Push up and simultaneously pull towards you the two (2) filter cover tabs. The lower edge will pop out, slide the cover down to separate the cover from the three upper retaining slots.
5. Pull out the old filter and/or slide in the new air filter P/N 97133-2D000 with the arrow facing in the direction of airflow (down in this case).
FWIW, my Hyundai dealers master mechie still says Castrol GTX 10W30 is the only oil recommended for the central Texas climate, both summer and winter.
And at my dealer, an oil, filter, lube, and fluid top off is $19 including tax. Let's see, now. Oil at $2 a quart x 5 (and you have to do something with the leftover 1/2 quart) that's $10, plus another $5 for the filter ....
Guess I'm getting lazy.
i found two problem today, but maybe they are not a problem just a common.
one : when i use key start my car but not start engine only open the circuit, i can heart a "ka ka" sound, like a some electronic power on.
two: when i brake down my car, and the car totally stopped, i can heard a "shashasha..." noise, it is short ,in few second ,this noise disappear.
these problem is normal??
thanks lot
I know that Song. Sounds like Shell Shock by New Order? :P
I have seen these anti-squeal pads come off in as few as 1500 miles. And it isn't just Hyundai pads, either.
Is it that the engine is burning more transmission fluid? Is that a cause for worry? Did anybody have the same or similar problem? Please let me know.
Vishal.
It is important to note here that Hyundai is very particular that you use their tranny fluid.
Congrats on your new Elantra GT. Try a Purolator 14459 Oil Filter. They are the exact same size as the Hyundai stock oil filters. In fact, they look near identical except for the color.
Hope this helps and happy motoring
Shawn
1) Vehicle speed sensor, input and output malfunction
2) Vehicle speed sensor auxilary input malfunction.
Do you advise to go to a dealer or get it checked by a decent auto shop? The dealers will probably charge me hand and leg for that. Any idea how much that might cost?
Vishal.
Anyway, let's sum up what you should do about that shimmy...
Before going back to the dealer, check the air pressure -- make sure it's 30-32 psi when the tires are cold. The dealer may have forgotten to check this, and I believe that the tires are overinflated big time during shipment. Even if they did check this, there is still a chance that some tires are under/overinflated while the rest are ok. That could cause vibration issues.
At the dealership, they may just try a normal balancing and send you on your merry way. With the Elantra, though, this is probably not enough. Ask if they can check the radial force variation (RFV) on the tires. If any of the tires come back with an RFV higher than 18 lbs, they should replace them.
Of course, the dealer should check and make sure the rims aren't bent. Chances are they are fine.
Make sure to tell the dealer to tighten the lugnuts to 80 foot pounds. That can make a difference not just with vibration in the steering wheel, but also with vibration from rotors that are warped from the lugnuts being put back on too tight. Air wrenches without the use of a torque-stick is a big no-no!!!
If the dealer can't get it right on this first attempt, demand they swap tires and wheels from another Elantra that doesn't have the issue.
This is a common issue with the Elantra, and Hyundai had better fix it once and for all with the redesign next year. (Perhaps one reason they aren't releasing the new Elantra this year is to give them extra time to figure this one out. Hmm....)
As for down the road when the vibration comes back (it probably will), you'll want to find a reputable local tire shop with a GSP9700 (check out http://www.gsp9700.com for more info) to take care of your tires. Some have also had good luck at Wal-Mart for whatever reason as well
Good luck!
so i went to the dealer today...they ended up not charging me anything...and they said the shake was because my tires were not balanced correctly. They rebalanced only the front tires and the problem seems to be fixed.... only time can tell I guess.
P.S. These are the small, rectangular lights on the front corners of the Elantra that have the orange covers, and are mounded just in front of the front wheel wells.
As I stated earlier, this is not just a Hyundai brand issue, I have seen it on other brands of brake pads, both foreign and domestic. In the past, these pads were not used, but a paste was applied to the backer plate of the disc pad at installation. This can still be done by removing the anti-squeal pad and applying high temp compound to the backer plate.
I would go check on my GT, but it is actually raining here in central Texas. Amazing, but true.
I keep on getting the check engine sign and when I got the code checked it gives the code, P0500 which means "Vehicle Speed Sensor Signal Error Fault". If I turn the engine off and turn it back on, the sign goes away. Is it a serious problem? Can anyone tell me what could be wrong?
I had recently got the vehicle speed sensors (auxilary and input /output) changed as I had thos malfunctioning and the car was not changing gears. NOw it is changing gears properly, but it keeps on popping the check engine sign and the code P0500 from time to time.
Please help.
Vishal.
The sound comes and goes but has gotten increasingly louder when it occurs and it sounds like there is a big rock in my wheel that makes noise as the wheel turns like this: Wckkkkkkkk, pause 1 second, wckkkkkkkkkkk, pause 1 second, etc. I can only hear it when I'm driving at lower speeds (35mph or less) because ambient noise on the freeway muffles out this sound. Thus, the faster the tire rotation, the faster the sound occurs.
I haven't seen anything like this posted on the forum so I hope somebody may have some input. I did notice the outer edge of my rotors are rusted a bit but I don't think this is what is causing the noise. Something about the caliper or bearings maybe? Please any input would be helpful. Thanks for your attention.
Jim
This does not happen all the time however, when it does it usually occurs when passing
at 60-75 mph or when shifting gears. You can see/ hear the rpm's go up, but car speed
does not increase. Usually have to let-up on the gas until they are engaged.
Before I go to the dealer (nearest is 95 mi) has anyone else had this issue.
Thanks of any information.
I recall the 01 Elantra having knobs that were VERY hard to adjust. I bet they don't pop either. (Can anyone here with an early 01 vouch for this?)
The seat in my 02 (with the easier-to-adjust knobs) stayed tight for about a year, and then it started to pop here and there after. Basically it doesn't do this unless I really move around in the seat. I also hear a creaking noise when I make right turns at certain speeds (it's worse in the winter, but it's not horrible either -- just mildly annoying and a reason to turn up the radio!). I'm pretty sure the creak has something to do with those knobs, as my body weight shifts toward the left (where the knobs are) during those right turns.
Of course, I can get into my passenger seat and it's solid as a rock (and it never makes noise when a passenger is riding with me).
People on the Kia Spectra board complained when the new model (based on the Elantra) didn't have a very adjustable driver's seat. I bet this had something to do with the issues the Elantra's driver's seat has had. Less adjustments means a more solid seat over time.
BTW, this issue doesn't have anything to do with the seat track issue the IIHS discovered in their tests of the 01 Elantra (which was fixed for 04). The driver's seat in my Elantra stays on the track just fine. It's just the cushion that's shifting ever so slightly because the knobs on it don't stay tight over time.
Could my pedal be softer than usual because all the rotors have been turned? The pads are all recent. Right now I have about 38K miles, and I had the brake work done a few months ago (when I was around 34K).
I've noticed some recent reviews for the Elantra mentioning the brakes being soft. It's interesting that this didn't seem to be an issue in years past. Why would 4 wheel disc brakes feel kind of soft anyway? Shouldn't they have more "bite" to them? Some have mentioned "progressive" braking before, but if you really have to almost stomp on the pedal to get the car to stop on a dime, that doesn't do much to add to my driving enjoyment.
Any ideas? Should I get both new rotors and pads? Is the master cylinder in my car starting to act up? Or am I just dealing with 2 different Hyundai dealerships that can't seem to properly bleed brake lines? (My car has ABS as well, which I believe has a slightly different bleeding process than non-ABS Elantras.)
On the '01 GLS, I do need to wiggle the driver's seat a bit when I slide it front-to-back to make sure it is locked. Once locked, however, it stays put.
The GLS seemed a little more prone to front lockup in panic situations, but by no means overly sensitive.
As a buddy once said, "My driving style doesn't warrant ABS, and if some idiot does something stupid I want the sound of screaming tires to reinforce his lack of judgement."
It is not uncommon to lightly turn the rotors on pad replacement. There is only enough material removed to take the "shine" off the rotor. This allows the new pads to seat more quickly, and also eliminates any pulsation felt in the pedal from the rotors being warped. Warpage can come from several causes, some as simple as water splashing up on the rotor when it is hot from braking. This is not specific to Hyundai, but a fairly common occurance.
Let me assure you that the Elantra has a very good braking system, and is well sized for the class and weight of the car.
Either way, my motto is that a problem is easier to check in a garage in the shade, than on the road in the rain!
30K miles
Driver over 50 (single/no kids)
1) Paint luster is low. Must keep car waxed (every two weeks).
2) Driver seat creaks.
3) Clutch pedal creaks.
4) Windshield has waves in the glass on passenger side (since new).
5) Paint blistered off 1/8 inch hole in front of sunroof (used touch-up paint).
6) Front brakes make that sound that indicates the anti-squeal pad has seperated from the brake pads (sometimes).
7) Front sway bar bushings need lube.
8) Had to use silver enamel touch-up paint on wheels as original finish is starting to chip.
9) Headlight lenses not as clear as new.
10) Leather on drivers seat is starting to wear slightly.
So there you have it. Some are nit picky (9). Just wanted to list the things that will go wrong with your Elantra 3-4 years down. Having said this...I cant find a car that I am lusting after right now. Closest thing I guess would be the Mazda 3 hatch but some days I think that car looks funny. I guess I'm stuck with my baby till whenever. Good thing I still like it :-)
2001 Elantra GLS
35K miles
Driver under 50 (married, 3 kids)
1) Paint luster is like new. Wax car 2-3 times a year. Several small door dings.
2) No creaks in driver's seat.
3) Clutch has needed repair on throwout bearing twice, after it started creaking in warm weather. Covered under warranty.
4) Windshield replaced a year ago due to stone.
5) No paint problems that are the fault of the car.
6) Brakes work like new.
7) Ride and handling still like new, smooth and noise-free.
8) Plastic wheel covers don't chip like alloys.
9) Headlight lenses have some tiny pinprick from road grit. Never have leaked.
10) Cloth interior still looks like new.
Purchased my car in Oct,2001 so my 5 years should be up in Oct,2006. Since I'm at 30K now I will hit the time limit first.
