You might thing about reposting this on the main board (you'll get more reponses). Yes, I would do it again in a heartbeat. Not just because of the car but also I am impressed with dealer service. I've owned other makes like Honda and Hyundai just seems to bend over backwards to keep me happy. This is my experience with my local dealer, your milage may vary. Any little complaint I had they fixed with no argument.
The car itself is more than I expected. I have the 5-spd with no ABS (GT) and the brakes are the best i've had in any car (really). The engine has enough power to keep me interested and ditto the handling. I have mine for 1 year and 11K miles and its been dead reliable. I parked next to a new Honda Civic Si the other day and decided the GT looks much better, much more interesting body lines. How can you argue with the features you get for under 15K? I would recommend this car to anyone (including a relative).
The short answer to your question is: yes, indeed, I would buy another of these cars. There is no better value, and Hyundai reliability continues to impress me.
It goes away when you stop at a light. It doesn't seem to get louder with higher RPM's.
Anyone hear this?
The first time they replaced a wheel bearing. This made very little difference. Today the mechanic went on the computer and saw a bulletin from Hyundai indicating that the elantra may need to have the suspension and engine bolts torked (tightened).
I also have a big problem with the Champaign color on the car. There is one chip on the passenger side that goes deeper than the paint color and the other side has more than five different scratches on it.
There is only 3000 miles on this car. I've owned probably 6 -7 other cars over the years none have reacted this way.
Has anyone else had the suspension problem described?
Would someone out there please help me to understand the 3 year warantee on the paint?
What is the dealer supposed to do for an owner with the paint problems listed above?
Has anyone experienced the same?
I believe one owner had the windshield reseated by the dealer and the problem went away. I guess I'm a little gun shy about doing that 'cause the last time I had a windshield replaced, I returned to the dealer to find a large burn hole in the passenger seat. Guess a heat gun is used in the process, and it slipped out of someone's hand. Of course, the dealer replaced the seat, but it took a month for it to come in.
Let us know if you do ask the dealer to do something.
I have the same sound coming from my 2 week old 2002 Elantra GT auto. It sounds like someone is crinkling plastic bags. I don't hear it when the road is perfectly smooth. However, when I go over a little bump I hear the crinkling. The noise I hear is not a motor noise and is not tied to RPM's. I thought it might be from a loose wiring harness. It only happens when I go over bumps, even small ones.
Also, I'm sure I hear it after the car warms up. I don't think I hear it in the first 5-7 minutes of operation.
Does my crinkling sound appear to be the "windshield" problem?
If so, where did you see other posts?
I just decided today to have my vehicle replaced under the lemon law. I really like Hyundai, and so I don't want the money back but I just had too many problems with my current car, so I want them to get me a new car. First, I constantly have rattles in my doors, which they tried to fix once with no luck, and the second time they said they couln't here them. It is true that they where not present at that time but I don't have time to go to the dealer right after my door starts rattling. The door seal had to be glued as well and it is still sticking out a little bit. Then the main problem I started to get was a cluch noise, resistance. The first dealer tried to fix it once, which did not help, and then they tried to order and replace some switch which even I knew was not a problem that was causing the noise. They returned the car to me with the same problem like it was already fixed. I thus went to another dealer. There, they replaced the main clutch cylinder, which did not help, and finally decided to rebuilt the whole clutch assambly which fixed the problem. After 3 months of driving, I am starting to get the same problem with the clutch (rubbing noise). They tried to fix it more then 4 times and they did not fix it so I have a reason to file a claim, and I am just doing that because I don't have time to go to the dealer everymonth with a 9 mo old (now) car. Also during the summer, my instrument pannel window cracked from the heat. They replaced that, but I had to go back because a piece of plastic was sticking up from the instrument pannel which they had to adjust. Just a lot of bad service. Currently I still have steering wheel shaking while braking in high speeds, so I assume the breaks or rottors are going bad, and I won't even bug them to fix it because it is too much trouble. I also have a wistleing noise comming from the left top driver side when going above 85 miles per hour, which they can never check, and finaly my trunk starts to squeek. You can see how many problems I have and it should not happen on a new car. The thing is, I love the car for the price. You get everything in it, plus a great ride and performance. I just don't want it to break that much. I hope they will give me a new car, and it will be more reliable.
Just wanted to share it with all of you.
Also, within the last week of having the car the drivers window won't go down with the "one touch" feature. Sure it's a switch replacement.
Have all of 600 miles on the car, even with the above hopefully minor problems, I certainly do not regret the purchase. Enjoy the drive.
But, brand new purchase price under $10,000 with cruise, mudguards, and wing, all repairs done free under generous warranty by my friendly dealer, decent power and handling, roomy interior, loads of comfort and convenience features, good ergonomics, comfortable seats, acceptable gas mileage for car of this interior volume and engine power, and the prestige associated with owning a genuine exotic Korean car...
Yeah, I'll keep this one in the family for a long time. And probably buy a couple more over the years (4 kids here). The improvement in the Elantras over the last 5 years (and company growth) is amazing. If it continues and the car remains available at the bargain price relative to the competition, I may not buy any other brand. I may replace our aging Ford Windstar with a Kia (Hyundai) Sedona van soon too.
Bottom line - still very happy and car seems to run even better as it gets more mileage. Only negative is lack of lighting in back seat area.
I just purchased my 2003 Elantra GLS yesterday and I have that same whisteling noise comming from the driver's side window. Did you find out what it was?
I am glad to hear that you have not given up on the company (I may have if I were in a similar situation). My '02 GT has been really great - I am happy with its features, value and cost. We have had no problems whatsoever - so, stay determined and politely insist that they address and document every problem.
Not to say that's what your wind noise is, just thought I'd share that little tid bit.
have a good one.
It is hard to describe where the sound comes from.
My last post said that the dealer was going to seal the windshield. They sealed it, and the frequency of occurences has dropped a little, but not enough.
Two of my visits resulted in the mechanics driving my car 30 to 50 miles per visit. A good tactic by the dealer to make me give up and not want to bring my car to them.
Oh well, if someone knows a solution that really works let us know. I will eventually try a few things like duct taping suspected areas and maybe pulling off the hub caps.
Otherwise the car has been great! Except for the gas mileage(22-26MPG) but than maybe I shouldn't be going 80+ mph...
I am still in the process of the lemon law complain, but I think everyone should know what happened to me today. So after a place to complain with the BBB, Hyundai contacted me to make an appointment with Loren Hyundai in Glenview, IL. where one of the repairs was made to show them my problem. So I made an appointment for today morning. I went to the dealership and asked for the service menager with whom I talked on the phone. He came over and said that I have made an appointment for yesturday and that I did not show up and he called HMA and said that the problem was resolved. I told him that the person who I have talked to must have made a mistake because, although he mentions about comming thursday, I told him that I couldn't and with both agreed to make the appointment for this friday. He answered with an attitude that it is not the other person that made a mistake but I have made a mistake and I have come in the wrong day when he only had one mechanic. (first) Then I told his that it only takes a few minutes to check that I have a problem with my squeeking clutch, and I can do it right there. So he made a face, and came to my car. You know what he said, that the squicking and rubbing is normal and that there is nothing wrong with the clutch. I asked him how come they tried to fix it if there the last 4 times if it was the same thing, but he had no answer (ofcourse because the clutch is broken again) and said that he does not know what they did before but this is normal. (second) Finally I told him that he should call the HMA and we have to straighten this out, and he said that I should call them myself, and when I asked him if he has the number he said that he wouldn't, and finally he told me that if I don't have the number I should call the BBB. (third) Finally I told him that I don't know what his is talking about, but the clutch is not supposed to sequeek or rub like that. I told him that my girlfriend has bought 2003 toyota corrolla and I drowed it many times and the clutch is butter smooth. You know what he said. That maybe I should get a Toyota, and that hyundai is not toyota. (fourth). I could not believe it. I went to the dealer where I got the car and ofcourse he said that the clutch was broken. I got the number for HMA there and I called them and made a complain there. I don't know if that is going to do anything though. Is there other place I can complain to so I can get this guy fired. It is kind of hard to get those guys since he is the service menager. This is ridiculus. Also HMA told me to make an appointment again with the other dealer, but when I call him he told me that he has nothing to do with is and I should contact HMA. (nice little cirle). So I'll call BBB on monday and make some more complains. Ohhh, and by the way, before I told you guys that I just wanted an exchange, no I just want all my money back with no subtractions, and I told that to BBB today. I am going to buy a Toyota like the guy told me. Maybe he was right :-). I will never buy Hyundai again. They are very nice when nothing is wrong and when you pay them.
What good is the incredible warranty if you always have to take the car to the shop instead of driving it? And if you drive it, it is never a pleasant, comfortable, noise-free drive.
I can't wait to have some money to trade it in for a Toyota or Nissan.
Tran
