Look closer, you probably have paint chips that were not tended to in time. Get a bottle of touch up paint, clean and fix the ones that are not peeling yet.
>>rebadged Escape
Umm.. actually I wasn't. If you read my previous post I said the new Mazda crossover. This vehicle is called the CX-7, and it neither looks like nor is anyway related to the Ford Escape. You can check it out here to verify: http://www.mazdausa.com/MusaWeb/displayPage.action?pageParameter=upcomingCX7
As we were driving and i was noticing the problem still there(he of course denied it), I asked him what my options where, if i cant get the problem fixed is there a chance of a rebuy.(BIG MISTAKE I MADE)
From being the nicest guy in the world , he transformed like HULK and started to get really smart with me, so the conversation ended.In otherwords he said that he found no problem with my car!
Now i am going to quote you all in on what he wrote on the first workorder invoise.
"WE INSPECTED CAR FOR PULL TO THE RIGHT.WE CHEKED AND FOUND THAT THERE ARE NO PROBLEMS WITH THE CAR AT THIS TIME. WE SPOKE TO THE CUSTOMER AND TOLD HIM THAT THERE WERE NO PROBLEMS WITH THE CAR BUT IF HE WOULD LIKE WE CAN CROSS ROTATE THE TIRES. THE CUSTOMER SAID THAT WHAT EVER WE WANTED TO DO WOULD BE FINE. WE CROSS ROTATED THE TIRES AND TEST DROVE TO FIND NO FURTHER PROBLEMS AGAIN .THANK YOU FOR COMING IN TODAY."
I must confess when i read it , that time it was me who turned in to the HULK!!It took me 3 hours and a thret to call the police and|or a lawer and the intire management team to finaly have them put in writing what really accurd .
Now I will quote to you all the second workorder invoice from that same exact day.
"CUTORMER STATES CAR PULLS TO THE RIGHT, WE INSPECTED TO FIND CAR HAS PULL TO THE RIGHT,WE CROSS ROTATED TIRES. CUSTORMER HAS TAKEN DELIVERY OF CAR AND IS STILL NOT HAPPY. THANK YOU FOR COMING IN TODAY."
At that point i still had the first workorder in my pocket oviosly not sighed but in my posetion ,and good for me they forgot about it.Only when I had the "realistic"one in my hand i reminded them about it.By the look on there faces it seemed like they wanted to remove it from my posetion with force, so i immediatly exited the office where there was other custormers.They even followed me to my car trying to convince me to give it back, i got in my car and took off.
I am new in this country and dont know how the sistem works, and dont know what step to take now.
If anybody has any idea or experience in these cases please, I am open for all sugestions.
and also fill free to contact me at dariell@volcano.net
PS. PLEASE BARE WITH MY POOR ENGLISH
Philippe
I think I would CALMLY go to another dealer. This should be an easy fix.
I have a question. ...When I go to the National Safety Association website, there are 3 TSB's listed for 2005 Honda CR-V. I printed TSB 05-022 and brought it in with me on my second visit to the dealership, but the other 2 bulletins refer to the pttr issue as well. Has anyone read these? I cannot open them to read, you have to pay to have a search done and it accepts only American addresses. The TSB I have printed was courtesy of a forum user.
Buy "add-a-circuit' from auto parts store. Plug it into the radio, or power outlet adaptor fuse. It will come with a socket for original fuse and an additional socket and a wire.
blueiedgod
Thanks for the reply. I’ll check out your suggestion, though I’m still a bit perplexed as to why my regular routine does not work on the CRV
t
blueiedgod
Just thought I’d post the resolution:
It was the paint on the bolt I attached the ground to.
A little scrape and the Radar Detector powered up
Thanks again
t
Phil.
Thanks again
t
Still use "add-a-circuit" to power the radar. This way it is protected by its own fuse.
t
Anyone knows how to fix by DIY? Or how much it will cost if send it to dealer to fix? Thanks!
Disgruntled, I called Honda and was advised to check it when the engine is cold. In short, I filed a complaint against the dealer. Not only was my ATF below Honda guidelines, they provided me with a 2005 owners manual for an 2006 car!
My first question is, when do you check the atf level of the resevoir tank - when the engine is running or when it hasn't started?
I am now getting harassing phone calls from the dealer Clair Honda Boston (www.clair.com)because I complained against them with Honda.
PLLLLLEEEASE HELP!!! (THANK YOU!)
I'd say get a new mechanic. The 2000 CR-V is rated to use 5W-30. The lower the W number the better it flows at lower temps. Yeah, any oil will do, but the repeated oil starvation on start up will eventually show its ugly head as excessive wear. The difference of "no pour" point between the 5W and 10W is about 20°C. As the temps get lower the parrafin in the oil starts to crystalize. Oil manufacturer's add "pour point" depressants to make the oil flow at lower temps. But these depressants wear out after about 1000 miles. So for the rest of your 3000 mile interval, you are starting up an engine with parrafin was in it for oil (not literally, but close) The lubrication does not start until the wax is melted and the oil is flowing, which may take 10 seconds, (Approx. 9.95 seconds longer than synthetic, 9 seconds longer than conventional 5W oil)
I'd say use true synthetic (Mobil 1, Royal purple, or even Amsoil) for the winter, as those are created without parrafin wax in the, and naturally flow at lower temps. Castrol and Valvoline sythetics are mostly highly purified dyno oils that have the same problems.
Change the oil to Honda specified 5W-20 weight, if you are lucky that goop (10W-40) did not damage the VTEC solenoid. If it is too late, you are looking at $800 repair.
Did you air down the tires before venturing out on the beach? Even JEEPs with lockable 4WD do that.
I doubt anyone has made a manual AWD switch as it is pressure activated and you would have to add an electric pump to pressurize the fluid to activate AWD. Once AWD overheats it will automatically shut off. Try replacing the fluid in the pumpking with fresh dual pump fluid. Do not use anything else.
Call local junk yards and see if they have CR-V's. Most have "pull your own" policy.
Has anyone had rust problems with their new 2006 CRV's?
The reason I ask, is that I was recently at a Honda dealership. It's January 2006 in Canada. So we are in our winter season. However, I was looking at the CRV inside the dealership and CRV's on the lot outside. I noticed that the muffler has rust on it. Could this be possible for a brand new CRV?
How can new vehicle have rust on the muffler already?
pogs
I'm no expert, but I believe a manual (05 or 06) will indicate that you are to check your Antifreeze/Coolant level in the radiator ONLY when the engine is cold. Doing so at another time is very dangerous because it will be under pressure and at high temperature.
I believe the level that is really critical though is the one in the resevoir. It should always be between Min and Max. If it goes below Min, you have a definite problem and should check the level in the radiator (but only when the engine is cold) and the rest of the system for leaks. If at MIN, I think they suggest adding Honda fluid to the MAX line in the resevoir.
Ultimately, I think your level in the radiator will normally fluctuate a bit and perhaps not be at the very neck when you look in there (again when cold), but you should see it. If you can't even see it when it's cold, or your resevoir level (when cold) continues to decrease, perhaps you have an issue with the resevoir or piping to it, or a leak somewhere inthe system.
I'm sure your manual tells you to use a special Honda Antifreeze which is pre-mixed with water if you need to top the system off.
As for your manual which you do have, I'd read the section on Engine Coolant, and I'd call Honda at the number in the back of the manual you do have and request one for the 06. Provide them with your VIN. Also, I think an 06 manual is available under "Owners Link" when you register it with Honda. The dealership told you about "Owners Link" didn't they?
5w30 is what I use in my 1999 CR-V here in Indiana, which has the same engine as your 2000. And while we don't get quite as cold for as long, we usually have at least a couple of weeks that drop below 0 F (about -20 C) during the winter.
Definitely go to another dealer though, it sounds like they've put you in their black book and will not listen to you anymore even if you are correct.
Good luck!
My conclusion: The CRV has definite torque steer for sure AND is very sensitive to uneven tire wear. I realized that I noticed PTTR the most after I swapped out the left front tire for the new spare after a puncture! A good dealership should solve the problem to the point where it is bearable. Marin Honda took care of it for me.
BTW-pulled an 800 lb trailer today, barely noticed it back there.
"An occasional problem on this vehicle is failure of the Exhaust Valves or Valve Seats. When the Exhaust Valves or Valve Seats wear the valves can burn. The cost to repair the Exhaust Valves is estimated at $250.00 for parts and $559.00 for labor. All prices are estimates based on $65 per flat rate hour and do not include sales tax."
Is this really a common problem with the CRV's? So many people seem to be happy with them, and I always thought Honda made bullet-proof engines. In looking at used CRV's are there any factors that I should look for as warning signs of impending exhaust valve trouble? such as valve adjustments early and often?
Heck, I got almost 60k out of the original tires.
You've had the PTTR corrected, mostly, and then it returned. And now you feel the problem is solved. Please post on this again after a few thousand more miles. I suspect the problem, like Jason or Freddie Kruger, will come back.
I bought my 2005 with the expecation of driving it for five or six years. Do you think the dealer might continue doing the tire rotations, damper adjustments and wheel alignments every few months -- the regular "fixes" for PTTR -- at no charge for that many years?
I've said it here before: we're not doing brain surgery in the cargo area, we're hauling baby furniture. The constant and fine calibration required makes me wonder which of those tasks this machine is made for.
I've got a '99 CRV with 115K miles and didn't know about the valve issue until almost 105K miles, which is when I had my valves adjusted. But I haven't had any problems.
I just brought a 2006 Honda CRV a week ago, and drove 250 miles now. Two things I noticed make me uncomfortable with this brand new product.
1. Actual gas mileage is 21 on freeway drive (no rains, no snows, no strong wind), not 22 (city) - 27 (highway) as specified. Will it get improved after the "break-in" period?
2. Temperature gauge pointer stays in the position of just little above the middle of the guage. I tested other 06 CRVs, the poiters are in lower 1/3 of the guage. Does my CRV engine works at higher temperature than other CRV with 1/3 gauge pointer position? My dealer told me it is normal, but I am not sure about what the dealer said.
Your knowledge and experiences on those issues are greatly appreciated.
How did you arrive at 21 MPG over just 250 miles? Check previous posts on how to calculate MPGs properly and at high level of confidence. 250 miles is just not enough miles to make is a reliable number to go by.
I get more than EPA estimates on my 2005 EX with manual.
As far as the coolant temp, see if it is low. You can find the instructions on how to do that in the owner's manual. If you have to add some, only add BLUE Honda antifreeze.
While your reading of slightly above the middle is within spec, I have rarely seen a Honda go above the middle point.
Actually, 21 is about right for 270 miles driven on a full tank in my experience. I get that in mixed driving. At all freeway I will get around 25 - 26 @ 75 MPH. How fast is the freeway driving? Also, are you stomping on the pedal, or using it more conservatively? Keep away from the 3200+ RPM range unless really necessary. Cruise control will help, if it is safe to use it considering the traffic.
I have a 2003; different transmission, but the new ones should be better than mine.
My MPG improved after the first 3000 miles or so.
antifreeze at or below the low mark. Went back and added
more antifreeze mix and everything is fine.
Most of my experience is with Toyota/Lexus vehicles, but
find it common to need to refill the coolant reservoir
after the system has been drained and flushed and air is
cycled out of the system.
Surely they gotta be bluffing, can this be true???
I mean lets face, a circumference discepancy of a few milimeters can be found between a new tyre and an almost bald tyre anyway, does that create a $5,000 bill too.?
Help me out guys, I'm begging!
I'd love to ignore them but my 2 year old kid goes in that car everyday and I can't take a risk.
PS, Please dont tell me to chase Costco, my wife lost the receipt and so I have no proof it was purchased there.
Did the dealer say the clutch is definately gone and needs replacing or that it will go soon? You could also take it to another Honda dealer for their opinion. Also, try calling American Honda, the number should be in your owner's manual.
Yes, the RT4WD system is very sensitive to tire size.
I would get a second opinion on that rear drive problem (AFTER replacing the tires, so the dealer doesn't have a "hint" that there may have been different tires on the car). An unscrupulous dealer might well try and get an expensive repair job when he notices a different tire size.
BTW, COSTCO policy is to replace tires with ONLY OEM compatible tires. They stock such tires. That COSTCO messed up and violated company policy.
As far as Costco receipt, they have it in the database, forever. All you need is the membership card.
I don't think the RTAWD is damaged, but the cicumference difference is not just mm, but more like 3.14xdifference in cm. So, if the new tire diamter is 5 cm more, then you have 3.14x2.5 = 7.85 cm difference. I doubt it affects AWD. The speed difference is mainly across the rear differential, not from front to back, because your other tire is the same as the 2 front ones.
Here is the thought. Put the spare tire in place of the new one, and keep the new one as spare. You can do it either now, or whenever you rotate tires next time.
Thanks for any help or ideas.
Bill
Needless to say I used the automatic starter the next day and the car was starting fine.
The following day I tried to unlock the doors and start it manually - and the same problem again. All other power and electricity but no engine. I called the guy who installed my auto-starter/cut-off/alarm and he showed me how to bypass the cut-off switch - still nothing, He came over and tried it - nothing. He used a harness to bypass the system and even brought a new ignition switch thinking maybe it was that - same thing. He has a few ideas of what it possibly could be but I want to know if anybody has any ideas.
Also, I know it makes sense to use the automatic starter to at least get it running, but the Honda alarm system with auto-start has a safety for manual cars and once you manually unlock the doors to your car without starting it first with the button - it disengages the starter until the next time you stop the car the way it needs to be (I'm sure those of you who have manuals know what I mean).
Does anyone have ANY suggestions or have gone through the same thing? Your input would really be appreciated.
The engine has abrubtly cut off twice in the last few weeks (no warning lights). Everything seems to function fine after the engine cuts off (i.e. all the power systems brakes, steering, etc) and once she pulls it over to the side of the road it starts again with no problem.
We took it to the dealer where we bought it to get it checked out and they can find nothing wrong (no error codes, and can't reproduce the problem).
We're stumped and my wife doesn't feel safe driving the vehicle until we know whats wrong.
Anyone have any advice?
