Lost? Ask the M&R Host for directions!
What can I do to get the tip if the key out of the ignition? Can I get a replacement cylinder assembly and new key?
thx,
Dave
What do I need to do to keep the fuel flowing? I've put 5 gallons of fresh fuel in the gas tank. I've taken the fuel line off infront of the carburetor. When I press the gas no fuel shoots out of the fuel line.
thx,
Dave
ALSO, once you get it running you may find that you have contaminated fuel in your fuel tank. Gas will go bad after a year or so, so you may have all kinds of gum and varnish in the gas tank that needs to be cleaned out.
But start with the simplest things and work toward the complex.
- Transmission mount
- Exhaust manifold
- Struts & shocks
The car also leaks quite a bit of oil and I am told that to fix this would be very expensive.
Anyway, I want to sell the car and am wondering if these things should be fixed first, and what a fair price would be?
Thanks for any help.
Chris Milligan
It all depends on whether these deficiences are readily noticeable and will spoil the prospective buyers' test drive. You are sellling a used car, not a new one, so you're not obligated to recondition the automobile. But if it clangs and bangs, or spews exhaust fumes into the passenger compartment, well of course you need to do something about that.
I rather doubt anyone would notice if the suspension is worn on a '90 Cadillac but an exhaust leak, yes, and they may spot the oil, too.
As for the value of the car, you can do an appraisal right here at Edmunds, using their nifty True Market Value software. You can even do a custom appraisal for your area code and compensating for mileage and condition.
Go here for that:
http://www.edmunds.com/tmv/used/index.html?tid=edmunds.u.mainindex.appraise..1.*
Hope all this helps
MrShiftright the Host
ECM Code E040 - Open Power Steering Pressure Switch Circuit -
(Engine Control System and Service Soon messages also present)
1. Where is this switch located?
2. Under what conditions is the switch supposed to be open and closed?
3. Can the pressure be tested in some way?
A message "Cooling Fan Fault" is displayed on the Driver Information Center, even though the fan turns on at approximately 230 degrees and apparently turns normally (i.e., free and fast, no binding) and brings the temp back down to normal. Message appears simultaneous with fan activation.
Questions are:
2. Where does the signal for this message originate,
3. what input generates it, and
4. what steps can be taken to correct the faulty indication?
Many thanks for any contribution.
cut and paste your question and re-post it here:
Technical Questions
MrShiftright
with head gasket leak? Just had this repaired for $1700; is it too late to
get all or some of my money back if this is covered in an after-warranty
assistance? Thanks in advance for any help on this matter.
You might post that question here:
Chevrolet Cavalier Forum
thanks,
Mrshiftright
host
First of all I gave up figuring out how to post in the Chevy Lumina section; therefore, I am posting here. Sorry, if anyone can explain to me how to do that I'd appreciate it very much.
Today my Econolube guy told me that I desperately needed to replace my intake manifold gaskets...cost: $500.
Of course, I haven't a clue what that means except he's probably right.
Is that a fair price for a 1995 Lumina with 122,000 miles???
Thanks so much!
Cheri
You can post that question here for best results:
Technnical Questions
The Lumina Topic is here:
Chevy Lumina Forum
thank you
MrShiftright
I backed into some kids car 2 weeks ago who was sitting outside my driveway late at night in a black car with no lights on that i didn't see. Anyways, i made a little dent in his one fender and a chip in the paint and have pictures of it. The kid called me back today and said it would cost around $1000 to repair it. I was like you got to be kidding me. I was wondering if anyone could help me (or at least point me in the direction) as to how much they think this would cost to fix. Here are the pictures:
and the URL's incase they dont' show properly:
pic1: http://members.aol.com/threemeats/car1.jpg
pic2: http://members.aol.com/threemeats/car2.jpg
pic3: http://members.aol.com/threemeats/car3.jpg
(Sorry The pics are a little big but i didn't want to degrade the quality so that you can see everything)
Any help would be greatly appricated.
Mark
Guy backed into my car...put about a canteloupe size dent in the rear fender and that was $1,600 because they had to paint the entire rear quarter, and pop out the side window to get that "edge" I told you about (under the weatherstripping).
Of course, I'd insist he get an estimate from a shop you trust, or at least show you two written estimates and then take the lower one.
I need to know which spark plug lead goes where for a Hyundai Elantra J2 1.8L DOHC motor
Can someone tell me please?
1-3-2-4 is the firing order
Got a Quick, Technical Question?
kirstie_h
Roving Host
Host, Future Vehicles & Smart Shopper discussions
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
skeezix, "Animal/Pest Problems" #23, 16 May 2005 11:41 am
Maybe some previously posted suggestions will help you.
kirstie_h
Roving Host
Or should I got to a body shop? How much would this type of fix cost?
You should visit our Chevy Tahoe/Z71: Problems & Solutions discussion, where other owners can advise you.
kirstie_h
Roving Host
Check out our Paint and Body Maintenance & Repair discussion. I haven't heard of the product you're talking about, but perhaps someone in that discussion has.
kirstie_h
Roving Host
thanks,
kirstie_h
Roving Host
No Start Problems
JOHN MAHONEY
MrShiftright
You should cut and paste your question to this forum:
Electrical Gremlins
thank you
MrShiftright
Hi there. I have a chrysler neon in the UK, automatic, yr 2000. It recently bled the transmission fluid all over the road due to a leaky pipe, and started to lose transmission power. When this happened I high revved the engine to get transmission to work (thinking I had a sticking problem), until I lost all transmission power completely - and then I realised it was a leak.
The shop replaced the transmission cooling system with one of their own and put new transmission fluid in. For first day there was no problem except that the revs seemed to be higher than before when changing up between 20-30 mph, and the move from a standing start seemed to need more revs to get going than before.
But today there has been a heavy vibration and delay when moving with medium to high revs from a standing start, and some kind of transmission slippage can be heard. I was worried that my high revs when the fluid leaked may have screwed the transmission - but reading this site suggests that there is a lot to understand about fluid, pressure, sensors, etc that could be my problem due to the shop fitting their own kit and fluid. Any diagnosis of this would be appreciated - and advice on what to do about it.
MrShiftright
host
The level ride will fill the shocks when i have a load, but will not let the car down when i unload the back. I have to dis-connect the air line to lower the rear. Chevrolet dealer can't pinpoint the problem, could be the $900 pump or the $300 controller. question is, is a tool available to determine which one could be faulty, and the manuel says that neither part is servicable. sorry, but someone made it orginally, so it should be able to be fixed. I own a small radiator shop/garage and am looking for some help. Is this the right place? thanks, hess1
Technical Questions
MrShiftright
Transmission Traumas
MrShiftright
Folks,
Please.....
If you aren't going to post the year, make, model and engine of the vehicle you are asking about, then please put the information of your vehicle in your profile.
I'll be honest, those of us who help out here probably won't answer the post if the information isn't your post or profile.
MrShiftright
Host of this here Board
jimmyray, "Saturn Problems & Solutions" #328, 1 Jul 2005 2:40 pm
Sebring Owners: Problems and Solutions Forum
and see if anyone there has come up against and solved this problem.
I changed the spark plug boots, valve cover gaskets and seals-(spark plug housing)
They were leaking oil. Problem is still there, water must be in a plug connection
somewhere. Please Help leaving for vacation 7/23/05 !!!!!!!!!!!!!!!!!
Message #89 1997 CAMRY 39000 miles - "R" light on while driving forward by rdata Mar 10, 2001 (7:59 pm)
I had this camry since new and always had dealer maintenance. Today I discovered my first problem. While driving forward the "R" (reverse)light stays on with the check engine in the dash board. Would anyone know what the coarse would ..."
rss1
MrShiftright
