I finally removed the rear seat center head rest and the problem went away.
Second problem I have noticed is that when the passenger puts down the sun shade on the front passenger side it hits the rear view mirror. I have to move the mirror to use the sun shade.
-juice
-Brian
Don
Not sure about the surging. Does it idle smoothly or fluctuate a lot?
If possible, try another dealer service area. You can also call the subaru 800 number and log a call.
-Brian
Also, do call the 800 number an open up a case number, and if they still aren't responding let us know and we'll put you in touch with SoA directly (you need the case number first).
It'll get resolved, just be persistent.
-juice
Try the fuel filter, too, which takes only minutes to change. Have them check the air filter while they're at it.
Just a guess. Warm ups are not a bad idea, but should not be required.
-juice
-juice
Juice, Can the ECU be tested to see if it is bad or do they just need to change it?
The service manager said he would go on a test ride with me so that he could experience the problem first hand. I was hoping to have a handle on what the problem may be before I went in. I was also hoping to find out if other owners have experience the same problems.
Thanks you both for your insight.
-Mark
You can try to reset it yourself, just disconnect the negative battery terminal for 30 minutes (engine cold), then reconnect and start her up, and allow it to idle until it's warm. Your first tank will have lousy mileage, but after that it'll be back to normal (hopefully).
But try the ride-along if they're willing to do that.
-juice
Thanks - ETH
-juice
I beleive an engineer on the board related some sucess and was going to post some photos of how the fix was accomplished. For me, this is too much screwing around if it really does not fit you.
At 6 foot 4, passenger side Outback front seat leg room has long been a bug-a-boo for me too. I have not bought my LL Bean yet but at the moment feel like I can live with it and hope to buy soon. If I felt I had to modify the seat rails for the car to fit, I would not do it.
The problem for me anyway was the glove box interfering with my shins.
In any event -- if you have yet to buy the Subaru wagon, rather than udergoing this engineering project, I would seriously consider the VW Passat wagons. Their front leg room is amazing and there is plenty of passenger and driver seat travel.
The VW gives something away in reliability when compared to the Subaru, and if you really NEED AWD you have to buy a 4Motion. But the VW has its own charms and is well built and reviewed by the press.
Don't buy a project. Maybe next redesign the Subaru will fit! Germany has you covered right now.
Try the Forester. A few really tall owners have fit pretty well. Headroom is amazing.
-juice
Eric
-juice
-Mark
-juice
Eric
Would welcome any thoughts?
Mike
I have to take the car in for repair soon. I was looking through past repair receipts and found one for Sept 29/2000--two months after I bought the car--I had it in for the same problem back then (at 91,000km). Is it possible that the lash adjusters were malfunctioning for over a year and a half? Juice any comment--
To be honest, the price sounds reasonable given the amount of work you are describing.
Do mention that the symptoms appeared early, and that may have been under warranty at the time. See if they'll work with you, perhaps split the costs. Or call SoC, and see if they'll share the cost, maybe pay just for the parts?
-juice
Could use some sage advice and/or solution.
Thanks-John
On my recent (last weekend 2/8-2/10) trip to Long Island from Rochester, NY my check engine light came on while on Long Island (Lon Gisland?) and the engine started idling REAL rough and hesitated badly upon acceleration. Once up to highway speed it was ok, though not great.
I put in some dry gas and premium fuel thinking it could be something like that. I was able to (I had no choice) drive back to Rochester while the CE light was still on. I brought it in yesterday to my dealer, Van Bortel.
The CE light was a misfire in cylinder 1 and changing the plug wire had no effect. So they told me they had to replace the fuel injector, but recommended I do all four at the same time. I told them to do the work (what choice do I have?) The cost came to a little over $500.
At 38000 this seems like a strange failure. I am one to admit if I did something wrong, but I am concerned because I don't think I did anything wrong! I only use brand name gas (usually 87 octane). The only thing I have never done before is put additives in the fuel tank (like dry gas). Should I be?
I was told this is not covered under the powertrain warranty. Is there anything that can be done from Subaru's standpoint, or is this 'my fault'? How can I prevent this from happening again? My wife's '98 civic has been operated from the same gas and impeccable maintenance for 4 years with no problems.
I have to pick up and pay for the car today.
Any help or advice would be appreciated!
-Howard
-Frank P.
Good luck with Toyota. They just admitted to having 3.3 million engines with a serious oil sludge problem, and at first they were denying it (unlike your experience with SoC).
It affects the Camry, Solara, Avalon, RX, ES, Sienna, Celica, and Highlander. What did you buy?
-juice
If all those checks fail. Consider this option. When you first start the engine its rough and knocks at that point the onboard computer may be adjusting the timing, fuel mixture etc to compensate for the "problem". Thats why I suggest starting with the small stuff on a long drive you could easily have picked up junk in the air cleaner or some sediment into the fuel tank. Check the plugs as well could have one thats cracked, bad wire etc. All options even new.
But try a thinner oil, or maybe a better flowing synthetic.
-juice
-juice
Is this a frequent occurrence? What causes it? Have any of you seen other engine problems crop up after this is fixed? Here's a wild observation: I used 89 octane fuel for 3.5 yers. I switched to 87 Octane 3 weeks ago. One week after that this problem started. Could that have triggered it? i can't imagine but its too much of a coincidence.
thanks for any advise.
Baps.
-juice
After 3 visits to the dealer, the engine still revs at 1200 and above at idle. The last two days it has taken to racing up to 2000 revs plus for about 20 seconds when started cold in the morning (it's still summer here in Australia!) then stalling completely. Seems ok after starting again, but still revs high after a 'pushy' drive. Any ideas?
Hi from oz!
po
Any ideas?
TIA
-Dave
