Also a recommended place to buy would be greatly appreciated. Thanks!
I want to install a goose neck mount on the passenger side seat bolt to hold a cell phone pedestal, but can't loosen the bolt.
I'd appreciate any advice.
Dan
Now, a question. 2003 Legacy wagon. 55,000 miles. Let's say I need to merge somewhere or get out the way of something quickly. In second gear, I might be going 30 mph (I usually shift up to third way before that), and then for whatever reason, I need to nail it for maximum acceleration. Once I step on it to go beyond 30, I hear a slight engine noise. It's a little bit high pitched and particularly loud. It reminds me of what an old fashioned tea kettle or pressure cooker with the little rattly thing on top would sound like. I had a guy from my Subaru dealer ride along with me to listen, and he thought it was the brakes, but I can't think of why very high revs on the tach would have any relationship to the brakes. This car has had every recommended service by the dealership service department since I got it in Sept., 2002. Any ideas?
Another chirp noise that the car made was from the timing belt pulley(s), but that one was not so speed-dependent and did get worse (louder and more consistent) with time. I replaced all the pulleys when I put in new head gaskets at 192,000 and it was gone.
I have a 2010 outback which is recommended for 15k mile service.
What the price for such service? Is it necessary or just some inspections plus oil change?
Of course that won't help if it's dirty...
On my 2.5l Forester it was on the passenger side of the transmission tunnel - but I've heard other models can have it on the driver's side.
FWIW, I accesssed mine from the top, through the engine bay.
- repeated short distance driving. My wife's commute is about 30 minutes each way, so I don't think that qualifies.
- driving in dusty conditions. I'm not sure but I suspect the levels of dust we have aren't what they're referring to. We're in northern Massachusetts (and not near the coast).
- driving in extremely cold weather. We generally have cold winters, but I suspect people who get extreme cold would say we don't get extreme cold.
- towing a trailer. We don't.
For fuel line and brake-related maintenance, they halve the interval if roads salts are used, and they are used here, but that's not relevant yet.
I checked MySubaru and they give two schedules! The "Manufacturer" schedule has the 7500 mile intervals, but there's also a "Dealer" schedule and it has 3750 mile intervals.
I feel like an idiot for being confused. With my other cars, they simply said if you have any of the severe driving conditions, halve the service interval for all maintenance. It was less precise, but simpler to interpret.
To any New Englanders reading this: what schedule do you use?
For your first oil change, I strongly recommend that you change it at the shorter (3750) interval. This is to remove the break-in wear elements, such as silicon, molybdenum, aluminum, iron, and calcium, which I can pretty much guarantee will be at fairly high percentages at this point. These same elements will be much lower on your next oil change, even if you do opt for the 7500 intervals. If you use standard (non-synthetic) oils, I would not personally opt for the 7500 interval under any conditions. If you switch to synthetic, 7500 is plenty frequent.
I imagine that your dealership shows only the severe schedule for two reasons: They can "justify" it based on the climate and they get twice the revenue if their customers bring in their cars twice as often. They really don't care how you, the customer, actually uses your car. :P
Now that you mention the break-in, I remember that one dealer once told me they tell their new car buyers to bring their car back after 1000 miles for the first oil change for that reason. I think it was even complementary. I forget what kind of dealer it was, maybe Acura. Granted, it could've just been a scheme to get people thinking they should get their oil changes at the dealer...
There's another factor here that nudges me toward an oil change now. We're having a baby and it's due in early November. After that my wife's car will be driven less, at least for a while. It could end up being six months from now before her car hits 7500 miles.
Anyway, thanks for the info and suggestion. I'll get it done tomorrow.
In the old days of the mechanical bimetallic clicking can flashers (as gizzer suggested), a lower current draw (bulb out) would typically result in a slowing of the flasher rate, while a short or over current draw would heat up that metal tab faster and it would click faster (but yes, some worked differently...). Today's timer chips are more likely set to flash faster as a warning to you when anything is wrong - either a leakage/short or a bulb out.
Check the back section of your owners manual for instructions on how to access the tail lamps. There is either an access port in the gate or a trim section that snaps off, or the light assembly screws or snaps in from the outside. If you don't have your manual, you can download it from the Subaru site.
Visiting Host
You must take your time and be gentle with the entire process. (basically, rub it in, let dry, and then buff it out). As someone else here said though.....the buffing frequency does increase, thew more you treat it. (BTW: Novus also works decently on the front screen of an older Apple IPOD (LOL)
It does really look great for the 1st few days though!!!
I have a 2002 Subaru Legacy with 167,000 miles. About a year ago the CEL came on. Drove it fine for about eight months then the car started cutting out when stepping on the gas. I took it to our mechanic and the codes showed P0447 (EVAP vent open) and P0130 (O2 sensor circuit problem B1 S1). I had those problems fixed and the car ran great, only thing is one week later the CEL came on again, this time the P0420 cat inefficiency code showed up. Our mechanic said the cat needed to be replaced and quoted $720.00 parts and $87.00 labor. We're in Montana and I've been checking out replacement cats on rockauto.com and partstrain.com and thinking it would save a whole lot to just do it ourselves.
So my questions are:
1. Does anyone have any experience replacing their cat themselves and have any advice to offer, such as brand that worked out okay, other parts needed besides cat etc.
2. Is it likely to be able to easily replace the cat and get the CEL to stay cleared after?
We are getting ready to sell this car and would like to get this problem fixed and the CEL clear beforehand....thanks for any help you can give us.
As for the cat, you'll need to be patient and have a generous supply of Liquid Wrench or PBlaster on hand for all the sure-to-be-difficult/seized bolts, as well as a few extra parts... just in case! I have not replaced a cat on a Subaru, but you may also need a set of exhaust gaskets for the engine, in the event the pipes need to be separated at that point in order to proceed with the replacement. A Hayne's manual will likely help you out in your effort and guide you through the process.
The price you listed from the shop, though, sounds in line with the price I was quoted for mine.
I have to tell you that this is a somewhat dicy situation. These boards are full of complaints from people with older, high mileage vehicles that have gone down this path. They replace the cat and then the rear sensor, and yet still get the return of a P0420 a few weeks after replacing each part. These systems are sensitive, and maybe close to the limit on emissions output, and it can be tough to get them cleaned up after a series of malfunctions as you report. I'm almost tempted to suggest that you make this the dealers/shops problem by getting them to guarantee this repair in writing up front. If they are 100% sure that they have done the diagnostics and know that it is the cat, let them do it and then hold them to their word if the code returns.
Yes, it is more money up front. But if you don't own an air impact and have never done this yourself, you are in for a real treat! At $87, they are only quoting around an hour of labor (my local rates), and I'll bet you are going to be at it for most of the day when you fail to get it apart without damaging a flange or two beyond repair.
Exhaust work is, well, exhausting!
When I returned my car back to the dealership, they were not sure what was causing this problem and wanted to replace the Steering angle sensor at my expense, but they were not sure if it will cure the problem.
My question is: Could it be that the replacement of the draft shaft and the power steering rack caused the failure of the Steering angle sensor?
Either way, you paid them to do a job and if the systems they repaired are not working properly afterward, they need to "man up" and make it right. If it turns out that there is a sensor that is bad, it is reasonable for you to pay for the part, but otherwise it should be on their dime.
As Wes said, it sounds like something wasn't assembled quite right. The pinion gear on the rack might not have been centered when it was mounted? Just a guess on the cause, but the outcome cries false instability reading.
Is the steering wheel centered when the car is tracking straight? If the alignment is off or you have to turn the wheel crooked to make the car drive straight, that would probably be enough to cause this.
My engine light came on and will not go out. My car is also losing oil, a quart every 5K or so.
I take my Outback for repairs for years to a reputable independent repair shop in LA.
I was told today that I need a new catalytic converter, and that I have oil leaking from both head gaskets. I know that 2001 Outbacks have had head gasket problems, but my car is over 10 years old and has over 100K miles. What shall I do? I can't sell the car because it can't pass CA Smog testing (required when you sell a car) without a new cataytic converter. The new heads will be expensive, due to the labor costs. I figure I am looking at over 3K repairs for a car worth maybe 4.5K.
Do I keep driving it until it dies, fix it, buy a new one. I am thinking about calling Subaru to complain. I think 2 head gaskets going bad with only 114K is a manufacturing defect. I love my car, love Subarus but I may now have to replace the converter and head gaskets, and the car only has 114K. I have had Hondas with many more miles and much less problems.
Any thoughts, suggestions?
As for the head gaskets... better oil than coolant! a quart every 5,000 miles is not bad at all, but it is bad that the leak is HG-related. Have you replaced the timing belt yet? If not, and you plan to keep the car, I would replace the gaskets. Otherwise, you could sell it, but with leaking gaskets I daresay it is not worth $4,500.
But the 2.5L engines are notorious for this issue, and Subaru isn't going to do anything about it at that mileage.
If you really love the car, it pays to fix it. I wouldn't wait until the engine self-destructs, no.
If you are in the San Francisco Bay Area, I can send you to a very good Subaru shop.
