Unfortunately these specific side-impact results only apply to 9-3's manufactured after December 2003, when Saab changed the side torso airbags to "improve occupant protection in side-impact crashes."
http://www.iihs.org/vehicle_ratings/ce/html/side/s0412.htm
All it means is that the pre-December '03 ones were not tested for side impact by the IIHS (though all 9-3SS models have a 5 star rating for frontal tests). The earlier ones are still very, very safe cars. Nothing unfortunate about it
Also, when the new style 9-3's were released, they were given 5 out of 5 in the European crash tests, which included 2 side impact tests. The test results were published in December 2002
A quote:
"The Saab 9-3 Sports Sedan received five stars for the impact tests, including a perfect score of 100% in both side impact tests."
So basically, Sabb took something that already scored 100% and improved itfurther (which it did not have to). This is a very rare feat indeed
The entire press release is here:
http://www.saabnet.com/tsn/press/021203.html
But the earlier models are just not AS SAFE as the post December 2003 vehicles. And that's unfortunate.
Why would Saab make an improvement to occupant protection in side impacts if it didn't see ways of making the vehicle more safe? Because it makes the vehicle safer. Thus the post-December-2003 vehicles are more safe.
As far as the EuroNCAP side-impact test goes, the results were impressive no doubt, but the IIHS side impact test is simply more demanding and more relevant. Fortunately, the post-December-2003 vehicle does very well in it.
A lot of vehicles score 100% in the EuroNCAP side-impact test so that's no major feat. Whereas the post-December-2003 9-3 is currently the only sedan to score a Good+Best Pick designation in the IIHS side impact test.
We'll just never know for sure how the earlier models would have faired in the test. They might have scored as well, or worse. I would suspect worse because the improvements Saab made were to the side torso airbag -- exactly where the significant injuries are being revealed in the IIHS test, after head protection is applied.
E.g. look at the Subaru Legacy, which aced the side-impact test in the Australian NCAP tests (very similar to the EuroNCAP ones). No issues with head injury. Yet it only scored a "marginal" in the IIHS test. Many Subaru owners are speculating that the issue was the side torso airbag -- exactly what Saab improved after December 2003. There's speculation that Subaru will raise the score by making improvements to the side torso airbag.
Similarly, the MB C240 and Volvo S40 did well with head protection, but in both cases the driver dummy registered significant torso injuries and they scored "Acceptable." Again, an improvement to the side torso airbag, as was applied after December 2003, may have been what put the newer 9-3 out on top.
Thus, yes, the 9-3 manufactered in December 2003 and earlier is a very safe vehicle, without question. But the post-December 2003 models are even safer! And I consider that unfortunate because I wish Saab had made the improvements earlier. You can never have enough safety, that's why a lot of us bought the Saab in the first place.
Invoice minus holdback minus October incentives for a base 2004 Linear is $22,043. (Some dealers add $480 for marketing/advertising/handling fees.)
A loaded Aero is much more expensive, but a base Linear is just as safe.
Is the car that bad and is it that far removed from Chevy's new Malibu LT sans the problems.
Constructive answers only, please and thank you.
The stereo is not audiophile quality. It's adequate for some, bad for others.
The key to enjoying a 9-3 will be the quality of your local service department. If they are capable of quickly and permanently fixing issues as they arise, it won't be a big deal. If they give you more headaches, don't fix a problem the first time, etc. it'll be a bad ownership experience.
The same is true of most vehicles, but especially with the European makes.
I have a 2004 Arc. I noticed what you said about this.... It sometimes happens when the gear is in between 5/4 and the RPM is about 2000 when you are accelerating. According to manual... it says it will kick in if RPM is below 2000 when your gear is in 4 or 5. So I think that's why somwtimes you feel the vibration because of that. I usually just switch to the maunal mode and keep the rpm above 2000 and then I get plenty of power without hesitation.
1. Why do the wheels get so grimy after only one or two days on the road?
2. Why does the rear right fog light not work? I was told by the dealer that it doesn't work on any 9-3 in the US.
3. Why doesn't the traffic program work? It never has in my car?
4. Why doesn't the speed sensitive volume on the radio work? It has never worked regardless of setting in the system low, med or high.
I brought my car to the dealer to address these issues and 24 hrs later they told me it was fixed but nothing seems to have changed. And they left the passenger window open overnight in the rain. Upon picking up the car today I noticed one of the pixel rows in the dash display is out. What a flog.
sorry to hear what you have problem with your car dealer. You might send those issue of car to "Saab USA" to ask for answer. They will happy to give you answer for your question. I did that many times, most of time they give me back in one day. Hope this help.
My wife's 98 Audi was the same and I am 99% sure that Benz rear foglights work the same way. (Volvo to iirc on my mom's Volvo growing up)
2) I agree with the above reply. Every other car I have seen with rear fog lights (er, light) only has one, and it is on the left side.
4) I have a 9-3 Linear with the launch package and didn't even know we had a speed sensitive radio. Of course, I just discovered that we can switch from AM to FM by hitting the Radio button rather than scrolling through the menu...
Yes, the stereo is mediocre. The brakes squeak incurably in reverse and occasionally at low speeds under light braking going forward as well, particularly when dirty. The rims are always dirty due to brake dust. A piece of passenger seat trim has come loose already. Certain elements of the interior aren't constructed of the greatest quality material. The front seat is only marginally roomy enough for me at six feet tall. The turbo engine is a bit unresponsive around town off the line, but nothing you can't get used to.
However, in its defense there have not been the slightest problems with stalling, transmission troubles, or rattles of any kind. The exterior styling is extremely clean. If the interior has a few lapses in the materials chosen, the overall look is still distinctive and pleasing--far exceeding that of the Malibu which is not a worthy comparison. The car is wonderful to drive on the highway with excellent tracking and plenty of turbo power on demand. The backseat and trunk space are superior to many competitors.
Truth be told, I would have marginally preferred a BMW 3 series, G35-X or Acura TL; however in the real world due to discounts, relatively cheap insurance costs and, in my case, eligibility for the GM employee discount, the Saab was considerably cheaper. In my circumstances, I viewed it as 90-95% of the car for 80-85% of the cost of ownership. Things may be different for others depending on buy vs. lease, length of ownership, etc. While I cannot say I am completely thrilled with the 9-3, I also can't name another car I would buy instead if I had to do it over again. Hope this helps.
The brakes squeeling while reversing is not a good thing in my opinion, why would they do that? Anyone have a solution to stopping it? I have heard backing up at great speed, then quickly putting the brakes on might help?? Sounds silly to me.
I have heard of the backing up and slamming on the brakes technique as well, but this was back in the 80s in the context of how to calibrate the parking brake when you have drum rear brakes, so I have not tried it on the 9-3.
In recent years, a number of manufacturers (like Saab) have introduced "active" head restraints and modified seat designs meant to reduce whiplash injuries. Previously IIHS used a crude static measurement of the geometry of the restraint. Now they're taking the actual seat assemblies and putting them on a sled to simulate what happens to an occupant when their vehicle is rear-ended by a vehicle of similar weight at 20mph.
Overview:
http://www.iihs.org/news_releases/2004/pr111404.htm
Results:
http://www.iihs.org/news_releases/2004/pr111404_1.pdf
The car has been to the dealer many times, and the dealer says (according to Saab) to reset the trip odometer when the distance to empty reading seems to be wrong. That seems to fix the problem temporarily. Any idea what's going on?
I heard that the 2004 93 Sport Sedan Aero does not handle well in the snow and that it needs snow tires on all four wheels?
I also heard that Saab has a standard package of 4 snow tires and rims?
Is this true?
Saab does have an early termination of a lease. I seen advertisements that say up to nine montrhs. I am turning mine in tomorrow. I do not have to pay the last two lease payments.
Maybe you can answer a question for me. On your 01 9-3 did you put snow tires on and did you get four?
a maximum of 3 lease payments.If you have any Saab
with what are considered low profile tires,eg.
205/50R 16"s, 215/45R 17"s,you should definitely
consider 4 all-season tires,true snow tires are a bit of overkill.
Any experience with this? What to do?
Saab issued a fix for it several months ago. Since I've had it applied it hasn't stalled since.
I know the Acura has a whole bunch of things going for it, such as a more refined ride, a hot engine, a super-nice interior, a fantastic sound system, outstanding reliability and better resale value. Should I give up all those things just for a little fun, which may fade after a few months, or will the fun always be there, even in the face of some of the aggravating repairs some folks have mentioned on this board? One attribute of the Saab that also concerns me is the turbo lag. Does it continue to be an annoyance or does one learn to adjust to it?
I need some feedback from some of you Saab 9-3 owners about just what it was that made you buy your car over some others. If you had to do it over again, would you still buy the 9-3?
While I am content with the 9-3, I still would have preferred the TL if the cost differential were not so significant. You can get used to the turbo lag, but not so much that you still don't notice it around town. It's a non-issue on the highway. More troubling are some minor but annoying quality issues. I've had some the brakes squeal in reverse (dealer can't fix), a window stopped going up all the way and a piece of interior seat trim came loose. All minor, but also more issues in total than any other of my previous 3 (all American) new cars in their first year. I am leasing and the dealer is conveniently located so it's been no big deal thus far; if I were planning on keeping the car 7 or 8 years and the dealer were far away I'd be a little concerned.
Now if you could wait a model year for the 2.8T, the fun might very well be too much to pass up.
3and14: Thanks for your honest appraisal. I know about a year ago Saab was offering some VERY tempting incentives on the 9-3. Surprisingly, though, this year they've upped the MSRP to the point that a 9-3 equipped the same as a TL w/ Nav is almost $4K more than the TL. I didn't think they were in such demand as you don't see all that many on the road. And, believe me, when I see one I do a double-take.
skysaab: You speak to what I think are the main reasons people buy Saabs. Individuality and the spirit of the car. I know that feeling can't last forever but you've given me a sense for how long it has hung in there for you. Glad to hear it.
I'm going to make my decision by this Friday. I'll let you know how it turns out.
Let me begin by saying I have the launch package on this car *big mistake*. Car was a college gift from parents, it's my first car, I thought if I selected Launch instead of ARC I'd get basically the same car as arc minus the engine. So you KNOW I was upset about soundsystem right off the bat, straight lied to me telling me it was 300watts then after I get the car, oops it's 150.
I've owned this car for a little over a year, put 37,000 miles on it. *College student, 20* So you know, been going to college parties, but that's besides the point:
1)Within first 2 weeks onstar did not work
2) Car rejected my key, had to have it towed to dealership, they replaced steering wheel lock column, ignition control module and gave me new key.
3)Winter came, car sound system/computer system went dead, said it was fiber opics freezing nonsense, so they reprogrammed system, still kept happening.
4) SQUEAKING breaks. They said SAAB's from launch package had bad brakes and SAAB issued new type of brake pads free of charge for all owners with issue.
5) I had radio issue described in past post in which I lost the last row of pixel displays, my speed level for music adjuster was not working, never has by the way, or the traffic reports.
6) Had a vacumm pump leak in car after an oil change, that was fixed
7) They replaced my radiator in car because for some odd reason, my car's coolant fluid wasnt being used, only emergency fan after shut off.
8) Sunroof refused to close during summer on hot days, had to have that reprogrammed. The only way to close it was to through the car into neutral for some odd reason and it worked.
9) Early on in ownership on rainy days, the car's steering wheel would lock WHILE driving after 5-10mins of turning on. Only way to alleviate the issue was to throw the car in neutral, shut it off and turn it on again while driving of course.
11) Tires stink. Rear blew out at 17,000 for no apparent reason. Replaced all four completely by 25,000
12) Telephone did not work, I spent literally 6 months getting this sucker to be fixed by onstar repeatedly until I finally gave up with the understanding of the car not being a gsm type phone or even digital. It's an analog phone that cannot be upgrading in the future so I am under assumption that all 03's will be out of luck using car phone within next year or so.
13) Have brought the car in over 20+ times based on all I have said above. Most took place before year 1 / 20,000
The conclusion: I fought with saab to give me a new car and they refused, the dealership kept bs me talking bout they gonna help me this and that, the head guy did nothing. I assume it was because of my age and I really couldnt go to my father for help because I was fortunate enough to even get a car, wasnt about to complain about it. Although now he knows but I told him Imma stick it out because when the car DOES work, it is one of the BEST cars to drive on the road. I am young but in my home we have a few other options that I've had the oppourtunity of driving "c230 benz, volvo S40, range rover, jag conv etc" and with those options, I really like driving my saab the most.
The car has been good to me last couple of months so I'm no longer complaing.
