The reason being the manufacturers have spread out the maintenence intervals to be competitive and get the "upperhand" on the competition.
If you are planning on keeping the car for quite a while, don't fall for it. Cut the intervals in half.
I've been in the Saab and European car business for 10 years and currently own 2 Saabs. I change mine every 5k miles.
1. does the factory warranty cover a new key (i only have one and it works but is in terrible shape) also, drying out of one spot of rubber on the window!
2. turning the car on, it sputters a tiny bit then runs fine, is that just the turbo kicking in, spark plug issues or what?
3. it is still cold here in alabama, and on a few bumps and dips, my suspension squeaks. is it just the cold, or should i have it checked?
Thanks so much!! my saab is amazing great so far!!! i read this forum for hours and you guys really influenced me to get it!! thanks!!!
Keys? That is sort of a wierd thing. Not sure about them. A squeaky suspension? It really should not make any noise. Dude, I live in the twin cities and when it is 25 below zero, mine does no squeak. Sure,it gets stiff as hell, but it does not squeak.
All you need to do is take it in and ask.
Congrats on a nice car.
After reading the posts about the cost, I am very glad I took the car in when I did.
Carmax did a great job taking care of the problem and providing me with complimentary transportation. Their service department reminded me of BMW (service, service, service). Never once did I need to call my service representative for an update.
As a side note, I just had a chance to compare my car with my dad's '06 bmw 330i. The Bimmer (which cost him at least 10 grand more than my car) clearly has superior fit and finish, but other than that, I thought my Saab drove just as well, if not better. I was pleasantly surprised!
The extended warranty, at least when i had a saab, was pretty good, but not quite as good as the original 4/50 warranty. I think a few items that will be fixed under the 4/50 were considered wear items under the 6/100. But it will cover most of the car-stopping problems.
27K for a '06 with low miles may be ok or may not depending on the options. I'm not up to date with options, but checking what the prices on ebay are may be a good hint. On ebay i see a 2007 aero with 9,000 miles buy-it-now priced at 23,988
This is her 2nd SAAB, maybe her last, plus we were not happy with professionalism at service dept. No loaner, rude over phone and waited 4 days for car.
I am a very high mileage driver and wanted good fuel economy. Finding a low miles car already depreciated fits me well. Edmunds had dealer retail around 18 and CPO a little over 20. Basically I have 90,000 miles of warranty left.
Gary
I test drove the Aero and was told the only difference was an upgraded interior (the 2005 Linear has lots of plastic and kinda looks cheap). I put lots of miles on my car (the gas mileage is awesome), and have very simple tastes.. I just deal with the plastic.
Safety features are awesome (airbags everywhere, standard traction control, etc) and make the car a real value. No complaints!
Hope this helps.
Both good cars, but if you are not going to hold the car for many years you might be better off with the audi.
1) No locking glovebox
2) No valet key--a way to prevent entry to trunk area.
THIS NEEDS TO BE CORRECTED.
Anybody have any idea what's up with that?
But if you want to be safe in the snow, get snow tires. Period.
dave
Is this normal, I'm not a crazy driver, I dont ride the brakes.
Saab 9-3 '07 rear brakes shot, rotors shot, 400.00 out the window. Front brakes are fine.
160 2 rotors
80 brake pads
160 labor
Makes no sense.
I wanted to use ceramics as they are much better but my mechanic insisted on using the factory replacements. I should have insisted as the ceramics are much better, and the next year SAAB uses ceramics all the way around.
Before you spend any money, check with a reputable mechanic and find out what is going on, perhaps your rotors do not need replacing
Also my dealer wanted over $300 to replace the rotors which could not be resurfaced. My mechanic was able to resurface the rotors and change a $800 repair bill to a $350 repair bill.
And BTW, you should not re-surface these rotors. They are soft and will be subject to warping quickly if you surface them. As a result, you will be back in for new pads and rotors most likely in a shorter period of time.
One more thing....rotors and brakes are a job that any guy should be able to do in your own driveway. Takes me about 30 minutes per axle and I buy all my brakes online (all Saab OE materials too). I am not a mechanic....just a regular guy. I think I pay around $180 for a set of rotors and pads online and ....$0 for labor. I can do front and rear for less then $400. The additional amount of work required to swap rotors once you are pulling pads is about 2 minutes. It is completely silly to not replace rotors and even sillier to re-surface them if you are pulling pads anyway.
also the shift knob was popping out, so the service guy epoxied the knob back on - without first putting in the spring for the reverse lever.
and, of course, when replacing a faulty turn signal switch, accidentally causing a blockage in the a/c drain resulting in the passenger side wells turning into a swimming pool.
and i have replaced rotors and pads myself, but the ease of doing it depends a lot on the car and the age of the car (rusted screws). i have another car that requires special tooling to remove the rotors.
I asked the dealer what's up with this. His reply, this is normal for a 93. It seems like a flaw to me.
I was also shock to learn during a routine tire rotation that my rear brake pads are at limit. Front is ok. Also, I notice the rear wheels has lots of brake dust from day one.
Talk to B&B Saab in Santa Clara. They offer to replace the rear pads at cost and I accepted. Rotors still ok for now. Still, it is incredible that pads have such a short life.
:confuse:
Some brakes require unique tools, but they are easy to find and rusted bolts and stuck rotors are easily remedied. First, if you use silicon this does not happen. Second, a can a anti-cease will do wonders.
Hey look....someone griped about paying what dealers charge to do brakes. Either do them yourself, or pay someone and don't complain. Rotors and pads are basic stuff.
The hardest part with the Saab 93 is knowing if you have 11.2" or 11.9" rotors in the front. It can be a little confusing especially with the different models and wheel packages. I had to measure mine the first time.
As far as brake dust....I think all Saabs dust like crazy, but you really should see a lot more up front then in the rear. They use pretty soft materials and the fronts should be doing most of the work.
My 2004 Saab 9-3 ARC had the transmission go out at 54,000, which as you know is 4000 miles beyond the warranty. Cost on the repair is $3500. The first scheduled transmission SERVICE on this car is at 60,000 miles. I contacted Saab customer service and Saab corporate to request that they contribute to the repair. They refused. This is a clean, well taken care of Saab, with a good service record and driven with care. Any suggestions on how I could convince Saab to help pay for it? This is not a Yugo, the transmission should not go out on a $40,000 "luxury brand" vehicle with this amount of miles. Any similar experiences? Any thoughts?
GM was having that pay employee price discount, which may or may not still be active, that + the arc trade in would get you a nice 2008 at a reasonable price.
it is basically your call - love it or trade it. :confuse:
Check your facts. Asbestos isn't banned.
