Chevy S10 - GMC S15 and Sonoma Care & Maintenance
e_net_rider
Member Posts: 1,380
in Chevrolet
has 4.3 and it died. Found no fuel going to engine. Replace pump and now has pressure at the fuel rail but won't run. Squirting fuel into intake will allow it to run. Any experience in this area appreciated. Thank You.
For the S-10, all I can say is to confirm the element is freezing, you can run till it doesn't blow cold, run the heater for a few minutes (man it's hot in here), then flip the air back on and see if it blows cold again. If it does, I'd contact the dealer about it, they may not be able to do anything, but I'd try since it should still be under warranty (assuming you haven't ran over the miles on the warranty).
Both mirrors, parts of the grill area and the door handles have started to fade from their original black color to a chalky gray'ish/white color. Any suggestions as to what I can apply to them to bring back the dark black color.. or am I resigned to buying all new parts?
is the four cyl a good engin
How sure are you of this? My wife loved her 1997 Blazer, and wants a new 03. I have been trying to accomodate her as well as ler her see/drive the Trailblazer. I wish dealers would tell the truth. I have been told by two of them that this is the last year for the Blazer and that there were no 4 door models because Chevy was trying to get folks who wanted that model to go up to the Trailblazer.
03 Blazer 4 doors have been virtually unavailable to dealers so far this year. Go rent a car and ask if they have a Blazer and you will find where they all have been going. Check with your dealer in late January of 2003. He should change his tune. The dealers told you what they knew at the time. Things change...
I was concerned that about 1/3 or the 100 plus complaints lodged against the Chevy S-10 for the 2001 model were in regards to hydrolic brake failure. Nearly another 1/3 were related to serious transmission problems.
Dealerships were not viewed as taking these problems seriously.
I am not seeing those types of complaints posted in this forum. The site was well worth the look especially if you are considering the value of an extended warranty.
I do not know whether the number of complaints to the NHTSA are "normal" or unusual.
Any ideas?
The noise occurs (say one out of 10 trips) on the interstate. I drive 70 and when i get on a offramp, the noise starts and stops around 25-30 MPH. If i start accelerating when the noise starts, the blazer will keep going without any noise. But as soon as I start braking, it starts back again.
Anybody have this problem? Heard of it? I am leaning towards a hub or transfer case problem. Maybe the blazer is trying to go into 4X4 mode when i decelerate sometimes? Thanks in advance.
89 S10Blazer, 136,000, Tahoe Edition, 4.3 L V6
Keep in touch if you have any other issues come up with your S-10.
50/50 Highway/City.
Got 16MPG out of the second. 95% 65MPH Highway.
I'm not sure I'm gonna like having only a 300 mile
range on the vehicle. Need to gas up twice a week.
Also note that the engine RPM's are about 300 RPM
higher at highway speed.
It replaced a Jeep Grand Cherokee that got 18/24
MPG and a 400 mile range.
Question: Is this gonna get better as the engine
breaks in ?
What can I do to improve it Change a gear or chip etc....
Thanks all you pro's.
over and out
I took the exhaust apart trying to get the starter to drop down since there wasn't any room to pull it up through the top. With a friend pulling the exhaust to the side and me pulling down on the starter, we still couldn't get the damn thing out. So then we decided to hell with it and took the cross-member out.
Yeah, that wasn't fun putting back in. *grr!* It took three entire shims plus one half shim on the outside bolt. It's a good thing that there wasn't any more space needed because I ran out of shims.
What happens next? I can't find the bolts that bolt the exhaust line to the exhaust header. Great. Now I have one side of the exhaust off and no bolts. The cool thing is that now it sounds like a frickin monster truck, rumbling down the road. It's nice to waste the ricers off the line AND sound like a huge-[non-permissible content removed] Chevy 350 under the hood. I have to bottle it up pretty quickly, though, because I don't want anything melting.
I have a new carb from Holley sitting on the passenger seat of my truck because it's a little too complicated for my solo-automotive-expertise. Vacuum hoses SUCK. I just don't have the patience. I can do it no problem with the motor is out of the truck like what was done when three of us rebuilt the motor, but on my own when the motor is in is just too much for my lazy butt.
FWIW, the truck was in immaculate condition, has nearly every option that was offered that year and looked nearly brand new. Old people take care of their stuff.
98 S-10 2.2L LS Trim Stadard Cab - Two Wheel Drive
Also, has anyone replaced their cap and rotor (have the HVS ignition). The service manual states spark plug and wire replacement interval, but nothing on the O2 and the cap/rotor.
Thanks for any help on this..
Replaced the cap and rotor on my 95 due to obvious wear at the contacts at probably 75,000 mi.
I own an '87 S-10 4x4 extended cab pickup 2.8V6, 4-spd auto transmission, 301,000 miles, original engine. It has lived thru 17 Minnesota winters! It is my daily driver, I commute 60 miles round-trip per day. 17 to 20 MPG. I love this truck, it is the best vehicle I have ever owned! But this truck is getting tired, and won't last forever!
Anybody have good or bad experiences regarding the new Chevy Colorado or GMC Canyon? Particularly the 4x4 Crew Cab model with the in-line 5 cylinder engine?
May I ask the number of O2 sensor you have. I have the 4.3 V6 and in looking up info, I've seen where 2 were listed (one before, one after the cat), but in another source it stated there were three used, two2 before the cat and one after?
What you do is take the handle off and there
is a threaded rod on both sides of the inside
of the handle, you can adjust these rods to
either latch or unlatch easier just take the
two screws off and play with it, i'm sure you'll
get it.
top of the valve cover (smooth valve cover)
on 2.2 ltr 4 cyl 2000 or newer. Tried twisting
with channel locks and it won't budge.
The cap/rotor is different on mine (99) and yours, particularly the rotor. The HVS system is used on the newer vortecs, think they started this system in 98? when the injection system changed. 94s still used the HEI II right (non-integral coil)?
I have recently purchased this truck. It runs fine. I have noticed the sound of water coming up from the passenger side. May be the AC ducks are clogged or what is it.
The coolant level is ok. Any help will be appreciated.
Qamar
I have a 2002 Blazer 4x4 V6 Automatic. It is due for a 60,000 mile service. The dealer is trying to get me to do all kinds of items that are not in the service manual, the 3 expensive ones being a full fuel system service, power steering flush, brake system flush. Does anyone know what all I should actually do for the 60,000 mile service on a Blazer.
Alan
